View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. Third thermostat, overheating again after 2 weeks
  2. ebay vendor - supercharger remanufacturer
  3. Interior Lights Out
  4. Rear Caliper Dust Boots Split
  5. Another Engine Noise Thread Knocking?? Sigh..(sorry)
  6. Clock not working.
  7. Engne noise when AC is on
  8. Ready, Fire, Aim... (2006 Cooper Auto Question)
  9. high rpm and service engine lamp
  10. Can a fried BCM cause the car to not start?
  11. Rolled down hill while in gear (!)
  12. Speedometer stuck
  13. Getrag 5 speed manual problems?
  14. Cost of New A/C Compressor
  15. passenger door doesn't UNLOCK **help**
  16. how to pull off intercooler and clean it
  17. help!!
  18. Noise while car is off in accessory
  19. Valve Seal Replacement? Has anyone done this?
  20. How do I restet sensor code for bad O2 sensor?
  21. Intercooler
  22. TSB: Change CVT ATF every 30k for longevity
  23. MINIUSA letter regarding failing O2 sensors in MY 04-06
  24. Air Conditioning help
  25. Dome Light? simple question.
  26. TSW Replacement engine mount?
  27. PCV valve CHANGED? When?
  28. 2004 MCS steering querey
  29. Problems keep adding up!
  30. Canadian parts store?
  31. Problem With Opening Driver's Side Door?
  32. Bad O2 Sensor Code
  33. AC Noise On Passenger Side Only W/ Fresh Air Selected
  34. Driver door will not unlock from interior handle
  35. Will this tool fit?
  36. i'm petrified: 03 mini cooper cvt whine
  37. Seat wont recline
  38. Heavy steering not PS Pump?
  39. mushroomed to point of metal failure?
  40. Please help! Speedo instrument cluster goes dead
  41. Broken headlight washer door!
  42. Changing Axle Seal?
  43. crack crack crack
  44. rear right wheel getting hot
  45. Running Issue
  46. brake fluid leak
  47. P0326 - Knock Sensor
  48. 05 super charger on a 03 ?
  49. electric waterpump or s/c rebuild?
  50. Chrome Hatch Latch thing replaced with Black one?
  51. Squeaky door
  52. Could someone post pictures or diagram of air hose locations?
  53. Detroit Tuned Bypass Valve vs Stock Bypass Valve
  54. need rear window clips
  55. Drivers Window Leaking Issues!!!
  56. MCS Engine Rebuild
  57. Bad Gas Cap
  58. Low Speed Fan Resistor - we need solution
  59. Windshield cracked I heard PPG is good, but where?
  60. Power steering pump vs. Fan
  61. Rebuilding the brake caliper
  62. Front end noise and dealer related issues
  63. OBD p1776 1776
  64. Chirp when leaving from a dead stop
  65. Help Please - Limp Mode starts when I run the A/C - obd = p1688
  66. OBDII code P1688 - limp mode when air conditioning is turned on
  67. ABS and Traction control light?
  68. Metal squeaking in gear box when getting on first gear???
  69. Great, now a misfire..
  70. CHECK THIS OUT: Crank Pulley gone bad
  71. replaced battery now remotes dont work
  72. Xenon Headlight Problem
  73. Driver-side Front Wheel Noise
  74. Driver side brake pad wearing faster than other side?
  75. "Hesitation" at 3000rpm/70mph
  76. Help! Front brake line blew and oem part not available
  77. a/c repair shock
  78. Survey: Crank Pulley Failures
  79. Strange Engine noise
  80. OEM Ride Height and Hood Gap?
  81. Bleeding Brake & Clutch systems
  82. 2xx miles over warranty + Coolant leak
  83. Here's a weird one...
  84. ATTN.: ALL BBK OWNERS
  85. transmission question
  86. Vibration on driver side window
  87. Hesitation
  88. Is there a body module avaliable from someone besides Mini dealer?
  89. ABS DSC warning lights on
  90. Location of 2008 S body module
  91. Belt Tensioner Rattling...
  92. weight sensor air bag trouble
  93. Replacing 3rd brake light
  94. HELP!!!
  95. Transmission Fluid
  96. Rattling Coming from Passenger Side of Motor...
  97. windshield crack
  98. A1 Cardone PS Pump
  99. what is it and how do i remove it?
  100. PCV valve hell
  101. A/C blower motor
  102. Step by Step How To on Replacing Radiator Fan..
  103. Window Operation not smooth.
  104. Lights on speedo turning on and off
  105. Loose Hood Scoop???
  106. Pag Oil for AC, what viscosity? How to add?
  107. How to program key fob
  108. Dent on hood :(
  109. Weird turning noise :S
  110. Lug Nuts or Studs?
  111. Noise when shifting from 1st to 2nd
  112. Brake warning light but..
  113. CVT transmission woe$
  114. HELP!! Mini Starting Problems
  115. Surging, SC whine, p1242, p1109, red hot exhaust manifold
  116. My first speeding ticket
  117. Xenon healight lens Cracked
  118. Locating Mini Mechanics MA/NH
  119. No Air Conditioning - AC Light blinks when turned on?
  120. Paddle shifter broken
  121. New radiator fan check
  122. Power steering failure - Fan is not moving
  123. HELP - Brakes are off and...
  124. Changed wheels on 2006 Mini now have seat belt light, airbag light, + no dash lights
  125. Steering + rad. fan issue
  126. Loss of power & fuel economy. Fuel pump bad?
  127. Coolant top off normal?
  128. Need help with this code P0646
  129. dsc light is on
  130. HOSE FROM BRAKE RESERVIOR TO CLUTCH MASTER CYLINDER?
  131. Sun Visor
  132. Coincidence???
  133. Noise / ticking from transmission
  134. URGENT PROBLEM: MINI dies with no apparent reason!
  135. HELP! Engine died in parking lot. No check engine light
  136. Knocking sound when accelerating and decelerating
  137. Better MINI Service Department?
  138. MCS transmission trouble
  139. Dead MINI!?
  140. How to generate "V39.0 Diagnosis report"?
  141. Question: OEM Front Rotors from non-Mimi vendors
  142. Brake Master Cylinder
  143. Doing brakes for first time myself - need advice
  144. P1125
  145. Transmission Whine In 4th Gear [06 MCS]
  146. how to tell if belt breaks on cvt transmission?
  147. Engine whine related to AC???
  148. Cruise control out--specific questions
  149. Different size sparkplugs for various years?
  150. Recent Long Beach Mini Service experiences??
  151. Pulsating noise when turning right
  152. Tough question: shaking steering wheel, not wheel balance issue
  153. No coolant in reservoir
  154. Chirping coming from wheels
  155. car dies coming to a stop only w AC on and high outside temps
  156. Clutch? Please Help?!
  157. Excessive crankcase pressure?
  158. Broken seat - I have to motor alone
  159. Tie Rod Ends, 03 vs. 05?
  160. 2004 MINI Cooper EML, oil, & battery light
  161. Vacuum hose to bypass valve
  162. Cigarette Lighter fuse blown twice
  163. Something is killing my ballast
  164. Switch bank gone bad ?
  165. Dent Dr removed door pannel, now the door wont open from inside!
  166. Help-Brake job gone awry.
  167. Clutch Replacement Pittsburgh PA?
  168. Hiccup at 3000ish RPM... where to start diagnosis?
  169. Are MC and MCS dipsticks interchangeable?
  170. RPM related whining and high pitch rattle
  171. Air conditioning hose failed
  172. How to replace headlight washers?
  173. Paint job crisis (please help)
  174. Broken plastic glove box latch
  175. Battery exploded!
  176. HELP! Suggested Non-Dealer Service in Jacksonville, FL
  177. Left side lights not working
  178. Car won't turn over when hot
  179. Crack in valve cover!
  180. Convertible top will not close
  181. Any idea what this is?
  182. Door lock actuator part# help
  183. MCS slave cylinder help
  184. Door lock and power window problems. (the third time now)
  185. Random E-Brake Light = No Windshield Wipers???
  186. Lost ignition key
  187. Gas Tank won't unlock
  188. Clutch failure cause or effect!
  189. '03 MCS Engine Parts Cost???
  190. 2006 R53 Water Drop under engine. Newbie planning a long trip.
  191. OBD2 Connector Pin 16 missing 12v
  192. Air Conditioning Additive/Intake Vents
  193. Where did my 2psi of boost go?
  194. another day, another A/C issue on NAM
  195. huge battery problem!!please help
  196. weird knocking when idle
  197. Engine stumble, a different type
  198. Bad Bad Day thanks to my MINI! Advice Needed!
  199. How to fill refrigerants, R134a
  200. Any one used Supercharger Technologies for repair?
  201. Tick Tock Knock sound - Drivetrain? - 2004 MC Auto
  202. Overheating help
  203. Body Control Module
  204. 05-S 6 speed transmission shifts hard intermittently
  205. Broken supercharger
  206. Grinding noise when hard turning from stop, help!
  207. Car wont start.
  208. Strange fix for stuck radiator Fan
  209. hesitation/loss of power in second? Still?
  210. Clutch Slipping? No noises. Upgrades?
  211. Exhaust broke at the cat! Help!
  212. Most weight in Mini Cooper.
  213. Steering knuckle pinch..
  214. Which is most likely to leak, PS pump or hoses?
  215. Friday Brain Buster
  216. Power Steering Fan
  217. Interior Cabin Lights Issue
  218. Leaking Windshield Washers?
  219. CVT tranny on the brink....possible solution
  220. Clutch Getting Hot- Overheating Quickly
  221. Goofy MINI Cooper issues...
  222. Loud 'clunk' if 3000 rpms not reached before shifting gears...!
  223. Dies on cold start up
  224. Oil Filter Housing Problem
  225. How to reset tire pressure light on 06 MCS?
  226. MINI some times does not want to start
  227. Warranty Question - Need Counsul
  228. Erratic temp gauge
  229. Will This Bumper Fit My '07 MCSC?
  230. Throw-out bearing?
  231. ABS/ASC/DSC codes that won't clear
  232. Power steering fluid tank leak around cap?
  233. Hot Engine-Impending Doom or Paranoia?
  234. Oil housing cap cracked
  235. The Dreaded Wheel Sensor-How to Fix it.
  236. Weird Knocking Sound
  237. 2003 MCS: Fog light burned out, finally...
  238. Front cigarette power doesn't shut off anymore
  239. Help- poor acceleration
  240. Pelican Parts - Cabin Filter
  241. Stuck gears
  242. Loose plastic trim on leatherette seats
  243. Thermostat gasket only?????
  244. Wont accelerate over 4000rpm
  245. Systems gone crazy
  246. Seat Belt Problem - File a NHTSA complaint
  247. Engine died at idle
  248. how to remove ebrake console?
  249. My MINI is mad. Electrical problem.
  250. Seat heater is not working???
