View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. Power interruption when shifting to reverse gear
  2. What a wonderful mess!
  3. Just bought used Mini Cooper S (R53) - Not Very hAPPY
  4. Belt Replacement 2005 MCS part 2: Which Belt?
  5. bypass valve help
  6. HELP Dealer messed up clutch install
  7. Rear Wiper Intermittently Working
  8. Heater Issues
  9. tranny issues
  10. temp gauge issues?
  11. Disc(rotor) Retaining Screw
  12. CVT Transmission won't upshift
  13. new engine already!?!?
  14. Stuck on manual shifting?
  15. Window winter problem?
  16. Can you please recommend me a good mechanic in NJ for a Clutch Job for a Mini S 2005
  17. Can you please recommend me a good mechanic in NJ for a Clutch Job for a Mini S 2005
  18. Headlight module out
  19. Fuel Pump issues I think??
  20. Peeling Steering Wheel Vinyl - How to fix now that Minspeed is closed?
  21. Door lock question
  22. Small bump / thud when accelerator is applie
  23. Another major engine failure.......
  24. need help car won't start
  25. weird door lock question
  26. Power Steering Replacement Instructions
  27. Belt Replacement 2005 MCS
  28. tire noise; wheel bearing?
  29. Problem with the air filter box
  30. I have a serious problem.
  31. 2003 MCS Steering Tilt Mechanism
  32. P0303 misfire cylinder #3 Frustrations, plz help!
  33. Whistling sound with Recirc off
  34. Tranny DOA on Thanksgiving Day....
  35. Steering play
  36. Big, cold snow storm
  37. Clunking/Knocking noise from front end when cold
  38. SC status: Stoked!!!
  39. low oil level 4k mi' after oil change
  40. Cigarette lighter fuse
  41. VERY BAD! Differential bearing 02 MC! HELP?
  42. Light blue oil pool on the floor under engine.
  43. Knocking from Engine Bay behind Glovebox
  44. Engine support bracket snapped!!
  45. car wont start
  46. Transmission linkage issue?
  47. smoke out of hood scoop
  48. Starter not disengaging, easy to replace?
  49. Tiptronic CVT Gearbox Fault mode
  50. PDC no longer working after new clutch
  51. Oddities with Aisin tranny and DSC
  52. Strange Occurence
  53. hatch/trunk lock problem
  54. Bad gas
  55. Do all MINIs have a power steering pump fan?
  56. Transmission Problems MCSa NOT CVT
  57. DSC issues
  58. misfire in cylinder #2
  59. warranty
  60. Windshield Washer Fluid Dipstick Broken
  61. Blown diff and cracked bell housing!!
  62. MINI service offering induction cleaning? (Needed to help fix my MINI?) Input please!
  63. MCS will not start when key is turned...HELP PLEASE!!
  64. Hazard / parking lights stuck on. Short circuit?
  65. driving lights and dash lights wont come on
  66. r53 stalling after fuel filter change
  67. Growl/winding noise CVT!
  68. coolant issues
  69. Cost to replace Serpentine Belt
  70. New owner with a random coolant leak
  71. HELP!! How can a squeak be related to the gas tank?
  72. HELP: Loud buzzing/ whine noise coming from stereo speakers
  73. Unrelated issues fixed by new plug wires
  74. Blinkers/Signal lights hesitating
  75. Need New Battery for My 2004 MC
  76. very rough idle, limp mode and a P1125 my car hates me
  77. Normal fuel gauge/sender issue but with lower MPG?
  78. speedometer doesn't work
  79. Do I have a complaint to the dealer
  80. Original clutch died after just 126k miles...
  81. 05 R53 Rear Wiper Parking Problem
  82. 06' R50 Transmission Failure.
  83. EML and Service Engine Soon Indicator light up at 49k
  84. P0304 cylinder #4 misfires...need advice
  85. Antifreeze & Oil Leak
  86. more O2 sensor questions
  87. OBD codes P0130 and P1237
  88. burning mustard colored oily matter from exhaust?
  89. 2005 MCS - do I own a lemon?
  90. '02 R50 5-speed owners please come in
  91. Overheating Problem
  92. Where is pass heated seat controller?
  93. 911 *** I am Freaking out
  94. dent in horn badge. can you order a new one?
  95. Get vehicle error code w/out OBDII tool?
  96. Wiring Diagram help! Anyone have a copy?
  97. location of airbag module?
  98. 100,000 mile service - Most bang for $$$?
  99. Where is the O2 sensor????
  100. valve spring compressor
  101. e-brake
  102. OBD2 codes
  103. 'Sproing!' sound at 21km/h - R53 MCS
  104. Coolant disapearing - no apparent leak
  105. Cheaper Parts
  106. Wing Mirror Switch
  107. Heavy Acceleration Causes Limp Mode
  108. Just replaced thermostat / housing - Rough idle?
  109. Problems after alternator & battery replacement
  110. Hard / Cold start issue RESOLVED!! *Vids*
  111. tach and dash lights dead
  112. map/baro circuit high input Check Engine Light
  113. Hatch release button fix
  114. CEL, chasing my tail
  115. Lock malfunction?
  116. little plastic rocker piece broke
  117. Reversed control on window regulator fix??? Weird.
  118. Hard Shifting
  119. Overheating- no coolant VERY LOW oil!
  120. Brake Squeal when wheels are turning
  121. Windshield wipers
  122. Horn Problems
  123. Check engine light on after closing hood
  124. Hard to Shift, Clutch not engaging?
  125. Borrow airbag light reset tool?
  126. Fans seized up.
  127. Fans seized up.
  128. 02 MCS radiator fan problem (not what you think)
  129. MCS coolant fan always running.
  130. OEM Driving Lights - Bad "Key Button"?
  131. CVT Jerks when put in Drive.
  132. Seat heater overheating?
  133. Roughness when braking or starting after a stop
  134. Aftermarket radiator support - one small difference...
  135. Steering wheel vibrate on my MINI?
  136. Steering wheel lock problem....Ideas ?
  137. PF16 fault after i hit a puddle
  138. This car is impossible to revmatch! HELP!
  139. SES light and dealer BS
  140. whistle noise?
  141. window problem
  142. Creaking/clicking sounds from drivers side front tire
  143. unidentified noise
  144. cooper vs cooper s head
  145. Car won't start - battery?
  146. 02 coolant leak, bleed system any DIY?
  147. Spark Plugs
  148. Centering/Aligning the Steering Wheel
  149. Interior touch Up paint?
  150. OH MY GOD -- 2 new problems
  151. Got a Puncture with conventional tires
  152. What size is th torqx bolt on the rack
  153. Power Steering issues
  154. Problem
  155. Power Steering fluid volume
  156. Door Lock Issues
  157. Foglights mysteriously on
  158. overheating when car is at a sitting
  159. Fresh Coolant Install - Need Help
  160. Strange Noise & Loss of power
  161. New Battery, dead again!
  162. Help! How to replace the Core/Radiator Support!
  163. Rear Window Wiper Is Always On
  164. servicing newbie question...
  165. DSC/Service Engine/cylinder misfiring
  166. How do you open the battery?
  167. Car sat, now won't start, NEED HELP
  168. No Radio, no HVAC, and wipers going crazy
  169. Orange module next to Battery
  170. Servicing Cooper S Supercharger Oil
  171. Battery - how long does full charge take?
  172. Will 05 wheels fit on an 09 MINI!?
  173. exhaust smell in cabin when idling
  174. weird noise from Clutch on 1st gear
  175. ASC light Flashes
  176. Need a Picture or Pinout for 3-Pin CD Changer Cable
  177. I think i broke some thing
  178. How to replace tail light
  179. Heater/AC fan not working
  180. drian plug
  181. electrical (headlight/gauges/fan) problems
  182. Seafoam question
  183. Does my Throttle Body look right?
  184. Quick question about Bypass Valve Hose Clamp
  185. Vibration under heavy accel, especially left turns
  186. Wet or Dry sump?
  187. '06 MINI cvt transmission problems?
  188. faint rubbing sound
  189. Suspension "loose change" sound
  190. clutch squeel/grind into first gear
  191. Need advice on Power Steering Pump install
  192. motor mount options
  193. Steering Pump
  194. That can't be good-CV Joint failure
  195. Having trouble removing wheel bearing
  196. Missing 2.5 quarts of oil
  197. Oil residue on garage floor
  198. SES P0136 after 15% Pulley install
  199. trunk/boot is messing up, any ideas?
  200. Brushes for power steering pump
  201. Is my supercharger dying?
  202. Hatch Release
  203. SES Light - Coolant/Battery issue?
  204. Service Engine Soon Light - Misfire Cylinder 4 (R53)
  205. Gas strut that holds up hatch
  206. Bearing or CV? Ticking when turning left...
  207. Cam Replacment
  208. Is this normal?
  209. Oil Leak @ 50k
  210. Vibrating Speedometer on cold start up.
  211. MINI Diagonosis without Guesswork?
  212. Air Conditioning running hot 10-20 secs.
  213. Horn(s) Issue
  214. Transmission OR Sticky Pedal?
  215. The Dreaded Check Engine light.
  216. mini problem
  217. Squeaky Sound
  218. Weird noise going uphill
  219. Coolant Leak near upper radiator fan hoses
  220. Clicking/ticking sound when on throttle
  221. Squeek that i just cant get rid of :(
  222. WTB front seats
  223. Shifting Problems :(
  224. Brake Issues - Mushy pedal after brake job. bad caliper?
  225. 05 MCS just about had enough
  226. High idle and jerky CVT Transmission
  227. Vandalized steering wheel emblem
  228. LOUD buzzing when in drive, 03' CVT
  229. Antenna Snapped
  230. 2002 MCS A/C wont shut off, Snowflake light wont come on?
  231. CVT failure symptoms?
  232. Will an 06 seat fit on 04 tracks in the 04 ?
  233. Start, idle, no go
  234. Brake Light short?
  235. Airbag light and Uneven Idle
  236. Dealer will replace clutch but NOT flywheel, is this ok?
  237. Power Steering and RPM
  238. P1239 - 1240
  239. water on passenger floorboard
  240. Belt Squeal 2005 MCS
  241. Help! My car's DEAD! :(
  242. 2005 car key mini sticker came off...
  243. Door Lock Curse
  244. First Post-First MINI
  245. Front window wipers stopped working
  246. trunk wont open!! * HELP!!
  247. mechanical door lock 2003
  248. Lower Console Gauges and Lighter failing?
  249. Replacing MCS 04 Belt Tensioner
  250. Paint Touch Up
