View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. Need technical help with Fault Code P1125
  2. dome light problems
  3. Seat belt will not fully retract
  4. Over heating and can't find a Leak.
  5. 2003 S - Replacing the fan blower
  6. ECU Reset Problem
  7. need help with my 2002 mini
  8. Vibrates at 3k+
  9. SEAFOAM PROCESS / THEN 1688 DIAG AND LIMP MODE
  10. synchros
  11. Passenger Window
  12. Replacement Windshield and Rain Sensor
  13. Shifter Cable Tool
  14. New Replacement Windshield and Rain Sensor
  15. Issue after changing clutch
  16. R50 Front Bumper chrome trim replacement Q
  17. Where can I get this part? please help!
  18. Out of Warranty Issues
  19. power steering fan runs when?
  20. Door Key lock/unlock won't work
  21. rattling noise from inside, ceiling area on driver's side
  22. I Hope you Know
  23. Front End Noise
  24. Any super smart people here?! (help needed)
  25. Cracked Valve cover
  26. Rack and Pinion Question
  27. Speaker Blown, Warranty?
  28. No signal to ECM from MAP sensor - please help
  29. Door Problems and one buried 04 MCS
  30. How do you change the clutch
  31. Is this whirring noise normal? *VID*
  32. How does my harmonic balancer look? *PICS*
  33. Shifter bushings
  34. Replace your rear wiper blade without going to the dealer!
  35. HELP:!! My R53 battery is locked out! Cant open latch!
  36. Boot won't open - how do I fix it myself?
  37. driver door wont open
  38. over Warranty Time but Under Miles
  39. Auto Shift problems - 05 MCa
  40. Axle bearing leak & bad welding joint (muffler)
  41. Brake lights dont light up.
  42. power steering fluid
  43. Any Luck with Lemon Law? 05 MCC
  44. My car is a mess need some help
  45. 03 cooper S water pump gear
  46. Tachometer red line lights don't work?
  47. ('06 MCS w/49,250 miles) Losing Coolant + White Cream in Oil = Fanfreakintastic
  48. Missfire cylinder 3 at track
  49. Drive axle and clutch
  50. Clutch Issue
  51. lil problem.....
  52. adjusting how much the windows dip
  53. My 2005 MCS conv wont start...HELP..i am freezing
  54. Dash Pad - Squeaks
  55. Please HELP: need a diagnosis possible bad clutch
  56. Loud THUD / Animal living in my MCS?
  57. Liquid on the ground
  58. Dropping rear subframe for realignment?
  59. Exhaust doesn't sound right after replacement
  60. One of those decades.. Tranny died. Thoughts?
  61. Multiple Problems PLEASE help
  62. HELP..how to change 05 daytime running light?
  63. weird clutch issue...
  64. 03 MCS Driver Seat "pop"!
  65. Cold weather overheatting
  66. Dash lights?
  67. Where to buy waterpump o-rings?
  68. overheating - not exactly the same as the other posts
  69. Key Fob Decal Question
  70. drives door will not open
  71. Where to get Window Parts?
  72. Power Steering Question
  73. Rubber Guard under Front bumper??
  74. MCSa Transmission Failure
  75. Cooling Fan and Temperature Spike?
  76. Urgent rear view mirror and locking help!!!!
  77. "tinking" noise from front passenger side. Axle? Wheel bearing?
  78. Noise from rear wheel
  79. just got 2002 cooper with 90k
  80. Cannot unlock doors with key fob or switch
  81. Blown Clutch Question
  82. FYI Frozen Gas Cap warning
  83. Uneven brake wear?
  84. What $3400 in damage looks like
  85. Mini windows whistle
  86. Stuck in gear
  87. Finding Vac / Boost leak
  88. Power Steering Dip
  89. Front bumper & underpanel questions
  90. valve chatter
  91. Blown Clutch!
  92. 03 Midlands trans died. Car for sale?
  93. Heater/AC fan motor replacement??
  94. mini cooper s with intermitten loss of electric
  95. clutch problem
  96. Car has gone haywire
  97. Steering Problems, please help!
  98. MCS R53, 6 speed manaul transmission problem. need advice.
  99. Darnit.. Running Oil-less.
  100. Aux Input Fails after 10-15 minutes 05 MCS
  101. need help with horn. there are 2 horns on the mini
  102. passenger door wont open
  103. HELP!!!!!!!!!!
  104. DSC Light stays on after going fast until restart
  105. The Bonnet and Boot badges are missing their black.
  106. Coolant all down the front of my block....
  107. clunky sound when twisting wheel side to side
  108. Differential Diagnosis: Thermostat vs Fan vs Other
  109. 5-speed Sparkle, Grinding type noise
  110. coolant leak
  111. Door Lock Pin Issue?
  112. R53 MCS Cold start rattle.
  113. OEM cup holder blows!!
  114. Help!! brake problem what next
  115. New Sidewalk Owner with questions
  116. OEM Lumbar Support is failing
  117. No idea, but problems, got codes!
  118. Starting Issue!
  119. Clutch, transmission or differential problem?
  120. glue fitting on vapor canister
  121. Where to buy tensioner dampener?
  122. Check gas Cap Light
  123. 2006 MCSC Leaking Oil Pan Gasket
  124. Car won't start.
  125. 2005 MC - Leather or Vinyl?
  126. Another BPV thread
  127. Acceptable oil consumption, again.
  128. 03/02 Front engine mount question!!
  129. Front Axle Issue - 02 MC
  130. Driver's Side Door Not Closing?
  131. 0-60 Problem
  132. 2004 Mini Non-S Noise
  133. Heated seats - blown fuse
  134. Headlamp Washer wont close!!!
  135. Rewiring under the seat?!
  136. Correct serpentine belt length for Cooper S? Found different sizes!!
  137. Questions regarding BC1 replacement.
  138. Anyone running Rotella in their MCS?
  139. R53...How do I change the Xenon bulb???
  140. Airbag sensor recall on 1st gen Mini?
  141. power steering gone, while driving?
  142. The penultimate straw...
  143. Auto Shop Could not Change Oil Filter
  144. Physically removing battery from '06
  145. Code P2096 2006 Mini Cooper
  146. Rear Wiper Spray Clogged
  147. disconnected OBD?????
  148. Trying to track down a noise
  149. 76k miles bad catalytic converter under warranty?
  150. 2005 MC (non-S) Belt Variations? (Kinda long...sorry)
  151. Gas door flew off
  152. rattle. with video.
  153. Help with Automatic Headlights; always on!
  154. check engine light
  155. Oil light on at idle
  156. Need a part number: 06 Hot Orange Pass. seat bottom
  157. arm rest not "latching"
  158. Supercharger Oil
  159. What do your oil filters cost?
  160. Battery/ Parasitic drain question
  161. Engine Miss at 70MPH
  162. can we switch speedometers between 05 and 03?
  163. O2 Sensor
  164. PLZ HELP...Air Bag light is ON!!!!
  165. HELP =[ multiple questions ugh
  166. red line, limp mode, then SES
  167. Noticeable play in the steering/suspension
  168. Dash Airbag light on.. need new entire seat bottom?
  169. Bleeder/cylinder/flush problem
  170. DRL High beams last longer than low beams
  171. Reed Valve Error P1477 (replaced pump already!)
  172. Lights Behind Temperature Controls
  173. Sub freezing starts
  174. strange sound
  175. My spark plugs at 53k miles
  176. Fog light not working
  177. Advice on accident damage repairs
  178. Signal and high beam problem
  179. Chugging/Sluggish Accel
  180. 02 MCS Tach problem
  181. Oil leak
  182. ABS and Tires Lights Simultaneously
  183. new engine at 80K?
  184. help with broken cooper s
  185. 03 MCS motor mount, strut towers
  186. Suspension issues 03 MCS
  187. Mysterious Whining Sound When Cold Outside on Startup
  188. shifting issues
  189. Temperature controls?
  190. Problems with minis
  191. Supercharger Seized up
  192. Cold weather, car won't start. Battery or something else?
  193. 2005 MCSa EML problem
  194. What color is OEM power steering fluid?
  195. SES light on and gauge reads 'NO CODES FOUND'
  196. Stripped oil pan drain on my 2004 R53.
  197. After years,DSC igintion retard causing carbon buildup on #4,throwing P0304 code
  198. 2005 mini has continuing oil pan leak
  199. Problem with CVT
  200. Problem free Midlands?
  201. Radiator Impersonating Pack a Day Smoker
  202. Help me diagnose a strange noise!
  203. Why do Mini's get air pockets in the coolant system from time to time?
  204. 30,000 mile service $550??? Seems high
  205. Passenger Airbag Sensor
  206. Divers seat height adjuster stuck.
  207. car not wanting to go into gear
  208. handful of codes, advice!
  209. Cold weather manual tranny problems?
  210. bad belt tensioner??
  211. Key problems in Northern California
  212. Auto Climate Control dead as well as MFSW audio buttons, Speedo and Dash lights out
  213. thermostat problems HELP!
  214. Occasional exhaust problem
  215. Rust Spots on Driver's Side Mirror?
  216. Backup Sensors not working
  217. planning to get leds
  218. My dealer just quoted me almost 2k to replace pump + sprcharger
  219. What is the part# for BPV ?
  220. Door Problems
  221. No clock after jump start?
  222. 2004 Antenna base snapped
  223. 2005 R50 Mini Cooper - hard to shift
  224. vibration while braking, vibration while Accelerating
  225. 2004 MC (non-S) Is My CVT Shot?
  226. Can't get it started
  227. computer show outside temperature very high than power steering stop working
  228. Driver side lights, not getting power?
  229. Outside Air Temperature Sensor Location?
  230. Rear end rattle driving me mad!
  231. Can somebody tell me where this oil is coming from
  232. Having an engine problem with my Mini! Help please!
  233. 2004 MC (non-S) Multiple Issues (EP Code, Car Running Without Key in Ignition, etc)
  234. Wheel repair in So Cal?
  235. Help! Headlights won't auto-level and can't figure out why!
  236. Car Leaning, tire rubbing
  237. Mystery part identification help
  238. Noise from drivetrain
  239. Digital display is off post-battery change
  240. Overheating Problem & A Solution
  241. Pre-Purchase Question RE Supercharger Life
  242. Hope that this NEVER happens to you!!!
  243. Interior lights cutting out ramdonly.
  244. starting problem
  245. Tensioner tool fabrication
  246. please help with airbags alert
  247. problems with my lights
  248. Cracked rear hatch handle? Anyone?
  249. coolant leaked?
  250. Plugs - 15% Pulley/CAI
