View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. Do you get a lot of steering wheel shake?
  2. Blow out on hose from water pump to flange
  3. Losing power, any ideas?
  4. Over heating and wierd noises
  5. tie rod adjustable? or replace only.
  6. Please help. It is leaking!!!
  7. RPM Gauge cluster not working
  8. flat spot , hesitation at 3000 rpm
  9. Steering wheel locked while driving - Help!!
  10. p0130 followed by p0420 (Coil mabye?)
  11. Possible dead battery?
  12. Replacing front windshield wipers
  13. What in the world is going on with my R53?
  14. 2005 Mini Won't Start
  15. ignition coil or coil pack problem?
  16. PS fluid leak?
  17. High Pitched Whine When Car is Off.. Won't Stop! Help!
  18. R53 stock Boost??
  19. 05 air conditioner problem
  20. Secondary o2 Sensor Solutions
  21. Help AC has no Power
  22. help - new car written off for water damage
  23. Spark Plug Seats
  24. Won't start after accident
  25. 2003 Mini Cooper S WRECKED
  26. No more electricty in my Mini....
  27. 2003 passenger seat stuck forward
  28. What is this leak?? (pic)
  29. loose door pane 2006 mini
  30. SOS!!! Major transmission issue. Please help!
  31. Cooper S Engine Code Issues
  32. Coil/wire problem?
  33. jingling tab on belt tensioner
  34. Midlands Transmission sounds terrible! PLEASE Help me find the problem!
  35. You guys are probably sick of this question, but clutch bleeding...
  36. OBC Temp Gauge Stuck
  37. Leaking sunroof and dead dash
  38. Rear Hatch Window water leak
  39. 03 Cooper, front seat stuck in folded over position
  40. Car cranks but doesnt start.
  41. Clutch pedal is hard to push
  42. Driver's door won't open from inside or outside
  43. Need help identifying (slight) oil leak
  44. what compression levels does a motor need a rebuild?
  45. airbag light but its not the seat harness
  46. brake fluid bleeding question
  47. sudden stiffness in turning steering wheel?
  48. Need help with Sea foam
  49. dead clutch?
  50. NO!!! OMG I see RUST on my 2005 !!!
  51. Door lock issue
  52. 2002 needs a tranny
  53. Unlock all doors at once?
  54. How to fix window seal on the outside and wheel arch trim?
  55. Auto trans info
  56. Hard to start
  57. I've had it up to here with my front suspension
  58. Mysterious Battery Problem....
  59. Does anyone know the name of this part?
  60. Inconsistant power?
  61. Wipers quit working
  62. CVT small problem
  63. Low Water Temp/High Intake Air Temps
  64. mcs 2002 no power CODE P0341
  65. R53 problems
  66. Noises when shifting
  67. SES light on, losing power @ idle
  68. DSC, ABS, Tire lights on
  69. Is replacing an axle half shaft and wishbone a DIY project?
  70. oil cap leaking
  71. Water in Engine oil
  72. Urgent!!:: Car Won't Start...Lights Don't Even Come On
  73. Key won't charge
  74. electrical gremlins redux
  75. Door groans, my ears bleed
  76. Car won't lock!
  77. rally light help!?
  78. Car Wouldn't Ideal Right
  79. Oil leak, need suggestions
  80. Power Steering not shutting off
  81. steering wheel ain't centered...
  82. Silver, metalic fluid leak.
  83. How to tighten the strut top nut?
  84. CVT Repair
  85. 04 Cooper: annoying on/off throttle jerk
  86. Video: Clutch noise..... HELP!
  87. MINI is cutting off when i start it up. i think its the fuel pump
  88. So We Were Getting Estimates Today
  89. Urgent!!:: Car won't start, even with a new battery!!!
  90. glove box chrome
  91. Bearing noise/whine
  92. Oil Temp fluctuation.
  93. POWER STEERING DIED 2003 MINI
  94. Chrome bit on the parking brake
  95. Cold start rattle question
  96. No oil Mini
  97. '05 driver's side door stopped locking/unlocking electronically
  98. Headlight not working!
  99. Lost Oil Fill Cap
  100. R52 Blowing PDC 5amp Fuse
  101. Broken glove box lock for '05 MINI Cooper S, any suggestions?!
  102. rattling sound below control buttons
  103. 2002 Mini Cooper S Help Needed
  104. Driver's door problem
  105. Gear Shift Sticking, Causes? Suggestions?
  106. Grinding noise.
  107. Problem with sunroof
  108. Coolant temp gauge close to 200F
  109. 2005 Mini Cooper Convertible - Overheating for 2 years
  110. 05 mini cooper s service engine soon light!
  111. Please help re: tachometer computer display not working
  112. Results after boost gauge install
  113. Air Conditioning Problem
  114. Rough Idel and Cylinder 3 Misfire
  115. Electrical Demons in the hatch/lighting
  116. Lost Clutch over night
  117. Any way to "guess" torque without a torque wrench?
  118. Program '04 key fob? Must go to dealer!
  119. squel/clunking noise from engine area?
  120. 04 MCS and battery/door issue
  121. Something Doesn't Smell Right
  122. Mesh screen in oil filter housing?
  123. Mini Cooper S - wheel problems...
  124. Gauge auto test wierdness at startup.
  125. Clutch pedal squeaks/groans when warm
  126. Clutch / Gearbox Situation HELP PLEASE!!!!
  127. head gasket replacement
  128. Service Engine Soon Light Issues - Please Help!
  129. Check Engine Light and Just bought my JCW! Hearing Fireworks!
  130. Parking sensor fuse keeps blowing
  131. Car won't start...Not the battery
  132. Mini won't start...Not the Battery
  133. Ticking noise coming from rear right.
  134. rattling clutch.
  135. Passenger Airbag Warning Light
  136. fog light bulb
  137. Mini Dead after stall and 1 restart. now no dash lights, good battery
  138. 40,000 mcs
  139. HELP!! Where is Air Temp. Sensor???
  140. P0420 BANK 1 O2 sensor
  141. rattle?
  142. Timing valvetrain and bottom end?
  143. Body Color washing off under hood
  144. Removing teflon coating on head and block mating surfaces?
  145. R53 has no reverse light.. help
  146. R53 Upgraded Thermostat Housing?
  147. Power Steering Noise
  148. Power Steering Fluid Question
  149. 2002 mini manual tranny fluid
  150. Fan and overheating
  151. HELP I cant open my passenger door from inside or out
  152. Strut tower - Hammer?
  153. Crank pulley wobble and engine knock
  154. '06 Sunroof sometimes so slow!
  155. Oil pressure light flickering....
  156. Heater Core (?) Advice/Assistance
  157. Help!! Can't go over 4k RPM or else I'm limp!! Help!!
  158. Soon to be no more Mini Cooper S...
  159. Strut Boot
  160. Oil Leak!
  161. Clicking sound from passenger seat in a 2006 Cooper S
  162. Keychain Remote
  163. Ever Change Differential Fluid?
  164. Sticky Clutch issue
  165. rust
  166. Head removal: how do I take out the two plugs to access the chain tensioner?
  167. power steering fluid
  168. EWS failure mode?
  169. Leak-prone areas?
  170. Crank sensor o ring
  171. OBD II port no power or signal
  172. Driving lights.......
  173. Oil Leak
  174. Dealer says Limp Mode is because of faulty damper!
  175. taking on water in the rear
  176. Too much seafoam??
  177. Odd overheat.....
  178. nav staying on, draining battery
  179. Head removal
  180. tachometer/speedo/dash lights acting up
  181. Passenger headlight went out
  182. I can't figure out how to set the clock/time on the odometer!
  183. Couple Questions
  184. r53 with 6 speed paddle shift tranny
  185. Round and Round I go...
  186. Supercharger Parasitic Drag and whine
  187. My Mini is sick! Need some help please!
  188. Flashing Engine emission light
  189. Getting ready for some 100k maintenance!
  190. electrical system brain fart
  191. Clutch Problems
  192. Codes EML and idle issues
  193. Couple of questions about 04 S
  194. Power Steering lines
  195. clock keeps going bye-bye
  196. 2003 MCS Misfire & Spark plug change
  197. Faulty temp sensor?
  198. Tweeter/Door Handle Rattle
  199. Axle replacement, FEQ not acceptable
  200. HELP NEEDED WITH CV SHAFT
  201. Headlight Alignment
  202. First service
  203. White Smoke from exhaust!
  204. very weird coolant loss
  205. Top won't retract past sunroof stage! Help!
  206. My roof won't retract past sunroof stage!
  207. Pulled plug #2, soaked in oil and metal bits...
  208. Engine stop at 5000RPM
  209. Do I need a new Steering Column? Or...
  210. Running on three cylinders?!
  211. Minor run in with pothole, now clunk in large curb
  212. Powersteering once again.
  213. Rain Gutter Replacement
  214. Help with lower control arm bushing replacement
  215. to many codes...help please
  216. Potential MINI A/C Leak Issue - DIY Fix !
  217. Does this mean it's time for a new radiator?
  218. a/c and radiator fan?
  219. Steering Angle Sensor Failure?
  220. a/c and engine fan.
  221. Exhaust Heat Shield Bolt Size
  222. 2004 Cooper HID Question
  223. Mini wont go into gear
  224. Where Does the OBD Plug-in?
  225. oil change
  226. Start problems
  227. How easy should the supercharger spin?
  228. Replaced all 4 headlight bulbs, now left side hi and lo are out--HELP!
  229. Rear tire cupping...any thoughts
  230. quick diognosis please (yellow liquid)
  231. Parking lights
  232. Front Motor and Transmission Mount
  233. Rattles and noises from door mounted armrest
  234. 2002 R53 Drivers door will not open
  235. What is a cycle for OBD II for Emisson Testing
  236. Flat Tire warning light?
  237. Door Locks....funny...kind of
  238. CRAZY LIGHTS!!!! HELP PLEASE
  239. Cracked intake manifold
  240. Squeaky Seat back
  241. Need a Used 2003 Cooper S Exhaust Manifold & Cat
  242. New muffler?
  243. Problems with my MINI
  244. Strange noise in 2nd and 4th gear
  245. Climate control dial removal
  246. Rear Hatch Leak
  247. to-do list prior to warranty expiration?
  248. Steering Wheel Wobble & Tie-Rod Replacement Questions, Possibly Wheel Bearing
  249. Oil Filter Housing
  250. Rotor T50!
