View Full Version : R50/R53 :: Hatch Talk (2002-2006)
  1. keeping the perfect balance
  2. What is the Paint Code for Silver paint on roof?
  3. 05 MCS check engine light-Limp mode code P1688
  4. Stock headlights?
  5. Apparently I've lost my mind... please help.
  6. What do you like most about your R53 MCSa?
  7. Looking To Buy A Cooper S As A Daily Driver
  8. Does this make sense?
  9. Automatic windows
  10. Is this "Normal" Coolant Loss?
  11. Thinking about a 2003 MCS
  12. Panther Black Sport Seat
  13. constant mist or snow on rear window while driving
  14. Multiple Mechanical Issue Help
  15. Looking for a roof rack for my mini.
  16. 2006 mini cooper service manual
  17. Whats better R53 or R56 Cooper S Auto?
  18. rims
  19. wet under front mats in no sunroof '03 MCS, ideas?
  20. Help, what is code P1498
  21. question about battery replacement
  22. need rear tail lights r53
  23. Replacement Parts for 06 S Transmission??
  24. removing chrome off on r53 tail lights
  25. 40kgs of road salt in the boot=oversteer!
  26. R50 shift lug same as R53 shift lug
  27. Cooper with Sport Package
  28. Help with lights
  29. Long Island
  30. Replace that oil plug gasket, or else.... (possible disaster)
  31. Best place to get new windshield in Mass
  32. Powerflex control arm bushing - for those who have them installed
  33. Suspension upgrade R53
  34. Should i get this windshield replaced?
  35. replacing control arm bushings and ??
  36. Where are all the R53 Mini Cooper S Auto owners?
  37. driver side door only locks from inside
  38. driver side door only locks from inside
  39. oil can henery's
  40. What is going to happen to my 05 cooper s?
  41. bmw TIS--you can find everything about your car
  42. Scuttle and 'S' Options
  43. Strange winding noise from Speedometer
  44. Pentosin CHF11s vs Amsoil ATF PS Fluid
  45. Does no PDC mean no power steering fan as well?
  46. engine code 1675???
  47. How to tell what options on a used '06.
  48. Please Help!
  49. 2003MCS Retrofit R-ViewMirror w/HomeLink?
  50. Mini came back from the body shop.....
  51. The Value of a 2006 JCW
  52. Painful Day!!!
  53. Possible New Owner
  54. does anybody know where to get these parts
  55. Removing Shift Knob
  56. whats next.. pls guide me
  57. 04' Mini fuel or computer issues?
  58. Plastic Silver Interior
  59. Mini World Inc.
  60. RMW flash tool
  61. detroit bpv and 06 MCS
  62. Want a free MINI ...
  63. Inspection #2 coming up (did research a lot)
  64. Doing some work on an older R53
  65. craked air filter!
  66. 2005 S having problem with all dash gauges
  67. Help...Outer Ball Joint Removal
  68. Do I have heat pads in my seats?
  69. Radiator fins comb, anyone?
  70. will this work for my car?
  71. 2005 Cooper 5sp, replaced shift cables, shifter is still stiff going to 1st or 2nd
  72. Question for MINI technicians out there!
  73. Exhaust Question & P0420 Code
  74. Calling all blacked out MINI's!
  75. Mysterious button under the bonnet (hood)
  76. boost gauge and fuel pressure regulator question
  77. QUESTION about alarm retrofit
  78. Changing your own oil
  79. obc question.
  80. Ipod not working in Mini Cooper :(
  81. Need help, parts and labor expensive?
  82. 05 console fit 03?
  83. Driving light question
  84. Service engine light ?How worried?
  85. Removing the interior A Pillar trim
  86. Squeaky seatbelt solution...
  87. Battery question?
  88. Squealing Clutch
  89. Another fender bender, are you forreal.
  90. How to remove the rear view mirror
  91. Cooling fan modifications
  92. Inspection on the horizon, what to ask about
  93. 06 MCS o2 sensor
  94. E-Bay find and fair price?
  95. CEL and tcs light after pulley install
  96. S Stevens
  97. Suddenly difficult to shift in to Reverse, First and Second Gears.
  98. ECU reset question
  99. Annapolis, MD area mini mechanic needed
  100. -### when I start the mini...
  101. is it possible?
  102. 2006 rear brake pad question
  103. 2006 MCS Idling rough
  104. MCS '04 Rattle and hum...
  105. "can't wait for march club" 2003
  106. Mini Cooper Service in Phoenix/ Scottsdale
  107. is this sound a timing chain tensioner going bad or something else
  108. Fuel Pump fail - Ouch$$
  109. R50 speedometer needle not on zero at rest
  110. Alignment
  111. Just picked up a chili red 2006 MCS anddd....
  112. Help locating a part's existence (Turn signal with OBC and Alarm)
  113. MCS Sport Suspension Plus...Which Shocks?
  114. Pulley/Belt question
  115. New clutch, flywheel, etc @ 72000
  116. Purchased Totalled Mini?
  117. R53 MCS EB quiting at 5500 RPM
  118. Installing driver's side axle... is this all the way in? See pix
  119. will the ECU reset?
  120. How to remove pedal covers???
  121. Clicking Noise When Driving (not just turning)
  122. Anybody have Oil Pan Gasket Advice?
  123. DIY Supercharger rebuild anyone ?
  124. 04 S Headlights
  125. Fixed my Rear Rattle
  126. Motor 1.4 or 1.6
  127. Help -03 R53 - Where is the wheel lock key?
  128. cargo (boot) cover
  129. Gauges clicking when starting the car?
  130. what is this? clear coat or paint going bad?
  131. R5/emx scan tool not working?
  132. '05 MCS brakes
  133. one of a kind mini now!
  134. Airbag/Steering wheel compatibility
  135. Replacing driver's side axle. Special tools needed?
  136. Replacement control arm bushings: which ones for longest life?
  137. Celsius to Farenheit
  138. need a little help
  139. unconnected cable dont know where it goes
  140. Front LIP and splitter?
  141. Who's car do I have?
  142. anyone in the costa mesa, CA area...
  143. fond wire under passenger seat
  144. Need tor replace headlight bulbs - which brand do you suggest?
  145. Any demand for rebuilt H&R RSS Adjustable Coilover set?
  146. Boot wont open
  147. Changing R53 JCW intake to Alta CAI
  148. busted mirror while parked...
  149. 2004 mini S
  150. too deep into the 04 mcs computer
  151. Advice for a potential owner
  152. power stearing is gone
  153. Question about the tire jack
  154. MY BUILD UP, continued...
  155. Disable the Passenger seat notice
  156. What to do? I love my MINI but....
  157. Violent car and wheel shake on 2003 MCS after snowstorm
  158. Extra key?
  159. Happy Holidays
  160. how to remove pin from clutch pedal/master cylinder...
  161. Winking Headlights
  162. Gauge options for MINIs with navigation (dual cluster)
  163. knocking or clicking noise on cold startup-normal?
  164. Tire problem?
  165. Any one rocking xxrs?
  166. 5 speed swap
  167. 2008 R56 MCS or 2006 R53 MCS JCW
  168. Not to sound like a n00b...
  169. Retrofit Chrono gauges
  170. 04 Mini Miss Fire And Small Leak? Help
  171. thinking about my MPG while reading some posts in my free time
  172. 1st Gen. annual maintenance costs
  173. Badges...
  174. Rain in the car (never happened before)
  175. 05 6 speed
  176. Slippery Pedals - Rainy Seattle
  177. JCW exhaust before/after
  178. Wiper Fluid Problems
  179. Mini not cranking.
  180. New Socal Owner
  181. Officially in the club now
  182. need a junk thermostat housing
  183. 2001 power point ?
  184. Help Locating Some Parts - Please
  185. MY new (to me) MINI
  186. R53 headlights
  187. moving a mini across the country!
  188. Considering buying an '06 MCS....
  189. When should I change the spark plugs?
  190. Reset ECU vs Computer Mod/tune
  191. '06 Mini S vs '07 VW GTI *Please Help Me Choose*
  192. Going Out Of Town to Buy a MINI
  193. How many of you turn off your low beams in the blizzard?
  194. Help! 04 (March) MCS key fob not working after BCM change.
  195. Trip advice/radar detector advice for journey
  196. Anyone install a reverse-spot light in their blank rear foglight panel?
  197. Sanity Check on Outstanding MINI Maintenance Questions
  198. vgs + boost guage (yes I searched :-)
  199. Who rebuilds our SCs
  200. Replacing dual mass flywheel with standard a bad idea?
  201. Any matte (satin) white R53's out there?
  202. What Came on my 06 Mini - how can I find out?
  203. MCS exhaust type question.. .
  204. Which Would Be More Reliable?
  205. First Brake Job On A Mini Today!
  206. Optima R34 battery doesn't reeeaalllly fit?
  207. brake bleeding - manually
  208. Recommended Alignment Shop in MA
  209. Top rear tail light broken?
  210. Inspection check list for used Mini?
  211. Used high mileage S good for dd?
  212. R53 "solid"
  213. ? about buying an 02 cooper s
  214. Trade for my Automatic please
  215. Please help me make a merry Christmas for my man
  216. 2002 Coop S
  217. Keep or sell?
  218. what is this sensor-looking thing on my dash?
  219. Locked out of my 2004 R50!
  220. High Mileage Oil Reccomendations?
  221. Sunroof lube?
  222. Dumb question on service engine light
  223. Is this stupid? Towing with my MCS...
  224. Parking lights (the one in the front bumper)
  225. 'Service Engine' Reset?
  226. R53 MCS 110K - What Mods suggested?
  227. Normal vs. Abnormal power steering pump noise?
  228. 50k mile maintenance?
  229. Irvine Mini/BMW
  230. Looking for advice...well reassurance.
  231. tailgate - manual operation
  232. My MINI's Garage makeover
  233. just had a little crash.
  234. What's in your GloveBox ???
  235. When is MINI 1 inspection due ?
  236. Service Mileage Numbers Question
  237. Where to find this rear bumper reflector?
  238. '06 Mini and Car Washes
  239. Which fluid spec does the 5speed gearbox have?
  240. ATE DOT4 Typ 200 brake fluid and Bleeding the clutch?
  241. May need to be moved? Baylor University Driving CLUB
  242. 06 or 06.5? how to tell?
  243. EML and service engine soon?????
  244. Remote control key
  245. Gas Mileage?
  246. What next? Problem list
  247. Clutch question
  248. BMW CCA LA/BEVERLY HILLS BMW Auto-x 12-5-10
  249. Stolen!
  250. Whistling Noise from front driver side
