- R53 Frontbrake rotor diameter?
- Engine mount replacement.
- Help - Steering Knuckle damaged
- Crowner ns2 or Schrick Camshaft?
- Gen1 HID headlight adjustment?
- Winter beater? 190K mile MCS
- Wiper blade inserts
- Single Beep From Backup Sensor When Shifting Into Reverse?
- 03MCS OEM Battery lasted 9 years - is that a record?
- Yakima roof rack
- Tips for changing out LCA bushings???
- 2006 Cooper R50 Conecting Rod
- Supercharger plastic painted?
- Unplugged my ECU without disconnecting the battery...
- Strange Engine Buzzing/Vibration while driving in the rain??
- Thoughts on 2004 S (less miles, upgraded) vs 2006 S (more miles, stock)
- Tire and brake problems
- Snow tires / small wheels... what a difference.
- Coolant emptied, leaked everywhere
- Wrong antifreeze; mobil 1
- EML light with no other warning lights (and no "limp mode")
- Clutch Suggestions
- does bad PS pump turn on Alternator light
- Help out a suspension noob. What to buy?
- Dashboard Rattle
- Maine, any Mini garages to suggest?
- Loud whistle over 90-100ish mph
- LED Load Resistor...
- Lamp covers
- Mesh Grill Installation
- Advice for Buyer of High Mileage MCS
- 2006 advice
- Sprint booster and Pulley
- Pic request: Silver Mini S with BRG roof and mirrors
- VMR replica question
- front upper struts on 03 S w/52,618 miles
- 2006 r50 Exhaust?
- TPMS question
- Are there coilovers that fit with 18x8 wheels?
- 2003 MCS P1688 - Please Assist
- boot around piston on front caliper
- Sad to Say, But the MINI is History...
- What to look for
- Anyone elses TA bearing look like this?
- Do R53 brakes suck?
- Aero Front bumper fitment questions!
- Seat covers
- R53 Xenon Interchangeability?
- Common Front End Bushings that wear out?
- Brake Lights
- New odd sound under full throttle (3rd gear and up)
- Rennline 15% OFF Holiday Sale - Now Valid!
- Weird issues upon start up?
- Motor Swap??
- 3 power steering pumps in 2 months? Am I missing root cause?
- Need Quick HELP & Answer on Clutch Slave & Release Arm/Fork ???
- Custom Exhaust on my 04 MCS?
- When do most people realize their power steering pump fan has failed?
- mini cooper R50 post catalytic converter O2 sensor high voltage
- Cowl Foam / Screen Replacement
- A Pillar trim replacement
- White Aero Grill??
- Stereo issue, speakers cut out.
- Ski Rack for 04 MCS
- Does your R53 clock keep good time?
- SL Auto Parts Power Steering Pump?
- Popping feeling in steering when cold out?
- bad auto ?
- Sprint Booster
- bypass valve problem?
- Automatic Gearboxes
- Exhaust replacement threw ck eng light
- Electrical issues....
- OEM headlight fs on ebay early model 50 bucks
- Head Gasket Job
- Rennline's Black Friday Starts Now!
- What a Overcharge for CVT Filters!
- The letters " E P " under the mileage ?
- Time for new injectors?
- Car not starting... Totally dead.
- Amber rear turn signals (on an '06 MCS)
- quick question strut mounts?
- New member looking at MINIs
- intake
- CVT transmission
- r50 coolant change-must be through the thermostat housing?
- Side Scuttles
- Now what...Parts no longer available for MINI
- Back Seats
- water/methanol AEM kit???
- just replaced my belt tensioner
- Engine bay rattle but only from 4200-4500 rpm
- 02-06 Mini Cooper Complete Service Manual Download Link
- *HELP* Engine wiring schematics??? 2002
- Clutch is messed up!
- 2006 Mini Cooper JCW won't start
- Will the mods ever end?
- 2003 R50s and Torx head screws?
- How to transport
- e46 seats in mini cooper
- How do you raise the engagment point of the cluth pedal
- How to adjust the clutch pedal off of the floor some more
- radiator fan runs on high
- What tires for my stock 17" wheels?
- Can't start after bleeding coolant
- Power Steering Fluid - question
- 04 MCS Meagan header install problems
- 2006 Mini Cooper S Custom JCW Start Up, Exhaust, and In Depth Tour
- Auxillary fan comming on!!
- Exhaust noise??
- Brake Line Failure
- Torquing value rear hub
- Custom Tuner Northern New England
- R53 Dipstick
- Best R50 (non S) intake
- CVT tranny 96k
- Bras - ins and outs
- UHaul tow dolly
- New wheels and tires
- Check engine light came on today...?
- R53 Driver-side door doesn't quite line up
- Ses/dsc & p0304
- Confused over control arm bushing repair
- New Owner
- Spark plug gap on R53 S?
- Facelifted r53 halogen headlights in an 02-04?
- Promini?
- Crown mini of richmond labor hour $89
- Passenger overhead grab hanndle
- What type of battery is the OEM replacement?
- So I run into my first problem....
- N18 BSH Catch Can help (2011 MCS)
- Any clue what model # or how much these wheels are worth?
- Sport package spring rates?
- Wanting New Wheels
- chrome trim.around car ?
- Ok to use fix a flat?
- Thinking about new wheels
- Selling my 05 MCS, one of the best years?
- Opinions Please
- Stock muffler?
- What Exhaust do I have?
- Should I sell my MINI? Opinions needed.
- Arm Rest Retrofit Question
- Service?
- 2002 R53 Opinions
- CravenSpeed short shift, now off center?
- Help with engine part number/code???
- Exhaust
- Anyone slammed on 18's?
- Quad Exhaust
- My new R53
- 05 MCS master option list?
- My new R53
- Road Trip - New transmission
- Twin charged lots of questions
- 2004 MCS R53 Gas Mileage Improvement?
- $100 programing fee?!?!?! My dealer sucks.
- best way to clean out your intercooler ??
- Rennline Track Mat Sale and Rubber Grip Pedal Product Release
- Gut Check
- Newbie here
- fuel cap replacement - S
- Missing engine cover
- Jet Black W/ White roof
- Anyone in the New England....
- R53 Upgrade Advice Request
- Thoughts on a 2003 JCW, please...
- just installed my aux input ;)
- EuroSpot 02-06 header?
- new exhaust tips what u think
- That Just Happen
- What upgrades can I do with my R50 03 Mini?
- Mnniprl
- fog lights ideas bulbs ?
- 2003 MC Headlight washer
- how do you know?
- Great service
- Replaced rack, and Bushings.. Still a slight tug at wheel
- Window Issue
- Do I need to change the thermostat
- symptoms of a failing CVT gearbox?
- vin number locations
- Pulled the trigger
- Coolant leak at Radiator
- Do R53 Stock Exhausts work on all year R53?
- Source for Power Steering Pump fan?
- Power steering fluid
- Key Fob Job
- MediaBridge Install - Complete
- Fog Light Removal
- Oil Help
- 15" on stock S set up = Negative camber of love.
- painting brake need help
- Clutch Clutch Clutch!
- Please Help......non-interference or interference??
- Is your MC your daily driver???
- Horrible Engine noise, with video
- Rear Hatch Dripping Water?
- anybody incorporate switch for garage door opener
- speed matching and heel/toe
- Silly Key Question
- Manual transmission brands and years?
- Rally Lights
- Running a cable from the boot to the dashboard - how to remove interior panels
- Maintenance service questions
- To sell, or not to sell?
- NCS Expert for R53
- s-lites with 225/45-17 Snow tires?
- No brake lights!???!
- 6-sp auto shifting out of reverse gear
- Heard a pop... annnd my clutch is dead.
- Any aftermarket alternative to the OE junky pot-metal muffler hangers?
- Will a MCS run without the SC belt on?
- does anybody know who can make a custom turbo manifol???
- Roof molding removal
- bedding in brakes in rain
- tire rotation
- strong smell from engine at 90MPH on base cooper
- Rear Brake Caliper Question(s)
- Anyone have any...
- Did I do something?
- Cornering/Steering "with the gas".....??? Info?
- Quebecers more than welcome...
- Remote lock, do light flash?
- Mini Cooper R50 AUTO CVT Transmission NO MANUAL SHIFT MODE
- Need help airbag troubles??
- Clutch Engagement Issue
- super charger and trurbo
- Coolant flush/fill using closed loop system in NJ/NY area? ?
- Popping sounds from engine/exhaust when coming down to idle after pulley upgrade
- trailer brakes
- 245/45r17 on 2005 CooperS
- Where the heck is the R53 picture thread?
- Body Kit Fitment
- SES light, EML light, DSC light, RPM drop
- Paint or vinyl?
- fitment of R56 seats into R53??
- Heat is on "hi" its warm, but not hot.
- PS Fan, battery disconnect, rear hatch, clown car shenanigans
- Trick to unplugging factory Sirius receiver?
- Removing/Reinstalling Front Struts
- 15% pulley upgrade questions...
- Found this JCW, is it fixable? What is it worth?
- new owner cup holder
- aeroforce interceptor or scangauge
- Front Strut Mount Plate - Rubber Cracked
- Best aftermarket (or stock) water pump & thermostat to buy?!
- Looking for Airbox top for R50 Automatic
