View Full Version : Suspension
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14
  1. KW Coilovers?
  2. Smoothing out my ride
  3. Suspension Upgrade & OEM Control Arms
  4. Different gap between tire and car = different ride height?
  5. How hard is it to install lower control arms?
  6. Rear Sway Bar: H-Sport 19mm or H-Sport Competition 22mm
  7. MC urethane bushings, where to buy?
  8. Car sitting lower on one side?
  9. Weird shock question
  10. Broke Strut tower bolt installing M7 brace
  11. Mods to get to 1 G
  12. Swaybar & Hacksaw?
  13. Coilover and Alignment
  14. endlinks on OEM sport sway bar
  15. 205/50/16 tire with 5.5x16 wheels?
  16. Feeler: Energy Suspension Bushings.
  17. outer passenger CV joint #3
  18. Camber optical illusion?
  19. MC Ride
  20. s stock shocks
  21. issue with 25.5mm H-sport rear swaybar
  22. got $$$, must "fix" the Mini
  23. Suspension ..MCS vs JCW vs Coilovers
  24. Rear control arm or alignment?
  25. Question to those with Koni Yellow's...
  26. Strut Upper Mounting Nuts
  27. Rear sway - questions
  28. Eibach springs on MC...good for MCS?
  29. Suggestions on rubbing tires?
  30. MC Suspension Upgrade....
  31. Do I really need control arms with m7 sport springs?
  32. 2005 MCS alignment questions
  33. M7 or H&R Coilovers
  34. Newb questions about suspension!!
  35. Two tips for front struts and springs disassembly.
  36. Bavarian Autosport performance front control arm bushing review
  37. R50 and R53 wheels on a R56?
  38. New Coilovers
  39. Should I apply Loctite
  40. WebbSport Extreme Rear Sway Bay - Opinions
  41. Tire Size and lowering
  42. I'm a newbie
  43. Lowest drop with 18's
  44. Creaking When Coming to a Full Stop
  45. JIC-Cross Coilovers
  46. Camber plates
  47. Anyone on Proxes?
  48. Eibach coil-over
  49. R50 upgrade to R53
  50. Hands down, the best suspension for the S...
  51. Next Move?
  52. Does this look right?
  53. New Megan Suspension
  54. Click/Honk sound from front left suspension
  55. Alignment woes
  56. List of different brands of Rear Sway Bars
  57. New FSD Owner
  58. 06 MCS rear camber range
  59. Helix Short Shifter question
  60. Rear control arms DIY?
  61. Wheel bearing dilemma!!
  62. Adj. camber plates and rattling front end
  63. What would a front sway bar do for my car?
  64. New Coilover on the way!!
  65. Suspension travel
  66. A quick offset/motion ratio clarification
  67. Suspension "Knock"
  68. Pulls to the right...
  69. Some Qs on RCAs for primarily street use?
  70. Strut tower Brace to work with Mushrooming ?
  71. Impacts from Lowering
  72. Who got the lightest MINI COOPER S
  73. USS Front Brace Install Woes
  74. Alignment: Before and after
  75. Has anyone recieved Helix camber plates within the last 2 months?
  76. Strut plate = Camber plate?
  77. Front Lower Control Arm Bushings Install
  78. WTB: used SS+ springs
  79. (-1.2 vs -2.1) Front Camber after Fixed camber plates?
  80. Ireand Eng. adjustable control arms squeak...
  81. strut bar dimentions? do it my self
  82. Brake Survey
  83. Questions about changing rear sway setting
  84. So Easy Even batgirlwildcat Can Do It!
  85. My suspension combo: JCW springs, Hsport bars, FSD's
  86. 05mc JCW 18 with H&R lowing springs
  87. Lower suspension springs
  88. SPC Performance Camber Links
  89. Eibach springs
  90. stock suspension question.
  91. Convertible brace part number?
  92. Grrrrrrrrrr... ProMINI front strut bar "upgrade" seems liike anything but...
  93. So what is the Choice suspension (coilovers/shocks/spring) for the Mini?
  94. Larger front sway bar + no rear sway bar = OK?
  95. ALTA control arms
  96. Chassis brace installation
  97. PSS9 helper spring question
  98. alignment?
  99. Megan coilover instructions?
  100. Koni Spring ?
  101. stock spring rates
  102. M7 spring
  103. Heim joint replacement / wear?
  104. Wheel spacers, anyone have them?
  105. Front End click/clunk...Help!!!
  106. What size of rear sway bar suitable for MINI ONE?
  107. Rear sway bar for 06 S with JCW engine
  108. Next step?
  109. Koni FSD with lowering springs
  110. Camber after front plates < than expected?
  111. balance
  112. Would a 0 offset wheel with arches work?
  113. Best Camber plates for Koni Yellows?
  114. H-Sport upgrade and new tires
  115. Recommend a RSB that isn't squeaky?
  116. koni coilover setup questions?
  117. Anyone running H&R Springs with Koni Yellow Sport Shocks?
  118. HELP! H&R Coilovers, car stuck in shop!
  119. M7 USS and RCB
  120. Wheel questions
  121. Two weeks with the H&R Sportcoilover - a review
  122. Suspension help pleeeeeeeeez.. :-(
  123. helix camber plates + FSDs - can't go lower than -1.9 ?
  124. Cabrio front braces on non-cabrio?
  125. What size sway Bar?
  126. What springs to get??
  127. lookin for best place to buy performance shocks and struts
  128. Big Brake Kits and Webspokes
  129. Had my car at Don's shop today...
  130. Best way to remove wheel gap w/o comprimising stock suspension
  131. front strut tool
  132. CLUNK! How many thread showing on FSD's
  133. The Skinny on H&R's sportcoilover ride height
  134. May have stripped a rear strut tower bolt...Help
  135. Coilover or not that is the question
  136. need saddles for H&R 25mm tubular swaybar
  137. Ireland Street/Race plates modifications...
  138. Front control arm bushing install
  139. Stock Springs rubbing with H-Sport Camber plates....???
  140. Is an alignment needed after springs?
  141. IE Street/Race plates and H&R Sport Coilovers
  142. IE fixed plates - 2 questions
  143. shock knock?
  144. Ireland Engineering - Another unhappy customer :-(
  145. The Definitive Alignment Settings thread
  146. m7 Coilover First Impressions
  147. m7 v.s. H-Sport
  148. Replacing Control Arm Bushings in Pairs??
  149. Best street/track rear control arms
  150. Koni Settings with Eibach Springs
  151. Suspension Review - Brakes, Wheels, Tires
  152. New H&R Srings
  153. BBR-GTI Power Grip Kit or camber plates
  154. A few more ?s
  155. Snapped my piston shaft! Doh...
  156. DISAPPOINTMENT with IRELAND ENGINEERING!
  157. Rubbing on front FSD struts?
  158. The great rear stress bar question solved?
  159. brakes ... ?
  160. Finding Center Line of car
  161. Teflon coated sway bar bushings?
  162. H-Sport Springs vs TSW Springs
  163. Need next mod advice
  164. Scraping problems with bigger than stock tires?
  165. Lowering - what hits/rubs first?
  166. Softening the ride on 17s
  167. Cross Suspension Question .... >>>>
  168. Front Sway Bar installation help needed
  169. Upgrade your brakes before you come to the Dragon
  170. gears back from service,...
  171. 5mm spacers on 42 ET wheels too much?
  172. Front lower control arm movement
  173. Any experience with Dinan fixed camber plates?
  174. Ireland control arms with aurora rod ends
  175. H&R 27mm Front Sway Bar/The Un-Expected
  176. Aluminum Front Control Arms
  177. Spring 'Swappin
  178. Ireland Engineering street/track camber plates
  179. Suspension Setup, need approval
  180. Bilstein PSS9 Linear Spring Swap (fronts)
  181. Bilstein SP Front Strut Install from Hell
  182. Ride Height - How low is "too low" for autocrossing?
  183. Spring thrust bearings - yes or no?
  184. Wanting to purchase a sway bar
  185. Camber Plate Confusion - Which one?
  186. How does one fix too much camber/castor ?
  187. M7 Coilover answers and more....
  188. What do you use spring pre-load for?
  189. Tire fitment model??
  190. Track sway bar setting help for lime rock
  191. PSS9 spring question?
  192. replaced h-sport with h&r
  193. HELP!! Strut topmounting holes
  194. TSW's new coilovers...
  195. quick question about OEM struts
  196. Lowering the 02MCS
  197. New struts?
  198. Rusty Bolts on Strut Tower Brace
  199. Is Mini Madness still in business???
  200. Poll - lower control arm, stock or aftermarket
  201. Is a 19mm rear sway on med = to 22mm on soft?
  202. Wilwood Big Brake sensor problem
  203. Megan coilover camber plates
  204. What's my next step?
  205. PSS9 and H&R coil users. Quick Q for you..
  206. H&R Coilover Install
  207. Koni FSD: Is this normal?
  208. Using two differant tire sizes??
  209. Ireland Engineering control arms worn after 1 year
  210. Question about what lowering springs I can fit
  211. CROSS Suspension MCS SPECIAL
  212. has anyone used spring spacers?
  213. yet another camber plate question
  214. SWAYBAR SIZE?????
  215. M7 Rear Chassis Brace=AWESOME!
  216. FYI H&R spring rate info
  217. jacking up MINI w/aero kit.
  218. 04 MCS: alignment settings?
  219. FSD comfort question?
  220. KW V2 or V3...
  221. Lost a Bushing...What do I do?
  222. Dumb question: front control arms
  223. Has anyone ever used, or even heard of this?
  224. K-mac camber/caster plate - do you like yours?
  225. H.springs or H&R
  226. M7 USS (again)
  227. Best Coilover setup for $1,000.00 or less???
  228. Suspension setup at DMH Motorsports...
  229. Whats the best rear camber angle to have for fast street
  230. Rear Control Arms
  231. New shocks/struts at 50,000 miles?
  232. Alignment immediately after IE Fixed Camber Plates?
  233. My M7 USS install
  234. Don't forget camber plates!
  235. Urethane bushing lube?
  236. Something weird happend after STB install
  237. front control arms
  238. Alignment after H-Sports?
  239. Taking a rear trailing arm bushing poll
  240. Help my car is leaning after camber plates
  241. Where's the "Uber" Customer Service???
  242. NO FRONT SWAY BAR!
  243. Another Happy Guy with 22mm rear swaybar
  244. Rebuilding the Detroit Tuned BBK
  245. Beginner Suspension Tweaking - What to do first?
  246. Front Swaybar Install How-To
  247. Oh No! Crunched suspension
  248. Where can i buy a replacment part fro my H SPORT REAR CONTROL ARM.
  249. KW V1 coilovers...thoughts?
  250. IE adj. camber plate Question
