- What are the signs of a failed strut?
- Konis, Bilsteins or Keep OE struts/shocks with new Eibach Springs
- New Year Suspension Plans
- H-Sport Camber upgrade
- Strut Tower Brace cause understeer?
- M7 USS...riv nuts went poo poo
- Springs vs FSD
- another suspension updating thread
- Help with PSS9's
- Help. Strut Nuts on front shafts are loosening.
- Alutec upper strut bar
- JCW STRUT BRACE 2003
- Need advice
- Strut Tower Brace? IS IT REALLY NEEDED?
- Anyone have this?
- FSD Spring Perches help needed!
- I drove a 2008 for the day, not impressive!
- Alignment specs needed
- Where to buy a good Rear Brace?
- How does different offset on wheels impact handling?
- Performance setup question...
- H&R Sway bar bushings
- EBC Slotted Rotors
- 18X7.5 and 42 offset. Want a good drop but what springs?
- Bilstein PSS9 vs Cross Comparison/Review
- Ireland Adjustable Camber Plate (street) Instructions?
- Koni Yellow Sports
- 18" rims with 225 tires
- Ireland adjustable camber plates vs. Ireland fixed camber plates for the street
- Help
- Best camber and toe #'s for city driving?
- Dinan VS Eibach Springs
- qwik question
- CROSS coilovers for $1725 shipped
- A quick question regarding H&R Coilover [Sport]
- Such a noob to suspension...please help explain!
- Pls share 17" offset 37mm + 205/45 tires + lowering spring, rubbing experience
- I need help deciding on a new suspension setup
- Cross Coilover & M7 STB
- SPC Control Arms
- TC Kline Koni/Vogtland set up question
- DetroitTuned BBK opinions??
- What's the purpose of the strut bar?
- Thoughts on these type of coilovers
- to coilover or not
- DINAN/M7 Strut Bar - raised hood
- Can I go lower WITHOUT buying Coilovers?
- Cost of JCW suspension installation
- lifespan of coilovers
- Alignment needed after drop?
- Web featherlight strut hole cover:
- broken suspension bearing... part number?
- H-sports Question
- Diffence between cooper & cooper S susp...
- slammed on 18's.... pics?
- Dinan stage 1 suspension? or better route for same price?
- EBC Troubles
- OEM Sway Bars
- SPC camber plates?
- Hartge spring + ultraleggera (offset 37mm) + 205/45/r17 = rubbing ?
- HSport Lowering Springs
- Want a ride in an R53 lowered w/M7 coilovers. So Cal
- Adjusting Rear lower control arms
- Window weld or Urethane?
- Racing CV joints?
- Who makes the softess riding Coilovers? 2'' drop?
- TXW springs ordered, need good shop in San Diego to install
- Webb Camber Plates
- Camber plate?
- Camber plates, koni yellow & lowering spring questions
- Diameter of stock springs?
- How much travel on the shock is ENOUGH? (Fully compressed, Coilover)
- Dinan suspension: anybody have it?
- Alignment questions for a stock MCS
- eibach sway bar
- koni FSD
- Camber Plates: Which one is the quieter?
- Q About getting a new suspension.
- new tie rods again?!
- running at Limerock , CT
- Texas springs installed
- KW2 Variants?
- Cross Coilover Questions
- Trailing Arm Bushings
- R56 Springs vs. Coilovers vs. JCW
- Eibach bars/alignment kit...any good?
- Need help from the wheel obssesed
- AP Racing BBK
- Inner Tie Rod
- Where to buy IE camber plates?
- Outmotoring Coilovers?
- Lowering=rubbing ..question?
- K&W coil overs your comments please
- H-spor sway bar question (pic)
- Why do they look different (H&R Coilovers)?
- H&R R53 Springs on a R50
- JCW Suspension Install - DIY?
- struts
- buying just front coilovers
- Good Wheel Alignment Shop near Arlington, VA Needed
- I'm a newb, sorry :(
- r56 and r53 suspension interchangable?
- Ordered TSW springs. Now what?
- A surprising bearing find
- Suspension Squeak..
- Spax Coilovers
- LOPSIDED MINI!!!HELP!!
- Bump stop question
- ARGH! wrong brakelines!
- Installed my H-Sport Rear Lower Control Arms Last Night
- New MINI Owner - Need Help with Koni Coils
- Ideas for mild lowering with good ride
- JCW springs and 205/15-15s
- Which adj camber plate is good?
- Pulls to the left
- Sway Bar Link Detached on Driver's Front - PHOTOS
- 215/45/17 and H-sport springs?
- Suspension Expolded Diagrams
- Coilover question
- Motive Power Bleeder Mod
- FINALLY!! M7 STB in stock at TiC
- Who makes custom spring rate coils?
- spring rate conversion ?
- Need help with suspension settings and tire pressure! (please)
- Stiff strut setting = Bouncy ride?
- What suspension modifications for a '06 R53 JCW?
- Strut/shock recommendations?
- Suspension repair
- Help with springs
- Rear suspension knock after M7 spring install
- Front wheel bearing replacement
- 03Indigo's Vogtland adventure :)
- I think my new tires are rubbing on my fenders
- Strut Tower Caps
- question about front camber plate
- Which is for my car?
- springs install ??
- suspension noise
- Alignment (for autox/HPDE) shop around Downers Grove Ill?
- New front pads+rotors = less braking power
- Need Suspension Recommendation for my 07 Cooper S, JCW Convertible
- Sway Bars
- JCW Strut Brace with Alta airbox
- Peter also told me that the M7 coilovers were...
- HR Springs
- Is my rear Sway Bar upside down?
- LOWERING QUESTIONS
- Eibach camber plates
- Adjustable camber plates -- ease of adjustment
- Lowest Drop Coilover
- Typical install costs
- why suspension is king...
- Rubber boot on the rear suspension.
- NEED HELP WITH LOWERING MY MINI!
- JIC Magic/CROSS Competition Coilovers
- Rear sway bar/understeer question
- question of spc rear control arm
- Teflon Bushing?
- SPAX coilovers? Good or bad? Drop?
- Strut & Camber Plate Torque Specs
- Effect of camber plates on understeer
- Stock 16inch Wheel Weight?
- DOT 5 brake fluid
- Would this be worthwhile change?
- more coilover chat AGAIN!
- Best place to shop for 2.5" ID coilover springs?
- 05' Stock Rear Control Arms
- Heim Joint Maintenance...
- Choice: Strut Tower Brace or rear sway bar
- TSW X-Brace - More pics
- Camber plates with stock suspension
- Megan Racing?
- M7 USS, STB, and H-Sport RSB installed!
- Lug Bolts to Lug Studs
- More coilover chat.
- strut mounts
- Which rear control arms?
- what are your alignment settings?
- Sachs struts.
- Good wheel alignment shop in Central Jersey needed (near Middletown)
- rear tire cupping ?
- Good combo?
- Sorting
- What Is "Mushrooming"?
- Eibach springs - 3 cm
- M7 Anniversary Edition STB
- Give me a break!
- 2003 MCS Rear Shock Replacement
- Rear adjustable coilover setting????
- brake dust shields
- Rear Sway bar
- What's the deal with camber plates and "noise"?
- FS: Never Used R56 H&R Coilvoers and Alta Control Arms
- Vibrations Felt In Scotland
- Are camber plates and control arms necessary when lowering?
- Before & After pics of Hsport vs M7 on FSD's
- Inner tie rod replacement
- Red v Blue Strut Tower Plates
- The next step...
- AST Sportline 1 V.S. Koni Review/Suggestions
- Adding GP trailing arms to R53 - what does it take?
- Seeking some information on Koni Yellow shocks
- A study in rear adjustable control arms, with pics
- Tightning the rear shaft nut.
- 2003 MCS Front Sway Bar Replacement
- Help!!!
- Installed TEIN SS coilovers with EDFC
- M7 coilovers reviews
- Camber Plates and Stock Suspension?
- taking apart the front suspension -- Compressor needed?
- Tein springs compared to H&R and Hsport?
- IE Ireland Engineering Fixed camber plates Question
- M7 coilovers ... mystery solved!
- JCW strut brace on a Cooper
- 16" tire recommendations
- major issue with Ireland Camber plates
- Race suspension
- Adjustable control arm question
- M7 coilovers
- Photos of your Mini with JCW Suspension
- LOUD Alta Lower rear control arms
- Lowering=not worth it?
- which sit lower H&R or HSport?
- rear clunk
- M7 Strut Plates
- Front Control Arms
- strut re-inforcement plate questions
- Front Control Arm replacement, how long does it take?
- IE Street adj camber plate setup
- adjusting rear track?
- the Strut Brace hair-spray trick...
- springs
- Koni Coilovers.
- Rear End Links
- shrooming
- question on m7 srp
- M7 springs - cut bump stops??
- Racing Dynamics Springs
- uneven drop, sometimes, on h-sport springs
- Click clank clunk!
- spring install
- shocks
- M7 USS or H-Sport Comp Rear swaybar
- shocks/struts
- how should i drop my car??
- Anyone have H&R springs for an '07 R56???
- Suspension Question.
- What coilovers or suspension upgrades are out there for my pre-March 02 MINI S?
- hotchkis springs
- AutoX and road alignment, need suggestion.
