- Camber plate questions? Ireland or Helix?
- Coilover basics aka Coilovers for Dummies
- Bushings are they worth while, if so which ones?
- Dinan suspension lower in the back? Or did I do something wrong?
- Lowering on H&R Coilovers some questions!
- Mini Mania Positive Steering Amplifier (PSA)
- Dinan sway bar observations.
- Cupped Tires ?
- Better ride with anti-mushrooming plates?
- Who makes the best anti-mushrooming plates?
- Getting coilovers for the first time. What should I do now?
- Suspension upgrades and Alignment
- m7 STB and turninconcepts.com
- New Stuff (well new to me)
- H&R Street do I need lower control arms?
- Greasable Heim joint control arms
- Looking to help a buddy swap back to OEM springs. Any secrets
- Any Vendor Accepting Paypal?
- M7 coilover install issue, front hub carrier to shock fit
- TSW Springs W/ KONI Yellows?
- New springs
- Ireland Engineering Rear Sway Bar Question
- Which Suspension mods?
- Urgent: Differences in strut housings?
- What all is involved with lowering springs?
- Ksport noises
- Wanted: Negative Camber
- Bilstein Sport Shocks & ??????? Springs
- springs for 18x7 40offset?????
- Brake Rotor Question
- Help Need MINI Suspension 101
- Lower ball joint spacers
- replace ball joints in pairs?
- No rear bar...
- Anyone have Forge strut tower brace?
- M7 Strut Tower Brace fitment problems
- HELP - Stuck coilover locking rings
- Thanks M7!!!
- Excessive Camber
- Repair of shock tower sheet metal
- Progressive or linear springs?
- Webb Camber Plates
- Tire Size Question
- what is best setup for autocross?
- Justa Cooper Sway Bar Installation Question
- Need longer screws to mount Dinan Strut tower brace?
- Control Arms
- Koni FSD raised my ride height. What's stock?
- Your MCS coilover reference thread. Pictures and info
- what else do i have to do after lowering my MCS wih H sport springs??
- 06 suspension compatible on an 02?
- The Lowest Coil-Over Syetem
- Lowering...rear control arms, yes or no???
- Rear sway bar end link with 22mm bar on MCS 2004?
- Rear Sway Bar Question
- Is my lowered MINI ruining my wheel bearings?
- Decipher Alignment sheet
- Quick thoughts on the Hawk line of pads
- JCW Suspension upgrade making weird noise
- Is there a verdict on shock tower plates?
- Comments on Combination
- I need help with tire sizes!!!
- Ride Quality: FSD vs Soft Yellows
- Cross Coilovers on a daily driver
- Camber/toe settings
- Best Suspension setup for 04 Cooper S (R53)!
- New engine mounts, new trailing arm bushings...
- I'm gonna break the rules here but I have good reason...
- sway kit
- Koni FSDs and Lowering
- Lowering my MCS 06
- First post-coilover suspension upgrade?
- Klunk Klunk
- Spring Rate/Coilovers advice when used with roll bars.
- H&R Sway bar Bushing
- Just installed cf strut bar
- Alternative to IE street/track adjustable rear camber links
- Manual steering rack.
- Wheel Gap BAD!
- Lowering and tire clearance
- Highspeed stability issues, with brakes.
- A quick JCW suspension review
- Wheel alignment - help needed please.
- Springs Question.
- Get low!
- 19mm Hotchkis rear sway bar installed!
- CravenSpeed Strut Tower Defenders
- NEED PSRS ASAP
- Strut tower connectors to the frame
- lowering question
- RANDY WEBB - HELP!!!
- Taking slammed MINIs to the next level! Snapped springs, Ahoy!
- Help! Ireland Engineering fixed camber plates Install
- Do I need sport suspension??
- Quick Suspension Install Question
- Do I need new rear trailing arms?
- RSB comparison
- rear sway bar adjustment ?'s
- I know im greedy and all.....
- Lowering for looks...
- adj rear control arms, any benefit?
- Front Lower Control Arms
- Make OEM Rear Sway Bar adjustable?
- Speedometer calibration???
- How tight on M7 STB
- Dead power steering
- 15 inch rims
- A MCS CAN jump... DOH!!
- Koni coilovers or Megan coilovers?
- Spring info
- JCW Strutbrace fitting problems
- RECS needed: front control arms
- Discount code for TiC
- Rear (interior) braces - any value?
- Swaybar end links
- BC Coilovers VS. M7 Coilovers?
- TSW's New Camber Plates... get ready!
- Bilstein or Koni opinions
- just want an opinion from the more informed
- H-Sport 19mm rear swaybar Review
- H&R coilover owners read inside!!!
- JCW shocks with standard S springs
- Megan Coilover install how-to?
- Interest in Ireland Engineering fixed camber plates to factory spec?Please read!
- Lowering springs - uneven?
- rattles & Knocks -- Gone
- Koni Yellow Install Questions
- JCW rear sway bar (from R56)
- ? for those with M7 Springs on 18's
- could someone shed some light...
- Help me find a 16mm front sway bar..
- Do I need to replace my spring hats?
- M7 Springs w/OEM struts?
- Noob coil-over questions...
- Just Installed PSS9 now car shakes!!
- Megan or BC rear Damper Knob extensions
- 18 Inch Rims, Lowered...Crap!
- Worn Alta rear control arm spherical joints
- Coilovers
- Loose end at high speed Part II
- My R50 and the M7 STB
- How to adjust Rear Pss9's
- Looking for Part Number.
- Knock Knock knock ing from passenger rear.. weird.
- R53 question reguarding brake upgrade
- Koni Adj. Yellow Sports, TSW Springs, and H-Sport Camber Plates Installed
- Eibach 19mm Rear Sway Bar?
- Konis - bump stop question
- Anyone Have any Info On these Rotors
- Noise with new TSW engine damper..
- Koni Adj. Yellow Sports, TSW Springs, and H-Sport Camber Plates..ready to install
- Strut tower cutting for coilovers with camber plates
- Strut mounts
- Will I be ok if I put 215/50/15's on the front and 205/50/15's on the rear?
- Calling all brake experts/mechanics
- M7 coilover reliability?
- "Thrust" Links?
- PSS9 HELP PLEASE
- I want to LIFT my MINI...
- So I made myself some endlinks today...
- Any comments on BFGoodrich g-Force T/A KDW-2
- Lower Control Arms
- OMP or Madness Lower Brace?
- Loose rear end at high speed braking
- Adjustable control arm height question
- Adj. control arm installation
- Bad rear control arm?
- M7 Strut Brace Hight Problem
- know of a diy spring install?
- How can you tell when the rear trailing arm bushings are going bad?
- H-sport camber plates... two designs???
- Rear sway bar
- has anybody seen this brace
- Camber Plates - Higher?
- Trim shock tower metal for more camber?
- Coilovers with varying wheels
- Damping adjustment - what for?
- eBay brake kits
- Best Sway Bar... for me (used to be in an S2K)
- Stripped Sway Bar threads
- What is your average speed around exit ramps or twisty roads?
- Dinan springs & Konis - too stiff?
- Air Bag Suspension?????
- Properly set up MINI
- K Sport GT Pro coilovers
- Eibach Pro Stree Coilovers
- TSW Werks and Yellows v. JCW
- WHERE TO GET SPACERS FOR SPRINGS
- Control Arm install problem
- MINI Madness lower stress bar
- powerflerx installed, rattle continues!!!
- Looking for budget suspension advice.
- sway bar hardware
- New Eibachs and 18's
- Alta PSRS VS. Powerflex front control arm Bushing
- Looking for a good suspension install shop in the Seattle area
- Whats the easiest way to install tie rods and rear lower control arms.
- H&R Lowering Springs
- BC Coilovers
- racing swaybars on a daily driver
- Rear swaybar help in Phx area
- rear suspention rattle?
- Dinan Strut Tower Bar
- Megan Coilover Owner Update
- Las Vegas Mechanic Needed to Avoid Dealer Labor Charges!
- MINI Dealer Wants to Charge Huge Labor!
- Alta PSRS for street use - How are they holding up?
- What to do about ALOT of extra weight in the rear?
- New SSR Comp Wheels and Avon Tech R 225/45-17 Tires
- Suspension Install - Time and Cost
- Powerflex Bushings Help!!!!
- Stock springs and dampers
- From PSS9s to Cross Coilovers
- M7 Springs and Megan Racing Exhaust for sale
- Webb Motrosports Phone #?
- coil overs or Koni FSDs?
- H-Sport, ALTA or Mini-Madness Rear Sway Bar R53 ?
- Stainless Steel Brake lines Install How To?
- front/rear shock tower bars Install ?'s
- H&R, Megan Racing, or TEIN?
- performance tie rod assembly
- Help Identifying Springs
- 2.5 id spring length
- Alignment specs, tips!!!!
- Palo Uber Snafu...
- Spring install...speciel tool????
- Alta bushings
- Gotta problem
- What Lowering Springs Come in RED?
- H&R springs on JCW dampers?
- Differences Between Dinan and Ireland Engineering Fixed Camber Plates
- URGENT: M7 progressive springs, which side up?
- MC S H-sport rear control arms
- Is the front sway bar a good idea?
- Front Sway Bar Instructions
- in the market for a new suspension but i need assistance
- Custom Alignment in PHX AZ?
- Coilover suspension shopping
- Upper Control Arm / Vehicle level sensor
- Sway bar bushings from Energy Suspension?
- Koni FSD
- Average install time for
- Just mounted up a TSW undercarrage brace...
- Santa got me a new suspension! :)
- Aftermarket Coilovers without lowering the car?
- which powerflex bushings do i REALLY need?
- Going to try FSDs with Tein S Techs...anyone else?
- Strut Tower or Underside Brace? Another one..
- Question to people with Bilstein Sp dampers (Installation issue)
