- Fitting Rear Anti-Roll Bar
- Is an alignment necessary after replacing shocks?
- Uh Oh. What did I do wrong installing Koni FSDs?
- How does a strut brace prevent mushrooming/cracking?
- Intermittent steering wheel shake
- Getting control arm bushings what else.....
- H&R spring rates
- Question plz help :( Coilover, Spring, Lowering
- Where to get rear sway-bar bushings for an H-Sport Comp bar
- Recommendations for a front camber kit?...
- Aftermarket Motor Mounts
- Wheel Spacers for Improved Handling
- my wife's cabrio S rides too stiff
- Welding Alta PSRS?
- Stock Front Swaybar Size...
- front sway bar install
- Looking for 02-06 coilover install thread.
- Camber Bolts
- Installed IE fixed camber plates something is wrong
- R56 rear trail arms on R53
- Springs aren't settling, what's wrong?
- I <3 The UPS Man
- coilover question
- 04 MCS 72k miles.. Need a bushing kit, any suggestions ?
- HELP!!! -- swaybar malfunction -- missing C-clamp
- Love my current setup, but may be looking to go lower...
- Suspension advice needed. What would you upgrade?
- Powerflex Lube Frequency
- recommendations for strut mount/control arm bushing
- Bad control arm bushing?
- wheel spacers on lowered 18s
- time for a more aggressive set up
- MCS stance
- Could someone definitively answer if FSDs raise ride height?
- Has anyone ever used these?
- Stubborn Strut Tower Nut
- Spring DIY instalation needed
- To cut or not to cut the bump stops
- Identify Drivers/Passengers Side IE Camber Plates
- Looking for a D-I-Y Guide for Replacing Shocks
- New Suspension Upgrade - Install 12/28
- rear suspension bottoms out
- Rear Wheels Fore-and-Aft Location Question
- Smoother ride than H-sport springs...
- BC Coilover Noises
- New LCA bushing and other goodies.
- Would anyone be interested in trading a Powerflex trans bushing for an IE one?
- Steering stopped working for a moment
- || Cut Coils??? ||
- BC Coilovers RM Series - anyone used them?
- H & R Font Coilover Adjustments
- anyone using eibachs coilover's
- How do i tell when coilovers are bad
- IE Fixed Camber Plates Question
- What is the stock ride height?
- IE Fixed Camber Plates: Longevity?
- Wheel Spacer Question
- bilsteins
- For my suspension friends - Hydro Unit ASC
- M7 SRP's can take a beating
- speed bump rattle
- spacers with h&r coilovers?
- Trying to determine what mods my MINI has?
- TSW KW/Hypercoil + Onasled setup = trackday fun
- Coilover questions.
- 100,000 miles with the Webb rear Sawy bar
- Cross Users?
- Winter Swaybar settings!!
- COMPLETE NEW SUSPENSION
- Front end problems
- Rear Shock Bushings, Any after market?
- Need Local Suspension Expert Wylie, TX
- Can't Use Koni FSDs. What's Another Good Option?
- Dealer: May need new control arms with JCW suspension
- Replacing front sway bar bushings
- Need some coilover advice
- Lower H Brace
- rear suspension creaking/need serious help
- vibration
- Need to cushion my ride some
- Mini Madness Rear Upper Strut bushings (HELP!!)
- front end thunk
- Japanese Parts Awesomness!
- Camber plate rattle? Normal?
- TSW Springs on Stock Suspension
- JCW big brake kit and my 16" X-Lites
- brake fitment issues
- Alignment off on my 05 MCS...would the traction light and tire pressure light go off?
- strut bar? yes or no
- alta's psrs/ castor
- Budget-friendly low-noise camber plates
- Alignment specs, correlating neg and pos toe
- Tire and component wear with upgraded suspension
- Corner balancing in Wisconsin
- I'm in trouble :-) (not really)
- front sway bar help
- progressive springs + stock height
- Rattle from front suspension
- Suspension & Brake Needs
- Where to buy: Wedsport TC005's
- A non-suspension thread for my suspension friends
- Replacing inner toe rods with sub-frame attached
- In dire need of assistance
- Suspension mods that work
- Anyone or any manufacturer that sells coilovers for under 600??
- Engine and trans bushings- PowerFlex or Ireland?
- Best place to buy Koni yellows...
- How long should tires last?
- How to tell when shocks need replacement?
- Weitec Hicon GT Coilovers
- Help with Pinch Bolt
- Is an alignment needed after new bushings?
- Rear Sway Bar settings
- probles in need of solutions
- Sway bar raves
- Strut Mount Pin is stripped
- Rear end "Clunk" after installing 22mm Rear Sway Bar
- Tein Super Street Coilovers, any new users?
- h-sport rear control arms weight
- Any rules of thumb to follow when adjusting height & dampers?
- Dunlop Sport Maxx on tirerack
- camber correction question
- Suspension Overhaul
- Lower Engine Motor Mount
- Opinions on what I should do.
- Latest adjustable control arms, comparison?
- Squeeky 22mm Rspeed rear sway bar drives me insane! Maybe Energy Suspension bushings?
- Evening out front camber, without camber plates?
- Megan racing, full suspension/coilover setup?
- m7 strut bar and webb air intake, does it work?
- What size spacers?
- Strut Bar from Amazon.com?
- To Grease or Not to Grease...
- Need advice on camber kit?
- anyone with H&R Touring Kit on R53?
- spc control arms
- SPC Camber Plate Issue????
- lowered my R52 and now i have ABS and tire presure light on
- coilovers on 8 inch wide wheels?
- Noob Coilover Question
- Springs?
- H&R Coilover Instructions anywhere?
- 2004 MINI ONE want a coilovers, do I need additional parts?
- additional parts for wheel alignment?
- Help with Swaybar!
- Coilover noise
- PS pump how-to?
- R53 brake upgrade
- What camber plates to choose?
- Suspension Bushings
- TSW + 215/45/17 rub?
- Thinking BC
- My older Megan coilovers are killing me...
- Vmaxx coilovers and R56 bbk
- Stock 05 sports springs vs JCW springs
- Alta Positive Steering Response System
- Comments about Mini Madness strut plates
- Can I stiffen the suspension without lowering?
- Vorshlag/AST coilover install (with Pics)
- Cross unavailability
- Wilwood Brakes
- Been driving an 08 S automatic for a few days...
- Looking for ride in MINI w/ Cross Coilovers - So. Cal.
- coilover install cost
- Comparing rear strut braces... The best????
- Choices to make on suspension.
- M7 Strut Bar Install Trick!
- PowerFlex Gearbox Mount Clarification Needed
- What is the length on the OEM wheel bolts?
- alignment settings recommendations for autox
- Koni FSD replacement question
- H&R Sport Springs + 18in rims?
- JCW R53 Struts anywhere?
- Online parts drawings and numbers
- Help--Lube Swaybar Bushings now...
- Toe In and Toe Out numbers
- Ripped front strut mount!!!! HELP!!!
- Control arm bushings w/o BMW tool?
- Steering Drift after Adjustable Camber Plate Install...HELP!
- A Power Flex bushing note...
- M7 spring info
- Tie rods replacement options?
- Madness lower stress bar
- Sport Suspension R50 vs Sport Suspension Plus from a 2003 R53
- JCW Suspension = H&R Suspension
- Best, in ride, handling?
- Silly RSB question...
- Top nut... (Resolved)
- Bedding JCWs?
- Hard braking and steering judder
- Rear end loose under hard braking
- Cooper Sport Suspension rear sway vs. Cooper S rear sway
- Adjustable camber plate with pillow ball for stock type shocks
- H&R springs fit on OEM struts?
- Strut bar fit vs mushrooming
- Sway bar recommendation needed
- Need some advice before purchasing lowering springs
- Squeeky sway bar
- Help PLease>>after spring intall...help
- Centering wheel spacers?
- DOHHH!
- LCA bushings without tool
- JCW springs - where to get them from?
- 215/35-18 vs. 205/40-18
- Alignment questions
- What adjustable shocks are available?
- BRracing ast coilovers
- Dinan strut top relocation plates
- Proflex bushings, who has them in stock?
- GT Tech lower mid chassis brace
- Difference in Coilovers by model?
- How much damage have I done, Warranty Coverage
- VMaxx question
- Megan Racing Coilovers
- V-Maxx + S-Lites = No Low???
- Peanut butter in the shocks!?
- JCW steering angle stop install help
- PSS9 rear rattle (just installed)
- Why is my caster so far off?
- H&R TRAK + Wheel Spacers?
- H & R coilover Comfort?
- What suspension components are avaliable?
- Post up your track setups
- Show me your Tein S Techs with 17" wheels?
- Bavarian Autosport camber plates
- Upper and lower rear control arms same?
- H&R vs. Tein handling and comfort
- Aftermarket FT swaybar endlink broke
- H&R vs. H-Sport (Hotchkis) quality?
- Will my wheels fit with BBK from Wilwood
- After setting camber with coilovers, I bust my ball joints
- JCW springs and Koni FSD's?
- Help please - alignment specs after springs/RSB, need advice
- Wanted - pics of R53s w/TSW (V1 or V2) springs
- Koni Yellows
- Toe inch to degree conversion
- Bavarian Autosport Poly Bushings
- Lowering springs with stock-ish ride
- Bought some coilovers, have some questions
- SPC/Eibach camber plates and KW V1's?
- Source for 19mm swaybar bushings?
- Need new lug bolts?
- Soft springs, big sway bars
- Trying to Find Rear Quick Disassemble Strut
- 18" wheels, lowering, no spacers
- KONI suspension kit... Anyone have this ?
- Lowering springs...
- Looking For Pics of H&R
- New Megan Coilovers
- Suspension and tire advice
