- Brake master cylinder
- E-Brake Issue?
- is anyone interested in FUNCTIONAL lowering springs? as in MILD drop?
- Checking for mushrooming?
- Adjusting rear camber myself.
- Is there a good HowTo on adjust Spax RSC coilovers
- Insalling Koni FSD - what else to replace while on lift? 57K miles
- Looking for new coilovers
- Is R50, R53, and R56 OEM suspension interchangeable?
- M7 Coilover: Spring binding HELP
- Life expectancy of LCA bushing replacements?
- SOS: Stripped Lower Control Arm Bushing Mount Repair
- Camber Plate Comparison
- Suggestions on future suspension mods?
- Suspension questions before install
- Lowering & Daily Driver Advice
- sway bars
- Lowering Springs Pictures
- StopTech kit installed
- Shock choices for stock ride height
- R53 - Knocking Front Suspension
- Sitting in a mini does it add take away camber?
- How do i install front sway on 03 MCS ?
- IE Camber Plates shot?
- The search for 5 seconds...
- ok to mix aftermarket brake pads?
- Camber plates or under tower indurators?
- strange noise after install of Megan coilovers
- 03 MCS w/ 73k miles
- M7 USS nutsert failure
- Rear anti-roll bar
- Max tire size
- need to replace ball joints, what else?
- ohh the rubbing.
- Ireland Engineering Camber plates Left & Right??
- coilover setup problems.. grinding/rubbing.. help??!!!
- ??? SWIFT replacement springs for Koni 1150-5079 Coilovers
- "New" Alta Rod End Feedback Sought
- help! vmaxx coilovers!
- Needed Coil over decision advice.
- Ireland (and Mason Engineering) Underbody brace review
- H&R Street coilovers & ride height issue
- Installing a frame brace made by Mason engineering-need help w proper bolts+feedback
- Rear Adjustable Control Arms
- just a simple alignment?
- Alignment
- Rears rubbing badly over bumps/humps or around bends
- Rear suspension rattle after KONI FSD install
- Front Camber
- 5-hole wheel adapters
- Aftermarket lowering springs
- Cross Coilover endlink question
- Rear Trailing Arm Bushing
- New Springs installed, now shake/vibration
- Front End Noise under braking forward OR reverse
- Has anyone ever cut their springs
- Front Camber, What could be the Problem?
- One side rear tire sticks out farther
- Bump Stops
- Driver side is sunk. HELP!
- How can I lower the front?
- Suspension Trade/Advice.....
- Changing My Springs! NEED HELP!!!
- suspension problem NEED HELP FAST!!
- TSW KW's where are they?
- i need some advice and help on my suspension.
- Tein pillowball camber tops - part number?
- Will 04' coil springs fit on my 03'?
- GTT Mid Brace: US suppliers?
- Lowering question
- Need experienced users advice
- heim joints in control arms
- Getting my IE camber plates installed tomorrow!!
- BBK-Wheel clearance question
- Can someone please help me put my suspension together?
- lowering advice??
- Feedback on the Mason upper strut bar
- What camber gauge are you using?
- Suspension Trade
- Need some pro advice. Are these bars worth it?
- Good balance
- Need input on everything suspension related
- What is your suspension setup?
- coilovers
- Rear coilover fitment question
- VMAXX question!
- Those with Dinan suspenson did you get bump stops?
- urgently needing pictures of Koni springs
- tie rod replacement
- Powerflex front sway bar bushing maintenance
- H&R Convertible Springs on Hatch
- Ireland Engineering Rear control arms, redesigned?
- ohlin now makes coilovers for the mini
- installed New camber plates resulted in a new problem!!!
- HELP, I need ball joint tool that fits
- Cross coilover help - frustration abounds
- TSW springs and IE fixed plates
- What is the best brake fluid?
- Anyone running KW Springs?
- lower 08 MCS, help please!
- Question About Tires
- Koni FSD below $600
- Koni Lowering Kit
- Vorshlag plate fitment
- Koni FSD Shocks
- Apex Springs
- how low can you go without spacers?
- My MINI Suspension Adventure
- Brembo brake problem
- H&R Springs
- Slight problem
- Rear sway bar for 05 s
- First Impressions: JCW Springs/Bilstein Sport Dampers
- Tire Pressure Monitors
- Rear Strut Bar
- Well I used to think I owned just a stock r53 until..
- Wait for springs to settle before alignment?
- Changing my current set-up
- Installing Cabrio Front Strut Tower Support Issue
- Looking for the Right coilovers, Track-use & Street
- Which camber plates for Bilstein PSS9 coilovers on 2003 R53?
- Whenever I hit a bump, I get a squeaking sound from the front suspension
- Steering Rack Issue?
- Strut top mount replacement.
- Are there any 18 or 17 inch wheels that will clear lowered coilovers and BBK's?
- MINI Madness Strut Tower Plates - Install Notes and Report
- Strut Tower Supports
- Which coilovers that are sporty, yet quite comfortable over really bumpy roads?
- Is there any advantage to having new steering rack poly bushings put in?
- Struts
- 06 JCW Suspension
- Great lowering solution for front end!!!
- R53 MCS Mushroomed and Tire Issue
- Camber plate swap?
- Installing IE race camber plates
- K-sport or Cross?
- 10 sec Drag Mini's do go round bends as well
- Help - Alignment settings (DD with highway usage)
- VMAXX with KW springs..?
- Are Cooper/Cooper S shocks identical?
- Wheel stuck on hub
- Control arms and tire tread.
- Photoshop : is this set-up achievable ?
- Ebay = Crap??
- Powerflex c/a bushings went in today
- Dust Shields?
- Best full suspension setup for daily driver Mini S
- H&R Springs
- Adding Cabin Weights When Performing Aignment?
- H&R Spring Question
- Stuck adjustable rear control arm?
- creaking sound when turning
- Pss9 expert...HELP
- Coilovers front end clunking noise
- Need to make a suspension decision but I need some opinions
- NM rearsway bar?
- Where to go in SF South Bay for Alignment?
- suspension upgrades
- TSW Springs and Ireland Engineering Fixed Camber Plate Install
- Koni Vs Eibach Springs
- broke my passenger strut nut off need help!
- Adjusting ride height
- New springs for vmaxx coils?
- Drop blocks.
- Mason Engineering Front Lower Strut Bar
- Are 02 (04/02 build) and 05 strut/spring/tophats interchangable?
- Does R50 JCW Suspension need front sway bar?
- 2010 Ksport Kontrol Pro, how low can you go?
- Couple questions about alignment and lowering
- Pictures of H-Sport (Hotchkis) Springs
- Choosing adjustable camber plates for JCW suspension
- What is the average life expectancy of stock shocks?
- Coilovers: Did you needed spacers?
- Koni FSDs on MCSC
- H&R springs
- pss9 and h sport front camber plate question
- lifting tire on hard cornering?
- Did these rotors need to be changed?
- What kind of longevity can one expect out of cheaper coilovers?
- Stock tire size rub on M7 coilovers
- New daily driver suspension (with front sway bar?!)
- Need recommendations asap!! (Wide fitment people gtfih)
- 2003 Mini S with Dinan rear broken spring.
- Any interest in SS+ springs from a 2003 Cooper S?
- Thoughts on Springs
- Slight or maybe Huge problem installing coilovers
- Suspension upgrades?!
- M7 Coilover: Disassembly and repair
- Koni Yellows - HSport Springs Install Question
- D!cks Garage, Suspension plans and Questions
- H-Sport adjustable rear control arms install
- Rear Control Arms Recommendation
- Ultra Racing 4-Point Front Lower Bar
- Lower control arm bushing bracket bolts!
- Issues with TSW springs and IE fixed camber plates
- universal swaybar bracket to fit 22mm sway bar?
- Advice Needed: Bushing replacements oem vs aftermarket.
- FIGS Engineering
- 04 MCS alignment
- Recommendation of a shop to install coilovers, alignment and corner weight balance
- 04 MCS H&R springs 1/2 in difference
- 04 MCS installing H&R springs. Special socket?
- Does Mini-Madness parts ever go on sale?
- Anyone running this combination on an R52?
- Impact wrench monkeys **&%#$$$
- Sway Bar Problem???
- Rear control arm bushings?
- Tire wear - TSW springs without rear control arms
- Confirm my alignment specs please
- Koni Coilovers
- L is driver/R is passenger?
- WT buy or rent your Hazet 21mm strut socket.
- if you could only do ONE Which ONE?
- Criticize my suspension plans, PLEASE!
- Criticise my suspension plans, PLEASE!
- Lowering Your Mini
- camber plates help??
- 06 - 09 Shocks/Springs interchangable?
- How to tell which springs are on my MINI
- Eibach (SPC) camber plates
- Miscellaneous poly bushings?
- H&R Rear Swaybar
- Can LCA bushings be done without a lift?
- Coilovers: Do i need rear lower control arms
- H-Sport "Race" 24.5mm Rear Sway Bar
- h&r rss club sport question
- h sport springs..do i need control arms if lowering only 1 inch?
- "bumpy" acceleration after spring install..
- Rear endlinks contacting trailing arm?
- bilstein pss9 installation
- Coilover/lower control arm bushing install
- Cold weather and polyurethane front control arm bushings?
- MCS Springs help
- Rear Strut Lower Bolt? Help!
- Vmaxx, need spacers?
- A question about bump stops and shocks
- Koni FSD mystery pic
- hello from canada and one question
- Why Am I Having Trouble With the Best Coilovers out there?!?
- Bilstein PSS9
- Rear sway bar link failure?
- No more wheelgap!!
- sway bar settings?
- Steering Rack Mount bushing
- Want to go back 2 stock.Will pre 02/03 shocks/struts work w/ H&R Lowering Springs?
- Replace ball joints with control arm bushings?
- Adjusting Rear-Toe without control arms?
- PSS9 "locknuts" stuck help
- Very Happy with Suspension Upgrade
- TEIN Adjustable Coilover Suspension with EDFC - any info?
