- JCW Suspension needs Camber plates?
- stock sway
- Bilstein Struts
- Help! Rear Sway Bar Install!!!
- Camber links or camber plates?
- M7 Springs?
- Deal on Rear Strut Tower Bar
- Just installed H-Sport Comp rear swaybar
- New Animal
- Newbie: What do I do for a softer ride?
- Camber plate recommendations.
- Help: Minor Mod Gone Mad
- Adjusting toe
- Benfer STB cause clearance problem with Alta CAI?
- Titanium strut braces
- Camber plates...
- Computer and average speed
- $1500 to make a stock mini as track-able as possible.
- stock end links
- will these fit?
- Just installed H-Sport Stuff
- Suspension setup recommended for track use
- About install new springs anybody have torque specs?
- Tire Pressure
- End links
- Deleting pad wear sensor...
- M7 Front Strut Brace
- When do you need rear lower control arms?
- Buying used springs ... a good idea?
- Squeaky rear sway bar
- Mini Newbies wants a lower car ... help
- Ground Control coilover sleeves for MCS???
- Warranty issues?
- M7 Springs, Koni struts suggestions/observations?
- Considering JCW-install as bargaining tool on 05 MCS
- 2005 Rear Suspension Adjustment
- Cheapest coilover
- Frame brace. Thoughts
- Ireland Engineering "Fixed" Camber plates?
- JCW susp. owners comments on rough roads?
- RDR Adjustable Rear Control Arms Questions
- eibach bouncy?
- Handling Question.
- Bump stops and H+R springs
- Question on this ebay STRUT TOWER BAR
- Any coilovers with stainless steel shock bodies?
- Koni Sports "yellows" vs. Koni Coilovers
- H-Sport 27mm front, 25mm rear and springs
- Camber Plates...
- Just installed front sway bar
- Normal for H-Sports of Not?
- My new Eibach and Konis!
- Are the bump stops really necessary?
- Lowering springs and 2005 struts/shocks?
- Installed! Pics of new setup.
- Lowering the Ride
- Problem with Xenon's After Eibach
- 19 or 22mm Alta Rear Sway Bar
- another sound from rear: bell like
- Roll Couple
- Carbon Fiber Strut Brace Question
- Suspension swap
- Red ALTA 22mm Sway Bar??!?
- 9hr install for springs/rear sway???
- Good performing springs with a good drop?
- Corner balanced the Mini ...
- Something rattling after lowering
- upgrades for rough road handling
- rear brace...which one?
- PSS9 help please....
- How many miles before struts etc need replacing
- Alta CAI and Front Strut bar- will it work???
- Swaybar Install Questions
- Ideas about Suspension upgrades
- Linear Springs
- Camber plate query...
- Tire rubbing
- Front Struts Dented
- Bilstein PSS9's installed, adjusted running great! Pics from New Dimensions show.
- front strut mount part number
- tighten up steering question
- control arms; h-sport or helix?
- Drop/lowering comparisons sought
- Who had problem with Rubbing on H-Sport springs?
- Eibach Pro Street
- Ditched the H&R Coilovers, installed the Bilstein PSS9's, what a difference!
- Coilover advantage?
- Aggressive Street Driver
- Busted Top Mounts, What's a Good Replacement?
- Alta springs...anyone??
- Pic request: M7 or H-Sports and 16" wheels
- A few sway bar questions, track related
- Question about bent sway bar link
- H-Sport or Eibach springs?
- Installing M7 Springs - Need Help
- Emulating Cooper S sports suspension on Cooper - help
- Q on SS+ on Cooper
- How long will H-sport springs last?
- H&R Coilovers installed, and Alta Adjustable Lower control arms. How LOW? LOW!
- Camber Adjustment...
- 19mm Mini Mania or 22mm H-Sport
- Q for those with big rear sway bar
- Sway Bar install Question?????
- KW Coilover Sale at ESE
- Mini Mania Springs = Eibach?
- Lowering springs - - alignment needed?
- Progressive Springs - Handling Characteristics?
- Question about JCW Suspension
- Upper Stress Bar for JCW Mini?
- M7 springs or H-sports?
- Frame Reinforcement Parts
- Track Day - Back end loose under braking
- Believe I blew my struts ...
- Max front camber without aftermarket camber plates
- H-Sport spings + Comp. rear sway?
- Another sway bar question
- Lowering difference MC vs. MCS,
- Does this look about right?
- 2004 Mini S M7 Installed Today Pics
- H&R inverted coilover - anyone with experience?
- Trailing arm stress point?
- H-Sport comp + endlinks?
- Bilstein PSS9 - FYI
- H-Sport camber kit. Comments???
- Who has the best deals on H Sport Rear Sway Bars?
- Who has Pilo Rear Strut Bar in stock?
- Stock Cooper S Alignment specs
- 05 MCS Rear Camber adjustment
- SPAX Coil Over owners need your input
- Rear Camber Adjustment
- Setup for the track...?
- Koni Strut question
- Anyone with Leda, PSS9 cross experience...
- Money burning hole - need advice on JCW suspension
- "clunk" when turning slowly
- Can't get my MCS Alignment done :(
- does any one install eibach pro kit in 2005 mini cooper s
- GAZ coilovers ... any good? Stiff?
- TEIN Springs
- Recommended alignment specs?
- Handling questions
- Swaybar on an '05 S?
- Suspension Kits
- Bolt Snapped NEED HELP NOW
- Coilovers, adjustable rear arms and Toe
- Maximum Camber
- Sporty Street coilovers? Eibach? H&R? Koni?
- adjustable swaybar drop links + alingment
- what lube for aftermarker swaybar bushings
- Baseline settings for Ledas?
- Street & Autocross alignment spec's needed
- Strange Popping sound with PSS9
- $500 Swarbar Install?!?!?!?!?
- 4 Alta Rear Control Arms Installed
- Looking to get a Strut Brace
- M7 Springs with which struts?
- tire rotation? HOW TO?
- New bumpstops with spring change?
- JCW Suspension Alignment Specs
- H-Sport Spring w/bumps Stops
- Mini Mania Rear Strut Spacers
- Ride Quality on Webb Camber Plates
- Newbie SS+ MC upgrade
- MCS suspension, brakes, exhaust on my MC
- Eibach Pro-kit springs, any good?
- Are the H&R coilovers monotube or twintubes?
- Alta sway bar setting???
- Strut Dented? How in the ........
- Whats the coolest Strut bar for the best price?
- Camber way off.
- M7 springs... any good?
- Which camber plate should I get?
- JCW suspension kit v. Koni Coil-overs
- Camber Plates a Must for Track Use?
- PSS9, H-Sport Comp, Alignment setup for track
- What to do if my coilover ceased?
- H-Sport Sway Bar Q's
- Correct torque specs on strut tower bolts on 05' MCS??
- Jacking up rear end of MCS
- Rubbing Question...
- TonyB
- PSS9s vs. Ledas
- Koni Sport adjustment range
- S springs in a Cooper
- Pilo Racing to the rescue!
- H-sport or M7 springs for an 05 Mini S
- Wanted: Aftermarket spring info
- Suspension +
- Thinking Seriously about JCW Suspension
- Stage 1 Suspension Upgrade Kit - Street Stage 1 Suspension Upgrade Kit - Street ??
- How to install strut/ stress bar on 05 MCS
- Steering wheel alignment?
- rear sway bar recommendations pls
- Rear Sway Bar, what will it do?
- racing dynamics coil over
- adjustable end link ?
- Convertable strengthening pieces retrofit
- Alta Springs
- Sachs performance suspension kit
- Tenzo-R Lowering Springs or TEIN S Tech Springs ?
- control arms
- Anyone with Tein H-tech springs?
- Any news about '02-'04 JCW Suspension availability?
- Ok! I need help finding the perfect coilover!
- mini madness sway bar
- Twitchy handling what am I doing wrong
- Boots for heim joints?
- o5 sport suspension
- Good deal on H-Sport control arms?
- What Camber Plates are you using?
- Floor jack for lowered MINIs
- Lowering Springs Max Load?
- New suspension company?
- HELP - added sway bar now it's unstable at speed
- Need suspension bits? Check Classifieds.
- Tein Super Street Coilover
- Front Camber Question!
- What clutch to get?
- H-Sport rear bar, I'm a believer!
- Clunk in the rear after installing rear sway bar
- Camber plate noise and higher ride height
- TEIN S-Tech springs
- Who's running Koni Sport Yellows with Hsport springs
- I want my old sport suspension back
- Anyone corner-weighted their MINI, at home?
- Lowering Springs
- To Lower or Not?
- Bilstein SP's installed...
- H&R RSS Club Sport Coil-Over Kit
- Will Lowering Reduce Strut Life?
- Who makes the shocks for Leda?
- Problems "losing" alignment
- Camber Necessary in Lowered Car?
- H Sport Spring Rear Coils
- Ground-control kits
- 2005's rear camber adjustable???
- Another thought on Adjustable Swaybar 3 positions
- Houston, we have a problem.....
- Need recommendations for AutoX/street suspension geometry.
- H-Sports and camber
- H Sport Camber Control Arms
- Mild vibration with recent spring change
- So I just installed a new rear sway bar
- Why wont the new JCW springs work on a 2004 MC?
- Bilstein PSS9s
- Joseph Alfonso at RSPEED ROCK'S!!!
- Good Suspension Article
- grease gun help
- buying new springs? here is the info you need!
- Randy Webb, what a guy!
