- Ground Control Camber plates!
- Central Coast Coopers...
- M7-srp
- Need alittle help: Replacement Front Shocks/Struts
- Camber plate without Caster?
- Webb Motorsports Extreme Swaybar
- Post upgrade questions...
- MINI Challenge KW Suspension
- On the fence HELP :/...
- Do MCS and MC lower differently?
- What front strut brace with Madness CAI?
- Installation price
- JCW suspension installation cost?
- rear suspension arm failure!
- '06 MCS Stock Suspension + Big Rear Sway?
- Rear sway bar effective rates
- Rear toe help
- My suspension plans
- Which camber plates (not HSport)
- Quick pics of Tein S-Techs on 05 MCS
- Full Package Suspension (One Manufacturer) or Different Manufacturers?
- H Sport Springs Installed!!
- Strut bar install question.
- MINI Club Sport Suspension?
- M7 Spring Setup Questions
- MC -> upgrade from SS to SS+ ?
- TEIN S.TECH & H.TECH Questions
- Desired Sway Bar Orientation
- Santa brought Tein S Techs, but.....
- HELP with lowering
- Question about susp comparing MC to MCS
- Mounting Koni FSDs
- Remove nuts JCW stray brace
- Rear Control arms - Helix vs H-Sport
- low budget / temp camber measurement
- 06 MCS springs and struts
- Ireland Engineering Suspension Products...
- suspension rattles
- EZ out Not
- susp. advice please
- Popping noises from H&R dustcover (?)
- End links and control arms
- Another swaybar question
- Anyone with H&R Sway Bar? [No lubrication needed]
- Should I Get A Front Strut Brace?
- Rear suspension noise on my '05 MCS
- Change springs and shocks on MINI Cooper. Whats next?
- Infinitely adjustable anti-sway bars?
- coilover install
- Input needed in suspension choice
- Calculating a MINIs curb weight
- Anyone with Yellow shocks? Paint it or not?
- Help with SPAX
- Will 18's rub with 1.5 inch lowering springs?
- Has anyone tried the Megan Racing Coilovers?
- Has anyone tried the Tein lowering springs?
- H&R's or H-Sport's, which is better performing?
- H-Sport Competition Package
- Anyone know the spring rate of Eibach lowering springs?
- Who sells KW lowering springs???
- Alignment setting
- TEIN where to buy?
- Bilstein SP Shocks
- blown shocks + Aftermarket springs = u ?
- Rear sway bar settings, Reminder
- Is there a performance advantage to 18" wheels
- M7 Spring installed.. now what?
- Coilovers - Which to buy????
- D2 Coilovers? What's that?
- Show pics of your lowered MINI S!!!
- Replace standard rear shock absorber with sport shock absorber
- 18in Wheel/Suspension/Tire Dilemma - Please help!
- M7 Under Strut System
- 2005 MCS suspension vs. MC suspension
- Noise after front swaybar install?
- Experiences with DMS Suspensions?
- help with 18" rims and M7 Springs?
- '05/06 Rear Camber Adjustment
- 19mm vs. 22mm for mcsa
- Rear Sway Bar
- Front Swabar Install Torque?
- who makes the lowest springs for mcs
- H Sport Camber Plate "Thunk"??
- adding springs but retaining stock shocks ?
- JDM lower strut tower bar installed
- Lowering Springs and Deep Snow
- Coilovers and Alignment..
- BMW CCA Article on Koni FSDs in latest Roundel
- DSC working great after cooler weather came...
- M7 spring / (??) Struts
- Newbie w/ suspension ?'s
- MC sway bar question
- MCS suspension on one/cooper??
- Torque spec needed HELP!
- To lower w/ stock ride?
- what to replace after hard hit
- Installed H-sport springs and sways
- Winter Pkg Mounted
- Eibach Problem
- Does Bilstein SP settle over time?
- My coilover saga comes to a happy ending- with pics…
- Coil Overs, interesting...
- Webb Motorsports Rear Swaybar
- KW Lowering Springs
- How to disable DSC ?
- Alignment: Toe Settings.
- front suspension component torque specs needed
- Exhaust cut-out
- Strut Bars...yay or nay?
- adjustable rebound setting and what do they mean?
- Strut Tower Bar...
- torque specs, front strut tower bolts
- How long do the stock stuts tend to last?..
- Cold Sway Bar Creaking?
- Koni yellows...
- H&R sports/Bilstein
- wanted: MCS stock rear sway bar
- Jack adn Jackstand recommendations??
- Swaybar - Any last words of advice?
- Bilstein's..
- I hate speed bumps/humps :-(
- Unanticipated effect of LSD
- LSD + sway bar ??
- Racing Dynamics springs anyone?
- M7 vs. H-sport:handling
- Need help with suspension mod
- Raising a lowered MCS.
- Alta Rear Sway maintenance
- Ground Control? Anyone?
- Springs for Leda coilovers
- koni sport kit
- Camber plates or adjustable arms necessary?
- Qs reguarding Rear Swaybar?
- megan racing coilovers
- PSS9 Before and after pictures
- rear sway bar installion cost
- anyone have Minimania springs on their cooper?
- Understeer: Springs vs Swaybar
- lets see roll bar/cage
- Pictures of wheel gaps please.
- Switch from M7 springs to H&R coilovers...looking for answers
- Want to lower my front end more, without coilovers...possibly?
- Help w/level sensor on control arm
- PSS9 settings
- Stupid questions on Camber plates, and handling.
- How do you grease this darn thing?!
- TEN springs for mcs.
- H-Sport Springs & Rear Sway Combo
- Which brand of rear sway bar?
- Bilsteins SP's with stock springs
- show me the coolest looking Strut tower brace
- JCW strut brace = poor quality
- Spring and Suspension??
- Anyone have the Dinan Camber plates?
- Suspension swaping ???
- Hard to oversteer?
- Instructions for RDR Camber plates with PSS9
- Slites really 55lb each?
- Rubbing Issue
- Will JCW Strut Brace fit Cooper?
- rspeed sway bar which one?
- Cobalt adjustable control arms from Moss Mini
- advice on stock height, tighter ride...
- Should I go lower?
- Anyone know Suspension Tuners in South NJ?
- without going w/ coilovers, which springs offer the lowest drop?
- Koni golds
- Suspension mods for a combo track/street car
- How much negative camber without camber plates?
- Sway bar suggestion with H sport springs
- Quality Performance Shop
- M7 Springs and Hamann wheels...
- M7 Strut Brace
- Increased negative camber in the snow?
- Will I be able to adjust rear toe with only a pair of adj. control arms
- Delrin Bush for H-S Control Arms
- Top three suspension mods for the street?
- Rear Suspension Problem
- How 2's on Webb Motorsports Camber Plate install?
- Which adj. end links to get after fitting PSS9s...
- New great stuff from Japan. (no, REALLY)
- Installed: Ireland Eng. Fixed Front Camber
- '05 mcs FRONT camber adjustable?
- Can increasing wheel/tire size increase body roll?
- New shocks w/H&R springs?
- Upgrading suspension
- Installing the Bilstein PSS9 soon,need some advise on alignment...
- H sports w/ stock dampers?
- Quick Q on Hsport comp rear bar (urgent)
- Air ride
- Scrub Radius
- "How to" - adjust rear Coilovers w/top adj?
- Front Strut Brace
- Help with spring rates, please.
- Part # need!
- Installed Dinan front and Pilo rear bars! Great Results!
- spring vs coil over dilemma
- eibach sportline??
- help with springs pls?
- Best Price for HSport Rear Comp Bar?
- M7 spring install quote...look fair?
- Pilo Racing Custom Coilovers Coming Soon
- Here's what rubbing looks like...
- Creak/Groan with WMS Camber Plates?
- Koni DA's
- Adjusting Coilovers
- H-S Control arm bush replacement
- Will 05 springs and shocks work in a 04???
- What's the best way to adjust the rear swaybar when it's on the car?
- D2 RS Coilovers
- turn in help?
- Pics of M7 Springs
- new bilstein coilover?
- differences in suspension & chassis dimensions between models?
- swaybars/strut braces/ ect ? help!!
- Basic question about stock rear (anti)sway bar
- Which Rear Anti Sway Bar?
- JCW strut brace - Googled & got one!
- Koni Yellows - rear assembly
- 1/4 vs 1/2 vs 3/4 vs 3/8" Rachet Drives
- Koni Gold FSD
- Ireland Engineering Street/Race plates?
- K-Mac Rear Adjusters
- Adjustable Rear Camber in Stock MCS
- Rear Sway Install Pictorial?
- Front End Takes Off!!!
- Will an aftermarket swaybar make that much of a difference??
- Will the DINAN strut brace fit the sock airbox?
- JCW susp. & H-Sport Comp. Rear Bar - need to eliminate understeer
- What shocks besides Koni, Bilstein, H&R
- My Suspension Dilemma! Please Help!
- How Strong are H-Sports
- Darn sway bar is squeeking again!!
- Lowering Springs....which ones to choose?
- Tein Super Street Opinions
- Understanding Skidding and anti-roll bars
- Torque Specifications / Specs
- MCS rear sway bar on an MC - any noticeable improvement?
- Will I regret getting M7 Springs?
- NY M7 spring installer ?
- Camber Plate Install?
- Rspeed sway bar install question
- Loose suspension
- H-Sport Springs vs Alta
- 20mm v 22 mm rear sway?
- Konis vs stock shocks
- How does a sway bar work?
- upper arms/xenon lights.
- do you have this problem?
- Trading shocks?
