- Big Brembo Kit replacement rotors
- Anyone use Girodisc brakes?
- Switching Run Flat Tire
- Pic Request Black Star Bullet Wheels on PW
- 02 Mini Cooper Non S Wheels
- MCS R56 17" Stock Wheels
- KW Varient 1 - are spacers needed even for a mild drop?
- Here is a great tire and wheel tool
- 235 on R57 or R56
- Stoptech Street Performance Brake Pads - review
- Low-dust brake pads?
- question on replacing only one run flat tire
- R53 oversize tire tolerance
- In a dilemma... (Help choose my wheels!)
- Team Dynamics Pro Race 3
- which wheels you like better ?
- suspension and wheel size question
- R100 Spoolers on 2007 MCS?
- Wheel Fell Off!
- Anyone running rotas?
- Spare wheels/tires and TPMS
- 2010 Camden wheels - which ones?
- Where would I find wide wheels?
- Brakes vibrate only when warm?
- rim size?
- Running 215/35/18 or 225/35/18?
- R50 / R53 Rotors different?
- Brake Sensor Question....
- JCW Rotor Question:
- Brake bleed with engine running?
- show me your WHEELS w/ 5-LUG ADAPTERS
- First upgrade, Wheels and Tires
- Upgrade from bald runflat to new non-runflat = WOW
- pic request: 16 inch OZ ultraleggera
- rub?
- voxx
- will this BBS RC fit on my 2006 Mini?
- Front Brakes + Rotor for 06S
- R53 cut into fender for brake ventalation?
- HANKOOK performance summer tyres
- 15" "holies" fit a Gen1 MCS?
- Need snow tires...advice?
- Wanted Wheel **refer to 1st gear parts needed**
- Spare Tire (yes again)
- Are these decent rims and tires?
- 205 or 215 tires?
- TPMS light goes off after new rear tires
- Bridgestone RE960AS's or Michelin Pilot Sport A/S Plus?
- R50 in snow?
- M7 Drilled and Slotted Brake Rotors?
- Curb Rash + White Wheels = Help!
- Screw in Tire, am I stuffed?
- Gold wheels on a Dark Silver?
- Which wheels are these?
- will 15" holies fit over R53 JCW calipers?
- Aftermarket wheels, how to center on hub (Rota Boost)
- Cooper S liteswith 215/45/R17 Pic
- best way to sell wheels
- Gave the Mini a little love yesterday....
- What profile for 17" bullets?
- Outmotoring brake duct review?
- brake pad replacement
- Does the TPMS work on aftermarket rims?
- Got some new rubber
- Brake anti-rattle spring source
- To Run Flat or Not to Run Flat.....
- What offset to avoid rubbing?
- 20-25mm spacers?
- Wheel Spacers
- Question about email contact from Tire Rack
- recommended replacement tires for 17" rims on Sidewalk Cabrio
- Tire manufactured date
- Thinking about these Wheels.
- 215/45/17 with M7 springs?
- Anyone here using 225/55/16??
- Getting rid of run-flats. Need comments on Michelin.
- New rims and tires - vibration at 65 ~ 70 mph
- Used 18" Exel TZ-10 (Hyper silver) FOR SALE (south florida) local only
- 12 Volt Air Compressor
- Busted Rim?
- planning turn back to 16" wheels
- New tires - big difference
- cover for spare tire
- Rims that fit the TSW MDM Kit
- Tire Pressure Monitor
- Tire Rotation
- BSA 220 Wheels
- Anyone running 235/40/17 Bridgestone Potenza RE-11 tires on an R56?
- Bridgstone G019 vs Yokohama S-Drives
- 17 or 18 what to do
- Some wheel opinions wanted
- Chain Alternatives
- Does the JCW Brembo fits on Replica R90 wheels with ET45?
- Tire Ware/Rotation/Replacement Question
- Will 14 inc Wheels Fit
- Brakes!!! OMG
- Brake pads?
- Need new tires for the stock 17
- my new rims
- Question about tire rack
- My Black 17x7 Motegi SP10
- Bad Road Noise -- Kumho SPTs?
- Hankook RS3
- What's the point of black rims?!
- Outmotoring Stud Conversion
- Good 16" performance tires w/ not much noise?
- Will these fit??
- Request for pics of 18" ultraleggras on a R56
- What brand of Rotors are you using?
- reasonable brake pads?
- Brake pad help?
- I gotta have these...
- Help identify these wheels (OEM)
- impossible = perfect tire?
- I think I'm going through tires way too fast!
- Will 17x7.5 et+50 205/45/R17 fit a Clubman?
- 16's for Mini's
- Rim damage frustration!
- 2007 R56 - Reason to NOT replace 17" with 15" wheel?
- Where to find high-res photos of every current OEM wheel?
- Brake lining warning light
- help me!!!!
- Brake Sensor Light?
- Closed end lug nuts on studs
- R103 16" 5-Star Blaster Wheels
- Lug Studs Sheered Off in the backplate.
- Looking for new tires for my 2003 MC, not sure what to buy
- Cant search Tire Rack for wheels without specifying make and model?
- New tires, wow....what a difference!
- New Mini
- Huge thanks to M2ME
- Need Pictures of MINIS with 15" Wheels ...
- Which Brake Pads?
- NEW WHEELS MAKING MY BACK TIRES RUB
- NYC weekend driver/winter tires?
- Kosei K1 Racing
- Unusual Tire wear
- Tire Rack Sucks
- Another TPMS question
- Tirerack Troubles
- Is Road Force Balancing Necessary?
- used wheels???
- SSR GT3 light weight wheel ?
- GP Rims on a Cooper S
- 4 x 100 +43 17 x 7
- Michelin discontinues the PE2
- Low Speed Helicopter Noise from Fron Tires / Wheels
- Need tire suggestion. Big rear small front tires.
- Do these 18's fit on a 2009 clubman s?
- Factory lug nut torque?
- Resetting Tire Pressue Monitoring System for New Wheels and Snow Tires
- Tires - Run Flats
- Confused
- Enkei PF01
- 225?235?
- Just bought a set of Michelin Primacy Alpin PA3 ZP Tires, but no RSC in a Circle?
- Newbie track tire help
- Keskin KT1 16x9 +30
- Anyone buy from ExpressWheel -Ebay Seller?
- 225/40/18 on 7" Rims on an R53, Questions.
- Anyone running or attempted to fit some Diamond Racing Wheels on a R53 or other?
- TPMS '07 vs '04
- Spinning when shifting to second
- Clubman suspsension cause wheel fit issue?
- R110 and Wilwood Dynapro 12.19 kit
- tire chains for '05 S (195/55 R16 runflats)?
- Will 15" Konig Rewinds fit an R56 Cooper?
- Looking to Buy Winter Tires will 195-50-16 Work?
- NOW WITH PICS! Help Identifying Camber Plates?
- 215/45 R17 how many miles off?
- Pokeage & Stretchage (Poke & Stretch Euro Style)
- Clearance Between Caliper & Wheel Barrel?
- 205/40/17
- 205 too wide for snow?
- Help! Trouble deciding which rims to buy.
- Winter Wheels and Tires showoff Thread
- 15in wheels on Clubman S
- another tire replacement question
- elementwheels.com
- Rookie Shops for Tires
- 225/35/18 td 1.2 18x8 et 45
- 17x7.5 et35 pics
- Another n0ob tire/wheel question
- Consensus: Best stock tire replacement for 09 MCS??
- new TPMS sensor question
- Clubman needed in South Bend IN
- Steel Wheels from Costco Canada
- New Wheel Tire Question
- Does anyone know a place in NJ that will patch runflats?
- New Pad,New rotors, New torx and a stroke
- New pads and rotors @ 28k????
- 15" to 17" S-light wheels on regular convertible?
- Nokian WR / WRG2 vs "Real" winter tires?
- 16x7.5 et20
- looking for pics - BBS RG-F, RG-R
- R90 issue
- Brake pads and sensor ?
- New wheel compatibility
- Swapping out run-flat summer tires
- Can 205/50-17's do any damage?
- Team dynamics pro 1.2 rims + new tires
- winter tire size question
- hardtop vs convertible rims
- painting Rims.
- New Set of Wheels, Reuse exsiting TPMS?
- MINI Silver Rim Touch-up Paint?
- Summer vs. All-season Tires
- ATE PremiumOne Slotted Rotor
- Bridgestone Potenza vs. Goodyear Eagle GT
- Run Flat for 4000 miles....
- Problem with Konig Feathers
- 16" tire choices
- Brake Pad Directional Clunking or Knock
- 17inch and gearing/acceleration
- 03 Cooper S Rotors
- Remounting tires
- Request feedback on Kumho Run-flats as replacement tires for OE run-flats
- Can someone confirm.
- The 2009/10 Mega Snow Tires/Wheels Thread
- Winter tire choice - for Seattle
- Lightweight wheels for track car with BBK
- FWD Tire Test: Summer vs All Season vs Winter
- non runflat tires
- Best Upgrade Ever.......!!!!!!
- Winter Options/Need Advice
- Tire Pressure Light
- Quick wheel question
- Need advice
- 16" Steel Rims
- All season tires.... can they be any good?
- FS: Snow Package
- Bridgestone Question
- SPYN Wheels and Marangoni Tires
- HUGE Props to Alex@Tire Rack!
- Are Wintersport M3s in 195/55/16 discontinued?
- Need some help on choosing a set of aftermarket wheels for my R56! Motegi/Konig/Enkei
- Combining runflats and non-ruflats
- Rear rotor replacement
- Will these fit my 2005 MC?
- TPMS for 2010s are different!
- Screw in front tire
- WTB: P205/45 R17 84V tires
- BBK Brake pads: Do they last longer?
- s lites to r 90s
- 15" Wheels for TSW BDM
- Which stock rims will fit on a 2004 JCW???
- TPMS question, 2010 MC and R81 wheels
- All season performance tires?
- When do you switch to your winter tires?
