- Bridgestone RE960 Pole Position
- need some help on which tires to buy for my rims.
- The Good and Bad
- How to turn off the Tire Pressure Monitor on a 2005 Cooper
- Tire size change on a R53
- Rims Don't Fit !!!
- puncture in runflat
- 949 6UL's with TSW BDM Kit
- TPMS Question
- my new wheels finally came today!
- R 95 replacement tires-non RF
- Compact spare, again
- Replacement RFs: NO WARRANTY???
- Direzza Tire Pealing Issues During Autocross - Suggestions?
- question about pads/rotors 2005 r53
- Violent Vibration when braking
- Purchasing new tires and asking questions
- Carbotech Bobcat 1521 -> AX6
- wheel weight effect on track
- R56 Wheel Spacers....?
- Replacing Run Flats
- tried to decrease the wheel gap and now....
- Valve stems and price gouging
- 50,000 miles break job?
- Brake Pad Questions
- Has anyone replaced the Mini emblem on their MCS stock wheel?
- tire size for 17x8 HM4's
- Do MINI center caps fit in other wheels? Powder coating experiences?
- HELP: Steel wheels; not hubcentric = vibration?
- HP All-Season Tire Recommendation
- New wheels this spring - Help me choose:)
- Brake pads
- What Color to Paint Brake Caliper?
- Yokohama Avid Envigor Anyone?
- Could you recommend on Wheels?
- Need some new calipers. Where to buy?
- pics of Chili Red w/ black top and black wheels
- any one running Kumho ecsta ASX
- Anyone want to share long term update on General UHP?
- Factory tires need replacing at 14k?
- Too good to be true? Brake Rotors & Pads F+R $219
- ContiProContact SSR vs. Pirelli Eufori
- Need some advice.. kinda quick on tires..
- I had to use "FIX-A-FLAT" now what?
- Just rotated my tires myself for the first time -- do they need to be balanced, too?
- 17s or 18s? Please HELP
- Goodyear Eagle GT vs Falken ZE-912
- autocross setups
- Pad surface extends over rotor edge
- Anybody running 215/45/18...
- Front wheel play/safety
- Optional sizes for 17's
- 17" Pirelli's?
- Compact spare
- Would love very detailed instructions on raising an R55 up for tire rotation!
- 205/55/16
- OZ Alleggritas
- Colours Project
- New shoes! Enkei RPF1's
- OK, this might be a stupid question, but I need help.
- What Are a Set of JCW Challenge Wheels Worth?
- Picture Request!
- TPS, technical questions
- These Run Flats are destroying my MINI !
- 14x1.25 black tuner lug bolts
- Prostop / Satisfied Ceramic Brake Pads
- REALLY loud run-flats... Is something wrong?!
- Lug Nut Torque?
- Stoptechs with Stock JCW Wheels??
- Needed - Torque spec for '10 TPM sensors
- Need proper pressure for My New tires
- Need Clue on Installation of New Rear Brake Lines
- ldm brake kit
- SO how many sets of wheels do you have
- 2007 Mini Front Brake pads? Can I change??
- 205/45/17 vs 215/45/17 What looks better?
- Grids Or Sport Signatures?
- Caliper Slider Pins - To Lube or Not to Lube?
- Brake Pads for Track Days
- After Market rims and tires tpms
- FINALLY! New shoes for me - an ode to Konky ;)
- A good affordable mod for the frugal mini'er
- 215/40/17 vs 205/45/17 ???
- Konig Holes 18", what offset is needed?
- How to lose run-flats??
- Removing paint from mini wheels.
- stuck rotor screw issue
- 16" by 9" max tire size?
- Wheel/tire warranty
- How do I fix a flat-spotted tire?
- Is ASA AR2 TPMS compatible?
- Input requested -- Tire choices & XL Load Ratings
- +40 offset
- run flats
- Black wheels
- TCE 13.1 brake kit on a R56
- Help for a non-car guy
- What is the offset on OEM 17" S-Lites for 03 MCS?
- 04 Mini S wheel fitment
- Tire Pressure Monitor System (TPMS)
- Aftermarket brake pads w/ slots for brake wear sensors?
- Selling Run Flats
- Tire brands? Anyone use these?
- A nice experience
- spare tires
- 15" spooler wheel vs 16" bridge spoke
- 2010 "Justa" 15 OEM wheels can be replaced aftermarket wheels?
- will 15-inch OEM steel wheels fit a 2010 Cooper S?
- Need a little tire advice
- Costco won't sell you tires.. if you don't have a spare!
- Cheap Source for Zimmerman Rear Rotors / Brake Bleeding Procedure
- New front pads
- need 1 cooper zeon 2xs 205/45 r17
- tire mounting recommendations
- what do you think and will these fits my 09 S?
- Help with picking tires size
- Will it fit?
- Spacers
- Pictures of R53 w/ Aero kit and 16" wheels?
- 2010 MCS TPMS
- ASA AR1's in 18x8... What offset?
- new mini new tires
- aftermarket wheels for 09 factory JCW
- Are ceramic pads easier on stock rotors?
- Anyone else think tires are too expensive?
- Questions about choosing summer wheels & tires when you're just a plain driver
- 205 or 225 - acceleration vs. cornering?
- Replacement caps for Rota wheels
- I think I was sold the wrong locking bolts.
- Winter steelie setup with trim ("beauty") rings?
- Does someone know where i can find these wheels?
- Upgrading wheels, tires. Please help
- What 17" rims would you recommend?
- Does new 17" rims mean I need new tires?
- Conflicted about wheel size ...
- Hub measurement
- My runflats need replacing soon on 08 MCS - options?
- SS Brake Line Help!
- Brake Pads & Fluid.
- Tire and Wheel Insurance
- Will R105 fit over factory JCW calipers?
- Dunlop Direzza DZ101 ??
- can't find 205-55-17, any suggestions
- Please ignore my stupid questions below ... BUT ....
- Help w/ new tire size, spare question
- Need wheels/tires advice
- BMW Rims for MINI
- 15mm Spacers - Yes or No?
- After Market Rims. What i need to know
- TIE ROD ENDS
- A bunch of stupid questions ...
- Caliper Size for 05' Mini Cooper
- New wheel options. pics inside
- A better tire for a aggressive gal....
- Help with brake change
- Brakes
- About to ditch the run-flats...what compressor to carry?
- Ventus V12 EVO K110 - Any Impressions.
- 2007 Mini - want new wheels & tires -
- Black or Silver?
- 215/55/16
- Pencil style tire gauge?
- Can I put 215 tires on my 17" wheels?
- Summer tires for my '06 JCW
- Looking for some opinions
- Coupla quick newbie questions please...
- Tires for 2007 JCW MCS
- Yokohama tires.
- Looking for 15x9 Rims + Tires for Mini Cooper.
- 17" R99 Wheels - will BBK Fit?
- New tires
- Spare Tire
- Just bought Rota MC's, do I need a lug conversion kit?
- Conti. DWS vs. Potenza grids 019?????
- 2008 cooper s tires
- Will wider tire fit on wheels?
- Dumping the runflats; Tire recommendations!
- Mini Tire Question
- Web Spokes OEM wheels with Sensors?
- Do I Need To Replace The Brake Sensors If The Light Is Not On?
- Spring Promotions @ Tirerack
- Are these black with a red stripe rims OEM JCW's?
- What colour wheels would you choose?
- R56 wheels on a R53
- All Seasons Needed!!!
- Toyo Proxes 4
- General Altimax HP
- Confusing tire rotation information
- wheel/tire fittment??
- Can any tire dealer do wheel alignment?
- 2-yr owner, new to board
- Question related to Tires
- 20% off P21S Wheel Cleaner Gel at DD
- shaking.
- Brake Parts Listing
- Brake Pad light?
- Spare tire?
- Anyone running 215 40 17
- Original OEM brake pads and rotors
- Quick help re: my runflats, please!
- Need help! Run flat switch to normal tires
- Question
- SSR INTEGRAL GT1 18x7.5
- Kumho Ecsta SPT KU31 Run Flats
- Painting OEM wheels
- Run Flat Tires Suck
- Need your opinion on "humming" sound
- Let's talk UTQG
- Feedback on 205/50x15?
- factory rim question
- Need help from the EXPERTS - tire size
- The Old Run Flats and the New Bridgestone Potenza 019 Grid's
- Difference between late R50/53 and R56 wheels
- R98 webspokes
- Comments needed on Falken Ziex ZE-912
- Help with summer rim/tire size for 06 MCS
- Repetitive alignment issue, after market wheels
- Rusting Rotors.
- how big can i go?
- Good Deal on JCW 18", should I buy?
- Strange wheel balancing
- Run Flats vs Normal Tires
- do i need brake fluid??
- wheel spacers needed?
- S-Lites questions and an opportunity to SHOW WHAT YOU'RE RUNNING
- Woops - my metal Hubcentric rings are stuck on....
- Seized eBrake Cables = fast rear brake pad wear
- R56 Brake Wear
- TPM Sensor torque specs
- New shoes for MINI
- Some RFT tires are much better than others.
- -Help! What rims are these?
- drivers rear tire scraping
- Slotted and Cross Drilled rotors?
- Couldn't take it anymore... gloss black it is.
- LF help with wheel sizing and possible tire choice!
- Brake wear sensor(s) slushed?
- What drag tires on stock rims
- best wheel locks?
- Question about spacers and bolts
- Trade Wanted - 17" White Bridgespoke
- Spare donut tire on JCW rear wheels?
- New be w/ TPMS question
- Which tires should I get?
- 16x8 RPF1 38mm offset, anyone?
- Pics of a 205-50-16 on a stock wheel please
- Mg Zr 16" rims on mini cooper
- Ordering one new wheel
- Bridgestone Blizzak LM-60 RFT
