View Full Version : Tires, Wheels, & Brakes
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42
  1. MCS on 16s instead of 17s?
  2. Can anyone ID the Brand of this Wheel?
  3. TPMS Question
  4. Car Drifts Just a Bit to the Right.....
  5. Caliper Covers
  6. Run-Flat vs. Conventional Tubeless Tires
  7. Big problem going from runflats to non-runflats
  8. New Wheels and Tires
  9. 215/45/17 Michelins installed on my JCW
  10. Car wallowing after wheel/tire swap Konig Feathers
  11. Tire symble in the speedometer stays on
  12. Something interesting about my tires.
  13. 02 MCS 17 inch tire question
  14. Brake service light on R56
  15. Pics of R53 rims on an R56?
  16. 15s trade for something?!
  17. Replace run flats with regular tires?
  18. Tire Question
  19. What is the MINI logo's part number.
  20. Tire calculations question
  21. wheel bolt question
  22. Donut wheel fitment R53 to R59
  23. How big are my wheels?
  24. Any advice for an upgrade to 16-inch wheel?
  25. Alternate Tire for '06 R50???
  26. Conti EC fitment question anyone running 225s
  27. Which brand to buy for Run Flats?
  28. What tires to purchase?
  29. What brand tires are you using for Summer ?
  30. review: Bridgestone RE-11's
  31. Replacement Wheels
  32. rear rotor question
  33. Thinking about switching to 16 inch wheels, what are my tire size options.
  34. Longer Wheel Studs for R56 Mini?
  35. Cooper 08: New brake pads. Upgrade?
  36. Tirerack - SSR rims
  37. Honda Fit HFP for Mini Cooper? TPMS?
  38. 17" wheels with stoptech big brakes?
  39. R56 rotors
  40. rotating wheels
  41. TPMS rebuild with new tires?
  42. Brake pads - only partial contact
  43. 17" wheel
  44. Need Some Help
  45. New Mini Cooper S heartache...
  46. Ahhhh. New tires
  47. Yokohama AVID ENVigor
  48. Wheels or suspension upgrade?
  49. Best R53 brake upgrade for <$1000
  50. Cragar S/S FWD Wheels
  51. Nitto,NeoGen's
  52. Will 225-45/15's rub on my 15x5.5s?
  53. Rear Brake Caliper Tool????
  54. Advice/Preference for Black rim.
  55. help with split rim bolts
  56. Service light on for brakes
  57. BBK install
  58. 17" runflats vs. 18" non runflats
  59. S-Winders Powder Coated
  60. Quite noticeable vibration while at speed, Possible cause tires?
  61. Brake upgrades for better track performance
  62. R50-R53 Wheels on an R56 - anything needed?
  63. Need help with snow wheels and tires
  64. 07 MCS TPMS Reset
  65. 15x8 wheels with 25mm offset
  66. Keeping run flats maybe
  67. Bridgestone G019 Impression
  68. What to do?
  69. Asymetric Tread Patterns
  70. The OFFICIAL Chili Red MINI Picture thread
  71. New Wheels/Tires TPMS
  72. Do R56 wheels fit other cars of differnt make?
  73. installing front brake pads on 2007 r56
  74. 215-50-17 non run flats??
  75. 14mm-12mm stud conversion
  76. Lug question?
  77. need to pick tires now
  78. Grease wheel centering hubs?
  79. 215/40R18's, 15mm spacers, and Coil Overs
  80. Aftermarket tpms sensors
  81. OEM GP R107 Wheels
  82. 15 mm spacers
  83. List of Tire (not wheel) Weights?
  84. White Walls
  85. ContiSportContact 3 SSR = WOW!
  86. enkie nt03 17x7.5 et 40 what tires to put on?
  87. TSW Trackstar?
  88. Looking for Challenge wheels or similar
  89. Tire Rack and Conti = AWESOME! Plus, what I did NOT know about my Mini's TPMS
  90. Looking for a light 16' - please help.
  91. KONIG Feather not an option?
  92. Caliper Guide Pin Replacement Questions
  93. More pedal travel with performance pads?
  94. Stupid tire size question?????????
  95. Bridgestone RE760 or Yokohama S lines, or other? What tire to get?
  96. Alternate source to TSW for 14mm > 12mm lug conversion?
  97. Widest tires for stock 03 17" rims
  98. Michelin Pilot Exalto PE2 OR Sport A/S plus ?
  99. winter is coming
  100. lookin for some black 17" wheels
  101. Tire pressure problem (or not a problem?)
  102. help with lug bolts...
  103. Mini Center Caps (Need)
  104. Increased torque steer after replacing Run Flats w/Michelin Pilot AS Plus 215/45/17
  105. Thinking about Yokohama AVID ENVigor (H&V) tires on an 08 MC ?
  106. Adapters? Good or bad?
  107. ONLY Large yellow TPMS light came on after tire rotation?
  108. Zexius Ohtsu XI 326 good or bad?
  109. Anyone know proper way of reinstalling brake pad sensor?
  110. '04 MC Brake Pad Sensor
  111. What size brake rotors for my sidewalk?
  112. 2010 MCS Front Brakes at 8000 KM(4900 Miles)?
  113. OEM rim replacement, 07 MCS
  114. XXR 518 black rims
  115. Just bought r98's....what do i need???
  116. Fitment 225/50/16 vs 215/45/17
  117. Driving on runflats?
  118. Runflats to Normal blackwalls?
  119. Flat run Goodyears worn after 7K miles
  120. Slime Quick spair
  121. Aftermarket TPMS?
  122. Panasport's
  123. Runflats again...
  124. Rear Caliper Compression
  125. Rear calipers for my 2003 mcs
  126. will dishes from an bmw e30 fit under the mini?
  127. Fair Asking Price BLK Web Spokes?
  128. Brake issues.
  129. Wheel opinions
  130. 18x7 rims
  131. Tire size for MO 2-S (bbs lm replica)
  132. Hawk HPS Pads no sensors for '04 S
  133. TPMS aftermarket wheels 2010 s
  134. Front wider than the rear?
  135. knockoff jcw 113
  136. RaceMax Wheel Spacers problem?
  137. R53 conversion to R56 aka JCW Sport Brake Kit
  138. Looking for opinions on new tires
  139. Different sizes F vs R
  140. Continental DWS on Clubman S
  141. Front alignment woes
  142. If you only change front brake lines...do you need to bleed?...
  143. Wheel Construction
  144. Well, Good news for Me!!!!!!!
  145. SNAKE in My Wheel
  146. Tire Suggestions
  147. Need brake help
  148. anyone running Toyo Proxes 4's?
  149. Replacing Run Flat Tires 205/45 R 17 2006 Mini Cooper S
  150. Tenzo Cuzco -- anything I need to know?
  151. Wheel color help
  152. Rebate time at Discount/America's Tire
  153. R95 JCW wheels & 215/40 18 Conti's a good choice?
  154. How many miles per set of tires do YOU get?
  155. Clubman S on Cooper S
  156. yes another will it fit thread
  157. Just switched from RFs to Bridgestone RE011
  158. Powder coated wheels
  159. Pilot Sport A/S Plus 205/45R17
  160. Help with choosing pads - R56
  161. Alternative to Potenza RE050A 205/40R18 Run Flats
  162. Anyone else running a similar color combo?
  163. new to mini
  164. 235/40/17 with stock wheel(black star)
  165. Ready for non-runflats.
  166. Pre-brake Squeal
  167. My 2 day old MINI just ate a screw
  168. anyone?
  169. run flats and rims
  170. NHT Performance Calipers - Horrible product
  171. What pads to buy? (Hawk HP+ alternative?)
  172. Wheel Time
  173. Which size tire on 16x7 Rota RBs?
  174. Original Equipment Tires for a 2010 MCS
  175. do i really need to replace my rear rotors??
  176. S Brakes on a Justa?
  177. Riken Raptor ZR tire
  178. run-flat pirellis are crowned.
  179. "Fix a flat" can questions
  180. 2nd gen compact spare
  181. 16x8 with +0 offset?
  182. Brand new and losing air...
  183. Anyone know anything about these wheels? Focal F10
  184. My new WHEELS!!
  185. OMG, some one identify these rims!
  186. PLASTIC SPRAY
  187. Air powered brake bleeding
  188. Need new front 17" run flats - Dunlop or Kuhmo?
  189. Tire width, profile, and wheel questions
  190. New Tire help for newbie
  191. How much are these rims?
  192. R53 EBC green stuff pads brake squeak
  193. How Much Air Compressor?
  194. Thinking of putting smaller tires on front? Good/Bad?
  195. 15 INCH WHITE WALL TIRES FOR MINI
  196. Black R84 on PW...I Photoshop'd my own
  197. Will MINI Center Caps fit OZ Wheels?
  198. DECORSA FUSIONS
  199. bout to order - spec check?
  200. OK, I've looked every place I can think of
  201. Wheel/Tire Advice
  202. 16x7x37mm rubbing on lowered R50??
  203. Last thoughts before I pull the trigger on Potenza RE-760 in 205/50-16?
  204. Hi from sunny England and quick tech question
  205. what wheel locks do you use?
  206. Continental DWS a bargain?
  207. Help: Summer Performance Tire in 195/55/16.. selection seems limited?
  208. AFTERMARKET BRAKE PADS AND ROTORS/BRAKE LINES
  209. Wheel Lift
  210. BRAKE QUESTIONS!
  211. Can I go from S-Winders to S-Lites? (TPMS)
  212. Tire plug question...
  213. STX Class Autocross Mini Wheel and Tire Fitment
  214. Get JCW R113 or 3rd party?
  215. 15" MC wheels on MCCS?
  216. Attn Alex: Mach V springs and Koni FSD's
  217. Tires
  218. Need help Picking new Rims!!!
  219. What do you guys think of these possible RacinHarts?
  220. Camden, TPS, Mission Control. HELP Please
  221. H&R Street Coilovers Clunking
  222. Assymetrical Tread
  223. TPMS on a 2006 MC - work, or not, on a 2009 MC?
  224. Downsizing wheels?
  225. Rim offset calculator iApp ?
  226. 195/55/15 on 15x7
  227. Tire pressure warning light reset
  228. 16" tire question
  229. Crown Spoke owners...I have a question?
  230. max performance summer tires
  231. Crack in superleggera rim, HELP!
  232. Need help to photoshop these wheels on my MC40
  233. Thinking of... Yokohama ADVAN Neova AD08
  234. webspoke help?
  235. a question about tires
  236. BBS RGR in Diamond Black Silver Paint??
  237. 235/40/17 tires with 8" wheels?
  238. 4 Dunlop Sport 01 Run Flats w/less than 600 ml
  239. Tire Recommendation for 15x7 Team Dynamics on R56
  240. Need Lug Bolts asap-`03 R50...
  241. Hankook Ventus V12 evo K110 for track/autox use?
  242. offset question
  243. 215/45/17 with 40mm offset
  244. Team Dynamics - tire / wheel vendors?
  245. Dumping the Runflats -- Final Answer?
  246. Conti DWS, soft sidewalls? Any other feedback?
  247. Help! trouble removing wheels
  248. where to find stud caps??
  249. ?Can a 225/45-17 replace a 205/45-17 ????
  250. finally ditching my runflats!
