- Bridgestone G 019 Grid vs Yoko AVID ENVigor
- Is this Rota MC?
- Going from 18's to lightweight 17's worth the trounle?
- Wtb 16" Wheels For 08 Clubman S
- Run Flats FTW!
- tire noise
- Noisy tires after rotating?
- Ok to replace just one tire?
- Opinions for my Cooper
- What tires for stock 15in rims?
- TE37 question
- Thanks Alex and tire rack
- Dunlop SP RFT VS Continental RFT
- Steel wheels, 2010 mini?
- 15x8 Pics please
- Brake Pad Life - front versus rear?
- New Carbotech Bobcats sound like a siren coming to a stop
- got rid on the run flats today
- Yokohama ADVAN Sport
- what tires are best for So California mountain snow driving
- Yay runflats!
- Team Dynamics PR 1.2s - 16"?
- Disk Pads / Rotors and Warranty
- Tread Depth Gage
- Who's replaced your pad after 1000 miles?
- R56 Rear Brake Clunk
- Help selecting a brake kit please.
- In search of brakes
- "New" R81's on the Clubbie
- resetting TPM?
- Can you reset TPMS yourself?
- Will these fit???
- Carefull with those Genuine MINI Wheel locks
- Black 17" JCW knockoffs
- Mod to R56S brakes, reco for rotors and pads?
- EBC Redstuff read pads wearing quickly
- To runflat, or not to runflat
- Avid Envigor -- 1st impression and Pix
- Early '07 R56 Needs Front Pads & Rotors
- X-LITE Rims - What do they weigh?
- Mini Usa does not recommend tire rotations
- Is the Yokohama Avid Envigor (H&V) a good time for the Cincinnati area?
- Anyone Refinished BBS R90's
- Will These Fit 2009 Clubman S?
- 16-inch MINI steel wheels
- Winter Tires
- 17" SSR Competition
- Brake Caliper Question
- Tire rotation and wheel balance-how often and where?
- Chromed OEM S-Lites: Let's guess the weight
- Tire help, got it narrowed down but need help
- KMC Rockstar
- '08 brake pads different?
- Spacers needed with S-Lite wheels...
- Is this too wide?
- Clutch bleed - help, can't figure out correct steps
- New Wheels
- tire recommendations
- 15 inch steelies with 195/60/15 tires fit a 04 MCS?
- Winter Tire Recommendation
- Mini One 2008 (uk) with Wolfrace Kochi Race wheels Black/Red lip???
- MICHELIN - Which All Season to get?
- 205/55/16 Fitment - Any rubbing issues?
- Rubber
- 17" non run flat Question
- Would wheels on Gen 1 fit Gen 2 w/o spacers?
- leaker
- Need new 15" tires - help!
- Different Size from OEM
- 03 MCS front brakes pads and rotors
- Polished Bronze! Infernos, anybody here of them?
- Tire Size/Type and gas mileage impact
- Spacers
- Toyo - Tires ??
- Audible Tire Pressure Warning?......
- I need tires
- Tire Size Question
- hubcap replacement
- Pics of installed gold zinc and black rotors?
- Wheel bolt question!!
- New Wheels!!
- TPMS Question When Switching Wheels
- Audible Tire Pressure Warning???
- 2004 Mini Rotor Replacement
- Slipstream lookalikes
- Nitto Gen and Hankook Ventus V12?
- Compatibility of tires of different sizes.Same car.
- r56 rear caliper and rotor bolt torque
- TPMS - How does it work
- 15x7.5 Konig Candy w/ 225/45/15 Hankook RS3 on R53 JCW
- Rattling Parking Brake Cable
- Don't quite understand the tire pressure monitor
- H&r spring drop on 16 inch wheels
- Time for new brakes!
- Tire Pressure Sensor
- Wheel Help
- Try not to use Fix-A-Flat if possable.
- Just ordered Conti Extreme Contact DW
- Stock 16" alloy weight
- Wheel gurus…18x10 Porsche Twists
- Weight of New Tires
- What wheel is this?
- Please show me red with custom wheels
- Tire recommendation
- Suggestions please!
- Damm need tires
- Should I get Chrome Wheels for my WhitePepper
- 05 MCS Autocross tire wheel questions...
- Enkei RS6 - TPMS Compatible?
- Wheel Repair Help Needed!
- New Wheels & TPMS
- Brake Pad & Rotor Choices
- New Rims
- what is the widest tire i can fit?
- 15" rims - no good tires for them?
- 18" Avant Garde M310 Wheels Anyone??
- New Rims!!!!
- i need tire advice (for my R53)
- need tire advice (R53)
- got some new wheels, need cleaning tips
- any reason these would not work?
- Rotate bridgestone re-11?
- quick question regarding rotors
- Rotors warped
- Front brakes - 27,700 miles
- Tires for 2004 MC...Hard to Find???
- Advice needed.. experts, help me.
- Drained brake caliper, spongy pedal now
- Rhythmic Thumping While Braking
- Love your pressure gauge? I need a better one!
- Best place for wheels/tires
- Got the Break Light on!
- how should i store summer wheels/tires for 2 years?
- Bending wheels, any way around it?
- Wwyd?
- Matte black rims help.
- White Wall Envy
- rims
- How to Adjust ebrake Correctly?
- stock ride height 16" wheel needs new tires. size ?
- Tire Question - Stretch
- What do do about 12mm vs 14mm lugs
- Will these fit??
- Possible 2008 wheel set?
- where to get some steelies?
- Need new tires- where to begin?
- Will 225/50/16x7.5 with +43 offset fit?
- Carbotech rear pads slipping?
- anybody running 225/55/17 on MCS 2003?
- Lost a Ultraleggera center cap. Where to get a new one?
- Best All Weather Tire Recommendation
- Spongy Brake pedal after JCW Brake Inst
- Bay area brake shop recommendation
- New tires = less milage or something else??
- Best Place for Alignment in Miami, FL USA
- new tires Yokohama S.Drive =D
- any real difference in handling with slightly wider tire size?
- 195/55-16 vs 205/50-16 pics?
- 15" wheels on '07 MCS?
- fender trimming
- Tires Causing a Drift or Pull....
- CALL FOR HELP! Wife may be stranded with brake issues
- Tire pressure monitor light came on
- Looking for a list of MINI OE wheels that states if each wheel is TPMS compatible.
- Track tires - What size do you run?
- Is this tire suitable for my 03 MCS
- I need new tires.
- I need new tires.
- TPMS Light question....
- what is so wrong with runflats?
- how can i optimize handling with bigger wheels/tires (17x7 - 205/45r/17)?
- Winter Tire/Wheel Combo Help
- Plugging run flats???
- Willwood Brake required offset
- Rota MC Wheels
- Replacing oem 175 65 R15
- Are all 215/45/17 the same size ???
- New Shoes
- R56 rotors
- 165/17/10 Yokohamas A032 fit on 7 inchs wide wheel???
- OEM Rims on 03 MCS - What are they?
- What size tire should I go?
- Hankook Ventus V12 Evo K110's and Correct Air Pressure
- Are R53 and R56 brake pad sensors interchangeable?
- 17 Wheels fitment on mini 2010 base hardtop
- Replacing one factory original wheel
- New Tire Question
- Winter Wheels and Tires
- Which rims do you like best for my car?
- Time for new brakes, suggestions?
- N00b question about switching to non-rft tires
- RPF1 15 inch on MCS
- my horrible yet amazing tire luck?
- Tire Size Calculator
- 205/50/16 vs 205/55/16
- Tire Size Advice
- Shocked at behavior of Dunlop Star Specs
- 235/40-17 on Crown Spokes w/ NM springs
- Advice please.
- Pressure in a flat run-flat
- Baby got new shoes (run-flats) $760 set installed
- Any tips for installing stainless brake lines?
- Suggestions welcomed....
- Meyle Rear Brake Pads
- New TPMS
- Keeping the brake pads and only replacing the rotors, is it ok?
- Azev?
- Painting Wheels Black: Pics and Options
- Brass brake caliper pin bushing issues
- Tire recommendation.
- Front Brakes...
- TSW/Toyo fitment question
- need to sub a couple of tires
- Help identify these wheels
- Lurker needs help with brakes!
- Rear brake rattle/clanking noise
- Rota RB 16x8 et20?
- Brake dust
- Anyone upgrade 15" wheels to 17"
- 195 on a 17x7?
- photo's of 215/45/17's installed on JWC
- Perhaps a deal on Sidewalk Rims..
- noob - rims question
- What a difference!
- powder coating - New Year Metal Finishing in Santa Ana, CA
- Ave Cost of Brake Job?
- Sumitomo HTR Z III ??
- New dude - warranty question!
- I dropped down to 36psi in my non-runflats
- Buldge on the sidewall of my run flat
- will lotus wheels fit on my car?
- Very pleased with my decision to switch to the Continental Pro Contact SSRs on 08 MCS
- abs dsc light on after front pad replacement
- Anyone with 18"? do you guys have problems?
- who sell dougnut or spare tires for my MCS conv
- 215/45/17 re 960 pp versus michelin pilot sport a/s plus
- Touch-Up Paint for wheels?
- New Tires and Wheels (inactive symbol)
- Brake compatibility with 1st gen mini's?!
- Rashed a wheel
- Glossy Black Konig Feather 16x7
- JCW upgrade and 16" Feathers Question
- R113 JCW Wheels - What non-runflat tires are people putting on these?
- Beyern Type 5 Wheels
- replica challenge spokes?
- My tire dealer was great. TPMS replaced N/C
- 1st Gen Cabrio Brake rotors
