View Full Version : Tires, Wheels, & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42
  1. Removing brake rotors problem
  2. Naive question
  3. tire help needed
  4. Tire Pictures Needed
  5. Wheight of Web Spokes? ANYONE KNOW?
  6. Stock rotors/new pads or BBK for track?
  7. Why so many 16" wheels for performance?
  8. Nitrogen filled tires?
  9. Looking for some show car wheels for my Mini
  10. What about these?
  11. Weird Cable Linkage Sound in Steering + ABS
  12. Tracking the AVS100
  13. Bent Rims/Run-Flats suck!
  14. rear brakes wear first???
  15. Rusted lug bolts with aftermarket wheels
  16. Flik Wasps?
  17. So, how much energy is in the wheels, and how much benefit is there in going lighter?
  18. superleggara or not so super?
  19. Red Baby
  20. 16" wheels with non-runflats?
  21. front end vibration after replacing runflats
  22. Rear Stainless Steel Brake Lines - Choices?
  23. Kuhmo V710 ??????????????????????????
  24. TCE Wilwoods - Holy Crap!!!
  25. Avon Tech M500 impressions
  26. anyone else having JCW brake problems???
  27. BBK with Panasport FS-16?
  28. Cheap decent/good tires :)
  29. JCW 18" Wheels - Fair Price?
  30. Tires For Some New Wheels
  31. Effect of wheel offset on handling
  32. Last minute dilemma...17" or 18"
  33. Handling worse with new wheels?
  34. New MCS Owner with Tire Question
  35. Will 17x7, et35 work on the MCS?
  36. Best Price on factory 17" R90
  37. Which anti-squeak goo works best?
  38. SSR Comp loose caps
  39. Alutec ZERO Wheels - tire size help!
  40. What does it mean when .... brake wear
  41. Tweel? What the....
  42. Impact of Wheel Width?
  43. Light weight White 17" rims
  44. Magnum cross-drilled rotors
  45. Total Cost of JCW Brakes?
  46. BBS RK or SSR Comp?
  47. 17" or 18" rims?
  48. Nitto NT555 vs. Pirelli PZero Neros
  49. New CF Brake cooling kits!
  50. lugs and hub rings
  51. 15 in wheels for Weekend track duty
  52. SSR Comps
  53. will 14"ers fit a MC?
  54. Got Konig (holes,freefall,rewind) Mini pics?
  55. Anthracite paint
  56. ?? 15" CP-035 wheel (11 pound)
  57. Stock lug bolts with aftermarket wheels?
  58. Is JCW brake kit worth the money?
  59. What torque setting for lugbolts on wheels?
  60. 16" wheel upgrade - what tires?
  61. Which Big Brakes for BBS RGR wheels?
  62. Questions on tire wear and stock setup
  63. Wheel Flustration NO LONGER Eating Away @ Me, Now it's the TIRES!
  64. "Don't put your best foot forward"
  65. Went to dealer might buy Mini with wheels
  66. Torque Steer - How do I minimize it?.
  67. Ditched the Runflats: Driving impression
  68. 16" B3 and Konig FreeFall (225/45/16)
  69. Damn these runflats!
  70. Ssr Gt1
  71. EBC Green Pads - with or without sensor hole?
  72. White 17" wheels wanted
  73. Load Rating?
  74. Strongest wheel?
  75. Stock 15 inch anyone?
  76. Brake question
  77. Tire pressures run-flats
  78. How is acceleration affected?
  79. wheel help
  80. Clack!!!
  81. Centerline Monsoon ( Storm ) wheel
  82. OEM Cooper Spare fit on S?
  83. Worries about rubbing with 215/45/17's?
  84. Edge Racing Mess Up
  85. 205/50/16 vs 205/55/16 on stock wheels
  86. Need help with track only tires
  87. Any one interested in a Rotor / Brake Pad Group Buy?
  88. Avon Tech R in 225/50-16
  89. Paint for the stock wheels?
  90. Rub Problems 18x7.5
  91. Advan RGII 17x7.5 +41....will they clear Brembo?
  92. Weighty decision - T1S vs Pilot Sport vs S03...
  93. Wheel opinion.
  94. Question for Alex (or anyone else) on tire pressure
  95. NO 215 / 17 R compound tires!
  96. Tire / wheel set for max comfort?
  97. Weight of stock 15" rims?
  98. Black R83?
  99. 195/65/15" studded snows-will they fit??
  100. 215/40-17 tires for MCS?
  101. Picture Request! Racing Hart C4
  102. conticomfortkit flat repair unit
  103. Floor Jack advice?
  104. Time for the first brake job...
  105. 225/50/15 will it fit an MCS?
  106. Anyone know the weight of the Gram Light 57S?
  107. ok everyone hates stock w/runflats, is the 2005 mini s any different?
  108. Rota Grid, which finish for DS/B MCS?
  109. Air Pressure for 215/45/17 Toyo Proxes4?
  110. Jack and Stand Points = Wheel is stuck!
  111. new Dinan MINI wheels?
  112. considering buying a plug kit
  113. Just dropped 16 1/2 pounds per corner
  114. Would these fit
  115. Whatcha know about bling?
  116. Metal Hub-Centric Rings?
  117. Chipping/scratches on my white x-lites
  118. OFFICIAL INFO CONCERNING E46 M3 CSL Replica Wheel
  119. Advice on these Motegi's....
  120. how long do the all season run flat tires last
  121. Infatuated With Mesh Wheels, Suggestions Wanted
  122. Brake Kits that fit R84 Wheels?
  123. Panasport Street v. Race Wheels
  124. Need reconmendation for exposed hub
  125. 215/50R 16 or 205/50R 16?
  126. I found a white rims touch up paint ..
  127. Inflation Rates
  128. Graham Lights - 57S
  129. Weight?
  130. 215/45/17, 215/40/17, 205/45/17... I'm confused!
  131. 215/40/16 too small?
  132. Stoptech BBK Installed
  133. other manufacturer rims?
  134. Changing from 16" Vspokes to 17" S-lites.. will speedometer be effected?
  135. Any input on runflats
  136. Wow (E46 M3 CSL Replica)
  137. just got two replacement runflats for the 16inch MCS
  138. To JCW Brake...or Not?
  139. ARRRGHH! Sold out of my wheels
  140. Advantages of multiple pistons?
  141. My new approach to rotating tires...
  142. run flats
  143. Problem W/perfect Rims! Plz Help
  144. Avon M500 215-45-17 rub?
  145. Tire noise
  146. Have anyone put a new M3 calipar on a mini s?
  147. Widest Tire that can fit on the 15in Holies ?
  148. Weight of S Lites
  149. Bought 17" wheels... Do I need anything else?
  150. Wire Wheels for MINI?
  151. Attn: Hamann HM4 wheel owners - HELP!
  152. Tire Recommendations - 17x8, 43mm offset wheel with M7 springs.
  153. Here’s a problem, … anyone?
  154. Aftermarket Brake Questions
  155. Brake pedal noise 'survey'
  156. Tire and Wheel recommendations needed
  157. WedsSport Wheels
  158. Aftermarket Wheels and Runflats...
  159. Help... advice on BREMBO BBK rotor service?
  160. New PIAA wheels arrived today !
  161. Running 17x8 Wheels... Offset confusing???
  162. V700 Victoracers
  163. 215/45/17 vs 215/40/17 Still confused
  164. EBC Brake Rotors.....
  165. tire recommendations?
  166. anyone running 215/50/16 on 5 spoke (R83's) ?
  167. Kosei K-1's with 215/45-17's rubbing issues?
  168. MCS Rear Brake tool rental / borrow?
  169. New Michelin airless Tires
  170. Enkei RP-F1 15x7 41mm offset don't fit!
  171. Is it worth getting a BBK??
  172. 325iX Wheels on MCS???
  173. Wheels that clear AP Racing brakes - APRacing
  174. anyone running 215s on stock 16s?
  175. Tire Rack - new product lines?
  176. SSR declared bankruptcy in Jan 2005
  177. JCW Brake Upgrade = SRT-4 Brakes?
  178. Cleaning Chrome Wheels
  179. HR Wheel Spacer
  180. Speedo, Rubbing Issues???
  181. Team Dynamics Pro Race 2
  182. hoping they'll fit!
  183. 225/45/17 Questions
  184. 3mm Spacer question for wheel and tire experts
  185. Toyo T1-R
  186. 15", 16", or 17" for track/DE wheels
  187. Will the following setup RUB (w/ 5mm spacers)?....
  188. Who has best prices for Team Dynamic Pro Race 1s?
  189. Dunlop 3000 on MCSC
  190. thinking going silver..
  191. 3 Wheels I like for track, Any suggestions on these? with Big Brakes
  192. Spare for MCS
  193. Tire size question???
  194. D@mn these are hot!
  195. Are these available in the USA ? BBS LM 198 17x7.5 ET40
  196. Volk CE28N Center Caps?
  197. Can't believe I'm saying this...Should I go 15's?
  198. 17" Bullets
  199. Tire Weights Avail Now on TireRack Website
  200. Compomotive Wheels
  201. lug bolts dilemma
  202. Falken Ziex 512 vs. Yokohama AVS ES-100
  203. 225's on 15x7?
  204. Don't buy from Wheels Boutique
  205. P-Zeros Rotation suggestions? Alex?
  206. New M7 brake conversion
  207. Konig Rewind
  208. Miltex looks like this?
  209. Tire pressures for F1 GS-D3s
  210. 5zigen Fno1R-C does anyone have those?
  211. More Wheel Ideas... This time I have parental support!
  212. wheel finish ruined
  213. 215/45/16 vs. 205/50/16 comparison
  214. Fix-a-Flat
  215. need help identifying these wheels
  216. Ouch!!
  217. MCS - non-flats and emergency flat preparation
  218. Latest thoughts on white vs silver x-spoke's
  219. Damaged tire, need advice on replacement
  220. Rotor Offset??
  221. Anyone Running 19s?
  222. Wheel advice please
  223. One Directional Rotors?
  224. Will it fit?
  225. Have Big Brakes- Need installer or advice
  226. where did you buy your Exel TZ-10 wheels?
  227. What would you want for the perfect brake upgrade.
  228. replacing 16" RFs on Cooper- HELP
  229. "chroming" wheels
  230. Proxes t-1 vs Eagle F1GS3D vs SO3 Poles
  231. 4 wheel alignment necessary?
  232. Let's talk wheels and tires
  233. Help with painting s-lites please
  234. M3 looking wheel for Mini
  235. 205/40 R16 azenis on X-lites?
  236. latest from MINI on JCW Sport Brake Kit
  237. Do I need to...
  238. Wilwood decision
  239. Question of the day - runflat machines
  240. Any pictures of DS/W with White wheels?
  241. Dunlop SP9000
  242. What wheels are these?
  243. Tire pressure gauge accuracy
  244. 215/55/16 tires
  245. 2002 cooper
  246. SSR Center caps
  247. Shiny silver wheels
  248. Optimum Tire Size
  249. Tire opinions needed! What tires should I get?
  250. What kind of wheels are these?
