- Can anyone vouch for Rota, Koning, Enkei
- Plastic centering rings
- 15 or 16 inch questions
- slick tires?
- Toyo T1R's - Where to get?
- tire pressure for 05 run flat confusion?????
- Avon M550 A/S or Falken Ziex 512???
- SSR comps 17x7 1/2 Anthracite
- tire pressure on Mini w/16" run flats???
- s lite fatigue crack
- one more option
- Wheels/Tires from Edge Racing?
- MINI Donut Spares for $109.20!
- Brake Pads – What Do You Like and Why
- How to ... help needed
- Great page for finding wheel weights
- New Rims for S Xpress
- Are black wheels just a fad?
- motegi, ssr, centerline or enkei??
- B3 Bbk
- How bad to drive on a bent rim?
- 17" stock wheel & tire value?
- streetdreams.org
- Hamann HM4 weight?
- Recommended Tire Pressure for 18" wheels
- Cutting rotors
- Brass Bushing Mod Install Writeup
- Spares for MINI COOPER S
- How do these look on my Cooper?
- Best tire for 15in Holey wheels
- 16's VS 17's (NeverEnding)
- Cross drilled rotors all bad?
- New Shoes for TWISTER
- Anyone have any exprerience Painting Wheels?
- TCE/Wilwood special
- Pics of my new Enkei J10 17" and Barum Tires
- HAMANN HM4, Where to buy?
- Rota Slipstreams or 5Zigen Fn01r-c
- Carry 4 17" Tires/Wheels in the MCS
- Hard to clean Rim ... Any Ideas
- JCW Brakes vs. 16" Wheels
- Toyo T1-R's in 195/55R16, anyone finding them?
- Porsche Brake conversion- Anyone
- OEM 195/55/16 to 205/45/16 vs. safe brakes?
- ABS Kill Switch?
- Question re: brakes, MC vs. MCS
- BF Goodrich g-Force Sports for $57
- Brake pad problem
- 15" OZ Superleggeras anyone have them?
- Run-flat installation equipment
- Slow leak on a run-flat, what next?
- Thoughts on possible 17" Enkei RS6 Purchase
- Anybody heard of Barum Bravuris tires?
- Brake opinion
- Which one? 16" wheels
- stock runflats and price
- No spare tire?? Hmm...
- Bronze wheels on DS/W?
- Another tire/wheel fitment question
- Pics of my new wheels: ASA JS1 w 225/45 17s
- OEM size two piece rotors?
- tire edge turning blue..
- where to get 16x6.5 wheels?
- 5lug conversion
- disc brake warning light
- langoliers hit MD roads, wheel busted, help?
- New standard 5spokes on MC
- 18x8 Wheels on MCS
- Where to buy RO_JA RT5?
- Runflat tire integrity?
- Noob Question - no runflats, what do you do?
- New forged wheel for the MINI
- 15" Delta-Spoke Wheels.
- Tire Size Change
- Scrub Radius
- Non run flat 16"
- Painting wheels
- JCW Wheels
- Torque Settings For Lug Nuts
- what do you think of 19" wheels
- New Tires Already???
- Changing to NON Runflats
- Goodyear F-1s, Two Thuumbs Up !!
- wheel help! enkei team dynamics?
- Bridgestone RE050A
- 15 vs 16 vs 17?
- What size track tire for 15x7 wheels?
- Nexo wheel and Exel wheel weights?
- Newb question... front, rear, or both brake pads and rotors
- whatever happened to R82
- JCW Brake Kit Installed Pricing, fair or not??
- Winter Tires for Cooper S
- ET on stock S-lites?
- 17" x 7.5" et38?
- Floating rotors, who's got em?
- Performance wheels, Larger or Smaller?
- question for alex
- Ever dented a 16" SSR comp. wheel?
- Tires for MC Straight
- WTB: Set of Holeys or 16" S-Lites
- Bridge Spoke's weight
- DS/B with Anthracite R-90's - Searched, No luck.
- New tires steering problem
- How To Fix Run Flats?
- Tire pressure and rotation
- new wheels
- White Wheels - exactly which white are they?
- 2002 Mini Cooper S Brake Pad Replacement. Need help!!
- Anyone Else w/Kosei K1 TS?
- Conti tire kit
- Asa Ar1
- 15" SSR Comp Pics?
- new setup!
- Tire Size Suggestions
- Unpadded jack and stands with the MINI?
- 16" dark wheels
- New JCW 18"
- Wilwood 11.75 kit and stock 15" wheels
- Yoko ES-100's
- Aluminum Lug Nuts
- Anyone done business with Wheelmax.com?
- FULL Review: Bridgestone POTENZA RE750
- 15 Holeys will they mount on an S?
- Exel TZ-16
- Stupid 17" question... Will they mount no problem?
- HP Racing Evo's??
- Brake/clutch bleeding??
- New Proxes 4 @ 215 45 17 and rubbing issues
- Opinions on Axis Wheels?
- Dezent Wheels
- offset
- Yokohama Advan Neova AD07- stellar tests!!
- Winter wheel options need help!
- Upper Brake light stays lit.
- correct psi
- Are Flik wheels good?
- ceramic disc brakes
- the abs and big brake kits
- Part 5 : Pilot HX MXM4
- Part 4 :Advan Neova AD07
- How long would the 11.75 race kit last unmaintained in winter?
- What tire brand do you like best and Why?
- Cooper Tires
- I know this is a tire rack sponsered thread, but...
- JCW Suspension questions.. Can I choose which springs?
- Wilwood BBK, post your kits and specs!
- RunFlats Are JUNK
- Brake Master/Hydrovac Repair Kit
- Question about offset
- Best JCW brake kit price?
- How much to professionally powdercoat silver R83 wheels?
- New tires coming soon -- what's the best size?
- PowderCoating lug nuts???
- Finally made the switch...no more runflats!!
- Wheel size/tire advice
- 3 choices..which would you choose?
- Wheel weight info...
- anyone ever get their tires mounted at Walmart
- Tire dumb person with a question
- 15 and 16 inch steelies
- Goodyear F1 GS-D3 Question
- Wheel locks: why bother?
- ABS fuse location?
- Weird Vibration. Not sure if tire related. Help please.
- need quick help? Will these rub?
- 15s ok for street on an S ????
- Miata Minilites,will they work on a MINI?
- AutoX wheel/tire decision advice request
- any experience with motoforge wheels
- Has anyone noticed the Dinan Brake Kit?
- Axis Seven Mods Anyone?
- New shoes put on at Hot Import Daze
- R81 Holeys: A Tribute.
- Pagid Pads destroyed in one session?
- Do 16" SSR Comps work with JCW brakes?
- Vibration with new tires and wheels
- auto cross set up wheels and Hoosiers
- Rear caliper threads stripped
- Need input, I'm totally wheel ignorant!
- Kismet coincidence: New wheels
- 16" Bridge Spokes
- Pro 17in S-Lite people
- Runflat to regular tire question- same width???
- Will it fit?
- run or non-runflats again...
- Changing brake hoses
- Considering new wheels and tires...
- Looking for photos with HB or IB/B car
- Anyone running 20's yet??
- Cross drilled rotor choices
- Kumho MX vs. BFG g-Force KDW-2?
- Wheelmax Tuner Spline Key
- Picts needed of Rota Battles on your MINI
- What Tire is Best?
- Was it extortion???
- 17" BBS RG-R centering ring question
- TeamDynamics PR1 vs Exel TZ 10
- Front or Back?
- New 16 in. replacement tire options!
- Hawk Brake Pads
- Sumitomo HTR Z as track day tire?
- What is the weight on Nexo wheels??
- 205/40/17 tires and M7 springs
- Did I boil my brake fluid?
- If not tire noise, what?
- R98 Web Spoke Wheel Problem
- Aftermarket Holies
- MCS Track Wheels
- Need 17x8.5 or 9" wheels!
- P# for Hawk Blue stock caliper fitment?
- Rotor Torx Bolt/Screw Thingie...
- Brake suggestions
- Wax for wheels?
- TDR Pro Race 1's
- Opinions and Will It Fit
- 15 16 or 17?? pros-cons....and tire suggestions
- My hub caps fell off.
- Tire size & ride quality
- heeeelp BIG BREAK KIT trouble!!!
- Dunlop DZ02G
- Kosei K1 Racing Center Cap Solution
- reproduction 60's style Mini wheel for BINI??
- What is the best brake/BBK upgrade??
- Tires!!
- Yokahama Avid H4S ?
- Best Tires Under $100...
- Runflats on aftermarket rims???
- Any rules to predict possibility of rubbing?
- Less than 48 hours on S-Lites, here is what is new
- Potential wheel/tire purchase- need advice
- mount & balance Qs.
- Recommendation on budget 16 inch tires?
- New wheels on the car...yay!
- BBS RX on Ebay
- Average wear of factory runflats
- Mounting Directional Tires The Wrong Way?
- Alignment Feedback Please
- Anyone put 15 inch rims & tires on a MCS for comfort?
- BBK and 15" wheels for autoX only
- Tire Pressure
- Tires wearing to quickly for my wallet....
- Stupid Balancing Question
- Rotas and Willwoods
- My wheels are on the way
- Pics of Silver Superleggeras on DS MCS?
- Wed Sport TC005 question
- Sendel S70 15x7 - fit or not?
- Cost To Powder Coat Wheels?
- My new shoes....RGII
- Finally decided on wheels..being installed tomorrow...
