- Rota MC Picture Thread
- Brembo GT replacement rotors?
- Value of Mini Webspoke 2 tone OEM wheels & Tires
- Looking for Lugnuts
- Vibration problems when I brake at high speed
- Momo winter 2 wheels
- Which ride softer? Springs or Coils?
- Wheels for AutoX setup?
- Would 17x8 front and 17x9 rear offset 22 work?
- 2-piece rotor options for R56 JCW
- Will these fit my R50?
- Brake upgrade recommendations.....
- Buying 2008 MCS - which tires to look for?
- Wheel/Tire fitment
- MCCS NM Springs Tire Help Needed
- 17" run flat for sale
- Shipping Tires and whees
- Rota Slipstream...
- Uniroyal Tiger Paw GTZ Anyone?
- What is the best wheel/tire size for the best milage
- Just install my Pilot Super Sport... mini review
- any good non directional tires?
- Old Continental Premium Contact 2 in back new Dunlop SP Sport 01 B in front?
- Non-TPMS Wheels on my '08 MC?
- Light weight wheels and daily driving
- Dunlop Direzza Z1 Star Spec
- NM Performance Rotor
- Just did my Brakes!! and i m loving it...
- Continental Premium Contact 2 vs Continental Pro Contact
- Tire/wheel replacement
- 3mm Spacer for R56
- 205/45/17 on 17x7.5 wheels
- Tire Advise
- Tires & wheels
- Rim Swap?
- Replacement For MINI R112 Wheels...
- Tires are wasted after 23K! How is Sears for tires
- ContiComfortKit and TPMS.
- Can You Polish the Outer Lip on Web Spokes
- Need a clear answer about S-lites on 2010 convert
- About to purchase... Input welcome!
- which wheels?
- 16" or 17" wheels
- Feedback on new General G-Max AS-03?
- Tire & wheel size fitment with jcw springs on 06 MCS
- would 215/45/17 fit on the R90s?
- After market wheels/offset/ 2nd gen/15 inch
- What PSI
- wheel size/clearance question
- Is the 2007+ TPMS model-year specific?
- 17x8 et 38 mm with 235/40/17?
- the best looking tyre for minis
- Well, now I did it...new shoes....
- HELP ME: Would these fit 17x7 38 mm offset?
- 17" Conical Spoke OE Wheels - How Heavy
- Wheel Insurance?
- Just installed JCW Drilled Rotors
- Falken 912
- Question on Wheel Fitment
- New tire advice
- Steering wheel shimmy/shake woes.
- Brakes: possible problem
- JCW brakes uneven sweep
- Are these OEM replica wheels to be trusted?
- New Tires Installed and ready for the trip to Fontana!
- Bridgestone RE-11 Tire size
- 225/45/17 too big?
- bbs rs for my 07 mcs laser blue I jus dnt noe wat size to get help
- rear brake calipers on Cooper with 100k+ miles
- Need an opinion on new summer tires
- Armor All wheel protectant
- Expected mileage from Dunlop Starspecs?
- Brakes question.
- TPMS light
- BBS centercaps for R98 Web Spoke?
- Carbotech full ceramic or has metal?
- MD Tires For Life Lawsuit
- Rim options
- Question about Mini Dealership Wheel Allignment
- Will these fit.. or what is it going to take to make it fit?
- H&R Sport springs/ 15mm wheels spacers?
- need some sage like advice ASAP
- Wheels and tires question
- Wheel/offsets for 2011 Mini?
- runflat tires on countryman
- Whic Autocross Tires for me?
- Question on R56 Brembo-style brake conversion (wear sensors)
- Confused about tires
- Lug Bolt Question! Please Help
- Rims?
- Brake issues
- who's running rotas, and how do you like them?
- Anyone make a conversion hose?
- Going from 16"'s to 17"'s
- 16 vs 17 Wheels
- When do you replace your brakes?
- Front brake pads
- New tires?
- Removing small scratches in ASA rim?
- Tires recommendation - Continental or Kumho???
- ALEX! - When are the Countryman S wheel fitments coming to your website?
- potential OEM wheel sale:
- offset question:
- offset question:
- MiPG change after dropping Run-flats
- Those of you who made the switch to conventional tires - how do you deal?
- SSR COMP Type C
- brake question
- 225 width Star Specs on OEM wheel?
- Recommend 175/65/15 tires or maybe 185s?
- half way rid of runflats...
- Blue & gold?
- Wheel Adapters
- R56 race pads
- Front RIM Wont come off!! PLease advise
- 215/45 or 215/40 ???
- Tire rubbing??
- Help! Vibration normal???
- 17x7.5 35mm?
- Painting stock r98's. What do you think?
- Venting a little: second Low Pressure warning in 2 days.
- 2011 TPMS won't fit new R90 wheels
- flat lead to a dead TPMS.. grumble
- Rear Brakes Pad Problems
- 2007+ Cooper S Brake Rotors?
- Please ansewr my stupid question
- Anyone running Konig Foils? If so, what tires?
- Lug Bolt Torque
- R53 TPMS questions
- Rim balance weight was missing with piece of rim it was attached to
- Sawblade Fitment Help
- Recommened tire pressure on 18's
- VW -Golf/New Beetle Wheels -17 inch
- EBC pads Red Vs Green
- Need recommendations...
- my new wheels
- Stud Conversion Issues
- 17x7.5 et38 all around?
- Please Give Feedback On 205-40-17 On Your Mini
- P185/55R15 Tire size
- Tires: Continental DW vs Bridgestone 760 sport
- Yokohama S Drive vs Hankook Evo V12
- Yokohama S.Drive vs. Avid ENVigor
- R56 Brakes and the R53
- Cast or Billet Wheels
- to rotate or not to rotate?
- How I Painted My Wheels On The Cheap (DIY)
- I want lighter wheels (and can you help me with therie weights?)!
- 17x8.5 et30?
- What to do? LOW TIRE
- Remember me - the one whose friends/family complained about the rough ride?
- best summer tire
- Runflat replacements
- TPMS Fault code - Gen 2
- R53 stock suspension, 15X8+36, & 225/45/15s
- Wheel Bolts for Aftermarket wheels??
- wheel and spring question
- My friends won't ride with me!
- What rims are these?
- New rotors and pads, dragging very slightly
- Ordering Wheels
- 17" Web Spoke Rim with Red Calipers
- What to do w/RF after replacing them?
- G2 Caliper Paint Thoughts
- What is the best wheel/tire size for STX Autocross
- 17x7 with 40mm offset and 215/45-17 - will it fit?
- Choosing Rear Brake pads (With Sensor)
- Conti DW's vs. RE760's vs. Other
- Alignment Before or After New Tires--Does it Matter?
- download a photo of your car and stick on some Rotas
- JCW R105 wheels
- Replacement Tires
- R102-16 S Winder Wheels & Tires
- Wheel Alignment
- Rib spoke, 4-hole spoke and 6-star spoke weights
- Tire Recommendations--Your Favs?
- wheel offset question! please help
- Pics. of your lowered MINI with factory wheels
- Ordered my wheels!
- SSR Type-C 17x7.5 requiring stud conversion on R53?!
- Hi all
- Borbet Type A
- Brake Dust!!!
- 235/40R17 on 17x7.5 et40? Trim fender?
- Updated my center caps
- Pictures of Motegi Tracklites on R55/R56?
- Switching from Run Flats to Non-Run Flats
- Run flat light again
- Brake pad wear and tear!
- 15x8 ET25?
- OZ Ultraleggeras with JCW BBK?
- Anoying light GRRRRR
- First Brake Service at 45K for my 07 MCS
- Repairing a bent wheel
- OZ Ultraleggers (17x7 40mm offset) on 2009 JCW Clubman
- Autocross Tire/Wheels
- 17" Wheel & Tires for under $600 ???
- OEM Tires with Winter Option
- ? about rims
- JCW 56 Brembos on my R53 feel like Mush!
- drag strip tire pressure and information needed
- Weight and Speed Ratings
- R112 JCW Challenge Wheel
- Ugly lift point blocks
- Volk TE37V 16x7.5 et25, will it fit?
- Tire laws in the USA/Canada
- Buying valve stems only
- Rear Caliper Bolt Size?
- new MINI owner - need tire suggestions
- R112 Challenge Wheel Pricing???
- Feedback: Bridgestone Potenza RE960AS
- 2005 MCS Factory Wheel Sizes
- Does anyone NOT run TPMS?
- Hamann Hm4's Used How much would you pay?
- Brembo GT fit on R113?
- R56 lug bolt
- Best off sets for 17" aftermarket wheels
- Wheel & tire/Size help
- 2003 - 2007 wheels/rims interchangable?
- fighting with front tires?
- Tuner Lug/Lug Nut Help!!?!?!
- Wheel Spacer
- Goodbye Run Flats
- Run Flats saved me today...
- Ne help 215/45/17
- Found my wheels, 17X9! Rotas in bronze
- 18x8 Rotas And Coilovers?
- Track day tires and brake pads, fronts only?
- Trying to break the 15" barrier
- SS Brake Line Suggestions...
- Rear tire feathering
- 05 s 17" rim question
- What brakes to buy
- Re-barrel 3 piece wheels
- Need Offset Verification
- Best options for High Performance All-season?
- BBS RX wheels
- Rusty Lug Bolts - Replace ?
- Tire Width Options?
- 17x8 or 8.5 gold rims
- Hankook Ventus V12?
- Center Caps all the same?
- 1000 Miles to Front Brake Pads @ 36k miles
- Bf goodrich tires
- Dunlop Direzza dz101 with Kosei's fitment question
- General Exclaim, Nitto NeoGen, Fuzion ZRI
- alignment time
- OE Tire Size Sticker?
- Thoughts on wheels??
- R53 vs. R56 MCS wheel compatibility
