- Brembo setup.....rear rotors and pads suggestions?
- will the wheel bolts fit?
- OZ Superleggeras or TDR PR1's?
- Pirelli PZero Nero M&S 215/35/18
- tire trouble
- I miss my P Zero Nero 91Ys
- 195/55/16 options... seem limited at best?
- 205/45/16 vs. 205/50/15 - advice?
- 18s!
- H sport Strut Tower Brace blowout!
- Sizing Question
- Most aggresive offset?
- Steering Stop Retrofit Kit for 18's
- Very noisy tires...
- Good deal on BBKs?
- Unmounting Runflats... does it ruin them?
- Factory brake fluid
- R98 Webspokes Clicking
- 17s w/run flats = 18s with normal tires?
- Rear brake piston retractor tool?
- 1st set of new tires.
- Keskin KT4
- New Wheels/Tires
- Bbs Rz
- Couple BBK questions...
- DBA Rotors?
- anyone running Konig Tuner2 wheels?
- Offset for Volk TE37 15x7
- Tire calculator
- Finally rid of runflats!
- Brake fluid replacement and ABS
- Soft tuner bolt?
- Strust sticker rubbing against tire...
- Help on type of bolt
- Goodyear Eagle F1 GS D3 215/35/18
- Toyo Proxes 4 vs. Pirelli P-Zero Nero M+S
- Brake ?'s
- John Cooper Works R105 18" Wheels
- Batmini + pypz mounted.
- Notched, Performance Brake Pad, Who Makes It?
- Black wheels on EB/W
- Cleaning a "Mesh" Wheel (R90, ASA AR1)
- Voxx Scorze
- Wheels and tires for street and track - research yeilds more confusion
- Speed Rating WR vs. ZR
- Konig Sideways or Trouble?
- My Rims are finally in! Check em out!
- Aftermarket Hub-Centric Rims?
- Red and White MCS with Black wheels?
- Work XD9....*drool*
- OEM width and offset of R98s???
- Different Wheels
- Painting Tire Letters?
- Going from S-Lites to 205/50-16.. What to expect?
- Best Runflat performance rain only no snow tires
- Volk GT-N Gunmetal on BLK Mini?
- Rotors and Pads Bed/Break In Procedure
- 15x8 +40 12.8lbs
- Mini Meets Dinan Article
- limited time offer OZ FORGIATA
- Looking to buy rims and tires.....
- spare BMP stud for lug nut?
- 17x8 +48 offset too high?
- Ready to rally to AMVIV!!!
- Goodyear Eagle F1 GS-D3 or Toyo TR1's informed opinions?
- How do wear-bars work?
- Going from run flats to regular tires
- Wheel hunt: ASA AR1 (BBS Mesh Stlye) vs. Rota Grid (Volk TE-37 Knock offs)...
- 225/50 on 16?
- RP: Tires, service, and such
- KEI Racing wheels???
- Nitto NT-01s
- What offset for TD PR1.2s in 17x7.5
- Looking for different wheel center caps... Have a question...
- Tire Rotation per mile
- Not for Everyone
- HB/W Owners, let see your wheels!
- SSR Comp Anthricite 17's
- Awesome Wheel Gallery
- Jack stands... from the top
- PIAA Sport Mesh wheels
- Recommended and maximum tire size per rim
- a new look
- Help? New tire time.
- Concerned about load bearing
- R6 - a brand new Hoosier is on the way!
- When to switch back to summer tires
- Tire "Shelf Life" ?
- Brake bleeding
- Runflats on Ultraleggeras?
- all season tires
- Gram Lights, what's the consensus, good, bad or just spendy??
- deepest lip wheels 4 mcs's
- How much brake fluid do i need?
- SSW wheels
- Wheel offset +42 or +48 what would you use?
- Pictures of R86 accessory wheel installed?
- Widest rear tire possible on 17" wheel
- Nokian NRZI...any feedback?
- will these wheels fit?
- wheel identification
- Tire Size For 18s?
- Replacement Tire - Question
- BBS-RGF with H Sport Springs
- EBC Green vs. Hawk HPS vs. Ferrodo DS2500
- which tire size?
- "STEERING ANGLE STOPPER" for 18" rims??
- 16" Panasports and Tire Questions
- Tire warning light. Do I need to get it checked out.
- Wheel/Tire Question
- New JCW R105s and Colour Coded Trim :)
- SS Brake Line "How-to" needed
- Have you had your MINI aligned
- Widest Possible Footprint
- Anyone here running Nitto NT-555s?
- Anyone using stoptech?
- recommendations for new tires and wheels for track useage?
- Anybody running R90 anth. on a HB or Indy
- Stuck Valve Stem Caps!
- Set of 4 Dunlop 205/145/R17 17" Run Flat tires
- Anyone in Boston area running 17" Rota Attack?
- Hole in Run-Flat Sidewall
- recomended pressure for SO3?
- will 15x7 with a 27 offset rub?
- Hankook K104
- Is this a deal or trash?
- TDR Prorace 1
- What would be better for the winter? 18" or 17"
- WRCs at TIRERACK- Alex, a question
- Flik Apex2 on Wilwood 12.16 street kit bbk?
- Good deal if interested
- Best tire size for Xlites
- Factory wheel lock question
- Low Speed Tire Roar
- Need to buy: SSR GT1 18x7.5
- flat tire :(
- Fuzions for sale
- Help Please..SSR GT1---Alex, or anyone
- Whats every1 running for rubber, and conditions??? I need some help...
- ASA EM9's are on the way!!
- What brake fluid comes from the factory?
- 17" Winter Tire (RF and Non-RF)
- offset help
- Hawk HPS or Performance Ceramic
- New shoes in 18" for Spring
- HOW Quickly did you DUMP your All-Seaon tires?
- brake fluid??
- Can you get Binno wheels in the U.S.?
- Gimme a "brake" already!!
- Rota Slipstream 15x7.5, 16x7.5 and 16x8 GROUP - SPECIAL ORDER
- Aftermarket wheels & trade-in question
- Michelin Pilot Exalto A/S, anyone have 'em?
- JDM wheel spacer with centric hub... Interested?
- Axis Decade Wheels
- So now my Mintex Reds are squealing...
- Final Rim/Tire Choice, Fit & Order Questions.
- hubcentric rings - how tight a fit is right?
- Wheels for BRG/w
- Anyone have ASA in 18"? please show pics.
- true polished lip rims anyone?
- 18" Flip Wasp anyone?
- Aluminum Slots and Magnum 500's
- Wheel Pro's only !
- TCE/Wilwood 13" BBK Install
- ssr comps 18's?
- Leaky beads
- Wheels From the Smart Car?
- Steering wheel vibration after changing wheels.
- Proper tire preasure for OEM 15”
- I Have Seen the Light! Went with 17" non R-F
- Snow Tires
- Pirelli P6 Allroad, PLEASE stay away!
- Why do I want to change my 16 Vs for 17 Ss?
- Exel wheels or ACE wheels, anyone?
- S-lites Chili Red? Photshop help !
- Winter Driving and Goodyear F1 GS/D3?
- Breyton Spirit Flat Black w/Pol Stainless Lip
- Are these going to rub?
- ROTA Slipstream - 16x8 - Anyone interested? possibly 15x7.5-8 and 16x7.5 too.
- How much brake fluid......
- Team Dynamics Pro Race 1.2
- Yet another wheel idea.
- I hate 17" Tires & Wheels!
- Ireland Engineering Big Brake Upgrade
- Warping rotors - an extension of a thread in the suspension forum
- 16x8 up front, 16x7 in the back?
- What do you guys think of these...
- Does anyone have these EXACT wheels on their Mini
- Bridgestone S03 or RE050A
- TDR Pr1s and lug bolts.
- Opinions Please 18" wheels
- Vibration on deceleration
- where to buy: '06 JCW GP rims?
- painting
- Team Dynamics Pro Race 1 offset...
- reprogram?
- paging Todd from TCE!!
- New guy here- I need some help...
- Advan Neova in the US?
- New JCW GP rims
- What to do; 205/45/17 or 215/40/17?
- Street Brake Pads, which & where to buy?
- 215 - 40 - 17 tires?
- Zinc Plate Flaking Off Rotor Edge
- nankang Tires
- Today's little project
- Someone ID these wheels please
- Brakes thumping after new tire rack rotors and pads?
- BBS RG-F - opinions, experience, recs.?
- 205/50/16 or 215/50/16?
- New anchors arrived...can't wait to get 'em on...
- Painted webspokes?
- Help - Switch from 17" to 16" on MCS
- brake pads
- 15" Wheels on MCS
- Bridgestone RE050 Potenza Runflats
- Recommended Rota vendors?
- rear wheel bearing replacement cost
- What about spacers?
- Requesting Wheel Recommendations
- Smallest, lightest, widest rims that fit 13.8 Wilwood kit?
- Stick-On vs. Clip-on Wheel Weights
- Help! Deep Scratch On Polished Lip
- Thank you Alex and Tire Rack
- MINI Sqealing Before Brakes applied???
- Tires and Wheels Size Question?
- SSRs
- jcw brakes
- Additional info on the BBS wheel
- who makes the copy of these Weds Sports?
- Nokian WR All Weather Plus 2's
- what wheels are these?
- Will Dealership Mount Non-Runflat?
- Question for Toddtce
- Bronze/Gold Wheel Pics?
- Got my new wheels and tires!
- Read for a laugh... Or a cry...
- can anyone name These wheels
- Name These Wheels
- Name These Wheels
- Yokohama Neova Ad07 235/40/17 Anyone try this yet?
- 18 x 7.5 help
- brake mods - unneccesary?
- are runflats remountable?
- Tire Rotation Question
- Different tires Front and Rear?
- Plug, Patch or just get a new tire?
- Oem 17 S Lite Wheels For 215/45/17 Tires??
- R84 Center Cap Alternatives
- Lug Torque with Anti-Seize?
