- 2010 Clubman replacement tires?
- Need wheel locks for Tenzo Type M Black
- OZ superturismo on chili red convertible. 16 or 17?
- One New 17'' Motegi Spare
- Tires
- problems with changing rim size...
- Just wanted to say Thanks....no more RFTs
- Anyone good with Photoshop?....can someone make my wheels black?
- Noob question about new set of wheel + tire pressure sensors.
- TPMS woes
- JCW Brembo brakes and tire thoughts
- Enkei RPF1 will they fit the R56 JCW Brembo?
- For Sale So Cal - Arcadia
- Conti DWS vs. Yoko AVID ENVigor
- Repeated dismounting/mounting runflats
- r91 wheels on r56?
- Observation of RFs & non-RFs
- Jcw matte black 205/40-18 want a bigger sidewall!
- Runflats or normal tires?
- 2005 Tires
- Brake & pad replacement
- offset37mm with 215-45-17??
- wheel question
- Which tires for the track?
- Need Size Help
- Tire pressure sensors - how do they work?
- Replace wheels, or get bigger/different tires & wheels?
- Show me your 18"+ wheels
- 205/45 or 215/45 Conti DWS?
- HELP! 2009 Clubman (Not an S) Wheel sizes please!
- S light specs
- Wheel question - Hub centric and offset
- Do any members have experience with these R112 knockoffs?
- Anyone with 17x8.5 20 offset?
- can I change my runflats for normal tires?
- 205-45-17 front 215-45-17 rear?
- Why so many people dislike the runfats?
- Bbs reps?
- Tpms
- How much bigger are the StopTech calipers than JCW?
- 225/35-18 vs 215/40-18 on R105s
- Rib spoke question and recommendation
- Clear Coat on Web Spokes
- is there a ss brake line how-to??
- Problems with offset 37mm??
- R90 on the new coupe?
- R1 Concepts Premium Series
- Valve stem cap?
- 2012 Wheel Fit Question
- R60 Winter pkgs.
- 07 MCS Brake fluid replacement
- Request! Spacers, before and after pics please!
- Who has larger brake calipers: Brembo or StopTech?
- Help to choose my tires for my new wheels for my 2006 S
- Air Pressure???
- Any feedback on Sparco wheels??
- 2006 "S" R53 Spare Tire possibility
- Help! with passenger rear brake caliper
- Wheel studs for 2011 Cooper S
- back from the dead
- Most popular black rims for R53?
- 16" chrome wire wheels?
- Wheel Spacers for 2008 MINI-S
- R113 Red Stripe Wheels
- Federal 595 RS-R Tires?
- ?? 16" steel wheels / steelies for R53 ??
- Expensive/Rare Wheel Thread. Let's talk.
- What do I do about hubcentric rings?
- White Wheels! Help!
- Chrome Wheels: Photos please...
- +40mm offset for 20x7.5 rims?
- dumped RFT for Bridgestone Potenza RE760 Sport
- Installing larger wheels?
- Geforce KDW 2 any good?
- Question about wheel diameter...
- Mud Flaps
- Plus Size Rotors for R56?
- Will a 40mm offset 17X7.5 wheel fit a R53?
- Tire size for R58.
- Winter Tires?
- Need new tires
- TPMS and Wheel Studs
- R57 JCW bike rack?
- My recent tire fiasco...
- Tire questions...
- tire pressure monitor light on after rotation
- What tires do you use for YOUR MINI?
- Helllpppp
- JCW Front pads are same size as Clubman S ???
- "Illegal" to replace non-run-flats?!
- BBS RGR 18" fit on clubman S? Tirerack only shows 17" option?
- 2012 MCS sport package wheels
- 2012 Mini Cooper S - pot hole friendly rims and tires
- Looking for advice on tire replacement please
- Stripped security lug bolt. Help!
- What can I sell new RF Perellis for?
- Making silver wheels black
- Quad Threat Tire Match....
- How careful do you have to be with 16 lbs wheels?
- Removing over-torqued lug bolt
- wheel sizing/offset for r53..what fits?
- Show me ur WHITE wheels. please!
- Best Run Flat's For 2009 Mini Cooper-S?
- 5mm spacers
- Can someone please be clear with the R56 to R53 wheel fitment for me?
- Stupid brake question
- Latest Dealer Tire BS - Grrrrrrrrr
- Where is the TPMS Receiver Module?
- Tire Replacement in Philly area - HELP!
- Miata fitment wheels on R56 Mini
- single 03 8 spoke rim needed
- H or V rating
- 205/50R17 on S Lites
- Run flat issue
- 2008 R56, what size 18" tires?
- Will 18x8 +35 work on R53?
- Anyone Go With A Higher Profile Tire When Replacing Run Flats???
- help!! lug bolts too big! (first post)
- New EBC Brakes!
- new brake pads and rotors rub? 2007 MC, R56
- Akebono Euro Pads Don't Fit my '08 Mini
- Help on Wheel and Tire size
- Mini Approved Tires
- Odd Tire Wear
- wheels
- Leased Mini Brake work
- Tire advice - R105 on JCW Clubman with 5mm spacers
- winter tire use on stock wheels
- anyone using 15" Wheels on there MINI Cooper-S ??
- Slicks on stock differential
- With new wheels, come new questions...
- Need recommendation on pads for StopTech rotors...
- BBS RG-F or Volk Racing RE30?
- R56 OEM run flats vs board with nails on freeway
- Mini Wheel Centers with Mini Wings
- R56 tire recommendaion
- Quick tire question - Help
- Pulse while braking at certain speeds - where to start
- Grey or Black wheels for an AstroBlack R56?
- Why keep my stock rims?
- Want to buy Breyton GTS-R's
- E-brake not working
- Help! I want to get rid of my run flats
- Lub Nuts
- Kumho Ecsta LE Sport
- R98 wheel fit question
- Ate R56 rotors?!
- Von Max VM!
- Best tire/wheel for long distance motoring
- Stopping From 200MPH
- snow tire question
- Anyone have this combo?
- Tire Pressure recommendation?
- Pepper white with these rims?
- Question regarding powdercoating aftermarket calipers...
- Tire Recommendations for R56 - 17" Wheels
- HELP! urgently looking for new set of 17" Wheels & Tires
- 18x7 Rims?
- Tire crazy!! Bbs rs
- Hankook V12 Vs. Bridgestone Re760
- How will it look?
- changing rotors
- Pic Request! Pepper White with Gold
- Dark Silver Clubman S.. Black or Silver rims
- What are these OEM wheels called? Value?
- BBS LM Replica question
- Will 15" stock wheels replace 16s?
- 50mm sidewalls on a 17" rim?
- Getting rid of run flats ordered Michelins
- Continental 2008 tires
- Would 16x7+33 16x8+33 fit R56 MCS?
- Run-flats on 17" vs. Non-run-flats on 15"...that much difference?
- Rotors worn before pads...why?
- Rotors worn out before pads...what gives?
- bent rims
- Car lost power.
- Rota Slip Stream 16x6.5 Tires
- What is up with Hawk HPS pads on the MINI?
- Love my new (to me!) wheels
- Manual Transmission folks - Heads up!
- Need some advice.
- Wanting black wheels 205/40/18...
- 215s R-comp tires for the track. will it rub?
- white wheels
- Rims on Pure silver MCS
- Wheels - Enkei vs Kazera
- Looking for members with OZ Superturismo GT
- Lug Bolt Cover Caps - M14 Head
- Nitrogen in run flats
- What wheels are these?
- Wheel Hub/Speed Sensor Question
- i cant decide
- 2009 MC tires - dealer or discount tire or sams club
- Rear tire wear
- Should I sell my stock rims?
- R53 to R56 Brembo BBK Conversion - NEED HELP!
- KONIG FEATHERS or SANREMOCORSE STREET 17"??!
- New rims/tires - suggestions
- Quick! Need Tire Advice - Potenza vs. Pilot Sport
- Do I NEED run flats?
- Drag Dr44's on a Mini?
- AXIS OG 15x8 on R53 Blue JCW
- Question about Hankook tires
- Snow tires, or get an SUV?
- 225/50R16 on a 2011 MCS - who's dunnit?
- Brake Pads - Best Ones?
- A MAJOR shout out for Todd/TCE
- TD ProRace 1.2 Silver Lip Pics anyone?
- help me find these wheels for minnieme
- 16" 5 spoke blaster et48 on Mach V
- Would 17x7 +50 wheels work for R56 MCS?
- 18's vs 17's
- Tire Pressure
- How often do the lower wishbones go out on the mini?
- Possible to swap TPMS from 15s to 16s?
- pick my tires for me.
- 5zigen GN+ Questions
- Wheel selection, I have a headache.
- Redline Brakes
- Question about BRAKE
- Bent rim: now what?
- Autocross stree tire life cycle
- my new rims
- 17" oem wheels on 2011 justa mini?
- Tires from Detailer's Domain
- spacer size for 949 racing 15x9 in the rear?
- Which Wheels?
- TPMS and aftermarket wheels
- falken azenis rt-615?
- My new Hankook Ventus V12 tires
- Buying Ferodo Brake Pads
- Front Brake Pad Change a Cinch
- Happiest day of MINI ownership = the day I kissed my run flats goodbye!
- Just my imagination, or are 225/50-16 tires a total fail?
- Want to upgrade the 195/55/16 run flats
- Wheel Torque Spec
- Are the alignment specs for the R53 and R56 the same?
- Has anyone ever ordered anything from machiii.net?
- Pressures and Rotation
- Can it be done?
- Pricing on R98's whats fair?
- Hard Brake Line.. where to get/part no/etc...
- Generally speaking, best MPG wheel size (and tire recommendation)?
- My first Mini...need front brakes repair
- Sparco wheels
- Slight pedal / steering pulsation on braking - replace only front rotors?
- BMW Tire Totes
- R56 wheel fit question
- Pictures of 205/55/15 Tires on stock 5.5" Spooler Wheels
