View Full Version : Tires, Wheels, & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42
  1. MINI Wheel Info / Pics?
  2. Help needed in figuring out tire size
  3. Need Some Advise On Wheel Mods
  4. Winter Set -- new wheels, new TPMS?
  5. Virtually Eliminate the Brake Dust on your Wheels
  6. Compare These Tire+Wheel Combos
  7. G-1 & G-2 interchangeable???
  8. 225/35 18?
  9. Wheel decisions!
  10. Just got new wheels for my MINI... Pics!
  11. Experiences with BFG g-Force T/A KDWs?
  12. Need brake kit suggestions
  13. Experiences with Pirelli PZero Nero M&S?
  14. Best size tire for a 16 inch rim?
  15. Konig BriteLite Silver?
  16. Tire suggestions?
  17. Exposed Axle?
  18. 1st Set of Snow Tires
  19. REQ: White brake calipers???
  20. 8j 18' offset 35
  21. What is the name of this rim?
  22. Michelin Exalto question
  23. Queston for experts Dunlop DSST
  24. Pro-rated RunFlats?
  25. Kumho Ecsta MX or Ecsta SPT
  26. Tires for Quiet Comfort on 16x7 wheels
  27. Is there a way to solve tires rubbing issues?
  28. M7 rotors
  29. should i get wheel spacers ?
  30. How do you know when your tires are worn out?
  31. SS brake hose help
  32. Rota 16x8 +48 offset
  33. Got my WHEELSSS!!
  34. HANDLING: 16" Bridge Spokes vs. 17" Crown Spokes
  35. Best tires to replace the stock runflats
  36. Turn rotors or new?
  37. Contemplating winter tires/wheels for 07 Cooper
  38. Best price for NEW R85 Wheels?
  39. Falken Ziex ze912 912 Experiences
  40. What's it take for a DIY brake upgrade?
  41. Drag DR-19
  42. ASA AR1 Anthracite
  43. What a difference metal hubcentric rings make
  44. Tire wear and tire pressure
  45. Tire noise
  46. hub centric rings stuck on hub
  47. TSW ROTORS NEED INPUTS ASAP
  48. 225 fit non-sport MCS '07?!
  49. All-seasons that can take autox abuse
  50. 17x7 RIMS offset 37mm, what tires size will you choose?
  51. 205-215 or 225 ???
  52. Diamond Black diamond Coating?
  53. Two piece Wheels
  54. Hawk Performance Brake Pads for R56
  55. Summer tires - a few questions
  56. Summer vs. All-season Tires
  57. Replacement tire suggestions?
  58. 17" lites on a standard Mini
  59. MINI w/wide white walls!
  60. Continental ContiProContact SSR?
  61. Cracked Rotors?
  62. Question about replacing one tire
  63. Tire advice needed
  64. Moss High Performance brake kit
  65. Will the new tire pressure sensor fit on S-Lite wheels?
  66. I need everyone's opinions PUHHLLEASSSSEEEE
  67. New Tires: Nokian V
  68. Bridgestone RE960AS Pole Position Tires
  69. MINI 17" Webspokes, how much $$ for them?
  70. looking for advice on tires
  71. Not to happy with Motegi. . .
  72. Newbie needs tire/rim help
  73. R90 Lug nut covers
  74. How well does the MINI brake?
  75. volks te37 question
  76. 205/50-15 wheels installed
  77. painting S-lites, or powdercoat?
  78. New BBS center cap tool from BBS Japan
  79. Advice for 17" winter run flats w/ wheel
  80. Tips for maintenance while the wheel is off
  81. R56 lug nut torque
  82. ATE Products
  83. Black wheels for 2005 MCSCa BRG
  84. The tire tragedy continues
  85. What options for late 2006 MCS for Steelies?
  86. Winter Wheels
  87. Feedback wanted: Flat black, bronze, or graphite for 15" winter wheels on PW/B
  88. Hawk Ceramic
  89. New tire pressure monitoring system
  90. Been looking for wheels for the past 3 months... HELP!!
  91. Cryogenic Treating of rotors worth the $$$?
  92. WHEEL SHAKE?
  93. Rota RB's now available in 17"
  94. Should I Get 17" Web-Spoke Wheels?
  95. New R90 Cross Spoke Delicious!
  96. new black s-lite thread, repainting them
  97. Rough Ride
  98. Big Brake Kit that fits 17" web spoke wheels
  99. 15" Rim Question
  100. Holey's on an R56?
  101. 18x8.5 - Need Help. Anyone Done It?
  102. Run Flats...hit me in the pocket...!
  103. So what if the wheels are heavy....
  104. Stainless steel brake lines for JCW brakes?
  105. rubbing with 205/50R16 tires
  106. JCW carbotech brake pads... available.
  107. Mystery wheels
  108. tires rubbing?
  109. need your opinions
  110. 17" webspoke Runflat Winter replacement?
  111. Best tires on the front or on the rear?
  112. Has anybody ever run these tires?
  113. Ultraleggera 17" rims need wheel centre cones - what size?
  114. Stop Tech DD Pads
  115. Do 16 " ASA AR1 wheels fit MCS ?
  116. What to do road hazard or order
  117. Recommendations for Non Run Flats for a stock
  118. BBS LM reps that FIT
  119. Non runflats and slime
  120. TSW brake kit
  121. Combination runflats and non-runflats
  122. Lower weight 'S' lites
  123. Tire width vs. gas mileage
  124. ISO: 205/45R-17 tires
  125. Getting new wheels_How much to ask for my old ones?
  126. 15x8 with +15 offset
  127. Anyone using Konig Supermesh?
  128. Need help with wheel weight
  129. OZ 35th Anniversary Wheels
  130. BMW CSL wheels for MINI GB (again)
  131. Hankook Ventus V4 Es H105 vs Kumho Ecsta SPT
  132. Will stoptech bbk fit with stock 17"s?
  133. question- changing bolt pattern plates
  134. Wheel/Tire sizing question - I'm lost
  135. 17x7.5 (37mm Offset)??
  136. Motegi vs. TR Motorsport Any Fittment Issues
  137. Factory tire brand
  138. New Tire Pressure Valve Cap Gauge
  139. Crown Spoke wheel cover
  140. Runflat--Repair
  141. Anyone know where to get OZ Superleggeras 18's?
  142. Tire question
  143. Wheel Help - R53
  144. How long will tires last in storage
  145. BBS center cap tool
  146. Does weight really matter?
  147. Will 225/35-18 fit on a 18x7.5 whell on an R56?
  148. Q: How should I rotate and which should I swap.
  149. 15" HP Summer Tire Recommendation
  150. High performance street tire recommendation
  151. Momo Corse RPM
  152. Lower Offset Drive Feel Difference
  153. New Tires for Fall-Feedback Wanted
  154. New tires and wheels
  155. got my new tires on :)
  156. MISSING MY RUNFLATS???
  157. Solid vs Cross drilled vs Slotted
  158. Running Nitrogen in your tires.
  159. street set up question. 17" on stock suspension or 16' on coilovers
  160. Anyone use the Pirelli Euforia tires in winter?
  161. Tire comfort
  162. R90 Replicas?
  163. Conticomfortkit
  164. snow tire size
  165. Winter Tires
  166. hubcentric-vs-wheelcentric
  167. 17" Runflats, what tire pressure???
  168. anyone got SSR Type-X?
  169. Track Wheel/Tire combo
  170. Lug stud/nut conversion for R56
  171. Cooper Weather Master S/T Tires
  172. My new bling.. Polished factory wheels!
  173. What tires do I need and can I get them at Costco?
  174. Hankook Ventus R-S2 or Falken Azenis RT-615
  175. Eibach Pro Street Coilovers ??
  176. miniviper
  177. What is "8J" width on a 17" wheel?
  178. Direct TPMS for week32+ (september delivery) cars?
  179. Wheel 16x7 Offset 45 Thread size 12.5 X 1.5 Will this work?
  180. Tire Rub on JCW with 215's
  181. speed ratings
  182. Help with pads
  183. Tires for Life Program
  184. Suggestions - Please!
  185. Goodyear GS-D3 country of origin
  186. wheel lug nuts
  187. 15" Rota on 07 MCS
  188. show your wheel spacer pics
  189. Everyone uses runflat tire?
  190. survey: do you buy road hazard coverage?
  191. Anyone Use Leak Lava?
  192. Rota Sub-Zero - steel gray?
  193. Poll: SSR Comp Color
  194. 16" tires with aero kit?
  195. Tire Bulges
  196. Input requested on wheel choices...
  197. Anyone have pics of Nex-o TS-8 wheels on their MINI
  198. Photoshop request
  199. Who is riding on these wheels TSW catalunya
  200. 18" Arceo Alpine Stars, Dare X4
  201. Does anyone think these would look ok?
  202. Ultra High Performance All-Season <$100
  203. How important is the load rating of tires?
  204. Does R56 MCS need brake upgrades?
  205. Kumho SPT's
  206. Sidewall height question
  207. Calculating necessary wider wheel offset with same width tires
  208. R95 wheels in black?
  209. 15" aftermarket wheels on a MINI
  210. any black rim/tire deals going on? do 215's fit?
  211. Lug studs
  212. GP wheel replicas
  213. Willwood Brake Calipers
  214. GP wheels on PW
  215. MOTEGI TRACK TRAKLITE
  216. ecsta SPT vs AST
  217. Another brake question...
  218. R56S Brake Clearence
  219. Tire size vs. odometer
  220. Anybody have experience with these 2 tires?
  221. R84s: Does model yr. affect wheel color?
  222. Where to Buy Metallic Centering Rings
  223. Road Force Balancing
  224. Diff between '06 and '07 brake pads?
  225. Dustless Brake Pads...
  226. help? Brake pad light just turn on
  227. Lightweight Wheels?
  228. run-flats vs. non run-flats
  229. Softest ride on 18's
  230. Help With Fitment, Please.
  231. Experience w/215x40-18 NonRF?
  232. 17x7 or 17x7.5?
  233. Stoptech 02 kit install on 06 mcs
  234. Flat tire Slime
  235. 225/50-16's on Stock Mini
  236. Sportec Look-a-likes?
  237. performance question for you lightweight wheel gurus
  238. Volk GT7 18x7.5 WEIGHT?
  239. Which Tires Have Better Dry Handling....vs
  240. Tires help
  241. Goodyear Eagle F-1 All Season
  242. Wheel fitment
  243. BFGoodrich g-Force R1. Who has tried them?
  244. Proper R-Compound Rotation?
  245. New tires advice----please
  246. Adjustments when changing wheel diameter sizes?
  247. Pros/Cons-Replace front pads only
  248. Pics of wheels with dark centers / polished lip on a MINI with white roof?
  249. Can someone confirm?
  250. I love the way these wheels look but...
