- The Complete & Utter Failure of an ASA AR1
- M7 Strut Reinforcement plates or STB?
- Wheel size questions
- probably been asked already but
- Quality Centering Rings
- pics request for konig imagines
- Tire Suggestions?
- Does anybody else notice this?
- what happened to the wheel website sticky...?
- Time for new tires...Yokohama S.Drive VS. Toyo T1R.
- Rainy Track Day - Adjust tire pressure?
- Confirm torque spec on brake caliper bolts?
- Big Mistake: shopping at wheelsnext.com
- Champiro 328 tires
- Ordering Wheels Online vs. Going to the Local Tire Shop
- OEM R90's Check Please!
- 215/45/17 Falken FK452
- Tire Pressure ? and the pressure monitor system
- Chipped Wheel
- BBS R90s fit an r56? Yes or No? Dealer is not certain...
- gathering interest: if I was to buy a new MCS JCW, any interested in buying the rims?
- Tire/Wheel upgrade
- Konig Feathers, opinions?
- Brake Pads and Rotors
- Brake Fluid Change
- R85 17 x 7 or 17 x 7.5?
- do you like or hate 17" s-lite wheels-tries.
- Ditching the run-flats?
- Yoko and the ride and how far they will go
- which new tire? opinions please
- 16" chrome rims ..... Which ones ??
- HELP ME PLease
- Replacing run flats for regular tires
- General Exclaim UHP ride
- which wilwood kit
- Enkei NTO3+M - Black Lugs
- wilwood clearance query
- New All Season Tires on an 06 MC - Suggestions?
- Help Me Decide: Tires for Auto-X
- Dunlop Direzza Sport Z1 Star Spec ?
- tires-easy.com (tires-easy.ca)
- Any problems from running wheels without center caps?
- Speedy Wheels - Any Good?
- S-Winder lug style?
- Wilwood bleeding question, rear pad question
- brake squeeling?
- Wheel won't come off
- cleaning/maintenance of lug bolts ?
- Do S-Lites accomodate TPMS?
- "REINF" Tires?
- Cheaper version of WedsSport TC005?
- Recommend asbestos pads for front brakes?
- 225/40/18 tires~
- 16 inch wheel/tire package for GP - 205/50-16 205/55-16 or ?
- How does my Tire pressure system work?
- Drag DR19 gun metal wheels for MCS
- Canadian08Mini'sTPMS
- Made a Brake Mistake, need New ones.
- what offset?
- how much does it weight?
- 16" Bridge Spoke vs. 17" Crown Spoke
- Tallest Tire on a Stock Clubman?
- Will These Fit
- 16x7" Konig Remember Wheels 4x100 +20mm Off-set
- What tires is everyone running
- s-lite
- Rota Grid's
- TPMS Sensors - How to attach to aftermarket wheels?
- Sportmax 002 17x7 on an R56
- bridgestones vs. sumitomo
- Big Tires on S Lites
- Caliper Covers?
- Re-Assurance before I buy
- Lighter Wheels = Better Gas Mileage ?
- Name That Wheel!
- Which Pump Do You Recommend?
- Removing the jacking pads?
- Rota Grid
- Clubman S Spare Tire/Tools?
- Offset question
- Broken Wilwood bleeder valve....
- R53 Pirelli & Dunlp differences? Why'd they switch?
- Dealer installed wheels?
- Wheel ?
- Better Long-Term Fix for Run Flats
- Speedy Fusion: Pics/Thoughts?
- Changed Pad Wear Sensor but nothing changed!
- Nitto Neo Gens?
- Ride Quality - 17" vs 18"
- Changing Bolt Pattern?
- Black Wheels - Let's See 'Em!
- 14mm lugs fit in a BBR Rk wheels
- To confirm: R56 w/rubber valve stem means no direct TPMS?
- R90 vs R85 dimensions
- Runflat wheel weight vs non RF
- Borbet LV4 anyone?
- R-90, Team Dynamic and Wilwood question
- How do you disable the TPMS?
- recommended tire size for 18 x 7.5 ET 48?
- Brake Job 02 Cooper S
- 18 x 7.5 with 48 offset.... would this fit?
- tenzo mach 10
- Spacers??
- ASA Ar1 or R90 replica???
- TPMS
- Any calibration possible for speedo off?
- Going spare?
- '05 MCSC Question
- SSR website url?
- 215/40/17 vs 215/45/17
- Different Tire Size for front and rear
- Millennium Tires for Life - Anyone heard of it?
- Tirerack said 215/45/17 will not fit my car. True?
- Hankook R-S2s are noisy
- Size Matters?
- Nitto Neo Gen 215/45/17 Tire Pressure
- ASA AR1 in 18s???
- KDW vs. PS2 vs. NERO vs. PE2
- 215/45 on a 17x7.5 +45 wheel... no rubbing?
- Speedo off.
- Red shoes for ma MINI
- Dumb question!?!
- I've asked dealer to switch wheels on my incoming Cooper - will they help me?
- Tire pressure scare!
- Rota Slipstreams
- Just ordered, Pirelli PZero Nero!!!
- Quality Question.
- R56 MCS Speed Bleeders?
- Lets see your OZ ultraleggeras...
- Tire and wheel calculator
- G-games Sidewinder
- Wheel question
- 16" Rota RB's
- i got my new OZ superturismo wheels!
- Any reason to switch wheels?
- Hub size for OEM wheels on 2008
- New rotors: suggestions?
- Will 215/45-17's fit my R50?
- tire replacement warranty ??
- Smoothest, Quietest 205-45-17 All- Season Tire???
- Swapping tires and/or wheels at dealer
- 18 x 8 OZ Ultralegerra offset
- Tire Experts
- Embarrassingly dumb question
- Off the wall question. Chrome Bridge spokes?
- Enkei RS-M opinions
- Underwhelming brake upgrade - why?
- How cheap is too cheap for rotors?
- Order wheels before I got my Clubman
- Aftermarket pads and OEM rotors - no maintenance coverage?
- Crazy to put the 16s from my old 03 MC onto my 08 MCS?
- help me understand what fits
- Hey guys I need help
- To go 16 or Stay 17......
- Anybody know where to get 2006 rear mud flaps?
- White wheel paint color code?
- Help finding correct paint to refinish silver OEM R84s
- Direzza Z1 Star Specs
- 18" OZ UL in Matte Graphite Silver finish?
- pad and rotor change question
- Replacing OEM 195/55/16 with Non Run Flat 215/50/16
- How wide can I go?
- Web Spoke Wheel Question
- 1st Thread! Questions RE OZ Ultraleggara
- Help! Spongy brakes at the track...
- Exel TZ10's if you have them I have questions
- Can you buy TPMS?
- Winter tires... summer wear?
- Goodyear Eagle F1 All Seasons
- Help me choose between 2 tires
- Will 16's fit ???
- Steering Angle Stop - required?
- Cooper Xeon tires?
- Stupid Brake Question??
- How to measure brake pad wear?
- 205/40/17
- Is TPMS transferrable?
- Brake pad sensor waring light....
- ContiPro runflats
- Offset for 18 x 7.5 rims or 17 x 7
- Is it possible to repair a flat runflat tire?
- Quality of ION Alloy Wheels
- Wheels choice: please help!!
- Brake rotors and pads input for justacooper
- ZE 912's?
- Kazera KZ-R on R56
- JCW 18" Tires - Options to 205/40-18
- Cryo-Treated Rotor, is this stuff for real?
- Tire/Wheel question
- wheel width
- Expected tire wear
- 17x8 wheels fit?
- Want to see photos of R99's installed
- level 1 brake upgrade
- Tire Pressure 215/45/17
- Non Run Flats with Spare or flat fix kit?
- Hub centering rings - help find source
- JCW replica rims?
- Anyone have ASA AR-2's?
- Bolt problem when fitting Wilwood TCE Plus 1 kit on 06 JCW
- Opinions
- Michelins or Falkens (both used)?
- MPG down by 10% after switching to new rims/tires
- Rota Torque's
- Tire Pressure Monitoring Systems and Sportmax wheels
- R1 Racing Wheels...Anyone Have them?
- Kumho tires
- Offsets!?
- Wheel mate or something like that?
- centering rings (Vibration or mounting ease)
- Advice needed: 18" JCW rims, want to go 215/35/18???
- Rota SVN's... not something commonly seen on da MINI'z
- 12.2 Wilwood with stock 17" S-lite
- The CLUBMAN wheel thread
- online tire/wheel store for konig feathers?
- Another "will it fit" thread
- Brake and Rotor Question
- Brake Job Pricing Ridiculous
- switching Runflats
- What size tires for 18 inch rims
- Should/could new wheels and tires require alignment?
- Brake dust revisited...
- R56, WebSpokes, H&R Springs and 215/45R17s?
- 7.5x15 6ULs?
- R53 Flat Tire Monitor
- what brand of ceramic brake pads?
- JCW Brake replacement rotors
- Factory Offset for Clubman 16" wheels
- Painting the calipers...any quick tips?
- Brake pads-less dusting desired...
- Thoughts on a reasonably priced 17 summer tire
- Tire chains compatible with 16s?
- BBS Wheels/Rims Closeouts
- My new tires...are horrible!
- Donut Question
- Looking for good online Wheel store
- Driving off the rims?
- Caster Question
- Wheel weights...
- Riken Raptor ZR - does anyone have these?
- Tire Size
- Compatibility of '02-'06 wheels with '07+?
- Wheels for snow tires
- Potential Brake Problem
- Break Ducts for R53?
- I'm buying white wheels, and could use YOUR help!
- Hankook Radial K106, 205/50/16 available for $57
- Getting new tires, bye bye Runflats
- STORING TIRES
- Where to buy 12mm Wheel Spacers
