View Full Version : Tires, Wheels, & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42
  1. RFT v. 55 series performance tire.
  2. Denver winters
  3. Hollies for the winter, and beyond?
  4. Opinions needed. TD 1.2 or OZ UL
  5. Falken 215/45 16 RT615 on 6.5" wide wheel
  6. Will these pads fit an R56 MCS?
  7. Comming to a garage near you:The Diffrence is in the details
  8. lug_bolts
  9. Wheel Spacer Help?
  10. Brake fluid
  11. Proper Tire Pressure 16" runflats
  12. which 17" tires
  13. Keeping Tires in Great Form
  14. Pics of Rota RB Flat Black No Lip on R53 Preferably 17"
  15. r56 mcs 16x8's
  16. New tires for MINI
  17. New tires at SEMA
  18. Can you plug a runflat?
  19. Anyone like their stock runflats and sticking with them?
  20. Brake job
  21. Winter: 205/50/17 or 215/45/17
  22. Will the Brembo 12.6 fit under S-Lites?
  23. Hubcentric ring ?
  24. Ripped off on a donut spare
  25. Picture of MINI with new wheels and tires.............
  26. R56 Lug Nut ?'s
  27. Anybody running 17" on an MC?
  28. Need help selecting new tires
  29. What is the weight of 15" Rotator Spokes
  30. Wait... I can realy opperate without this??
  31. 5Zigen ZR+ 18x7.5 Tires?
  32. Stoptech or Wilwood
  33. TPMS for MINI
  34. brembo BBK fronts-- what to use on back?
  35. What kind of wheels are these?
  36. time for some wheels...
  37. Track tire pressures for Z214
  38. Snow tires and runflat - good combo?
  39. brakes?
  40. Torx bolt on R53 rotors driving me mad!!!
  41. Hard to brake after replacing rotors and pads
  42. Quick question on 15" mag for R56 MCS
  43. mixing it up
  44. Random wheel questions
  45. Help me wheel Gurus!!!
  46. Steel Rims for R56 MCS
  47. Will these rims work???
  48. Best 215/45/17 tire for MY needs
  49. Looking for Quiet Tires
  50. Bridgestone RE960 Pole Position
  51. GP Wheels on a non-GP MINI
  52. Should I bother trying to get this wheel fixed?
  53. Wheel/Tire size
  54. write way to remove rotors and other related questions for r53
  55. Urgent help needed
  56. R90 Lug Bore Size?
  57. This pretty neat....
  58. Blacked out R84's
  59. RUN FLAT - Its not a nail, but it did give me a flat.
  60. Anyone know about dry tires
  61. Centric Rotors + Axxis Ultimates = happy braking
  62. 2nd gen wheels???
  63. New single tire, where to put it?
  64. Spline lug bolts okay?
  65. Best tires for cold and wet?
  66. $56 Eagle F1s!!
  67. soft socket for lug bolts
  68. need suggestions for tires
  69. It never ends...
  70. NEED HELP THANKS!!!
  71. Enkei RPF1 15x7 on 09 Cooper
  72. Time for new FAT winter tires...
  73. F1 GS D3 Review
  74. F1 GS D3's Closeout at Tirerack
  75. Hubcentric Rings
  76. BRG caliper paint
  77. Will a 15" fit 08 MCS?
  78. 16" Bridge Spoke Replacement Tire Size
  79. Do u lose m.p.h or miles
  80. AB S R56 needs some LIP
  81. Boiling Brake Fluid?
  82. Do 16" Konig feathers or helium fit on R56?
  83. Tire suggestions for 17" Borbet LV4
  84. Blizzak LM25 or WinterSport M3
  85. Quite possibly the best racing wheel ever...
  86. Will Kazera KZ-D's fit on a Factory JCW?
  87. Looking for BRIGHT 17" wheels
  88. Used Rims for Winters
  89. Brakes or engine?
  90. Astro Black w/ Anthracite R90 Wheels?
  91. Costco refusing to put non run-flats on my car
  92. Need Wheel/Tire Package for Team Dynamics PR 1.2
  93. Wilwood brakes with Detroit Tuned disc
  94. 215/45/17 winters yay or nay?
  95. Non-runflat tire suggestions?
  96. Market for used tires?
  97. Runflat to conventional tires?
  98. Correct wheel size
  99. JIC Magic J-Force 05 Wheel 17x7
  100. Discount Tire Direct spline lug bolts
  101. Anybody else HATE buying wheels?
  102. Tire/Wheel Change Out & TPMS?
  103. New Shoes Anyone?
  104. Did my brakes, noticed brake fluid under car
  105. Question before I order, brakes
  106. Wider is better
  107. How long should tires last?
  108. Longer Lug Bolt for 2005 MCS?
  109. Tire question
  110. LIMITED EDITION - Enkei's NT-03M
  111. newbie -- got a wheels/tire/spec question!!
  112. R90 RIMS ON A CLUBMAN
  113. TPMS sensor/valve stem question
  114. Yoko S Drives at 700 miles
  115. Anyone with 17" black crown spokes?
  116. TSW BDM BBK vs. Detroit Tuned BBK
  117. Kumho Ecsta XS??
  118. Should I put new tires at the front or end?
  119. Tire Rack installer: EXACT MOTORSPORTS in milpitas
  120. S-Lites vs. Crown Spokes?
  121. How to R56 Rear Brake pad replacement?
  122. Sources for TPMS sensors
  123. Center Cap Alternatives for RPF1 Enkei?
  124. JCW Brake kit R53 < Stock Brake R56?
  125. Wider wheel question (17" Drag DR-19's)
  126. Team Dynamic pro race 1 discontinued?
  127. Show us your Gloss Black or Matt Black Aftermarket Wheels
  128. Wilwood EXP 600 FTW!
  129. R56 / Rota Formula Question
  130. New Tires - Weird Wiggle
  131. "Spare" to borrow in Mpls/StPaul area?
  132. 38 PSI for MCS tires?
  133. Does anyone know where to buy new Millie Miglia wheels?
  134. Newbie seeking brake dust removal advice
  135. Interchangeable brake options from maybe a BMW??
  136. Which wheel looks better on the car?????
  137. Winter tire 16" thoughts...
  138. New Tires
  139. Winter tires
  140. Pictures of MCS R84 stock rims with different tires?
  141. Help, Similar Rims?
  142. New wheels!!
  143. Wheel experts - need your help!
  144. 15x7 Rota RB will not Cooper S?!?!
  145. Installed carbotech pads - question
  146. New Wheels
  147. GTI Denver rims
  148. Wheel Repair Rockville Maryland?
  149. "Real" lug studs in a MINI hub?
  150. conti comfort kit ?
  151. 18 inch ROH Adrenalin Wheels
  152. Tire Rotation? Clubman with stock 15" tires
  153. Pulsating brakes after pad/rotor change
  154. Ronal R38 - 17x7.5, et35...will they fit?
  155. Torque Specs for OEM Bridge Spokes
  156. R56 Tuner Lug Locks
  157. 205 65 r15
  158. r109 and r112 rims where can i buy them?
  159. 14mm x 1.25" chrome lug bolts for 2008 MC
  160. Brake Wear Sensor Not Turning Off
  161. Will the Tomason TN1 17x8 Wheels fit the Clubman
  162. Would these SAAB wheels fit?
  163. R56 Spare Tire??
  164. Wilwood clearance
  165. Konig - Zero
  166. Paint match for OZ Ultraleggeras
  167. Enkei rpf1
  168. F1 GS D3 ?'s
  169. Questions about Rota RB wheels and Webspoke wheels
  170. Ok to drive to deal with 3 lug bolts?
  171. Rota RB/R56 Pics?
  172. Aftermarket wheels questions.
  173. picture request: R56 with 8J 18" wheels
  174. bigger sidewall?hmmm
  175. Good deal on Brembo GT kit at Tire Rack
  176. Lug nuts?
  177. Anybody running Black Motegi Racing SP10?
  178. Poll: DS or Matte DS S-Lites
  179. Brake Job for an 02 MCS
  180. Best price paid for S drive
  181. Will 15x8 Rota RB clear JCW brake?
  182. TCE Plus 4 Installed...finally.
  183. Pirelli Winter SnowSport 240 vs Bridgestone Blizzak LM-25?
  184. What size of snow tires for 15" rims
  185. Yokohama S Drive Tires mounted
  186. Need Help Quick! 2007 MCS going down to 16 inch wheels
  187. Does anyone NOT rotate their tires...?
  188. XPOST: Max tire Width on the Challenge Spoke
  189. When is a runflat flat?
  190. BBKS: How to measure if they will fit.
  191. I have a 2009 JCW tell me if these would look good
  192. MINI Cooper ONE hubcaps?
  193. Union Jack lovers...
  194. help me spend on 17" track/daily wheels
  195. spare tire donut
  196. Information on "new" unsafe tires.
  197. Want new rims.
  198. New Tires for MCS
  199. Do Konig Rewinds for '03 MC only come in 15"?
  200. 215 or 205 on Konig Feathers?
  201. Softest riding 215/40/18 Tires
  202. Chrome crown spokes?
  203. painting chrome rivet/bolts on Konig Hotswaps
  204. Ride Diff on 16" OEM w/RunFlat and AftrMrkt 17" Non RunFlat
  205. 18" Black Rims
  206. Voxx Wheels
  207. Let's talk track brakes...
  208. OEM to Carbotech Pads: Rotors Need Resurfacing?
  209. Firestone Firehawk GT
  210. R1R or RE01R
  211. Enkei Nt03 M (hyper Black) HELP!!!!!
  212. looking to upgrade pads/rotors
  213. need Tips on painting my Slites
  214. Question about 5 spoke "Rocket" wheels
  215. How NOT to install Carbotech pads...
  216. Will 15" 4x100 VW Jetta Spare Tire Work
  217. craziest color wheels.
  218. Left rear inside is bald
  219. Wheel question
  220. Changing to winter tires
  221. Wheel lugs,splines,locks or Tsw conversions?
  222. Snow Chains on a MCS
  223. BBS CV will they rub?
  224. Replacing RunFlates with regular tires
  225. Will these wheels fit my MINI?
  226. Winter Tire Confusion!
  227. Question about the R98
  228. *REALLY* dumb question about Dayton Rims
  229. Rim opinions wanted
  230. Buying track wheels and tires but no TPM sensors
  231. Wheel/Tire swap question
  232. Annyone know of a wheel spec 16 by 7.5 for our cars?
  233. Team Dynamics Wheels
  234. Mindless weight question, wheels.
  235. Snow tire sizes
  236. 15mm spacers with web spokes or s-lites?
  237. Webspoke Air Leak?
  238. Is 14.6 lbs per wheel about as light as I'll get for 17's?
  239. Top Three Rotors for MCS?
  240. Rotors from local autoparts stores?
  241. Anyone have the Rota auto-x wheels?
  242. Anyone sprayed their rims black?
  243. New OZ Racing Alleggerita HLT
  244. Pics of Rota Torque (Flat and Royal Black)
  245. Am I the only one that likes 15-16" wheels
  246. Brake wear indicator
  247. How many lbs of torque do wheels need?
  248. Hi all, I have a question....
  249. Rim and tire questions
  250. 175/65 R15 to 185/65 R15 Mini Warranty Question
