View Full Version : Tires, Wheels, & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42
  1. Any experience with 225/45/17's on S Lites MCS 2006?
  2. Who uses speedbleeders?
  3. Actual real world difference with lighter wheel?
  4. How firm should the pedal be after flush/bleeding?
  5. Do I need a brake disc hardware kit?
  6. Anybody interested in Rota RB's and tires.
  7. Stud conversion
  8. ATE Super Blue at local retailers?
  9. LY/B and wheels options.
  10. Wheel and tire setup - potentially
  11. Dyna Plug kits
  12. Will 215/45R16 fit?
  13. Another 215/45/17 tire question
  14. New for 2009 from Breyton
  15. Anyone Running 225/45/16 on R56?
  16. Bridgestone RE01R blowout!
  17. Replica vs original
  18. Looking for GP replica wheels
  19. To Parada or not to Parada
  20. Factory wheels painted or powder coated?
  21. Help picking summer tires
  22. TireRack ratings
  23. Switching out RFs. Exclaim UHP, Exalto PE2s, Goodyears?
  24. Exploding Dunlops
  25. From 205/45 17 TOYO T1R to 215/40/17 Potenza RE-11
  26. R98 reassembly
  27. Flush brakes or just bleed them?
  28. Civic 15" as a winter set
  29. New tires - HELP!?!?!
  30. Pads advice please...
  31. New wheels for the 330i
  32. Small blister on my runflat sidewall...
  33. ET 40 vs ET 48
  34. The LIGHTEST brakes?
  35. What offset for me application
  36. Buying new tires
  37. New rims on!
  38. Yoko S.Drives vs. Firehawk Wide Oval?
  39. I'm absolutely torn on tires, please help me make a decision.
  40. Tire size decision
  41. Run Flats - is there ANYBODY out there who LIKES them?
  42. ASA AR2's pitting/staining problem
  43. Winter Blizzaks for sale with wheels
  44. 18x7 Wheels + 215/35 tires will 5mm spacers fit?
  45. Best choice?
  46. Thoughts on these wheels
  47. Wanting new pads/rotors for 04 JCW
  48. Pics of 19s on R53 MINIs?
  49. Help me choose my rims
  50. Slimmest profile BBK
  51. A different feel on my new general exclaims
  52. If I have studs do I need hubcentric rings?
  53. 08 MCS cc-id 142 tpm warning after rotation?
  54. Help me find 18" rims like OctaneGuy's rims!
  55. 09 MCS tire and wheel redux
  56. CRAPPY OEM TIRES???
  57. Powdercoating confusion
  58. Opinions on Konig Zero In
  59. Brake bleed procedure?
  60. Wheel repair
  61. New for 2009 OZ colors!
  62. Want to replace run flats
  63. Tires-Easy
  64. I need quiet summer tires
  65. Offset - PLEASE HELP!
  66. Work VS-XX query
  67. So sad. Tried to fit 18x7.5 offset+42 onto R56 MCS - FAIL!
  68. Winter Tire defect
  69. R90s to replace my Crowns? Photoshopped... need your opinion
  70. Recommended replacement pads?
  71. Falken 912 absolutely SUCK as an all season tire.
  72. Anyone replaced their Konig Feather center caps with something NOT ugly?
  73. Kosei v. Motegi, which is best?
  74. What are your favorite track tires?
  75. Harbor Frieght brake caliper tool set on sale!
  76. Help me decide
  77. Pressures on door sticker vs tire label
  78. Old tires, new tires and fitment
  79. Ordered pads from AutoXCooper.com
  80. So, I need new brake pads
  81. Wheel vibrates under braking?
  82. Thunking noise after changing wheels
  83. Aggressive fitment MINIs? Post pics!
  84. Minimum tire clearance
  85. Recommend me a set of 215/35 R18 tires!
  86. Sanding brake calipers
  87. New wheels and tires?
  88. Monza/V-Spoke R84 X-Lite wheel question.
  89. BBK sizing
  90. Wheel mounting stud
  91. 205/50/17 tires on stock 17" crownspokes?
  92. Best wheel & tire for autox ? 06 S
  93. Which of the 3 cheepo brake rotors? Never heard of them...
  94. MCS Tire Size Question. Best for overall Handling?
  95. BMW TPMS and Mini Cooper Question
  96. Persuade me... please
  97. What's up with Edgeracing?
  98. What do you think I need?
  99. Brake wear
  100. Need new summer rubber
  101. Scored some winter wheels and tires!
  102. Anyone with motegi sp10 wheels?
  103. DIY BBK install (pics only for now)
  104. R99 Wheels Alternatives, Imitations or Similar
  105. Tire Pressure Monitor
  106. 18" tire MINI fitment (help with choice)
  107. Air Compressors
  108. Brakes dragging
  109. eBay scam - are these really OEM wheels?
  110. What offset on 8.5 wheels?
  111. Can't find wheel...
  112. Help 18x8 35mm offset on tien s type RUB?
  113. R56 rotors
  114. Brake pads/Rotors for BUR-LEE!
  115. Yoko S-Drive VS. Michelin Pilot Exalto PE2
  116. Goodridge G-Stop Brakeline Kit
  117. **Must See regarding Aged tires
  118. S-lites on R55?
  119. So what if it's cheap?
  120. Goodyear Eagle F1 (GS-D3) vs Yokohama S.Drive
  121. Changing Hub
  122. Tell me two things
  123. Widest possible tyres on a 7.5J Rim?
  124. Plugged a run flat...
  125. So happy \ New Tires \But TPMS Service Kit?
  126. Winter tires = lower MPG?
  127. Break sticks after accident
  128. 1986 BMW 5 Series
  129. Jacking aero kit MINI to paint calipers
  130. Lowest Offset Wheels On R56
  131. Which tires?
  132. How to estimate effect of wheel/tire weight on acceleration
  133. 1st real black ice incident, need replacement R84
  134. 2-piece stock sized rotors
  135. best tire/ shocks/ struts for sand?
  136. Urgent! Need Brake Pad Reccomendations!
  137. Snow tires on my Clubman - my experience so far
  138. Need Urgent Help Please!
  139. Bought Blizzacks, and NOW the snow stops!!
  140. Dream wheels?
  141. What spare tires can I use for 05 Cooper S?
  142. Brake dust covers / sheilds - opinions please!
  143. Paint them white?
  144. Best Way to Protect Wheels/Tires from Theft?
  145. 205/55's rubbin?
  146. Flat Tire Question
  147. knock knock noise when emergency braking..help!
  148. OEM wheel offsets and Scrub Radius question.
  149. Carbotech pad issues...
  150. Will 215/40/18 tires on 18-inch OZ Ultraleggeras cause rubbing with JCW suspension?
  151. Is getting only front winter okay?
  152. Breyton Flame Black
  153. ordering tires from tirerack...
  154. Anyone know of finishlinewheels.com?
  155. Open Tracking the MCS
  156. Spares, donuts, compressors and sealant reviews
  157. Show me your broken wheels
  158. Goodyear GS-D3 being discontinued
  159. Tire help - ContiProContact vs ContiSportContact
  160. How much could i get for my OEM runflats
  161. R56 Brakes and Wheels
  162. Tug's new shoes!
  163. Urgent - Snow Chain Question
  164. Anyone tried General Altimax HP tires?
  165. FS: Bridgestone Blizzak WS-50 215/45 R17 Snow Tires
  166. ROTORPROS.COM??? ANY EXPERIENCE?
  167. Have you used your Dunlop SP Sport 01 in an inch or two of snow?
  168. Auto Socks
  169. New tires for Ultralegerra 17"
  170. Outmotoring wheel locks
  171. 15" Tire Recomendations
  172. Nokian Hakkapeliitta's first snow test
  173. Chains/Cables 09 MCS
  174. What kind of paint?
  175. 15x8 +36 6UL on r56
  176. Regular rims vs. white painted rims?
  177. Kumho ASX vs Bridgestone Potenza RE960AS Pole Position
  178. Another Should I get non-runflats for S
  179. Pros and Cons of No Center Caps on Wheels...
  180. exel wheels bolt size?
  181. Any Tirerack.com discounts or referral codes for discount?
  182. 6061forged
  183. Lightweight (10# or less) 15" wheels for R56
  184. Moving TPMS to a different set of wheels
  185. Motoforge????
  186. Complete Newbie to Aftermarket Wheels - NEED HELP!
  187. Zoom Tires, El Monte CA (SO CAL) Fraud? Legit?
  188. runflats off finally
  189. If I only change my tires, do I have to worry about TPMS?
  190. Rays/Volks CE28N finally arrived...!!!!
  191. trying to find some snow tires
  192. I need longer lug bolts
  193. R56 Crown Spokes won't fit on R54 Cabrio
  194. Two TireRack order questions
  195. Does this brake"lead" connection fits my R56?
  196. 4x100 to 5x130 on r56 mcs
  197. Help Needed w/15" Rota Wheels
  198. Show your Winter Set Up
  199. my brakes suck!
  200. A good set of trackday wheels?
  201. Aftermarket TPMS sensors
  202. 205/55/R16
  203. Wheel lock key replacement
  204. R56 brake pads (pic) which are rear?
  205. Anyone used the Psiclops tire pressure guage
  206. How to change my tire?
  207. Center caps for R84 wheels?
  208. HAWK Performance Ceramic Pads
  209. Is alignment needed after going from 17" to 18" wheels?
  210. Stock All Weathers ok for the DC area "winter"?
  211. Wheel experts
  212. Non-RunFlat 18" tire recommendations please
  213. Runflats comming off but Qs.
  214. New pad=soft brakes, but for how long?
  215. Fit Question: Steelies, JustaClubman
  216. Help me understand my MINI rims...
  217. Pics of my Chilli Red 2003 MINI Cooper with Black 18 inch Konig Again wheels
  218. Brake experts - need your help!
  219. Somewhat humorous Tire Saga
  220. Nakayama Schumacher R8 wheels. Anyone have them? Opinions?
  221. My R105 JCW wheels nervous breakdown
  222. Runflats make little sense!
  223. ebrake only on rear left caliper?
  224. Photoshop request - Painted wheels.
  225. Wheel Gap Question
  226. Do spray on snow tires work?
  227. Dunlop SportMaxx summer tires = GOOD in cold weather
  228. Pad Suggestions?
  229. Switch or Wait?
  230. Tire for Pacific Northwest MCS
  231. Lug Bolt Help?
  232. Necessary to replace rotors on first pad change?
  233. Dunlop 205/45-17 9000 Run Flats (4) for sale!
  234. New rotors/pads
  235. Anyone running Rota RB's in 16x7???
  236. Tire size for 18" wheels?
  237. Will this work? 215/45/17 on R97
  238. Snow tires... is this normal?
  239. Snow tires recomendations?
  240. Hufeisen Wheels for MINI
  241. New Runflats on 16's
  242. TCE Caliper kits.
  243. First Flat Tire w/ Runflats
  244. Odometer/Speedo with wheel/tire change
  245. Some thoughts about tire changes
  246. i need some help finding my dream wheels
  247. Excluding TPMS sensors from new wheels?
  248. Speedwerks lug conversion installation
  249. 16x8 rota rb + 35
  250. Status report on Motegi SP 10 wheels please.
