- 2010 Justa Cooper Front Suspension Bottoming
- Holy bump steer!!
- Wheel Fitment Question
- Confused. Are adjustable rear control arms needed...
- How many Gs can we expect
- GTSpec under brace system
- ok, shock,strut,springs,coilover??? huh?
- sport suspension vs non
- Is my Squeaking Normal?
- Front Strut tower brace vs Front Sway Bar
- Looking to revert a Cooper S to non-sport suspension...
- New Springs installed, now shake/vibration
- H&R 1.4 inch drop, anything else I need?
- KW Coilovers - Long Term Check / Review?
- JCW brake question
- Strut Bar
- Shop for Alignment
- Anyone using the Eibach 19mm rear sway bar?
- What Is The ALTA PSRS? Why Do I Want One?
- ALTA Suspension Components Buyers Guide
- need info before pulling trigger on PSS10!
- New Conti Extreme Contact DWS
- Information About Adj. End Links (Rear Sway Bar)
- Koni FSD - Who's got the best price?
- rear camber change
- Co-op coilover/spring install in MD area
- Misfire And Overheating
- track/road hybrid suspension
- Alta Lower Control Arms V2 Bushing Question
- Front Strut Tower Brace
- Guess I'm going with coilovers afterall....
- BC coilovers installation...
- Piece of cake, rear bar
- 15" wheels on R56?
- Front wheel clearance with different mfg coilovers?
- Road race track alignment settings?
- installed me some new parts
- Best setup for daily driving?
- What's a good shop in Toronto?
- any point to lowering stock 15"?
- H&R Spring Replacement
- Advice for R55 S Coilovers..deciding today
- Torque Spec for top bolt.
- In case ya get lights on your dash....
- For the love of God, can someone please tell me the freakin' difference?
- Bilstein PSS10 and Wheel Fitment
- Best tyre for 18" wheels and coilovers
- After lowering noise while turning
- Anyone use bilstein shocks w/ aftermarket coil springs and then switch?
- H&R Sport Cup Kit
- Trailing Arm Stripped? Rear Bolt Size
- rear track rods
- After installing lowering springs how far should the strut post extend past top nut?
- Control arm and lowering spring install questions
- Tarett rear sway bar settings
- Cross coilovers - what's the HIGHEST it will go?
- Noise while driving, might be struts...
- Help needed
- Rear Strut Bushing Problem
- JCW suspension kit and R57
- H&R coilover reviews?
- Do all aftermarket coilovers need spacers..
- Best way to get a softer ride?
- BC Racing r56 coilover review
- Installed new M7 Strut Bar
- Probably dumbest question ever....
- help: R56 + kw v1 + R90 = spacers?
- torque specs
- Which OEM springs have these part numbers?
- JCW suspension ride height
- FAO: KONKY
- Coilover Help for a UK Mini
- Torque values for top mounts, please.
- Somebody shoot me and put me out of my misery...
- Replaced the Run-Flats with Michelin Pilot Sport AS Plus - verdict TWO thumbs up!
- Help! Weird vibration after lowering springs installed.
- EBC Red Stuff Pads
- 800 miles on coilovers...now clunk.
- Break-in period and springs
- Is a shock upgrade needed after upgrading to lowering springs?
- Wheels Flush with Fender Arches - Offset + Width
- Trailing Arm Purchase? Who is cheapest?
- Replacing rear track bars
- HELP!! Alignment Issues!!
- Rubbing under suspension compression
- Sway bar quesiton?
- Megan Racing Coilovers with JCW STB help!
- Springs: NM or H&R ?
- Eibach Springs or Coilovers?
- Would I find any advantage
- What Coilover's TO BUY!!!!????
- K&N air intake/what strut bar will make it over this intake?
- Adjustible camber plates
- Custom Strut Tower Brace
- Rear bars with poly bush?
- ALTA control arm bush
- Few Questions?
- Cooper S vs. Cooper S with Sport Package Suspension Difference?
- Coilovers and highway handling
- just wondering
- H&R Street Coilovers Clunking
- Control arm bolt fell off
- H&R RSS Coil Overs
- Wanted: Drivers Side Front Strut
- Anyone have lowering springs on an R57?
- R56 V-Maxx Coilovers
- Need confirmation--are adj. front end links supposed to be set shorter or longer?
- Alignment that requires calibrated weights?
- metal clanking noise
- Studs?
- OEM Suspension Life
- H&R springs
- whic STD?
- Strut Brace
- Most Aggresstive Spacers on Clubman?
- Perhaps lighter struts in the future
- H&R Springs with 18" R1 Wheels - Are rear ground control & alignment a must?
- wheels
- Opinion - Ebay 07+ MINI COOPER WHEEL STUD CONVERSION
- sugestions of suspension installers, Denver Colorado
- rear sway bar bushing bracket bolts
- time inserts or new trailing arms
- rear camber plates
- non-s with strutbar
- stock 16" wheels with coilovers
- Texas Speed Works VS Alta
- Opinion-bump stops
- question on additions to springs
- Issues with TSW springs and IE fixed camber plates
- H-Sport TVS Stage 1 VS M7strut tower brace, and 25mm rear sway bar
- Looking for Suspension Shop recommendation Dallas Texas
- How to remove endlinks lower parts
- Lower and more comfortable?
- car alignment after suspension upgrades
- Made and 11th hour switch...hopefully for the better?
- Help confirming shaft diameter...
- creeking after lowering
- Installing Koni yellows, anybody have instructions/how-to giude?
- Bump steer NOT helped with new poly bushings.
- Lubing Sway Bar Bushings
- Reputable Installers in Bay Area
- which lowering springs are best on stock shocks n struts
- Do I need to consider mushrooming?
- JCW 18.5mm rear sway bar for $135?
- Anyone installed BC Coils on R56?
- Coilover vs springs
- WHOAH! Fantastic new suspension additions!
- Lowering "Bonus"!
- Coilovers Questions- KW V1
- "Bumpy" Acceleration after lowering
- Is sport suspension worth $500?
- OK, here's my last rear sway bar question, I promise:
- Anyone live in Los Angeles (west side) area? Need recommendations...
- STD's, new Mini still needs protection...
- Rear sway bar question!
- Solution for steering issues?
- McPherson struts and coil springs
- I have found the perfect Coilover fo ME!!!
- Rear Suspension Bushing options
- Partial stud conversion kit
- Steering wheel "Bucking" over bumps, dips, etc
- H&R sport performance or H&R RSS
- Non-Sport Suspension Struts... what are my options?
- Does the suspension depend on the tune or the tune on the suspension?
- Best suspension for my situation
- coilover top pinion bolt
- front end links question
- H&R Springs Install Cost & Warranty Question
- H&R vs Eibach lowering spring
- suspension and my skill level in driving?
- Help to install rear sway bar in Manhattan
- Question about Whiteline rear swaybar
- Out of Curiosity...
- R57 down spring-help me
- MC-S vs just a cooper suspension difference?
- Leased car suspension Upgrade?
- what is a strut tower defender? and Strut brace??
- Coilovers
- Stock JCW Suspension on Cooper Non-S?
- help, front sway bar install
- Need Advice! Stripped lower shock mount!
- 19mm Sway Bar Install
- Changing the shocks to Koni FSD -- do I need a Mini-specific service place?
- First Mini cooper 09
- lowering my MINI, Help Please.
- Koni FSDs on R55 vs. 1st gen. Minis.
- Installing two different brands of springs...
- Alignment Question
- Suspension Theory
- Replace rear camber link with NM springs?
- Rattle from front left
- NM springs + Koni FSDs? "Final word" from NM.
- Texas Speedwerks
- Eibach pro-kit arrived
- R56 Rear Sway Bars
- Front Control Arm Bushings
- I didn't cut the bump stops...
- NM Springs
- Ill begin the intro (and first pics) of my Mini
- wheel and tire size
- Don't plan on changing suspension, any other things I can do to improve cornering??
- BRAND NEW H&R COILOVERS FOR 279.64 ON MAZON
- Control Arms After Lowering?
- Vibration after lowering question.
- CROSS TOP MEASUREMENT
- TSW KW Varient 1
- Help me decide on my suspension set up
- Coilovers recomendation
- Has anyone every raised their MINI?
- How are KWV1 Coilovers so Cheap at Mini-Madness?
- Anyone running KW Clubsports?
- nm springs or entry level coiovers ?
- NM eng or B&G springs?
- What are the spring rates of OEM R56?
- Stock Sport Suspension question
- Alignment After Rear Sway Bar Install?
- What do you guys think of this TSW ASAN wheel?
- How do you know if you have JCW suspensions?
- Anyone got Bilstein Shocks on their R56 yet?
- Will R53 Springs Work on an R56
- Rear Sway Bar Diameter?
- Alta 50% is back guys!
- KTS Coilovers for Minis?
- KW V1 on R56 Help
- ALTA Sport Suspension Package
- Question about H&R Street Coilovers.
- Clunk after Coilover install
- Cost estimate for removing coilovers and installing stock?
- rotating the wheels
- mini cooper s lowering springs DIY HELP!
- Questions after H&R cup kit install
- R56 MCS Rear Neg. Camber?
- $250 for a rear sway install??!?!
- Finally Lowered with Wheels
- VOLK CE30,SSR TYPE C ,BBS RE OR OZ ULTRALEGGERA ?
- eibach coilovers
- First mods
- H&R + additional shock absorbers
- Do 215/45/16 tires fit on the R56 Star wheels?
- JCW Suspension Before and After
- 245/45/17
- R56 struts interchangeable w/ r53 struts?
- Looking into getting coilovers
- R56 Front sway bar
- Will H&R sports spring make it more comfortable than stock JCW?
- Suspension "Tuning"
- Cross coilovers for Clubman
- justaCooper handling roadmap
