- What do you think about this setup?
- Best Downpipe? Exhuast Depot, Riss Racing, ..?
- Ordered a DP from ExhuastDepot, its been 1 MONTH!!
- VVT Question
- Clutch Replacement Questions for an R53
- Is there a maximum WHP for an auto MCS?
- 18s summer high performance wheels for JCW
- exhaust burble/poping..
- Tune vs. Other modifications
- R56 chiptuning
- JCW R56 goes 2.05.701 @ Buttonwillow Time Attack 1st round
- Anyone have experience with this intake?
- Muffler delete ?
- Twin Turbo MINI
- Alta oval tip cat back for mcs 07
- RMW-ROCHESTER TUNING_APRIL 16-17
- JCW baseline dyno + NSW/XXX/hardcore under bonnet porn!
- CAI Question
- VIBRANT VS FLOWMASTER VS BORLA
- GT28RS Project
- Alta Exhaust and Factory Warranty
- CATTED DP's and CEL
- oil cooler, anyone installed on R56, thoughts..
- Seattle RMW Tune
- DoS vs. factory JCW intake (K&N)
- Retrofit ALTA CAI foam filter with paper filter?
- noisemaker delete question
- Water/Meth Injection For The Track
- I borrowed a DP lost the return address...
- BMC CDA on R56 Mini Cooper S
- R56 Alta Lightened Crank Anyone Have?
- I abso-FREAKN'-lutely love my new DoS intake!!!
- '10 mcS to JCW power with Flash?
- Some sound clips...
- Cold air intake vs hot Air intake on FI cars
- OBX Exhaust Header
- "My" Cold Air Intake
- Loss of power between 5-6k rpm
- For those that can't wait for RMW's remote tuning... alternative!
- Mitsubishi TD05-big16G - 271 Hp
- Vac only and Boost only...
- Easy fix for rubbing boost tubes.
- does your inner cooler cause a lot of vibration?
- goPoint Technology
- supersprint exhaust
- Looking for....
- Found A New CAI
- boost tubes
- Drill Air Box
- Blow off Valve Question ANY REVIEWS?/ HELP
- as much as I would love for this to be true..
- Exhaust Depot - Out of Business??
- Cravenspeed SSK and NMEng Torque Are Insert are in:
- NEW hard turbo inlet from ALTA
- List your MOD with performance gain and MPG lost/gain
- Do You Know?
- Well, was it worth it?
- JCW R56 goes 1.24.103 at Street of Willow
- Want to improve performance what to get?
- GT28RS Tuned @ 338whp
- TPS reports through ScanGauge
- Loss of boost! 6 psi. HELP!
- 2009 JCW cold air intake?
- water/meth injection suggestions?
- Spark plug non-fouler mod on Alta TBE
- spark plugs eh?
- Exhaust Opinions Needed
- BSH catch can and dual boost port install
- manual boost controller
- Riss o2 sim FIXED
- is Alta Catback Exhuast Worth 500$?? need opinions
- wrong forum
- Hood scoop options...
- HOW TO HOOK UP MY MINI COOPER S
- help with alta bov
- Help Regarding M7's VELOCITY Throttle Booster
- how much is a fair price for labor at a dealer to install a JCW stage 1 tuning kit?
- SWEET RIDE!
- Best intercooler ever..??
- Check engine light help/suggestions
- LSD Options for R56
- boost interruption
- Akrapovic Exhaust
- Help installing Helix intercooler
- What does yours rev to.....
- Riss o2 sim impressions
- Velocity Adjustable Throttle Booster System- Wow
- Intake
- alta blow off valve
- 50+ FWHP with M7 AGS-R intake?!?!?!
- ***OFFICIAL SIGN-UP THREAD for FLASH TOOL***
- ALTA has a lieftime warranty now?
- ARC (ATOMO) Products
- Exhaust for 2010 S
- catless we go!
- Anyone running a Riss catch can with an Alta CAI and hard pipe?
- JCW: How much boost should I be producing?
- Running with no cats? Please tell your experience
- OBX catless downpipe?
- Question about DDM RIS system
- A word about RMW.... worthwhile.
- Dealer JCW Satge 1 or JCW Parts and RMW Tune?
- RMW tuning day at Helix in Philly Mar/Apr '10
- Remap Problem
- Power Ideas...
- Alta's Turbo Inlet Hard Pipe Fitting issue
- Headers on a turbo MCS?
- pulley on a 2007?
- Mini Cooper S Launch Control!!!!
- RMW Tuning Day in eastern Connecticut is on the Horizon around May 25-26, 2010
- **Riss Racing** R56 Mini Cooper/Clubman S Sequential BOV System! (Video)
- guestamate my HP
- Forge IC without ECU tune
- Riss Racing R56 o2 fix Launch!
- JCW Tuning Kit comes with this?
- How much boost are you getting?
- My only option...more or less
- R56 S PCV System ?
- JCW exhaust?
- Tuning
- JCW Stage I exhaust inlet pipe diameter?
- aftermarket clutch
- Need input from people that tore down timing......
- New Arqray Ti Exhaust :)
- Intake & Exhaust Noise - Yes I searched 1st :-)
- Air Intake
- Riss Racing Exhaust Installed
- Thinking about mods for 2010
- Catted VS Catless
- RR Downpipes, feedback?
- R56 Noisemaker Revealed!
- Exhaust Depot Downpipe... Ceramic Coated?
- resonator delete!
- NM Cold Air Intake or M7 Cold Air Intake?
- Best Exhaust for an 07 Mini Cooper S?
- JCW Kit Parts
- Shorten shift throw?
- RMW Orlando Tune: Post up your results!
- Big turbo upgrade with the Garrett GT28RS!
- Big turbo upgrade with the Garrett GT28RS...
- What do you get when you add DOS cai and a Quicksilver exhaust....
- A different oil catch can question
- Wanted: stock turbo for development work
- Post pictures of your mounte scangauge
- Oh no, not again, ANOTHER melted valve cover...
- primary cat gone vs all cats gone
- Trying to reach Riss Racing? Start here.
- Opinion
- Unichip Universal Tuner Kit
- Riss Racing's restructure
- Riss Racing Inc In trouble please read
- Giant Hole in Alta Downpipe
- Running lean why?
- yet another CAI question
- NM Engineering products in MINI JCW
- APEXi Units?
- Message from Adam@Riss Racing
- Better ways to spend Modding Money?
- No Oil Change for a Year?!?
- R56 Factory Service Manual?
- NO OIL!!!!!!
- FMIC ?s
- Anyone have a used R56 flywheel for sale?
- ?s about clutch/flywheel
- RMW & Maitland Importers Tune day Dec 12
- fuel system cleaners...check this out
- Unichip Destoyed My ECU
- Oil Leak????
- Forge BOV questions
- Clutch replace @ 9.5K
- Water temps about 215F. Is this normal?
- JCW dyno pull
- Mini Boost gauge work with supercharger pullys???
- Evotech Software Tune
- eBay short shifter
- DoS CAI Owners: Defenders of Speed wants your feedback - CAI Baffle Development
- Data logging
- Which Front Mount Intercooler should i buy
- nm-eng what to expect?
- New(er) m7 Super AGS Install?
- Any feedback on the Forge CAI
- Quicksilver exhaust
- I am only boosting 10 or 11lbs , overboost to 12.6 help me figure out why?
- why are people selling their unichips?
- m7 Oil Catch Can Info?
- Need help identifying a OBDII code
- R56 MCS 174hp N14B16 Dyno tuned to 245bhp
- Lots of Alta... Bad dyno???
- CEL went bye bye
- Where to buy: Motor Mounts & Stud Conversion
- Alta exhaust resonator delete?
- Ported & Polished Head - A Missing Link in the R56 Quest for Power/Torque
- Alta CAI, Turbo Inlet and Noisemaker Delete Install.
- R56 boost reading: REV2 vs. boost gauge
- R56 Cutom Tune by Mynes
- way motor works tuner
- JCW sparks
- Arqray exhaust. What to choose???
- ED Downpipe Heat shield
- JCW Tuning Kit for '09 Clubman/Worth it?
- HELP loosing boost because of?
- denso for R56s in denso JP site only??
- Carbon Fiber Boot, Bonnet, Doors, and more
- Limiter in first and second gear
- GT28rs Turbo kit. Did you guys see this?
- modify wastegate acuator
- Scangauge xGauge - Now display BOOST without MAP
- RMW Tuning Feedback -How's your R56 MINI doing?
- Gearbox oil viscosity?
- '09 JCW DYNO results - Forge Intercooler
- P2187 CEL
- Defenders of Speed Vs DDMWorks
- GReddy RZ BOV on r56
- check out this exhaust for only $300
- rmw tune in stamford ct at ics
- JCW intake with aftermarket filter?
- RMW N/EAST TUNE--ROCHESTER NY
- My new exhaust!
- Need Help Find Samco Induction Hose
- GTSPEC STB
- Air / Fuel Ratio works with Scangauge xGauge
- Help
- O2 Sim / P0420 code delete
- P1497 CEL
- Eisenmann exhaust?
- M7 Oil Catchcan
- blow off valves
- Intercooler Performance Gains?
- Alta or M7?
- factory air box
- GT28 turbo kit from ati
- Problems with Alta boost tubes, check yours!!
- MiniMania exhaust OEM Tips
- My custom Stainless Cold Air Intake
- Alta Catback vs. Custom DIY
- Installing an LSD in the R56
- Forge R56 Intercooler Props
- noisemaker diameter? for bov
- RMW Custom Tune Party in Austin, TX, Oct 16/17
- My New Mini Cooper S 2009
- Mini tuning in Australia
- DDMWorks RIS and brake vacuum
- Ibiza Cupra R FMIC on the 09 207 RC !!
- Has anyone Tried Superchips on their R56?
- Milltek Turboback
- Alta vs Helix FMICs (For those who want to see the difference)
- aeroforce interceptor scan tool
