View Full Version : Drivetrain (Cooper S)
Pages : 1 2 [3] 4 5 6 7 8 9
  1. HELP losing boost. At 1/4 track right now.
  2. Downpipe instal HELP!!!
  3. Where can I find instructions on DOS noisemaker delete installation?
  4. Octane boosters
  5. RMW now has Alta Access Ports in stock!
  6. downpipes
  7. HELIX FMIC Update
  8. Shifter Feel
  9. Got me a M7 Heat Shield and saw some rare MINI's too *lots of pics*
  10. Sound clips of OBX DP and JCW exhaust
  11. VSS on a R56
  12. Alta AP Tuned before & after OBX Catless DP results
  13. replacement o2 sensor
  14. JCW turbo on Cooper S
  15. Weird boost problems
  16. Extra o2 bung...
  17. Exhaust, CAI and ECU Tuning
  18. Mini shops in Orlando?
  19. Welcome your opinion and why.
  20. RMW Updates
  21. Recomindations please and why?
  22. ALTA AccessPORT Sport Button Poll
  23. NGK Spark Plugs
  24. 2010 MCS intake help please?
  25. Ceramic coated Riss Racing downpipe
  26. a Clutch replacement question...
  27. P0597 Cel:Thermostat Heater Control Circuit/Open
  28. Bsh Dual Port Device
  29. ALTA AccessPORT Dyno Results...
  30. Swiss-Cheese Intake?
  31. Magnaflow cat back exhaust
  32. Factory JCW Exhaust on MCS
  33. Help Me Find My Exhaust!!
  34. Time to mod the mini!
  35. Another Dang Exhaust Question
  36. RMW Custom Tune Party in Austin, TX, Oct 15/16
  37. CAI Comparisions
  38. R56 Throw Out Bearing Issue
  39. Cheaper way to help underhood temps on Cooper S....
  40. Heat Shield Testing?
  41. BOV, DV, Noise Maker Clarification
  42. Narrowing down exhaust choice
  43. R56 Stock BOV
  44. AC Schnitzer
  45. 3rd day on track with Alta's Access Port and tune... review
  46. Adjusting Exhaust--
  47. Warning: Cravenspeed Dipsticks
  48. plasma ignition
  49. NM or ALTA pipping
  50. My car is making noises….
  51. IC pipping
  52. Installed Alta's AP... my impressions.
  53. ALTA wants you to take this POLL
  54. ALTA accesport vs RMW
  55. Need OEM Intercooler ASAP !!! Please
  56. open downpipe
  57. R56 Mods
  58. ddmworks ram air scoop
  59. The Official ALTA AccessPORT Thread
  60. NOBS Engineering CAI
  61. Remus Power Sound Exhaust
  62. Rwm Tune Or Unichip Tune?
  63. GForce ECU chip anyone?
  64. Multiple upgrade questions
  65. Helix or Forge intercooler and why
  66. ALTA's Next Evolution In MINI ECU Tuning
  67. 2.5 inch vs 3.0 inch exhaust (sound)
  68. Wheel stud torque spec
  69. Alternator/water-pump belt change-R-56
  70. 22MPG... more inside..
  71. If you guys want Magnaflow exhausts...
  72. RMW Tune
  73. CEL Code Question
  74. DDM RIS intake opinions 'from owners only'
  75. Flash tuner tool coming soon from Evolve in UK
  76. Borla Type-S Review
  77. NM ECU tune
  78. obx downpipe + obx exhaust?
  79. itg replacement filter
  80. newbie intake question
  81. DDM Exhaust for R56
  82. Carbotech pads HIGHLY recommended!
  83. HELP - New to mini P0172 code
  84. Anyone have a built engine/replaced engine?
  85. Used Porshe Brembos on R56?
  86. Riss Racing O2 Sim...
  87. Anyone know exhaust angles
  88. 2009 MINI, What do I upgrade first
  89. Intercooler sprayer
  90. Newb looking for parts
  91. Removing Downstream Cat
  92. wmw performance bov?
  93. What is the best $2000 you can spend on city driving?
  94. Yamaha R1 Muffler project.
  95. exhaust tone w/ catless dp
  96. Lots of $$$ What to buy??
  97. NM discharge pipe or Madness muffler delete?
  98. Thermal Dispersants on a DD?
  99. BSH Catch Can Not Catching Anything
  100. Brake Cooling duct revamped air intake?
  101. P115D help please
  102. Quaife ATB differential in an R56: What I've learned
  103. Tunes in FL?
  104. Camshaft Installation Manual On Mini Cooper R56s??
  105. converting internal wastegate to external
  106. Specs of OEM turbo?
  107. What's a good way to lesson the "grabby" nature of the brakes?
  108. Expansion Tank Relocation
  109. Do all R56 S aftermarket exhausts fit the R57 S?
  110. Modding a forge BOV Adapter?
  111. Mini lowers price on HPFP
  112. Aftermarket exhaust sound
  113. Different JCW factory exhaust p/n for cars built May 2010 and after?
  114. R56 Cams...
  115. Emissions Test - FAILED
  116. Finding Help
  117. Alta IC Success Stories?
  118. MPH with a tune
  119. Your Thoughts... OS Giken or Cusco LSD?
  120. MCS n00b - engine tunes question
  121. Exhaust Depot + Q300 Exhaust
  122. chipping
  123. another cell???
  124. New filter for stock air box?
  125. Crank Pulley Help!:confused:
  126. How much hp can an AUTO handle?
  127. Brake wear warning light
  128. help magnaflow
  129. Running too lean with Alta IC on R56_S?
  130. Useable Power
  131. Intercooler Question
  132. Installing alta CAI
  133. NM "Pipes"
  134. Sprint Booster????
  135. trans swap?
  136. power mods
  137. Complete Picture?
  138. RMW tuned R56 driven by Ian Stewart terrorizes the more powerful cars at Sebring!
  139. Cleaning Super-AGS filter
  140. help with cell???
  141. Turbos 101-103
  142. NM Eng Intake info
  143. Looking for a solution
  144. Garrett GT28rs
  145. best exhaust for the r56 (nm's?)
  146. Battery dear! Can I jump start it?
  147. Oregon RMW Tune
  148. Best choice of Downpipe for Cooper S? with no Check Engine Light
  149. Check out the newest Whalen Shift Machine!
  150. Limit of Aisin Transmission??
  151. ECU Mod, Aftermarket Parts, and Warranty
  152. Stock CAI vs aftermarket CAI's - request for data
  153. Stock MCS CAI vs stock JCW CAI
  154. Where I can get ecu tuned for R56 around MA, CT, NH area?
  155. R56 Turbo Inlet Hard Tube?
  156. NM intake soon to be CARB certified
  157. Engine bushings?
  158. Rev Limiter?
  159. R56 Sprint Booster
  160. QUIETEST INTAKE with PERFORMANCE gains?
  161. RMW ROCHESTER MAY 21-22
  162. Stock intake tube slipping off turbo inlet
  163. bad wastegate? or?
  164. R56 Flywheel vs Wheel Dyno Power Numbers
  165. Show Pics of your Whalen Knobs!!!!
  166. Borla Exhaust system/2009 Mini S
  167. Limp mode after 4k (rpm)??
  168. R56 @ Pacific Raceway
  169. Upper Bulk Head and BSH OCC
  170. Post your 2nd gen dynos!
  171. Pleading Request!!
  172. Will Resonator delete make my car noticably louder?
  173. Base 1.6 or "S" model??
  174. Interested in a RMW tune party in Eugene, Oregon?
  175. Bragging Rights- What cars have you beat or lost to?
  176. Mynes stepped header
  177. Positive Steering Response System Alta?
  178. HKS BLOW OFF Valve?
  179. Way Motor works down pipe?
  180. Howerton Engineering Water/Meth Injection
  181. Recently Installed Alta Intake and Boost Tubes
  182. Is the helix or NM short shifter adapter (Stay or runaway)
  183. RMW tune..
  184. Redline products for Manual Gearbox...
  185. Pulley installed; lound noise from supercharger
  186. I just bought the Magnaflow exhaust.
  187. Has anyone installed the M7 Vortex 2 hood scoop?
  188. Has anyone installed the NM rear sway bar and the NM intercooler pipes?
  189. Exhaust Depot Downpipe Install
  190. I need a catless downpipe, who has one?!
  191. Whats up with WMW?
  192. NM Short Shift Adapter?
  193. Big Brake Kit question
  194. Exhaust dilemma
  195. R56 Cam options?
  196. SS Brake Lines...
  197. Riss Racing Stage 1 BOV - Power Loss - HELP
  198. BSH Lower Motor Mount
  199. Exhaust questions
  200. BMW/MINI Cooper Specific OBD II Codes
  201. Exhaust Depot P0420 Code - Laugh or Cry???
  202. Boost Gauge rattle?
  203. Spark plugs
  204. need help pulling the trigger!
  205. Alta R56 S Turbo Inlet Hard Pipe?
  206. How loud do you think this would be?
  207. to Anybody who has installed M7 AGS-R intake...
  208. R53 Stock Boost??
  209. HELP!! ED Downpipe install help please.....
  210. Seafoam and PCV issue
  211. Downpipe Question
  212. What kind of pulley should i consider?
  213. blow-off valve???
  214. Velocity booster?
  215. Dyno chart after RMW tune
  216. Tuning (RMW or other), Dyno & AFR....
  217. The Safest way to more POWER
  218. HKS powered MINI r56s
  219. nm engineering exhaust?
  220. HELP! Dieseling Problem
  221. Help with EC removal?
  222. brake pedal feels spongy
  223. Finally gotten around to posting videos of installed DoS CAI
  224. Grounding kits
  225. Stock R56 airbox.
  226. 2nd Gear Tranny Problem
  227. Exhaust depot turbo back issues
  228. Downpipe
  229. JCW strut brace and K&N typhoon intake
  230. Cravenspeed Short-Shifter quick question
  231. Milltek Exhaust
  232. '07 MCS upgrade JCW kit
  233. Mini-madness Stage 1 vs ALTA Power Pack #1
  234. MINI Madness Polyurthane Engine Bushings
  235. Batteries
  236. Exhaust SystemInput
  237. DP options and CEL on 07 R56
  238. Magnecor HT Leads
  239. K&N Typhoon CAI
  240. new items this week
  241. ceramic coated vs. polished
  242. Detailed question about tuning.
  243. I Want More HP! How can I get it?!
  244. Invidia vs Stratmosphere exhaust
  245. Tuning engine
  246. DoS R55, R56, R57 Turbo/'S' W2A IC Introductory Pricing Released
  247. Just installed NM Cold side tube
  248. Anyone have experience with the PCD Stage 1 chip?
  249. Newbie - Help with intake/exhaust mods
  250. Fuel economy
