- Low oil pressure under hard cornering.
- RMW dyno tuning DC area May 13-14
- Helix Shift Adapter Installation Writeup
- Alta Turbo Back Exhaust
- Tune Questions
- If you have a stage 3 alta tune I'd like your opinion..
- Turbo Leak?
- Torque Steer Fix Crosspost from JCW forum--applied to an "S"
- Problem with Alta Intake
- When is this 22psi map limit/cut going to be solved??
- Which is a better delete pipe?
- Plasma Ground for R56
- Lost a screw need opinions
- Mini S Exhaust: Borla, Alta or NM
- R56 Straight Pipe Anyone?
- 1/4 mile times and mods?
- OS Giken LSD 1.1 or 1.5 way?
- BBK Kit?
- Experienced Superknock at 6,600 miles
- New Owner: Cold Air Intakes?
- Boosted_Mini's Bored At Work Build Thread:
- Another Exhaust question
- Alta AP, down pipe, or fmic first?
- short shift kit
- Gforce chip??
- Done all Exterior and Interior Mods! Time for Performance!
- Access Port and dealer support/warranty. Anyone had issues?
- How many people have actually swapped their turbo?
- JCW Exhaust Pricing
- Best exhaust with the best hp increase.
- Intercooler piping
- New AccessPort for sale....$825
- BOV Blew Off!!
- Catless DP and resonator delete + WMW Catback too loud!
- has anybody broken a fitting on the valve cover
- looking for stock parts
- Recirculation (DV/BOV) valve.
- Helix vs Alta FMIC
- Oil Cooler
- PCV hose delete.
- upgrading DV on 2011 MCS
- 2011 Functional Hood Scoop???
- Custom invidia q300
- R56 Stratmosphere Stainless Exhaust
- GT28RS Build Questions
- Better Clutch?
- 2011 R56 DDM Race System
- Best exhaust for D-Stock
- ragazzon exhaust
- Who else does tuning on R56?
- NM exhaust on '11 MCS?
- Stage 2 & Stage 3 Tuning Questions
- Agency Power Exhaust
- Very stupid question!!
- When is a good time to get a tune??
- Is this a Stage 1? If So any good?
- Intercooler Hoses Question
- Forge Motorsports Undertray question
- RWM dyno tune in CT...slots still open..Gen 2 welcome!
- Exhuast Question
- Scanguage II installed
- Another FMIC worth noting
- Wavetrac LSD
- If your R56 is dropping boost check this:
- question for the access port!
- Just put an Alta cool air intake on my R56!!
- Intercooler Accessories
- Misfire Cooper S 2009
- Loudest Blow off Valve sound, which intake?
- Assistance on Starter Performance Mods...
- Help............R56 BPV Question
- Akrapovic down pipe installed
- requesting engine dimensions
- Stupid exhaust question
- Stock clutch, when to change, power wise?
- intake pipe (cold side)
- OldBrokenWind's Thumper head, GT28RS, & Alta "stuff"
- Noob inquiry about getting a "tune"
- 2011 Bov & Cai
- 2011 MCS accessport group buy
- ABF Tech Division R56 turbo back exhaust system
- Silicone Coolant Hoses For Mini Cooper S Turbo
- Blow off Valve
- Intake Routing Project
- Is there a stroker kit for the MCS?
- problems bunch of codes need help!
- Aftermarket performance and tuning for the Cooper S Countryman
- Introducing the ALTA BOV Spring Upgrade
- psi with alta accesport
- Group Buy for Defenders of Speed Intake, who's in?
- R56 pulley
- $1,000 Budget...
- Riss Racing vs. Exhaust Depot ???
- Transmission Question
- 2011 auto mcs mods
- New Owner, magnaflow?
- Is It Possible to make a 2nd Gen S Go Fast
- Stock diverter valve stopped working
- DDM ram scoop and M7 AGS?
- R56 Clutch tester needed
- "Hypothetical" Exhaust setup
- new car Mods.
- Exhaust Depot ??
- JCW Downpipe Diameter
- Lard in Oil Catch Can???
- alta tuner
- Alta CAI help
- Extending Slots on Strut Bar... calling machinists
- Will a ddm works race intake system fit with a strut brace?
- any pics?
- Some Noob Questions on parts to get..
- R56 V-Tec Swap?
- Hi-flow intake tube?
- Magnaflow exhaust part 16815 Good idea?
- Anyone put a K&N panel filter in an 07' R56?
- Quicksilver exhaust installed and love it!
- AccessPORT or Dimsport
- Recent install
- BSH OCC install with DDMworks Race Intake
- Mini Cooper 2007 spark plugs
- Helix Motorsports
- Dual mass flywheel.
- JCW Kit for 2011 MCS
- JCW dealer installed exhaust vs. Alta
- Looking for 2011 MCS Blow off valve kit.
- R56S Custom Exhaust question
- Exhaust>Subs
- Meth/Alky/Water injection
- Temporary rough Idle upon stopping. :c(
- Exhaust Choices
- K&N Air Filter+Dust=Help me Please?
- Acorns in the intake
- HELP needed - engine sputtering after tune!
- NM Eng Intake + QuickSilver Sports Exhaust
- Flowmaster Mufflers new contest - "Show us your flows"
- new car 2007 mini cooper s need some ideas
- 0 to 60 times and more.....
- Seafoaming???
- please recommend mini specialist in SoCal
- Anyone try Cravenspeed's OBD2 Bluetooth tool?
- TyrolSport Releases New Front Mount Intercooler for R56!
- Standalone ECU
- Buying From Alta
- Obx cat back
- If you haven’t had an RMW update lately, you may want to look into it. : )
- New OS Giken GT1CD R56 Clutch??
- Disconnecting the expansion tank
- forge bov and forge bov adapter problem!!!
- HKS Exhaust/bov
- what do i do? unichip
- r56 Stratmosphere exhaust no longer in production?
- non s converted to an s
- Plz Plz Help
- Any one here have a NM cat back exhaust?
- Air Intakes - Stock S vs JCW vs Alta
- custom exhaust or jcw stage 1 exhaust
- Milltek exhaust installation and review on my R56
- Adding / Retrofit sport button R56
- Akrapovic systems
- autometer boost gauge help
- K&N Typhoon intake for less than $200shipped...
- NM Air on R55 S
- Tune... What?
- Oldschool is coming back
- Does anyone has a Dimsport tool for sale?
- Stage 3 Mini just threw a code! (p2885)
- alta 3" stanless catback dual tip legal in cal ?
- JCW brakes with R111 rims?
- squeaking pedal...
- Random valve cover question
- New Borg Warner EFR Turbo
- question about programming ECU?
- Spark Plug 07 Stock MCS
- losing boost again
- R56 Gear Question?
- JCW Turbo to MCS
- how about rissracing?
- Weight of stock exhaust?
- Oil Catch Cans: BSH vs. M7?
- Parts installed and a few concerns
- Aftermarket Intercooler...universal?
- OCC needed on 2011 MCS?
- maybe a different exhaust question
- Manual Tranny Lube Questions
- New FORGE BOV any input?
- Long term use of the Accessport
- Road side assistance is on the way...
- My MotoringFile AltaAP review - 1/4 mile included
- RMW's My Genius Software....
- Code P303a- What is it?
- MCS boost sensor
- ALTA Billet 56 MCS Turbo sneak peak....
- Forge BOV
- Intercooler options
- True Flow 90206 Air Filter Universal 3" Inlet (5.5" x 9"
- power from a 2007 s
- Decat caused power and torque lost?
- Electronische Wegfahrsperre (EWS)
- Just got the Invidia exhaust
- Found something interesting on wikipedia...
- Schrick Cams
- Need a manual shifter quick
- AccessPort Group buy or discount?
- Black Friday sale discount not applicable to ALTA AccessPORT?
- Limp Mode?
- Alta Downpipe + Stratmosphere catback
- Cooper S - worth upgrading to JCW brakes or not?
- start track racing
- Got this Crazy Idea
- Cold tube/sound generator hard pipe
- JCW CAI for a MCS
- Teaser... FMIC
- Control problem
- Fleabay Intercoolers?
- DoS CAI & JCW Intake Tube
- LF Flywheel R56S (on rush) - Where can I find one really fast?
- Turbo S vs Supercharged S?
- Intercooler muffler delete for $8
- Wheel Hub replacment???
- Exhaust Depot Downpipe on eBay $360
- R56 Mini Coolant
- Stepped Core FMIC
- Where to buy anti rattle clip for R56 front calipers?
- WMW turbo downpipe...
- my project begins
- Ram Air Scoop & Cold Air Kit
- What best oil catch can for money?
- Downpipe with 200 cpsi
- Got a Magnaflow cat back. Direct bolt on?
- lost for an exhaust
- For anyone curious about the "helix 13" bov
- OS Giken Super Lock Limited Slip Differential (LSD) - looking for feedback
- OS Giken STR Clutch/Flywheel - looking for feedback
- Wastegate Problem MINI S 2008 US
- Exhaust impression
- Flash2Pass install on 2008 Mini Cooper S
- Alta Intake Problems
- CEL Fault codes
- Zoomer cat back
- An added benefit of a short shifter...
- Help! 2009 R56 Flywheel compatible with 2008 R56?
- BSH Boost Tap + eBay Catch Can Install
- NM vs exhaust depot
- Got my best 60ft, 0-60 and 1/4 miles times tonight *pics*
- Hard turbo inlet?
- Max reliable power....
- Back Pressure?
- oil change
- 2011 exhaust
- WMW Performance Blow off Valve -- opinions?
