View Full Version : Stock Problems/Issues
Pages : [1] 2 3 4 5 6 7 8 9 10 11
  1. SZL Replacement Question
  2. Seat Heaters suddenly wonky
  3. Sunroof - loud cracking noise
  4. Gear box noise
  5. R56 Turbo 55K miles oil usage question
  6. and the fun continues...
  7. My engine wants to stall ...
  8. Yellow "Brake" Light - Hill Assist Fail
  9. Power mirror/seat heater fuse blowing in '09 Clubman S
  10. Latest problem
  11. R56 Headlight Problem, check engine light
  12. R56 2011 Oil Seal Leak
  13. Rear bumper fascia part number?
  14. '11 MCS starts then dies
  15. Shocks/ When to replace?
  16. Door Rattle (sooooooo annoying)
  17. I think my speedometer is off
  18. Valve noise when cold.
  19. Low fan not working possible solution
  20. Strange problem. Almost sounds like my Mini is backfiring!
  21. Possible Clutch Problem
  22. Weird engine sound in clubman s when accelerating
  23. Lower Radiator Hose
  24. Should MINI take a page from Lotus?
  25. 2011 MCS Hazard Lights Turned On Themselves and Now Headlights Turn Off
  26. Where is coolant bleeder screw?
  27. turbo oil feed line access from bottom?
  28. Primary Water Pump
  29. MINI Extended Motoring Protection XXL
  30. Stuck between a rattle and a hard place
  31. Thousands of Minis and Mini Coopers recalled
  32. P0300 - Cylinder Misfire Detected - What should I do?
  33. MINI USA Announces Water Pump Recall Affecting 89,000
  34. Oil Leak!
  35. Need Dealership information
  36. Broken Spark plug caused $8000 Engine damage
  37. Predicting 6 speed auto troubles?
  38. Knocking and clicking from manual transmission
  39. Anyone hear a slight scrape sound at ~2k to 2.5k rpm?
  40. Help Me Diagnose a Tranny Problem?
  41. The continuing saga that is our Mini
  42. 2011 non-s cooper cold start engine rattle
  43. Sound & Microphone suddenly dead
  44. Has anyone ever had their timing chain paid for by an extended warranty?
  45. Turbo Dead at 72K....
  46. Coolant leak - oil filter housing?
  47. Approaching the line
  48. CEL on my wife's cooper
  49. turbo issues
  50. Part numbers required?
  51. Ignition Coil Cylinder 4 Error
  52. Hard Starting, Cold
  53. New to the Fam but has arrived with a few probs
  54. Mini Not Paying for Oil or Fluids Between Scheduled Maintanence
  55. 2007 MC S turbo problems
  56. Both Window Toggles won't work
  57. Red Warning Critical Failure
  58. Oil leak update/ question
  59. rough idle cold start R56
  60. Beware! Turbo design flaw
  61. Radio static
  62. R56 Justa Cooper - Cold Engine Rattle Clatter Noise
  63. Turbo\DV issue
  64. My Awful experience at Keeler in Latham
  65. Stupid question time...
  66. Engine Whine on an 08 Turbo
  67. Yellow Check Engine Light -But -No Code Thrown?
  68. a picture of the OXYGEN O2 SENSOR with socket
  69. Thermostat leak
  70. MINI out of warranty, check engine light on
  71. Boost leak / coolant leak
  72. AC Compressor not turning on..any ideas?
  73. Knocking from right front wheel well
  74. 2010 JCW Clutch Issues
  75. Sunroof Sunshade Rattle
  76. Oil Change Mystery
  77. oil on turbo?
  78. HPFP, Timing Chain, Cold Start "RESOLVED" for 2011 and 2012 "S" Models?
  79. Weird warning light? Anyone else see this?
  80. 2011 MCS (Squeaky Engine Bay Sound) Video Inside...
  81. Rubbing sound at 1800 RPM take off......
  82. TPMS issues
  83. transmission no longer feels connected to engine
  84. Emergency! Engine/turbo failure possibly due to low/no oil
  85. Stuck sunroof, left side
  86. Power steering speed-sensitive question
  87. Automatic Transmission Stalls - Any Ideas?
  88. Sunroof buffer
  89. 2007 COOPER S - 82,000 miles - Repair, Scrap, Sue?
  90. Need some quick advice re: window problem
  91. Help me find Diverter Valve
  92. Power Steering Malfunction 2007 S
  93. 2011 just a cooper steering issue
  94. Several Problems with 08 Mini Cooper
  95. LOVE my car, but....
  96. hard start/rough idle 2007 R56
  97. Run Flat Tire Repair??
  98. Door not closing all the way?
  99. Spare fuse in fusebox
  100. Warped rotors
  101. Cheap online replacement bumper cover?
  102. Timing chain issue could also happen in 2010 r57?
  103. name that sludge :)
  104. Is it drivable with engine lights on??
  105. How, exactly, does the valvetronic software cause engine to 'slip'?
  106. Broken oil pump solenoid and thermostat
  107. 2012 Cooper Hatchback changes
  108. Slight grind between 1st and 2nd when cold
  109. Water pouring inside car when it's raining and you open the door(or window)
  110. HPFP symptoms list? I think mine died.
  111. Which dealer to use near Asheville for Timing Chain/Tensioner Failure
  112. Innovate OT-2 OBDII Gauges
  113. have a red warning light need some input
  114. replaced coolant temp sensor, cant get system to bleed
  115. MAJOR electrical issues, nearly every warning light went off
  116. Interior lights flashing?
  117. Half engine power... Supposed vacuum pump issue.
  118. "The Rattle"....
  119. so help me out here
  120. What's that rattling sound?
  121. MINI Service Common Sense?
  122. New Key Charging Error
  123. Anyone do SIM110207 themselves
  124. 2007 All motors...going...
  125. Xenon Control Module bad ... replace myself?
  126. Increased Emissions: O2 Pumping Current Sensor Open Circuity
  127. Roof Rack Clearance
  128. no start condition, starts on ether, runs fine after. every day
  129. Clubman S - brakes
  130. Cold start on 2011? Anyone?
  131. Thermostat DIY
  132. Cold Engine Rattle/Knock but NOT timing chain tensioner
  133. Sport Mode Default
  134. Leaking Oil/Coolant Again!
  135. 2011 MCS Magnetic Drain Plug Pics @4500 miles
  136. Turbo Oil Pipe Leak
  137. Back Up Key Issues
  138. Best anti-scoop melt product
  139. Engine stalls on cold start
  140. Help with CEL Code
  141. Wheel well
  142. coolant fluid reduce
  143. Mini From a Flood
  144. Timing Chain Tensioner Measurements
  145. Headlight problem
  146. "Lines Cut" on Rear Passenger Window
  147. Not another cold start issue? Searched and not found anywhere else.
  148. Rear Sway Bar Bushings Worn? R56 2008 justa Cooper
  149. Cam tensioner replaced, cold start rattle gone!
  150. 07-08 R56 NHTSA Complaints--Spontaneous engine bay fires
  151. Harsh Bump Causes Airbag Warning Light to Illuminate
  152. I Love driving, but hate owning my Mini
  153. Newbie question
  154. Important facts about stupid "ETHANOL""
  155. Unusual sound from engine
  156. D.A.B/Battery/ECU/Memory/Sunroof help please :)
  157. Turbo Bought the Farm
  158. Squeak After Shutting Car Off
  159. Bouncy Idle
  160. No Power/No access with FOB or Real Key
  161. Stall? WTF!?
  162. Engine replacement on day one at 90 miles. What would you do?
  163. Vacuum Pump Failure - What is the Reasons(s)
  164. Rain Sensors seem to be wrong
  165. Is this the "rattle of death.."
  166. 2012 MCS Sport button light stuck on
  167. Creaky Headliner/Sunroof Trim
  168. Lost all radio functionality
  169. Odd electrical/electronic problem
  170. Oil not draining
  171. Service icon not in owner's manual
  172. Cost for full SIM110207 Service (cold clatter)
  173. Noise just during take off/at start
  174. Electrical Problem. NEED HELP!!
  175. R56 cooper s - 5.000 miles - possible death rattle ? Please help
  176. Blown Transmission
  177. Dangling Wire Near Passenger Rear Wheel
  178. Leakage and spots.
  179. Battery and Warranty work question
  180. Is it OK to reveal the name of a dealer that does a great job or a poor job?
  181. possible pcv failure?
  182. Hi can someone id this warning for me?
  183. MCS Clutch Dead at 34k: Replace with MCS OEM, JCW or OS Giken GT clutch?
  184. My Broken 2012 Cooper S
  185. Help! Replaced tensioner, now chain bad
  186. Headrest interchangeability: mini-mini, VW-mini?
  187. Clutch issue
  188. Good repair place in So Cal? Don't wanna pay the big bux at Long Beach Mini
  189. 2011 Oil Leak
  190. Crackly Door. Seals?
  191. How are these "revised" timing chain parts still failing?
  192. Secret Compartment is Stuck - How the heck do I get it open?
  193. Oil change nightmare
  194. Computers gone Crazy!
  195. Clicking noise from front wheels
  196. Sunroof vent position problem
  197. 2011 Mini Cooper Cigarette lighter ring light up at all???
  198. 2 days in and issues!!!!!!
  199. $571 for a New Battery?!
  200. Engine Malfunction Light on 2007 MINI Cooper S
  201. What are these codes?
  202. Transmission issue
  203. 2011 MCS - Knocking while accelerating in sport mode
  204. 2008 Mini S leaking radiator fluid
  205. Mini Cooper S R56 07
  206. Loose Vents
  207. Is my rear wiper missing a few pieces?
  208. Cd player not working :/
  209. '08 convertible rear trim issue
  210. Death rattle? Or something else?
  211. 07 Starting issues!!!@!
  212. 2011 Mini Cooper S Rough Starts
  213. 2007 MCS manual shifter linkage falling apart
  214. Rear Sunroof Pivot Supports Broken
  215. Dealer CAN'T reproduce my idle and clutch problems! So typical.
  216. Can you normally hear the timing chain?
  217. Sudden, seemingly unrelated electrical gremlins.
  218. 07' R56S Transmission issues.
  219. US 2007 Mini Stock Radio CD used in OZ
  220. A/C Heater Blower Intermittently Worked.. Then now stopped working at all.
  221. Interesting thread on cold start/idling issues from Mini Owners Lounge
  222. Electric steering wheel lock malfunctioning
  223. Need a new clutch
  224. valve cover replacement? Plugged PCV valve?
  225. Losing small amts of oil and coolant
  226. 07 Coooper Engine Failure Frost plug let go
  227. Clutch Click on Master Cylinder
  228. Dash lights fading
  229. Cruise Not Disengaging Easily on 08 "S"
  230. Radiator hose free from clamps and hanging low!
  231. why does this happen only in Oklahoma and Kansas
  232. clutch fail...
  233. speedometer stuck
  234. p1497 cel and cannot locate vacuum leak
  235. Warranty
  236. 2007 MCS Engine Failure - Follow on Twitter!
  237. My TPM won't reset.
  238. Help me diagnose this noise.....
  239. Check engine light on but no code
  240. Interesting occurance, Top gear roll on...
  241. Warranty Issues with dealer
  242. Leaking Coolant - Far from a Delaer. Advice
  243. Advice please: wiring switches in 2009 Cooper
  244. A Little Advice Pease About My Water Pump
  245. Odd noise when I press in the clutch, pressurized air?
  246. Oil catch can / carbon build up solution
  247. Mini Cooper Stripe Decal Maintenance
  248. Carbon Build-Up
  249. Carbon Build-Up
  250. Warning Light????
