View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 [6] 7 8 9 10 11
  1. Popping sound from rear
  2. OBDII Reader will not Link to 08 Mini
  3. After Spraying Washer Fluid - No wipe
  4. 2010 mini, Knocking noise from boot?
  5. Fraying seatbelt... anyone else??
  6. clutch grinding noise
  7. Rattles from Panaromic Roof
  8. Metallic scraping/rattling noise?
  9. sunroof adjustment?
  10. Sulfur smell...
  11. need help with intermittant horn working
  12. really quick question, suspension squeak, WD-40 safe for components down there?
  13. Random Stalling
  14. Camshaft Noise "Not Death Rattle"
  15. Help Identify R56/R57 Engine Part
  16. Boot hard to open using latch
  17. Noise when depress clutch
  18. Clutch Warranty Help
  19. R56 cold start zip pull noise?
  20. Is my CD player broken?
  21. Problem with my mini
  22. Potholes and alignment question
  23. Melting Hood Scoop Finally Solved
  24. Engine Rattle at Shutdown
  25. Autolock feature turned off? another other things..
  26. Door unlocking issue
  27. Cracked Thermostat Housing
  28. Don't do this!
  29. Cracked turbo inlet hose
  30. Inner fender liners scrubbing? Anyone?
  31. Navigator playing up
  32. First Problem - Service Visit
  33. Stock radio won't stay in AUX setting
  34. Chrome trim broke off key, warranty?
  35. My Mini SMELLS!
  36. ANNOYING rattle from hatch
  37. Front brake pads and rotors replaced 19,000 miles
  38. DETERMINED
  39. 2nd High Pressure fuel pump replaced - 1 week?
  40. Audio Tuner disappears
  41. Turbo water pump failed
  42. Dealer Warranty Work = Car running like ass
  43. My new MINI is junk: yet ANOTHER problem, now with the steering.
  44. Tapping noise in rear
  45. Noise Question!
  46. rattle sound with video.
  47. what is this steering noise i'm experiencing?
  48. REAR WASH WIPE
  49. MINI Engine Rattling Humming Loudly- New Part
  50. Clutch/engining clicking noise
  51. Passenger Side Window is SLOW..
  52. Clutch Squeak
  53. Blue smoke upon startup?
  54. a British thing or what?
  55. Multiple ticks on acceleration (sounds like a metronome)
  56. "Death Rattle"
  57. Engine Malfunction Light = Turbo, not covered under Warranty
  58. hatchback rattle
  59. Reduced Engine Power When Full Throttle
  60. 08 Cooper S cold start engine light and reving
  61. Radio: what is the AUX connection used for?
  62. Does your A/C make a loud whirring noise when it starts up?
  63. Smoke inside cabin upon starup
  64. Engine Malfunction Indicator
  65. 8k on front stock run flats and almost bald!?!?
  66. Grinding sound when braking
  67. Clutch rattle? Throw out bearing? Flywheel?
  68. Power steering going out?
  69. Dying battery?
  70. Engine won't start after fueling?? HELP?
  71. Door rattles found
  72. Yellow check engine light and below zero temps
  73. Why are Mini Coopers still junk?
  74. Rear Seat Removal?
  75. Clutch issue that doesn't match the others.
  76. Clutch Pedal
  77. I am hearing a rattle in my heater.....
  78. Sound of water in the dash, and stiff doors
  79. URGENT! Check your seatbelt fastener!
  80. 2007 Mini Cooper S startup issue
  81. Rattles Galor
  82. Does Anyone Know how to Reset the Pinch Protection Feature in 2009 Mini Cooper S
  83. 09 justa cooper stops on freeway..brand new!!
  84. Rubbing noise after car sat for 5 days
  85. 07 cooper rear end clunking
  86. 09 Oil Consumption
  87. Mini Engine Light on w/ 5k miles?
  88. Pop pop poppin' off shifter...
  89. When slowing for a stop....
  90. Broken or Design Flaw?
  91. Need insight...
  92. R56 Diagnotic Code P0012 - Cam Shaft Position Actuator
  93. random water temperature increase in traffic
  94. Clutch Issues........Smells like burnt rubber!
  95. TERRIBLE SMELL..........Clutch?
  96. Intermittent bulb out?
  97. engine wrning light...brrrrrrrr...safe to drive?
  98. My MINI in the cold.
  99. High pressure fuel pump/injector reliability
  100. 2010 Recall?
  101. Run Flat Tires: Second Question
  102. ClubBeast is Dead
  103. Leaking Water Pump
  104. 2010 Mini backup problem
  105. Passenger door will not open from inside
  106. Dreyer & Reinbold
  107. 17" Run Flat Tires
  108. Dealer advise needed
  109. Window Problem/ No suction
  110. Cold start in ALASKA
  111. power steering fan on R56?
  112. Bad Brake Master?
  113. Gas light on even though tank is full
  114. 2010 MCS - Factory Alarm Goes Off Randomly
  115. CEL/Increased Emissions warning & failure to start, at 120 miles!
  116. Exterior A-Pillar gap problem....
  117. Dashboard Rattle
  118. 2010 MCS Auto EML Light in Extreme Cold Weather
  119. Motor Dies Immediately After Initial Cold-Weather Startup
  120. Same Performance--Sudden Drop in MPG
  121. New tranny at 1100 miles!?
  122. lost interior lighting...along with high beams and fogs???
  123. Red brake light & DSC light sporadically going on
  124. Clutch squeak/screech
  125. Unbelievable - Atl dealer forgot to remove shipping blocks on suspension on delivery
  126. 2008 Mini S USB doesn't charge my iPod
  127. fuel pump noise?
  128. Speedo Indicator lights
  129. Parts Parts Parts needed
  130. Bad Oil Leak
  131. Car pauses when shifting to fifth at high speed
  132. Chain Tensioner Rattle: SIM 11-02-07
  133. Help - Automatic Transmission
  134. Parking light lens
  135. Windows are possessed
  136. Car "charging" while braked at stop?
  137. Clutch not covered under warranty???
  138. My Mini Gets Morning Sickness
  139. Another Gear Shifter question
  140. High Pressure Fuel Pump
  141. Brake problem after Disc/Pad Change
  142. '08 MCS: Heat blower gone...
  143. Tire Pressure Monitor Light won't turn off!
  144. Dead on the offramp
  145. Passenger door area rattle
  146. Found a part on RealOEM, how do I get it?
  147. 2010 MCS Poor Seat Build
  148. crevier loaner...
  149. 2010 Clubby S died
  150. Misfires High Pressure Fuel Pump
  151. Weird Pedal
  152. Bzzzzzz....
  153. Engine Knocking!? HELP***
  154. Water drip from small black oval tube?
  155. What is this stuff on my engine?
  156. CC ID 036
  157. Hand On Shifter?
  158. Auto tranny "problem"???
  159. Trimmed In Clutch
  160. What is this loose hose hanging here? (pics)
  161. Unable to reset service alert for rear brakes
  162. Axle leak?
  163. boot latch clack
  164. JCW cutting power during overboost
  165. Cruise control subtle surging
  166. DSC and Brake Light acting weird - 2010 MCS
  167. Tire Pressure Sensor Reset
  168. Help... this is not cold start chatter anymore!!!
  169. Clutch and flywheel replacement
  170. CEL: "increased emissions" = fuel pump
  171. Dirty Fuel Filter = CEL
  172. New hub
  173. Transmission
  174. 09 Water Pump Failure - Damage
  175. another one bites the dust....
  176. Colder Weather = Reduced Boost Pressure
  177. Paint Issues (Dark Silver)?
  178. Torque Values Mistaken in Manual?
  179. Warranty and Expected Life
  180. New lifters ,and maybe a head!!!
  181. Wheel arch snaps broke. Needs help.
  182. Passenger airbag off Over rearview mirror
  183. Wiggle While Driving, Tread Squirm?
  184. German Engineering = Way Too Complicated?
  185. Auto Transmission surges...
  186. Mini Wheel and Tire Warranty
  187. Windows go down by themeselves
  188. Occasional loss of power
  189. Key Fob/Dead Car
  190. rear view mirror help
  191. Help again please.... CEL
  192. Torque Steer mostly resolved
  193. Comfort Access issue ...
  194. Proud owner of new 09 Clubman S.... sort of...
  195. Rear sunroof squeaky rattle
  196. Remote lock/unlock won't work
  197. High pitched squealing sound from water pump area
  198. Headlight Surround's Bubbling
  199. Power steering problem on 2nd generation
  200. R56 Wiper Blades
  201. Brake loss after sitting.
  202. Sunroof Glass Shattered
  203. CEL.. Help please. Philippines no dealership....
  204. Helpppp!!!! Engine light?
  205. OEM Chrome Scoop issue
  206. A screw/fastener sticking (picture)
  207. MINI Strict service
  208. Windshield Damage
  209. ACC - Automatic Climate Control
  210. Effectiveness of Clear Bra?
  211. Battery issues
  212. Intake Valve Deposits
  213. Front brakes gone in the first 19 000 km
  214. 5th visit to the dealer in 3 1/2 months: should I just sell my car?
  215. Broken Vanity Mirror
  216. Someone stole my emblem
  217. Check engine light issue
  218. Engine Hot, Then Overheating! Help!
  219. Bad news: Apparently, 2010s also suffer from cold start rattle
  220. Car never starts the first time around... Why could it be?
  221. Early Build 07 MCS's
  222. Car wont shift into 3rd gear!!! Help!!
  223. HELP would be the best thing right now...
  224. Headlight connector help please!
  225. First the Window, Now the Head Lights
  226. Won't start, gas pedal stopped working while driving
  227. Gave a jump to another car and now mine will not start
  228. FOB startup TROUBLEEE
  229. 2nd gear syncro warranty question
  230. Squeak when coming to full stop / new wheels put on yesterday
  231. Airbag/Seatbelt lights on after Heated Seat Install
  232. Ran out of gas...again
  233. Driver's wing mirror on R57
  234. *POP* then squealing...
  235. 2009 Cooper S Automatic Transmission Problems
  236. Found this screw on the passenger floor
  237. Shifter very tight
  238. How have you been treated by your BMW dealership?
  239. R56 Turbo blown.
  240. Blue fluid leaking INSIDE my mini by the driver side
  241. Intake/Engine Whistle on non-S Clubman
  242. Burnt clutch on 2008 after 14,500 miles?
  243. More than just the hood scoop melted during test drive [video]
  244. Turbo Rust?
  245. Can some one take a photo of the engine bay...
  246. dropped brake reservoir cap, help!
  247. Rough solutions? - Codes: 016,012,011,017
  248. Dreaed Red Battery Light
  249. High RPM Engine 'Buzz'
  250. Fuel gauge accuracy
