- Battery already dying on brand new '10, also running very hot - Cooper S R56
- Scoop Color
- Audio source selection weirdness
- Stereo weirdness.
- R57 boot not staying latched
- Clutch
- 2010 Cooper S Mayfair Oil Bottom of Tail Pipe
- Brand New MCS Odd whistle/squeak
- Creaking noise behind plastic hatch cover
- 2009 MCS - clicks, then acceleration
- Any real fix for the Sunroof Sticking Issue
- stitching needs repair on my sport seats already?
- Run Flat Tires
- New 2010 Cooper has loud radiator fan noise
- 2009 Cooper S spontaneous fire
- I've only had my Mini for a week and it's already stalling
- ABS issue
- Low speed stalling
- Clutch squeak from engine bay.
- Death rattle fixed, but new CEL and missing parts?
- Bad Gas
- Mini wont start
- TSB or known fix for this rattle?
- How smooth is your MINI at idle?
- 08 MCS rolls back when parked on a hill with 1st gear engaged
- the end of the road...
- iPod not charging... is it just me?
- Metallic clatter (not cold start) - need advise
- misfire?
- Weird boost issue
- Windshield on my 09 Factory JCW finally cracked
- Door Won't Open When Hot -What's Up?
- Air Conditioning
- 2007 mini overheating
- Rear Light Replacement
- dealerships terrible gasket install *pics*
- Bentley Publications - Mini Service Manual
- Charcoal Canister
- CEL 3&4 cylinder misfire detected
- Power Window issue
- Metallic buzz at 5k RPM?
- Vacuum Leak?
- Key Fob Rattle
- Radio snafu
- Funny engine noise - Really need HELP
- Gremlins in my Clubman
- Anyone knows what "2F37" fault code means?
- burnt oil odor
- Tear in driver leatherette seat...will warranty cover?
- How to remove or adjust the spring that holds up the trunk/boot lid?
- Whoops! My thingy popped off!
- AC leak, dealer blames me!!!
- 07 Cooper S horrible handling??
- MINI-less just for a day.
- Bad cat?
- ? Clutch Problems 2009 S Cabrio
- Half shaft?
- Seafoam on 93K engine and ... hardly any smoke
- WOOOHOOOO... I FIXED IT!!!!
- I'm leaking coolent
- MINI Canada rejected my warped hood scoop claim
- Is the Mini Extended Service Plan worth it?
- How to clean/maintain?
- Squeaks and Creaks
- Positive camber from hitting curb?
- So many little problems in 2010 model...
- Won't start
- Transmission Noise
- driver side door lock??
- Best Repair Manual
- Baddd engine noise...please listen and help!!
- Recurring Engine Carbon Buildup Problem
- Radio gone silent
- Horn not working, what to check/where to look?
- R56 Exterior door handle sticks?
- Timing Chain Tensioner Replacement COST??
- HPFP again! replaced twice in 10 months
- Timing Chain Tensioner Replaced?
- Auto Transmission slips out of gear @
- Here we go agaaaaain.....
- Nock type noise from rear when turning off
- 07 auto jumps out of gear!!!
- Got '07 Cooper S, vibration and noise questions
- 08 mini cooper ac compressor wont come on.
- Starting issue
- Defective Electrical Harness
- 2009 MCS Check Engine light many times
- What comes with a remanufactured motor?
- Timing belt "just fell off" ('07 Cooper S)
- Please HELP! Dealer left PCV hose unhooked
- "Factory / OEM" Scan Tool Equipment
- code 2885
- Clicking Sound With CEL CC ID 029
- Rear Ended in my 2010 Camden edition
- repairs starting to annoy me
- 48000Km vehicle service?
- HELP: Spontaneous engine bay fire
- Paint flaking off on my brand new MINI Cooper
- Replacing Cylinder Head Cover - Twice a year?!
- CONDENSATION?!!?
- Fuel injection?
- Bluetooth problem? and ipod resume play problem?
- r56 power steering assistance loss
- Normal or Abbie Normal?
- Noise when turning A/C on?
- 09' Justa Clubman
- Broken Headlight Bracket?
- Clarification - Timing Chain Tensioner Noise
- Grabby Clutch on 07' JAC
- Add fuel system cleaner only right before oil change?
- Start up issues
- Picture Of My Valves......Before SeaFoam
- Check Engine Light.....
- 2008 MCS with gas smell from air vents
- Service Engine Warning Light
- Transmission replaced and then came loose under warranty!
- 2007 Cooper S problems, sulphur smell, etc.
- things my clubman have so far.
- Noisy Driver's Side Window Under warranty?
- Engine Buzz??
- Door Lock won't open from inside
- Transmission Replacement
- Clear bra and stripes
- Is the black trim on your wheel arches even?
- Covenience Access Problem
- Dead......maybe not......oh yea, dead
- Water in Doors
- Wisconsin Crashed Yellow 09 MCS?
- Roof problem already!
- new mini owner-some insight on auto shifting?
- Odd Turbo Sounds
- Stuck in Reverse
- Thermostat replacement
- Strange Coolant Leak...
- > 25K miles and never had Rattle?
- Need advise - VIN Mystery...
- Fried Turbo
- Thought you guys might like this....lol
- Black Star Bullet metal/finish question
- '09 Mini S, Injector Problem
- Warm restart - smell gas
- Mini R56 S 2007 error codes
- NEED HELP OR OPINIONS
- Hit a pothole, throw your headlight aim off...Possible?
- FUEL PUMP
- Steering wheel lock warning
- Cold start rattle quick remedy.
- HPFP?
- Clunk in front end-looked everywhere
- Starting issue – Not the rattle
- My turn
- half power light on.
- Wipers with Rain Sensor Stop Wiping
- 2010 gremlins? Boot rattle, frozen door locks?
- Flatbed Sandwich - Car Dies
- any suggestions?
- Getting New Engine in my 07 Mini - Crazy!
- "can't continue journey" true/false and if false, how long?
- Mono-chromatic mirror gone bad!?!
- Sunroof wind noise. Any actual fix?
- Warranty help
- Sirius Receiver Help Please!!!
- 09 Clubman Transmission Problems
- Car going into ds mode while driving?
- Battery Light on - After Tranny replace
- Steering going out!!!
- Air Conditioner Bracket Broke on JCW R56
- Yellow Car on Lift signal popped up. Any ideas?
- Reading and Sun Visor lamps not working
- squeak/clicking in clutch 2009 MCS
- Question for Just-a-Cooper Owners Only
- Strange sucking sound during revving of engine
- ipod connector covered
- New Mini owner and a few questions/problems?
- 7600K. Shrieking noise. New Flywheel!
- Can I get from the radio to some ear plugs?
- Burning oil smell?
- weird window - driver side won't stay closed
- Flying Scuttle
- Help. CEL again.... with dealer diagnostic screenshot
- headlight alignment help!!
- View from the cheap seats
- Excessive Battery Discharge?
- Odd engine sound
- Clear Bra Issues
- Bad Gas - Dirty Fuel System Issue
- Engine light came on!
- Need info. on Head gasket change
- CEL 2845
- Any Ideas On the Problem
- Low Compression in one cylinder
- noise at 3k rpm...
- Need Help, Driving Lights
- Personal Profile Help
- MCS automatic engine revs up when coming to a stop
- R55 S clunking with jcw brembo brakes
- List the problems you have had with your Mini.
- Did I just make things worse?
- 2007 MCS power loss after 3500rpm
- 2007 Base Mini w/ tranny GRIND!!! :-(
- Squeeky brakes are driving me crazy! Need advice
- Loud Clutch Squeling noise on my 09 R56. Help.
- Odd noise/Question
- Auto Shifting Problem
- rear knocking sound video: any guesses?
- yellow engine light indicator
- Steering Issues
- Cylinder 3 Misfire
- brake light on, abs and service light flicker.....
- Stop the DING!ing (not the usual topic)
- What is this noise?
- Are these repairs normal?
- R56 Front Driving Light - Replacement How To?
- Engine problems --> Not use top tier gas
- Control Module
- Looking for a service bulletin
- Seat belt in a twist
- Sunroof shade keeps opening!!
- Has MINI fixed any of these issues?
- Intermittent Wipers
- help with passenger seat belt alarm
- CEL "increased emissions" and mystery chime problem
- ticking noise @ idle
- Idle...anyone else?
- Aircon Problem
- Break in or not?
- Anyone had trouble with their seat being hard to move?
- Headlight Warning......reset?
- Front bumper
- Check engine light
- CD Keeps Popping Out of Player
- im going crazy
- Video of timing chain clatter....
- Turbo Sound Boost?
- Camshaft/Valvetrain Noise
- HPFP,CEL,Clutchs problem.
- Vacuum Pump Location
- Liquid on the ground
- Scratched glass from wipers, covered by warranty?
- Gear Shift Indicator Light
- Timing chain rattle cured or not?
- How to fix squeaky roof?
- Yellow CEL and Alta Air Intake
- 11k miles and 16qts of oil later...
- Coolant level seems to be lower often
- brake pedal makes knocking noise in park only-auto trans.
- Changed the fuel filter, and now no start?
- MINI shocks longevity?
- Don't despair, it could be worse....
