View Full Version : Stock Problems/Issues
Pages : 1 2 3 [4] 5 6 7 8 9 10 11
  1. Help please
  2. PICS of 2011 MCS New Design Valve Cover - Carbon/PCV Fix?
  3. Heater isn't heating...
  4. Shaking in reverse this morning
  5. Engine Swap
  6. Suspension knocks
  7. Spark Plug Ignition Coil Rust/Corrosion
  8. 2010 MINI Cooper (Non-turbo engine) port injection or direct injection?
  9. PCV line on 2011's
  10. Buzzing noises.
  11. Reliability Mods
  12. help finding screws for Pillars on center console
  13. Chrome headlight trim bubbling
  14. TiMing chain slide broke, causing oil pump chain to snap
  15. 2nd Gen R56 Purchasing Advice
  16. Insert Navigational DVD
  17. Water Pump Leak on 2008 Cooper w/56,000 Miles!
  18. Quick Knocking question
  19. Those that are having engine failures
  20. 2010 mini camshaft sensor
  21. radio display says "alarm" huh
  22. Car overheating
  23. Radio won't turn on for 30 minutes
  24. Problems with my R56S
  25. Brahman Mini Denies Warranty for Engine Failure on a 2009 Clubman S
  26. Mirror cover falls off
  27. Warning light combination
  28. 07 CooperS oil filters - FYI
  29. Rockers knocking and a P00AA code, help?
  30. Rattle buzz found it!
  31. No Recall planned for HPFP
  32. 2010 Cooper S Bottom Door Seal?
  33. A few things not working
  34. R56 2007 engine failure twice
  35. Clutch and Warranty?
  36. Warning about being able to shift (automatic) transmission without applying brakes?
  37. Stuttering / Turbo noise
  38. I didn't even make it 600mi to my first check engine light!
  39. So is Mushrooming a problem on R55,56's???
  40. Clutch Engagement Point
  41. Is this gonna be a problem?
  42. Car seems to lurch occasionally at constant throttle in higher gears
  43. Squeaky driver's seat - 2007 Cooper
  44. Possible clutch problems
  45. car can't handle accelerating on the highway
  46. BMW institutes "voluntary recall" of HPFPs 2007-2010
  47. BMW Admits HPFP Problem - Article
  48. engine chirp at idle.
  49. Engine noise
  50. Random creaking noise from steering
  51. boost pressure deviation..... turbo problem
  52. Gen Two Justa Cooling Fan
  53. Buzzing in driver's ear, '09
  54. Auto Dimming Mirrors go dark during Daylight!?
  55. Realtime Traffice issue
  56. Thumping noise + a few others
  57. So My R56's Engine Went FUBAR
  58. MCS starts and turns off??
  59. in for service again
  60. Timing Chain/Death Rattle -
  61. Louise is in for repair so time to upgrade!!! ;-)
  62. No Audio an Sirius Radio problem on 2011 Clubman S
  63. Scoops with Heatshields Feedback?
  64. convenient access intermittent
  65. Just had the timing chain & tensioner replaced and...
  66. Does this come off?
  67. Loss of Boost - What Could Be Wrong?
  68. Squeaky . . . headliner?
  69. '09 MCS Bonnet rubbing bumper and fenders
  70. Code problems
  71. According to my dealer, this is not covered by my warranty
  72. My Xenon Headlights
  73. MCS feels like its having a problem getting fuel while cruising
  74. Misfire from defective Spark plug - Sorry in advance for the Non High def pictures
  75. Transmission noises?
  76. Weird Noise! Help!!!
  77. Good mechanic to fix timing chain rattle in So Cal
  78. Steering Issues
  79. Intermittent low boost issue
  80. Clutch Advice Please
  81. OEM wheels and tires
  82. Engine Squeal
  83. SEAFOAM just in gas tank?
  84. Lower radiator hose drooping & worn through on Cooper-S
  85. Knocking/Creaking Sound on Clutch Let-Up
  86. Troubleshooting the fuel filler door lock
  87. Engine Failure light @ 2945 miles...bummer.
  88. Just bought a MINI, now I have a CEL??
  89. Seafoam Procedure, please post it
  90. Fuel door lock stopped working
  91. SAGA of the dual Mass Flywheel and the dealership hurting my AeroKit
  92. Why ME?
  93. Hood Cable Issue
  94. AC Vents won't stay in place
  95. Loose Boot Trim Handles
  96. Seriously though...why a noisemaker?
  97. Clutch releasing in 6th gear while cruising - any ideas?
  98. Oil Light Came on After Hard Corner
  99. How do you access the spark plugs?
  100. Whats the deal with Inspection II?
  101. Update on my car
  102. Northeast Owners - Turbo Rust?
  103. Dual Mass Flywheel (DMF) Induced Early Clutch Failure
  104. 2010 base model with 1,900 miles engine whine
  105. How To Remove OEM Antenna Base???
  106. HELP! New Engine/Fuel Pump problems and dealership issues!
  107. Miles to Tank on OBC different...
  108. weird battery problem?
  109. Has the HPFP issue been fixed in 2010-2011s
  110. 07 R56 weird idle problem and extreme hesitation
  111. Turbo weeping oil?
  112. weird clicking/rubbing sound any ideas?
  113. Slide Rail Replacement?
  114. Comment/Observation regarding Torque Steer...
  115. 2007 MC Whine When In Gear
  116. New Mini Stalling Issue
  117. Survey, carbon-catch cans-and oil changes
  118. Engine Noise
  119. New to this Fourms any diy listed on this site?
  120. Took Delivery of my 2010 S and it broke down..
  121. Annoying Rattle!! -- Comfort access system ECU
  122. 2008 Mcs Tire Issues
  123. Excessive Flywheel/Clutch Assembly
  124. Mini Problem - Not Starting
  125. LOL Wasted Service Appointment
  126. Into the shop for rattles/noises - wish me luck!
  127. Mood lighting out of sync
  128. I Lost A Lug Nut?
  129. Auxiliary / Cigarette Lighter Broken
  130. Clutch "pop" half-way through pedal press
  131. MINI versus the car wash
  132. Low Electrical Problem - No Start Issue
  133. multiple warning lights - ABS, DTS, Brake, TPM, CEL
  134. Cold Start issues...
  135. info needed about 04 r53
  136. Chirpy Engine
  137. Cold Start issue?
  138. Passenger window pops out of Track at high speeds?
  139. Cold Start Death Rattle
  140. Side Scuttle fells off
  141. Yellow sunroof light
  142. blown head gasket?!
  143. HELP: Missing rear control arm bolt!!
  144. Headlights aimed down, How to re-aim?
  145. Horrible engine noises at low rpm:
  146. Oil level. Is this normal!?
  147. Boot latch only opens via fob
  148. 2010 JCW Engine noise
  149. Chirp, chirp??? WTF??
  150. Rear (Drivers side) Brake Caliper Removal????
  151. moving driver's seat(back part)
  152. Yellow engine light after NM Charge pipe?!
  153. Water pump and friction wheel
  154. Metal sound from rear
  155. Glove Box Lock Cylinder removal?
  156. HELP!! Replacement of tranny, they seem to have forgotten to add motor oil?!#%*!!wtf?
  157. 4th time's the charm? (Another death rattle horror story)
  158. Dunlop DSST weather cracks dry rot
  159. Morning hesitation
  160. CEL Issue - Dealer Diagnosis and Questions
  161. CEL at 70 mph and misfire
  162. Passenger window rattle
  163. So, I was driving on the highway to work today...
  164. temperature sensor and check engine light
  165. Rubber tubing behind/below intercooler sagging 2008
  166. Rev Limiter
  167. doors on the R56...WTF...crap design that will barely stay open!??!?!
  168. Bavarian Technic vs. AutoEnginuity Scan Tool
  169. How can I trigger symptoms on a possible failing fuel pump?
  170. Radiator System Smashed to Bits by Phantom Object?!?
  171. drive train rumble?
  172. Armrest - anyone removed it?
  173. malfunction of MPG reading
  174. Headrest angle of evil...
  175. Hatch wiring harness wearing away paint
  176. LO sign on AC indicator
  177. Multiple Component Failures
  178. Rough engine note?
  179. miniusa refuses to replace my warped hood scoop!
  180. "Squeak" noise when engaging first gear on an uphill
  181. just bought 2007 mini s and yellow half engine light is on
  182. Inaccurate gas gauge got me
  183. Hole in my Radiator?! HELP!
  184. timing chain tensioner....AGAIN
  185. Burnt secondary thermostat
  186. Disturbing outcome to noise on '10 JCW...
  187. Headliner rattle
  188. car is jerking slightly while hard acceleration until engine warms up.
  189. Dramatic Oil Loss - Oil Leak
  190. Engine knock -- but not the kind that you think it is.
  191. Intake Valves - how to check for carbon?
  192. HR rear speaker FUBAR
  193. A tapping noise on the left rear suspension?
  194. Weird Noise
  195. Gas Gauge Problem
  196. MINI Canada offers MINI NEXT protection
  197. Shift Mechanism Failure - 2007 MCS
  198. Pop sound from drivers side front wheel well
  199. My mini smells like a tractor trailor truck overheating its brakes....
  200. misfire caused by too much alcholol in fuel ?
  201. Screeching from dash
  202. MCS - No boost
  203. Let's figure out how many people have had HPFP and Cold Start Issues
  204. Getting CEL, Throwing Code U3FFF
  205. Steering Lock Warning Light Question
  206. Clutch failure on non-S models
  207. Bizzare Incident
  208. fault code - 2884 Charge air pressure control deviation, plausibility
  209. Rear wheel alignment
  210. High Press Fuel pump, bad gas or Seafoam?
  211. computer/power problems
  212. internal cracks in the foglight
  213. Chrome belt line doesn't line up
  214. How to Test Control Arm Bushing
  215. They replaced the valve timing motor today
  216. I asked Mini a question! Follow along! Timing Chain Issue
  217. Anyone Had This Problem
  218. MCS Centre Consol Very Hot And Trunk Problems
  219. Power Loss and engine light
  220. The Saga of the High Pressure Fuel Pump
  221. 12v socket not working, Fuse?
  222. Possessed Pass Side Window = Complete Reprogram
  223. Scangauge problem
  224. Turbo Smell?
  225. Question - dash panel to right of HVAC temp controller
  226. Rear body rattle, please test
  227. illuminated sun visor cover broke...
  228. Drivers side door handle cover.
  229. Rear interior door panel keeps popping off.
  230. Ticking from radio speakers
  231. 2010 Cooper S 2 weeks old and dies
  232. 2010 MCS
  233. Convert top from day 1
  234. Does anyone has an auto trans R to D issue?
  235. Battery Issue with 07 MCS
  236. cc-id 139
  237. AC not very cool..?
  238. My R56 jerks!!!
  239. Identifying an oil leak
  240. OBD Settings Randomly Changed?
  241. CEL P0112 & P0238
  242. D-Can Car?
  243. random intermittent misfire
  244. Clubman water leak!!
  245. Clubman Dies at Random!!!
  246. Great Service, New Problem - Cruise Control
  247. Mini service-First Oil Change
  248. Plastic burning smell from under the hood..
  249. Airbag Problem 938A Fault Code
  250. What are the cylinder numbers?
