- Squeaky Clutch Paddle Issue
- Cracked Xenon headlights
- 2011 washer nozzle weeping...
- Timing Chain Replacement and Frustration
- Buzzing/humming Sound While Driving (Justa)
- Possible climate/vent issue
- Dipstick will not go in
- In-tank fuel pump
- Yay, Clouds of White Smoke!
- CHeck Engine Light on 2011 w/ Black Smoke Ughh
- French Facebook Group: "Prince" (R56) Engine Petition
- Question on Remanufactured Engines
- *Help* My 2011 MCS "Sings" at 5k RPMS..
- Sound of the clutch engaging
- Fast blinkers
- Cold start rattle as 64k, Options?
- Check engine light, before ignition
- 2007 S Cel Issues
- timing chain tension bolt issue?
- Just got the Timing Chain Replaced - Yay Mini Nashville
- It pays to visit your dealer
- Gen 2 Technical Service Bulletins (TSB) Database
- Oil Starvation says the dealer! HELP.
- Just a Mini engine light on 2 codes P0113, P0342 any ideas?
- Waterpump issue
- Dead Pedal cracked
- Metal shavings in the intake...fun...
- blown engine
- Help! 48K...Decision Time
- Is this normal
- Noobie in need of help - corolla for MCS - reliability issues
- Melted hood scoop after two years - is there a TSB about this?
- AC compresser filled with Rocks??
- Rattle/Tinning Noise in engine (hot)
- Stiff Power Steering???
- AM Radio Lost Signal
- Driving home and this happens....
- Odd rattle or cackle coming from the front
- warning light
- Sunroof problems
- Missed a shift and hit about 6500 rpm in my JCW 09 mini!! HELP
- Oil leak help
- Tensioner 11-31-7-607-551
- water pump and oil filter canister replaced
- Our MINI just puked all it's vital brown fluid on the ground...
- Clunk in boot area.
- What can cause squeaky noise?
- 1.6 Justa Cooper?
- Removing fuel line from HPFP
- Add me to the List of my Wife called me with and oil Leak
- Mirrors folding in when it rains
- No start problems
- Mini Warranty
- 09 Justa Mini 6 speed Intermittent No Start
- Timing chain failure
- Unhappy soon to be ex-owner 2008 MCS
- Removing Head
- Door handles stiff (comfort access if matters)
- Chirping serpentine belt???
- Clutch replacement by independent shop?
- 2011 MSCa thump/clunk in Sport Mode
- What does the Brake light and vehicle check icon mean
- Clutch survey. How many miles on your Mini/other clutch.
- Oil on plastic skidplate????
- SOOO Frustrated with Mini's Promotional Programs
- Another victim of the Timing Chain Tensioner
- Turbocharger failure - Compressor nut
- Fault Codes 2DCC, 2880 and 2D52 ???
- Windows going down, 1 blink instead of 3X
- Long story from an Armed Service Member
- Slipping out of third gear
- Rear washer with wipers parked
- Post-accident starting problems in 07 MCS hatchback
- '07 MCS auto has a cricket... or something.
- Clutch Groan: How to talk with dealer?
- Locking crank
- Rear cupping and clacking noise
- Sell or Not to Sell over Turbo issues?
- Cam timing
- DTC, brake, seatbelt & Airbag lights all on, help. :(
- So my wife calls me about an oil leak....
- Level Sensor (I think)
- 2007 S hatch door won't unlock
- vacume pump engine failure/servo motor Help!!
- Another "Wierd Battery Problem"??
- Idle issues - hunting after startup.
- Question about dealer oil change
- What did I kill?
- Code P2418, P2400. Where is canister?
- Oil leak
- IHKA Faceplate
- timing tension bolt and...
- leaking resonator?? non-s clubman
- Blinking lights and the Sunroof
- Whining Noise coming from valve cover!!
- Red "Oil Can"
- R56 hard start, rough cold idle
- Auto tranny won't engage
- ABS Unit Faulty Just After Warranty Expired
- Water Pump Issues and other goodies
- My car was repaired and now smells like @#!%
- 1st Dealer 15K Mile Service Due - Questions
- 2011 MCS in the shop, question about loaner car
- Death rattle, carbon buildup, and tensioner question
- Minor oil leak - pictures - where is it coming from?
- 2010 Convertible Bluetooth Issue
- 2011 Vibration ????
- Key fob opening locks but not switching on ignition
- Tire Pressure Monitor TPM not Resetting
- carbon blaster
- Increased Battery Discharge - multiple times in two weeks
- Noisy Turnover. Loss of Power. HPFP?
- Great car - worst armrest ever
- Coolant leak, engine damaged?
- Hi There! My 1st post and its (potentially) not good.
- warranty question
- cylinder head removal HELP!!!
- Turbo failure on my 07 MCS
- Can I prevent valve build up?
- windshield creaking
- Howto retrieve Check Control messages
- 2011 Satellite Radio Stuck in Aquiring
- Fuel filler cap wind noise?
- rough idol
- Question about cold start engine noise
- Please help me with my JCW
- 15 days old, 5 days broke
- Water Pump Replacement at 18K Miles???
- New Glove Box New tail light...Feels like new
- Help me diagnose this clutch/trans sound
- Window won't go up
- Help me diagnose - belt slapping?
- Power window and boot door question
- CEL Code P1497 & engine stuttering at idle
- 5000 miles- Noisy engine, and the other morning a little rattle at idle.
- After dealer visit, turn signal behaves differently & car feels less torquey
- powerfold mirror.....issue
- having to reset time of day on 07 mcs weekly
- Death rattle, fuel pump, carbon problems, Talked to Dealer.
- Oil Filter Housing Gasket Leak
- Missing Splash tray/under tray / guard?
- 2008 Clubman S with big problems from cold start noise
- Summary of Problems in 3 Years.
- Really displeasing noise from the engine
- HELP I need a new MAF sensor!!!!!!!!!
- Poor Idle - Carbon Cleaning Connection?
- 2011 clutch compared with 2010
- USB Media Connect/iPod y-Cable Help!!
- Car in shop - need help
- new glove box now what to do about airbag
- Ok so my mass air is reading 0
- Seatbelt problem with our '08 MCS
- Have to reset TPMS again and again and again...
- Windshield cracked
- Husband hit a pothole-Dash looks like a Christmas Tree
- Your odometer when new - how low can you go?
- Fluctuating RPM's at startup
- Speakers covered in 3 year warranty?
- Window seal issues
- Steering
- Headlight bulb removal
- Maintenance Manual and Repair Instructions
- Does it need to be fixed?
- 2009 Clubman S needs new intake manifold
- Clutch problem on one-year-old 2009 Mini Cooper Clubman S (R55)
- Popping sound when in reverse
- Idle issues
- Carbon Buildup Cleaning
- Brake Issue. Urgent Help!!
- Strange Buyback Experience - LemonLaw
- Drop in Fuel Economy After Service
- Limp Mode, no CEL?
- Misfire Cylinder 3 and 4
- Seatbelt hitting neck...
- Passenger Seat Does Not Return to Position
- sun roof doesnt open when cold??
- P112b Code?
- Moisture in intake manifold 2010 S 4300 miles
- Engine Carbon Treatment
- Wastegate issues anyone?
- Major Oil Leak
- Fault code P1128
- sun roof issue
- 07 MCS - warranty almost up and a couple of problems
- Another electrical gremlin...
- 08 Justa Clubman Electrical Gremlins
- Mini won't start, Yellow engine light on
- Oil pan
- MPG Readout is Way Off?
- What should I say to the dealer?
- Boost Pressure Ramdonly goes Away and Then Returns
- Manual Transmission Suddenly Stopped Working
- Electrical Wiring Bundle Delays Thermostat Replacement
- Run Flat Tire HELP!!!
- Anyone with new fuel pump???
- Shutting off the TPMS ,for winter ( how )
- 2011 MCS Owners - Noisy engine at idle?
- 4th Yellow Check Engine Light on 6-Month-Old Clubman
- COLD Start repair reprograming?
- Help! Lease return and warranty questions
- Multiple warning lights many problems
- 2011 MCS forgets setting after sitting...
- What is a normal operating temp?
- 2008 Cooper S leaking Coolant... UGH!!!
- Acceleration issues in cold weather?
- Over Boost problem 23psi!! P0108 and P0030 codes
- Very very surprised!
- Interior Ticking Sound
- Not all bad
- HELP! wont shift into gear. stranded on road.
- not sure what happened
- $389 for "fuel service"?
- Stuck Sunroof Problem
- I need some advice..
- Need some guidance to CEL Service - Car at dealer now
- P0015 CEL ["B" Camshaft Position -Timing Over-Retarded (Bank 1)]
- new cel please help
- so that cold start rattle..
- lock/unlock/trunk buttons no longer work on key fob!
- Noise When Cold
- stupid cel need help
- Window won't automatically roll down when door is closed
- Clunking between 30 -40 mph
- What does my car want?!
- Trunk latch is constantly releasing...
- Newest Problem
- Mini heat cooler at idle
- Engine Vibration Over 3k and Cold
- 07 mini service icon not in the manual
- No heat when stopped
- Problems with stock radio
- Cabin Filter Replacement
- Back to dealer
- Rattle in the Back
- Help! Heat stops blowing hot at idle!
- Need some help, broken foglight clip
- Just a simple observation
- cold start chugging in D
- Almost 3 years; what should I have done?
- excessive carbon build up
- Blower motor noise only when cold
- 3k RMP Engine Rattle
- NEW JCW Clubman 2k mile blown clutch
- Parking Sensors Not Working
- Clutch out
- Hood scoop warped form heat
- My Satellite radio died?
- Window rattle issue
