View Full Version : Stock Problems/Issues
Pages : 1 [2] 3 4 5 6 7 8 9 10 11
  1. Bank 1 Oxygen Sensor Voltage?
  2. MINI Failure
  3. engine swap questions
  4. Something leaking from bonnet
  5. How to Reset all Radio / Nav / BT settings?
  6. AC issue due to lowering???
  7. Grinding sound + white smoke?
  8. Check Engine Light
  9. PCV hose leaking oil onto valve cover
  10. MCS Problem!!!
  11. Engine/radiator smoking?
  12. Under what conditions will Mini perform the TSB for the tensioner rattle?
  13. Putting a JCW Clutch in a...
  14. Worried new Mini owner
  15. Hesitation (bog) Issue
  16. Intermittent CEL
  17. Auto Shifting Noise
  18. Radio doesn't turn on all the time
  19. Does your MCS makes more noise when turns on A/C
  20. Do i have a promlem.
  21. Do these service records look bad?
  22. 2 CEL's
  23. A/C blower only runs at ~30% speed?
  24. Just Hit 15K / What to Expect at Service?
  25. Battery Life
  26. Whistling flywheel?
  27. Timing Chain problem fixed? As of When?
  28. MINI Troubles
  29. 2011 MCS more problems! NOW: clutch and gear shifting noisy..
  30. CAI rubber boot tearing — anyone else seen this?
  31. Warranty Works!
  32. P2188 CEL not going away
  33. fan running after car is shut off
  34. R56 non start
  35. Throttle Response
  36. battery question
  37. Clutch burned up after Valet Parking
  38. Coolant problems please help, drizzling out of the car
  39. 2011 mini question
  40. Carbon Build Up On Intake Values (Help!!)
  41. What does this mean?
  42. At idle, engine making gentle fart sounds.... WTF !??!?
  43. Help! My mini broke down in Myrtle Beach
  44. Really, I can't find the A/C drain line... help
  45. help with clamp part number
  46. Courtesy Overfill on Coolant
  47. Engine bounce in stop-n-go traffic? Torque Arm Insert?
  48. Extended Warranty or Not?
  49. Indicator Lamp CC Message / OBD2 Scan Tool Code
  50. Driving lights fogged...
  51. Upgrading Software Version - Dealer Refused
  52. r56 Battery Replacement Help
  53. Report Problems to Dept. of Transportation
  54. 2010 Cooper S Speaker Buzz
  55. My MINI logo on the steering wheel is looking ugly!!
  56. Brake Lights Staying On
  57. Another Mini wake up call about poor quality
  58. Fob won't unlock, all warnings on upon ignition...
  59. gurgle gurgle gurgle!
  60. Snap, crackle, pop! The music of my MINI...
  61. squeal/ chirp when ignition turns off (video)
  62. A/C Compressor
  63. opinions
  64. Service Prices...
  65. Help! MCS Oil Consumption progressively getting worse
  66. Timing Chain/Tensioner Problems
  67. Oil light with only 1.5k miles?
  68. Not holding full boost
  69. Vanity (visor) mirror broken
  70. busted piston ring at 50529 miles!?!
  71. Check engine light on, fan runs all the time
  72. Stupid codes...
  73. 2nd water pump failed @ 6500 miles
  74. Starting problem after several days
  75. Unexpected Service light
  76. Cargo light problem
  77. Headlight/High Beam Problem
  78. Radiator dented
  79. A/C fan stops working intermittently
  80. Whining noise in the front
  81. 2011 Silver Mini Convertible - Paint
  82. Help with 2009 Clubman S Carbon Issue
  83. Grinded the gears...
  84. Trunk lid grab strip
  85. Lost my power steering
  86. Is It Because I'm A Girl?
  87. Airbag light / seatbelt light
  88. Maintenance Service Extension
  89. Engine Failure in 2011 Countryman
  90. Strange suspension inconsistency
  91. Morning whistle ??
  92. 2010 MCS ISSUES- Stalling, crackling, Radio Shuttoff, hatch....
  93. Deceleration Rattle Emanating from Dash
  94. Rough ride
  95. power steering fluid appearance
  96. Will it take more than 2 days to replace high pressure fuel pump?
  97. cc-id 142 TPM no reset option
  98. 2011 MCS with 2K miles squealing engine noise - water pump?
  99. Club door beltline trim problem
  100. Should I be Worried?
  101. how long to face fuel injection problem?
  102. Sun Roof Decal Problems
  103. Buzzing noise when accelerating (Cooper S 2009)
  104. Anyone know what the O2 sensor voltage amount should be?
  105. Hot weather = leaks
  106. A/C blower motor going bad?
  107. Does Anyone Have Info On A Full Engine Gasket Kit?!?
  108. Any had the hood paint peal?
  109. Exterior bulb warning on brand new mini
  110. Bluetooth disappeared all of a sudden!
  111. Noise
  112. Climate control panel inop in '11 Cooper S
  113. ABS Pickup Ring
  114. Under hood grease leakage
  115. Service light, brake light and engine light
  116. A few engine issues in my '11 Hardtop
  117. loosing powe & oil consumption
  118. Speedometer
  119. Problems, Problems, Problems
  120. 2nd Bad Clutch on 11 MCS in 3600 miles
  121. Run Flat Tire Warning Signal
  122. Windshield
  123. MINI caught fire!
  124. Engine Light
  125. Engine Light
  126. Ticking noise
  127. Accidently overfilled my oil...
  128. 2011 MCS owners, does your......
  129. sand in airbox
  130. Key fob battery recharge and convenience package
  131. Service indicator has read "1100 miles" for 4-5 months
  132. 09 Cooper Knocking at idle when warm: Help!
  133. Engine not sounding quite right upon start up
  134. Alternator belt help needed
  135. Did the dealer destroy my engine?
  136. OCC void factory warranty
  137. WON'T START --help
  138. Key Fobs and the Convenience Package
  139. Mini On A Lift! Help!
  140. 2011 Manual Transmission Clunk
  141. New Turbo @ Less Than 30K Miles? Really??
  142. Alternator Drive Belt - est. cost of replacement?
  143. engine noise- not the timing chain rattle
  144. Accellorator Lag
  145. Baby's 1st check engine light :(
  146. OMG Sunroof opened by itself and rain pored in
  147. 11' Cooper S C-Pillar Flapping Noise
  148. Screw down the front defroster!
  149. possible valve cover oil leak?
  150. Damaged roof, sun roof and spoiler
  151. Is a Software Update available?
  152. DIY Fuel Injector Replacement or Cleaning? (MCS/JCW)
  153. Check Control Message - Check OK
  154. how to kill a warning lamp??
  155. Dead Battery
  156. Idling problems
  157. Duplicating the cold-start chatter
  158. And another Clutch bites the dust....
  159. Pop sound after engine shut off - 2011 MCS
  160. Stereo wont turn on
  161. 07 Cooper S gets LOUDER the more I drive it...cold start or no?
  162. Engine Tapping noise
  163. Burble is nice, but dang this thing has gas...
  164. What is this?...
  165. Seat backrest shakes!!
  166. Cold Start - Low Oil - High Pressure - Dip Stick Pops Out - Timing Chain Rattle
  167. Temporary rattle and power loss under hard acceleration
  168. backfire/near stall when starting 2011 MCS
  169. Removing door panel = need to reprogram car's computer?
  170. Need a new radiator and radiator fan?
  171. 2008 Cooper Error Codes
  172. Electric Motor Noise after Shutdown
  173. Suddenly Noisy, Sounds Like a Diesel
  174. Door handles seem harder to open
  175. Any unresolved issues on 2011 MCS
  176. P0128 OBD CODE and 2F07 MINI Code
  177. Brake failure
  178. Cel B173b
  179. Blown turbo??
  180. N18 – Cold Start Exhaust Rattle Noise (Turbo Wastegate)
  181. Mini Death Rattle - Car at Dealer - Advise Please!
  182. broken shifter knob cap (manual)
  183. Burning Oil - may not pass smog
  184. Yellow Engine CEL & odd codes
  185. MPG Computer read out going crazy
  186. 2011 MCS sunroof is creaking.
  187. OEM Windshield defective (twice)
  188. Sticking Clutch Pedal?
  189. Blown clutch at a track day
  190. jump start by an idiot
  191. HELP!!! INPUT BEARING OR 25k Maintenance Plan?
  192. P0300 Random/Multiple Misfires
  193. HELP! Added Engine Restorer to car and now have Rough Idle
  194. Disturbing Sound When First Driving
  195. New MINI won't start
  196. Recuring thermostat gasket leak
  197. 2011 MCS Cold Start Noise
  198. Code PO 503
  199. Fix for scratch on a-pillar? roof?
  200. Timing chain issues
  201. Troulbleshooting- Thermostat or Water Pump
  202. After 440 miles of brand new Mini it is time to join YELLOW engine light club :(
  203. OEM Dunlop runflat tire wear
  204. Clutch squeak and soft clutch
  205. Have these problems?
  206. Dentist Drill noise at 2500RPM+
  207. Sputtering on start-up
  208. Auto up windows stopped...help
  209. Petrol/Gas issues
  210. "Clunk " coming from engine compartment.
  211. 2011 MCS Vibration
  212. Car stalls on start-up
  213. gasoline smell
  214. Hood Insulation from Mini Mania
  215. Rear brake service due in 900 miles
  216. BMW Induction cleaner
  217. Now it's the turbo...
  218. cold rattle problem
  219. Need Contact Info/emails For Mini Usa Corporate/legal
  220. Door is not flush to the body.
  221. Strange hesitation and tick noise today
  222. Common Problems
  223. Timing Chain issue
  224. hpfp issue?
  225. Brake Fluid service light
  226. Timing Chain/Electronics
  227. Weird electrical issue perhaps?
  228. I think I had the "Death Rattle" - now my Mini S is dead. :(
  229. 2011 MCSa / 300 miles / Oil around filler cap
  230. Seat Stiching
  231. sunroof thing opens on its own?
  232. Help! Check Engine Light
  233. steering wheel turning by itself
  234. Big trouble in little Mini
  235. Alarmed after purchase of CPO 2007mcs
  236. boot won't open!
  237. '07 Mini Cooper S won't start!
  238. R56 Issue
  239. Multiple issues days after purchase
  240. headlight adjustment
  241. New 2011 MCS Concern
  242. single knock new turbo
  243. Window squeal / squeak!!
  244. Oil smell
  245. R56'ers gather 'round . . . '11 MCS engine knock story
  246. Failed Piston - Break it in again?
  247. Car says passenger door Ajar, but it is Aclosed
  248. Amazing mess 2010mcs head gasket blown day after service: Advice?
  249. Clutch pedal arm hitting hard line from master cylinder making a click
  250. What does symbol :Yellow lightbulb w/exclamation point" mean?
