View Full Version : Drivetrain (Cooper S)
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. FU pully
  2. 204.9 & 177.8 at 6600 elevation
  3. Is the intake tube from the grill necessary?
  4. Installed alta catback now theres noise.
  5. 1st mods help-pulley etc
  6. Pulley help
  7. R53 MCS ATF replacement
  8. Recommended methods of securing water/meth tank in trunk?
  9. Anyone upgraded from the stock LSD
  10. TCS system
  11. Ahh my clutch is farting!
  12. Mynes Road Tour - SF Stop (Sept 12 & 13, 2009)
  13. Prime location for sprayer nozzles.
  14. Where to have a pulley installed?
  15. Sport Tips & Resonator
  16. Got my mini today
  17. R56 Brembo JCW brakes to R50-R53?
  18. Want to stay safe, but fast
  19. Spark plug comparisons, actual spark
  20. 17% Pulley, GRS Intercooler and 7600rpm rev limiter....safe?
  21. looking for a shop in San diego
  22. yahoo!! finally
  23. Running too cold
  24. OBX De-cat header VS Janspeed De-cat header
  25. Colder Plugs really necessary in new england?
  26. Newbie with an 05 Cooper S.
  27. Need help please: P1229, P1689, P1109, P1242, P0300
  28. Forge intercooler
  29. My MINI is all grown up and headed to College.
  30. flat power spot after 16% pulley install
  31. How do I get this engine bush out?
  32. New Cam Sprocket Bolt with New Cam ?
  33. HELP!! Damaged my transmission
  34. Temptation: Considering first mod -- 15% reduction pulley
  35. no exhaust? loudness
  36. Mynes Bytronik Individual Cylinder Tuning on Stock ECU
  37. Q? Are driver and passenger side muffler brackets the same?
  38. R53 Exhaust, Head, Header Survey
  39. RMW's guess what's in the box part 2
  40. Does an 06 JCW come with a Quaife???
  41. Multi-Layer JCW R53 Brake Question
  42. What are the best engine upgrades?
  43. RMW in July '09 Roundel
  44. intake help and anyone got a k&n intake?
  45. Centrafugal superchargers for mini?
  46. powerflex bush kit
  47. A hole into the cowl area
  48. How loud is the RMW race system?
  49. Track Tires vs. Performance Street?
  50. Tune for power...
  51. 6th Gear Swap - Lower Ratio
  52. Help! My car puked oil and I don't know why.
  53. Where does this powerflex part go?
  54. inlet temps?
  55. audrey's going into surgery. your tips and suggestions?
  56. Mynes closing up shop in AZ?
  57. New ACT clutch + flywheel = master/slave cylinder failure
  58. 1/4 mile with the Cooper S..
  59. Will a 2007 limited slip Trans/diff fit into the 2003
  60. Help with shopping list - p/n's?
  61. Alta Exhaust, 2006 MINI Cooper S write-up
  62. I Need Help...
  63. First, Cheapest Mods
  64. new Manual Trans at 63005
  65. Magnaflow Exhaust for 04 MCS
  66. Which Meth Kit for DD?
  67. Intake/strut brace conflict?
  68. CARB Exempt Cold Air Intake
  69. Alta CAI V2.0 purchase inquiry
  70. My next mod....GRS Intercooler or RMW Street Header?
  71. ALTA intake install question
  72. Individual Throttle Body Kit
  73. The intake match-up thread?
  74. Custom exhaust options
  75. Mini Mania BOOST UPGRADE PERFORMANCE KIT
  76. quick ECU swap question
  77. Installed my B&M short throw today. Thoughts...
  78. Transmission fluid
  79. Alta vs. Minspeed exhaust?
  80. Unichip Custom Tuner big numbers 33hp&32ftlbs
  81. Possible to make an 03 exhaust pop like an 05-06?
  82. exhaust w/cut connecting studs still usable?
  83. Alta Sportone polished oval tip exhaust
  84. Best way to prolong Power Steering
  85. Alta Exhaust Install ?
  86. Stronger Bypass Valve Spring?
  87. What Does This Sound Like to You?
  88. Edge Racing Sport Header
  89. O2 Sensor Extension?
  90. 180 Degree Thermostat Options
  91. Good Tuner in northern NJ??
  92. Damaged Cylinder Head
  93. 260 WHP!!! Thanks Mynes!!
  94. 223 WHP!!! Thanks RMW!!
  95. Equivalent Gates Part No. to the NAPA 060535 belt
  96. Need Good Garage in Vancouver or Seattle for Pulley Upgrade
  97. Seeking minimum power gain
  98. difference in b&m shifters after 2003?
  99. Stock exhaust size?
  100. RMW Header and Cam installed and intermittent P0136 code
  101. Alta Twurbo Kit YES or NO?
  102. Royal Purple Operating Temps
  103. Limited exhaust options? HELP!
  104. R53 Groan During Hard Accelleration
  105. Stock Header Modification
  106. Detroit Tuned Motor Mount
  107. What Royal Purple do you use?
  108. chrono pack oil guage accuracy
  109. Aftermarket Clutch & Flywheel
  110. Stock boost PSI
  111. New pistons: any suggestions?
  112. GRS and Forge Intercooler Core Size?
  113. Engine eats piston - want to see?
  114. Injector Color Question
  115. How to install powerflex engine, tranny, steering column bushes?
  116. Stock muffler rusting out v. Suggestions
  117. Painting polished exhaust tips (Alta) black?
  118. OBX Header Ceramic Coated Mild Steel or 100% T304 Stainless Steel
  119. Catch can tubing
  120. Feeler... Mynes tune party in NC
  121. Oil cooler - getting the DE bug
  122. Solid engine mount
  123. Help! I want my power back :-(
  124. First real Mod Question
  125. Borla Mufflers
  126. P0302 - Cylinder 2 Misfire
  127. Fixing run flats
  128. Strange Problems.
  129. Supercharger help
  130. Zoomers Exhuast System
  131. Resinator to quite down a Borla Sport?
  132. HOLY CRAP! I knew it would work, but I didn't expect this well!
  133. Starter to Flywheel distance?
  134. What has changed over the years?
  135. Oxygen Sensors
  136. Correcting MPG readout after installing larger injectors?
  137. Used injectors... are they reliable?
  138. ECU question (kind of technical)
  139. Pulley Install Video?
  140. Brembo slotted/Power Slot/TSW Rotors...which ones?
  141. scangauge question
  142. Need help removing oil pressure sender switch.
  143. RMW vs Magnaflow II
  144. Doug thorley/jardine exhaust
  145. MINI Cooper S mechanic in SC
  146. Clutch Info / How to?
  147. GRS water to air cooler
  148. Another turbo-back exhaust bites the dust
  149. It's Getting to be That Time...
  150. What is the MSD model number the Mini Cooper S uses?
  151. Supercharger Pulley Install
  152. new injector install problem (help please)
  153. Another Header and Cat Option???
  154. What is your take on Dynolicious?
  155. MYNES Technical write up... BMW/Siemens Catalyst Monitor Sytem
  156. Alta Intercooler Couplings
  157. Best aftermarket pulley?
  158. RMW vs Magnaflow
  159. Brake pads - axxis vs mintex
  160. Blew my motor :(
  161. My Modification Wish List. Need Input
  162. New RMW meth trunk kit mounting "cover"
  163. Dyno tuning tends to work
  164. B&M Short Shifter for '06 MCS
  165. M45 ....how long can it last?
  166. Advice on Getting to 200+hp
  167. Gauges
  168. BMW Installation Tool for Crank Pulley Failed
  169. ? for those with boost gauges
  170. M7 DFIC
  171. Quick question regarding Megan header
  172. ATI "super damper"
  173. Lazy take off with A/C on.
  174. Crank Pulley removal without holder tool
  175. Remote Tuning for R53 now available from RMW
  176. Camshaft Re-Grind
  177. DFW Performance installer
  178. Birthday Mod!
  179. Over-heating question
  180. Wiseco piston issues?
  181. Mini-Madness JCW Pulley Remover
  182. $2000 of power
  183. Anyone have their exhaust crack before??
  184. Jcw injectors,Schrick cam, Unichip piggyback for sale
  185. Cleaned IC after 160,000 miles...
  186. Likelyhood of TVS900 Materializing?
  187. Milltek Exhaust Qusetion
  188. Aftermarket Supercharger Intake duct
  189. Removal instructions for DDM CAI
  190. ECU reset effect ECU tune?
  191. Removing Magnaflow Resonator
  192. Where can I get replacement filter for Mymini CAI??
  193. Clutchmasters FX200 + Flywheel Review!
  194. MINI Madness Intake manifold
  195. Looking to make my MINI go fast! Ideas?
  196. Fail Start
  197. RMW cam...
  198. Stratmosphere exhaust
  199. looking for a place to install 15% s.c pully in upstate ny
  200. RMW Utah MONSTER Tune Event!!
  201. Mynes Headers Throwing Codes, Say It Ain't So
  202. pulley arrived
  203. MCS COSWORTH or ARP
  204. RMW Tune Carlisle, PA
  205. SC pulley install torque values
  206. Does an intake and Pulley = a tune to run reliably ????
  207. mini mania stage 2 impressions?
  208. Revolution Mini Works (Jan) Tune Event Louisville, KY
  209. MegaMynes Header Dyno Results
  210. CLutch and Dealer problems
  211. MegaMynes Headers
  212. Tuning Party in Houston
  213. Did Someone here race a Porsche 996 on the 91fwy???
  214. Help
  215. Help! Oil question
  216. GP MCS Turbo
  217. Dummy needs help
  218. Extreme knocking noise: Time for a rebuild :-(
  219. R56 JCW Tips fit R53?
  220. Shredded another SC belt yesterday!
  221. Mynes performance NY / LI tuning party
  222. Portable scissor lift???
  223. Supercharger Eaton M45 Service and repair without a core fee.
  224. Radiator fluid / power steering fluid
  225. Why does TQ drop off from peak, and how much SHOULD it drop?
  226. RMW Street Header Dyno
  227. Fidanza flywheel
  228. Houston-TX shop needed
  229. Transmission woes
  230. Throttle problems?
  231. Exhaust sniffers and AFR's
  232. Does Dinan CAI clear JCW strut bar?
  233. TSW Damper installed - now I hear a clunk...
  234. EML light and loss of power
  235. My R53 is in need of some parts!
  236. Help tune my car
  237. Serpentine belt w/M7 16% pulley
  238. Header question...
  239. Oil Cooler Question
  240. Conflicting O2 sensor data and A/F ratio
  241. M7 OCC DIY Baffle
  242. JCW installed, RMW tune done!
  243. Special tools for loan?
  244. Tire size question
  245. RMW tuned after AMVIV 09 (Part II)
  246. Poor man's header
  247. Since being on meth
  248. My dyno chart!
  249. Dynapack vs Mustang Dyno
  250. Need tire size advice, are 205/55-16s ok on non-S?
