- Helix gets to install the RMW/Aquamist Meth Kit
- Quieting Alta 3" exhaust suggestions
- Does a new BV require a tune?
- Lil problem - this happen to anyone else?
- Any one running the Dinan Suspension with 18s?
- clutch recomendations
- Rear O2 sensor? Messing with things?
- Alta CAI Install
- Just installed an OBX header easy peezy lemon squeezy
- Aquamist group buy
- Squeeling after a cold start, pulley? tension stop
- HELP ASC light and EML P0108
- Modding Automatic MCS
- Does anyone have any info on this?
- Has anybody seen this cat-back system before?
- Injector Question
- Poor Gas Mileage
- Resonator Removal
- CAM upgrade in the different regions of the world
- Need Help with mini madness lower engine bushing
- BLEW MY SUPERCHARGER @ 28,000 Miles
- 200 whp
- Anyone doing JCW ECU tunes in NYC area?
- Detroit Tuned BPV vs. OEM BPV.
- Alta short shifter grease?
- noob need some help alta intake check enigine light
- MCS Vs GP
- piston recommendations?
- RMW remote tune... wow!
- anyone heard of CATCO highflow cats? any good?
- Intake & Exhaust Noise - Yes I searched :-)
- OBX header
- Invidia Questions
- Clutch Time
- Throttle Body, New/Used/Other
- What is top speed of MCS 05 Dinan stage 5 208 hp?
- Just bought an 05 s model with blown head gasket
- Mobile Phone Performance Data
- 380cc-400cc injectors without a tune? Dyno's?
- I want your old Motor Mounts
- Clutch pedal is dead. Please HELP!!! ASAP!!!
- Adding a head to a daily driver =worth it??
- Two ?'s for a motorhead...
- Exhaust
- 05 S.. exhaust..
- p0171 help please
- UNHAPPY WITH MY DYNO RESULTS...
- First Mod....very pleased!
- INtake Boots
- Tune-up question. Need advice
- New Clutch/Flywheel/engine mounts. Thank you WMW for the new car feel.
- When install ALTA Intake system , does any electrial wiring required?
- Wish I had some LSD
- Powerflex bushings installed
- Intercooler Air Diverter?
- Does anybody knows a place to tune my MCS in Northern Virginia
- What are your shifting techniques...for a aftermarket clutch/flywheel?
- RMW Tune in Bay Aera
- Camshaft
- Time and Parts to replace Shift Cables '02MCS?
- Poly Bushing...
- Alta Exhaust, 2006 MINI Cooper S write-up (part 2)
- Octane booster
- noob here. looking for some help please
- Anyone use BeHe in MD for a tune???
- Threw a code #1125
- RMW at Eurotuner GP 09
- Alta V2 Intake and Water Question
- Overboost or what!?
- Adjusting Bypass Valve
- Dyno Results - 2005 R53 Mini-Madness Stage 3
- How much neigbor cost for install 15% pulley?
- self tuning options searched and came up empty handed
- Aftermarket Crank?
- Aftermarket Flywheel
- When to change/clean intake filter?
- resetting the odometer - the hard way...
- Turbo a R53?
- Anyone know of a good place to get my 15% ALTA pully installed in Arizona?
- plasma booster
- One-Ball Exhaust upgrade in boston
- squeal noise; driving me insane
- RMW TUNE IN ORANDO DEC 12
- After market exhaust too loud.
- Not So Good Vibrations
- Ahhhhh clutch problems
- need help identifying a pulley.
- Where to get a tune in NJ/NY area?
- Dinan intake fitting issues, Stock lower airbox warped???
- Tune Shops
- 300hub hp on a M45.... it's done!
- Need help. Best place in N.Carolina for Mini Mods.
- High pitche whistle after dinan intake install, is it normal?
- Require opinions on ACT Clutch & Flywheel on R53
- will the Intake Cowl Mod work with the Dinan intake?
- Cant Decide on Exhausts DINAN vs. Strat Milltek
- Installing header, cant bolt it back on.
- After Market Clutch Recommendations
- where does this piece go?
- How to Install CamShaft
- What tire to get...
- TVS 900
- Have a pulley, apparently need a tune - DC area
- 6-Speed Manual: Slave Cylinder Solution
- BBS RG-F 15 x 7 wheels
- Engine Noise not Barn Owl
- rattling somewhere in the engine????? need HELP
- What is the best CAI and Exhaust system to get
- AC Delete Options
- more problems FML
- If Your Car Feels Sluggish Read This Now!!
- 16% pulley = New rattle?
- MCSA Tranny Fluid Change
- I'm WAY late, but finally PULLEY-ed the trigger!
- Cylinder Head Thickness: What is?
- Borla Exhaust Quick question
- Boost Leak
- REplacement Dual Mass Flywheel
- R53 Intercooler M7 verses Alta
- LW Flywheel/Clutch - grinding; fan always on?
- Engine Change Advice
- Front mount intercooler
- CNC Mini headwork by ENDYN.
- Boost Leak? Clutch Slip? DSC? Snow Tires?
- CAI registry
- To Cam or Not To Cam?
- Comparison: Stock 05 to post mod syndrom
- Where's this plug go? :) Clutch job almost done...
- Hankook Ventus V12 Evo Tires
- Oil filled engine mount failures - and possible remedy
- HELP! radiator fan gone all wierd
- quick exhaust question
- Have you ever (EVER!?!) heard of this happening?
- Header and 17% Pulley Installed
- Where can I get a tune!?!
- ASAP direction of fx300 clutch disc!
- Alta intake installed, mini review
- Tuners in Florida
- Lighter Flywheel R53
- Seeking tuning flash tool in MA
- How to get rid of lash
- Is alta developing a new exhaust?
- Anything else I should do while I install my alta intake?
- "Glitter" on rear end of the MINI
- Test of the Mini by Arden !
- Modifed my Alta diverter today
- Automatic Transmission Limit?
- Putting away for the winter
- Alta foam filter split - which glue to use?
- supercharger
- Where put my money???
- Straight through exhaust?
- yet another RMW tuned MINI :-)
- MT Cooper S Does Time Attack
- Has your mini ever broke?
- New intake, oil buildup on back window?
- Minspeed clearing out inventory
- I need traction!
- Urethane motor mounts as a complete set?
- San Diego pulley install?
- removed precat added magnaflow cat too loud
- GIAC INFO
- Big Power Options...What happened?
- Help! I think my s/c just blewi
- Problem with Hawk HPS pads
- How much work to add crank pulley to s/c pulley job?
- Powerflex Upper Engine Support
- best place to get performce parts
- Horrible noise coming from pulley/engine
- Home made CAI
- Exhaust vs. injectors for a mild tune?
- JCW Intake question
- Alta Drop in airfilter vs CAI
- Alta Header
- First Build Gearbox (02 - 04)
- I need help with a tune
- emissions nightmare
- Wouldn't a 2% crank and 15% sc pulley = more than 17%?
- m7 intake vs alta intake
- Can I make exhuast tips myself?
- New Head Install
- Short Shifter Mod
- Thermostat M7
- Has anyone here personally owned both a 15 and 17% pulley?
- Help! Pulley swap
- Early Crank Pulley Out, Facelift Crank Pulley In.
- Supercharger issue
- Pool on LBs new HP
- Used Stock 2006 LSD to 2004 MCS | Time and Issues?
- Fuel Consumption
- Problems after installing Detroit BPV :(
- Project 1.8L Rotrex SC Stroker
- Supercharger pulley swap
- Over Reving MINI
- Brembo BBK rotor options
- RMW Custom Tune Party in Austin, TX, Oct 16/17
- B&M shifter differences
- WEBB HEAD and NEW to MCS
- OEM LSD Help Needed Please!
- 380 injectors, JCW Re-Flash or a Different Tune
- 130whp dyno results...
- Supercharger
- side exhaust
- 17% Supercharger Pulley - Plugs and Injectors Required?
- Ran into some hiccups when installing the oil cooler
- Question about pullies and manufacturers...
- New to the Mini World
- BOV?
- New head for my S
- Anybody ever install this crank pulley?
- Need MTH Cartune since computer crash
- Oil leak at tappet cover
- What happened to the RMW vs Mynes tune thread?
- One for the Auto-box owners
- The ALTA scoop request
- Need Help with my MCS 04!!! Don't start
- How to fit powersteering tank
- Best value clutch/flywheel
- Unusual injector question
- sc pulley install questions
- How do you know when the supercharger goes bad?
- supercharger pulley help
- Intakes
- What does yo-yo mean?
- Brakes need a lot of force
- P 0171 with RMW Header
- Whats the deal about forge coolers?
- Your top 5 mods list
- RMW Dyno Tuning Day - North Georgia
- What can i do to my stock airbox
- Custom head build thread
- How long can JCW brakes last?
- Putting a Mini SC into an Alfa Romeo
- RMW Tuning OR Hubie Tuning??
- Cusco LSD + CM FX300 clutch / flywheel impressions
- Old alta pulley vs new
- m62 still an option
- what vacuum number should i see on my boost gauge at idle at sea level?
- R53 2005 Steptronic manual shifter no go =(.
- jcw injector's duty cycle
- Where to spend on the rebuild
- RMW Billet Stroker Cranks for sale!
- 1.8l vs. 2.0 l
- Metal Dust on Boot?!?!?!
- More RMW cars with Kevin's Auto Care in Canada
- Bottom-end death rattle -- rebuild options?
- New RMW Power Numbers - 277hp
- What can go wrong?
- TCS System
- REVToaster
