View Full Version : Drivetrain (Cooper S)
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. Greddy Evo 2
  2. Oil in thorttle body intake side...
  3. Thumper Head+Cam=
  4. Post your dyno charts
  5. Alternative to Expensive CAI ('02-'06 S)
  6. Belt Tensioner + 15% Alta Pulley HELP!
  7. N-Take Air intake
  8. How do i sell a Modded MCS?
  9. Question about "mods and mileage"
  10. Time for a reduction pully?
  11. pulley installed; lound noise from supercharger
  12. Tell me what you think of your MagnaFlow exhaust?
  13. Replacing Pulleys - crank / sc / belt tensioner / idler
  14. Next Mods, guidance needed!
  15. Intercooler issues...
  16. What mod next?
  17. Converting 2003 MCS to 2005~6 Getrag trans
  18. Newb to Mini's (Modd Plan)
  19. Dinan or Alta
  20. Uncertainty...
  21. OEM exhaust manufacturer
  22. Cat. question
  23. Engine Swap Question
  24. Bye Bye stock mini motor
  25. Need Help With Choosing an Exhaust...need opinions...
  26. intercooler spray
  27. '06 R53 Jan Tune at Mach V
  28. 15% Pulley and only 7psi Whats going on?
  29. Alta Exhaust Issue?
  30. Insane rattle, exhaust?
  31. 04 MCS Clutch
  32. 03 R53 Tune and Dyno by Jan (Graph/vid inside)
  33. Has anyone tried this alternative to the Sprint Booster?
  34. alta tensioner stop
  35. What gear is everyone doing their Dyno Pulls in?
  36. Fiveo injector owners chime in please
  37. Tune after pulley install?
  38. Help with mod plan
  39. JCW exhaust
  40. High Intake Air Temps
  41. custom air intake
  42. Check Engine Light, code 08343 and P0130
  43. Looking to get some performance upgrades!
  44. Aftermarket engine bushing / mount options and opinions
  45. Clutch slip on 6 month clutch
  46. Change the CHIP -->> FAST COOPER??
  47. Oil Catch Can - Worth it?
  48. New Intake!
  49. pulley + plugs + JCW injectors = trouble starting?
  50. Schrick vs RMW Race Camshaft
  51. Fuel Injectors?
  52. Funky Boost.
  53. SLR Performance Chip
  54. Where i am at... Help needed!
  55. Getting a QTP Electric Cutout
  56. engine Rod/Main bearings
  57. Custom side exit exhaust mcs
  58. Stock CAI vs Aftermarket CAI: HP/Torque differences
  59. 15% or 17% reduction pully?
  60. Stock Intercooler Dimensions
  61. Why is the MINI performance world so secretive?!
  62. 300hp to do?
  63. Post Pulley Install Problem?
  64. 2004 MINI S SteelHorse Project Update...
  65. Will I hit 200WHP after tune?
  66. My MINI R53 ("project" and dyno thread)
  67. Homemade Water Injection!
  68. what compression levels does a motor need a rebuild?
  69. M7 Intercooler?
  70. MinSpeed Website?
  71. JCW exhaust price?
  72. Where to go from here
  73. the 400hp mark
  74. Loss of power/cel after exhaust depot exhaust install
  75. newb needs help (long sry)
  76. One-ball Mod makes your car sound like a Civic?
  77. busted crankshaft pulley
  78. Burning Smell After Hard Acceleration
  79. Detroit Tuned Tensioner Stop install in less than 20 minutes!!
  80. ANY THOUGHTS ABOUT ADDING NITROUS??
  81. tsw engine damper need periodic adjustment?
  82. ECU tuned, rev limiter now at 7300rpm
  83. 380cc Injectors - At what point could they be running lean?
  84. Schrick 264/272 Cam
  85. Going from stock to 15% or higher Q
  86. how to install sprint booster
  87. cravenspeed dipstick
  88. Meth Kits (Part 2)
  89. Alta Crank Pulley Install-Bake it and Place It
  90. Meth kits: IDC v boost type kits
  91. Completely
  92. 6 Sp Getrag transmission and Clutch problems
  93. ALTA CAI
  94. Free Meth System
  95. This might be a stupid question, but...
  96. maybe a good time to upgrade that pulley
  97. Bypass Valve Replacement Instructions?
  98. HIGH water/IA temps!!
  99. detroit tuned bypass valve didnt come with instructions :(
  100. Post-tune P1689 error code - any ideas?
  101. qusetion for folks with clutch disengaging issues.
  102. Tune required with 15% pulley ?
  103. MCS MK I vs 2004 MCS
  104. Header Heat wrapping
  105. got the one ball today
  106. Runs lean with spark plug change
  107. ATLA Shifter - Turn in for "new driving experience"?
  108. Conflicting research: oil pressure sender 3/8 NPT or M16x1.5?
  109. cravenspeed ssk plus the helix ssk????
  110. Just had CAI, pulley, sway bar installed at Helix... wow
  111. 2003 MCS with 16% pulley
  112. So how much power do you think it will all be worth?
  113. custom tuned car, remove mods, how will it run?
  114. Boom!
  115. Thermostat housing and coolant change
  116. M45 Snout Rebuild?
  117. Has anyone tried the AIS meth kit??
  118. Upper Midwest Tuning Party?
  119. installed pipercross intake
  120. Trying to find Red side mirror cap !
  121. To pulley or not to pulley? 9Not the typical s/c pulley queastions)
  122. installing alta pulley
  123. Ignition upgrades.. Why?
  124. NGK Iridium Installation Question
  125. Intake??
  126. Out with the old Tension-Stop, in with the new...
  127. More Burble please!
  128. Intercooler has bent fins...Replace with...?
  129. Need help with SLR chip install - 04 MCS
  130. If you had $700 to spend, what would you get?
  131. If you could only do ONE Which ONE?
  132. Clutch Help... Possibly?
  133. FYI on ACT clutch/pressure plate bolts
  134. ??? Factory Upgraded Power Steering Fan Duct & Panel
  135. Anyone use a unichip uni-q piggy-back ecu
  136. OBX Donut replacement?
  137. Injectors: how big is too big?
  138. Fluttering/Ticking noise coming from engine bay
  139. Laminova Intercooler System 2002-06 MCS
  140. Potential Mod List
  141. Installing 17% pulley - problem!!!!
  142. Pulleys.
  143. Any real benefit to JCW injectors at this point?
  144. Huge Oil leak after pulley and oil catch can install
  145. Houston Area Tuner Recommendations:
  146. [HELP] What is my best choice for R53 CAI? Alta? M7? Dinan? K&N? Pipercross???
  147. Another S/C thread
  148. M7 Exhaust for R53
  149. INVIDIA vs Borla Sport (loud system)
  150. Shark Injector needs a 15% pulley?
  151. Anybody used TyrolSport in NYC for installing mods?
  152. Copper Head gasket
  153. R53 charger pipe question
  154. m7 16% pully reduction question
  155. Dropping a 06 1.6 into my 03
  156. Head removal soon. Head-gasket recommendation?
  157. Selectable Sprint Booster - highly recommended
  158. Now EP6-DT/EP6-DTS 271hp @ 346,5Nm
  159. Whats next? on the mod list
  160. painted inside exhaust tips (Alta)
  161. Spark Plug Heat Range
  162. One Ball MOD?
  163. lsd question?
  164. Engine mount expected life
  165. '04 Upper Engine Support "Bad" - Replace whole bracket?
  166. RMW Race Header install
  167. Lilith's Update
  168. Want more power at altitude, but keep reliability
  169. How to measure Boost on SC
  170. Help choosing upgrade for my mini
  171. 380's or 440's injectors
  172. Alta CAI Trouble?!
  173. My Plans (input needed!)
  174. Insulating the I/C
  175. Two questions
  176. Cat Back Muffler Systems
  177. Belt size w/ 15% pulley
  178. how much tranny fluid...
  179. t4 turbo on r53 engine
  180. 17% pulley
  181. How many boost(psi) are you running on you R53 modified?
  182. HOOK UP THIS R53
  183. Use an Eaton M45 from a different car?
  184. Blown Engine = Need for a New One
  185. MINI MEET? in SanDiego or OC?
  186. which LSD do i have and how to identify if my pully has been changed???
  187. Realistic gains from common mods?
  188. Difference between Alta 15% Pulley v2.0 and classic?
  189. Which Exhaust? Scorpion/milltek/stratmosphere
  190. cleaning sensors
  191. Head swap DIY???
  192. -3an oil line sufficient for remotely mounting sender?
  193. Alta CAI & High Pitched Whistle
  194. getting ready to upgrade
  195. Air Fuel Ratio Loggers
  196. Gasoline "Lots" in my intercooler, poor MPG
  197. BSH R53 Lower Engine Mount
  198. Software for MCS tuning
  199. P0108 Tranny Still Slipping and Still need Help
  200. I ditched my OEM lower motor mount
  201. Just Installed: Dinan Intake
  202. clutch/tranny making funny sounds
  203. Scangauge II, accurate?
  204. Clutch Chatter?
  205. Car runs like poop now :(
  206. Short throw shifter for a 2004 mini
  207. Alta Air filter slippage
  208. Weird boost issue? 12lb's with 15% pulley..
  209. Stand alone
  210. upgrades????
  211. QUESTION: Random Oil Light appears?
  212. 92K on R53 change to 19% and 380?
  213. Iridium Plugs and R53?
  214. RMW TUNE!!! AMAZING DIFFERENCE!!
  215. do i need a tune or ecu upgrade
  216. A Mystery..
  217. Speed Daddy header
  218. Compression Test, How-To???
  219. INTAKE HELP!
  220. K & N air filter replacement
  221. Long Day
  222. Severe engine damage WILL occur at or above 15psi?
  223. A few questions about intake and pulley
  224. Hiss!
  225. BPV or Supercharger.
  226. OBX LSD call out.
  227. Cherry Hot Headers
  228. Upgrade To The GP Intercooler
  229. Clutchmasters FX200 problems anyone???
  230. Supercharger upgrade?
  231. how to get the most whine outta your mini
  232. Serpentine replacement... HELP!!
  233. brembo brakes with volks??
  234. Megan Header Question
  235. Borla Question
  236. Boost Leak - Not caused by IC boots. HELP
  237. Alta CAI R53 only $118!!
  238. In A Need For A Supercharger R53
  239. What pulley do I have??
  240. Newman or Shrick
  241. Tranny Slipping
  242. Using OEM Airbox with CAI
  243. Old header rusted out need help with OBX
  244. Service Engine Soona after CAI installed
  245. Clutch bleeding problem
  246. Alta CAI with Dinan Strut Towar Bar??
  247. 230 whp help
  248. Grub screw on BPV
  249. revolution mini works "thanks"
  250. Anyone running an RMW head in the Washington DC area?
