- OCC advice
- Stock diameter back-cut or undercut Valves available?
- Replacing stock crank pulley
- JCW sport brake kit - red caliper paint question
- Injectors colour coded??
- 03 R53 - How do I remove the hood scoop?
- Question about S/C reduction pulley
- Who shims their gearbox?
- ic boots??
- Valve Spring Compression Tool Recommendations?
- finally got my Snow meth kit workin!!!
- I can't figure out, why my boost is so low.
- 2003 Mini R50 Hood Cowl vents
- I saw this unique exhaust.....
- Busted Connector, now what? (massive picture)
- What to do first
- Head design concept
- 19% pulley? low end torque
- Need advice on ignition system
- Just dynoed my r53 in Germany!
- EVERYONE. Please Please Help :(
- LOTF Engine Damper Help Needed
- Exhaust system question - need help
- Hand held tuners?
- Magnaflow to Borla Street?
- Looking for Software for a hybrid R53
- Putting together a list
- 15% Pulleys - Alta, WMW, Mini Mania?
- Any OBDII software to log the boost pressure?
- New Brakes
- Where to get a tune in Houston...
- Need specs. on Dinan exhaust system D660-0030
- WooHoo--R53 in Bimmer magazine (Oct '10)
- Unichip question
- more low end power
- Got RMW tuned!
- WARNING! Use Factory Oxygen Sensor
- Have any NAM members used this product ???
- Looking for a quietest intake. Dinan?
- HELP - at the end of my rope.
- Map Sensor Issue
- Magnaflow install, need to remove exhaust hangers?
- MCSa Pulley Install
- Map Sensor Locations?
- Getting some air?
- New graphing software
- Planning my first performance Mod
- HELP! Pulley install fail!
- How much stiffer should a DT BPV spring feel from stock?
- Throttle Controller Question
- Clutchmasters FX400 rattle/raise idle RPM
- does heat from the reduction pullie produces kill my boost psi??
- normal vacume??
- broken crank pulley
- Lazy Throttle response after CAI
- o2 simulator bad?
- My s00per loud mini (r53)
- IK22 to BKR7?
- fresh air intake tube
- bypass valve problem??
- Picture request.
- what would be a good top mount engin damper..
- Exhaust tip color look normal to you?
- Erratic Run Fixed
- Radiator Hoses R53 - Help
- Just bought a Snow Stage 2
- Colder plugs on a stock motor?
- do these numbers make sense???
- 2% crank pulley or 17% SC pulley?
- Any one test WMI on MINI without tuning for it?
- ns1/ns2 cam question
- Removing a MiniDoMore hitch
- Installing LSD
- Anyone Else Not Like Ngk Brk7eix-11??
- downloader or custom tune needed?
- 17% pulley boost
- eliminating on muffler???
- Header or not?
- 2002 R53 OEM Engine Upper mount vs TSW
- will this set up take to 200 hp to the ground??
- Not as much pep
- No muffler exhaust setup question
- o2 simulator
- Looking for someone that has and wants to sell M7 ags v.3
- WMW remote tuning
- Tensioner rattle temporary fix
- pullet ignition upgrade from alta
- MCS engine stalls when cold
- Stupid mistake!!!!!!!
- Help! Brand new tensioner damper bad? Also an install problem
- Just picked up a used Dinan Pulley
- Upgrade MCSc under 700
- Obx exhaust on '06 MCS
- Dinan CAI replacement air filter
- Time Attack Vid AE PErformance v ABF MINI
- New Mini Owner/ Modification Questions
- Borla for Stock Exhaust Anyone?
- RMW tune day Thomasville, NC
- Thoughts about Mini Madness
- Best way to boost performance
- Will a bmw dealers diag.tool work on a mini?
- Engine Sputtering at stop
- TSW Engine Damper, bracket bending.
- a couple of questions about aftermarket cams
- Rocker arms needed!!!
- For those with ability to read AIT IC fin cleaning
- Performance Chips/tunning
- The Best Manifold
- Cam + 440cc/380cc injectors + tune
- June 2010: Seattle RMW Tune Results
- Why you NEED the pulley tool
- Girls's Guide to Removing the Bumper, Bumper Carrier, and the Modular Front End
- Tuning Kit
- Puller Tool question
- R56 Rotors On R53 With R53 Calipers??
- Pulley Belt
- Exhaust and Water
- Transmission Oil with Quaife LSD
- Boost loss/belt slip
- Losing TONS of power with use of AC
- Does anyone know the weight of a 1.6 supercharged
- Pulley replacement question
- How old is too old for engine mods?
- Problems after Supercharger/pulley replacement
- Bought an 03 MCS yesterday. Questions
- JCW and S with same mods - same result?
- Supercharger pulley install
- Fuel Injector Upgrade - Help!
- Exhaust question
- Need some pricing advice.
- Supercharger Belt Damper Polyurethane Bushing
- Looking for a pulley puller
- New Borla Exhause - Need oem hanger?
- Exhaust choices?
- 2003 Mini Cooper Engine Swap-KLZE v6
- Forge intercooler diverted add on
- 05 MCSa - VGS Will Do Anything Positive?
- Is it just me?
- Revolution Mini's Works sneak peak of new performance parts
- Many Many Questions
- Ticking noise after cam install
- Do pullies effect the car's reliability?
- Timing Chain
- Mods lead to lower performance
- What belt size??
- Belt size?
- Any Places in Ohio for Mini Tuning?
- Ignition and spark plugs... sigh!
- Engine Missfire
- In too deep
- Cleaning the Stock Inter-cooler?
- Proud new owner of a r53
- 06 R53 Custom Intake
- Theoretical idea for oil pressure gauge sender
- stock muffler thread refresh & request
- Tensioner stop just fell off, what should I do?
- AFE Intake??
- HELP!!- 06s running WAY to lean!!
- Atla catalytic converter replacement.
- After CAI, Pulley and Tune.. what's best bang for buck?
- Unichip question
- How many hours should a shop charge for a Cam Install?
- Do I need JCW injectors or not?
- Dusting off the cobwebs
- where is my power? (bad dyno results)
- Tuner in Cincinnati area?
- The right Brisk plug?
- question/problem with os giken.. help
- is this a good deal, or too expensive?
- His/Hers "shifter" for intercooler sprayer
- cam swap
- CARB Legal - SMOG friendly power upgrade advice
- Time To Start Modifying! What To Do First...
- vlave cover
- Best CAI for the price
- NEED HELP ASAP!!!!!! I have a huge header problem!!!
- POWAAAA
- pulley change on '04 mcs
- supercharger upgrade?????
- Pulley and plugs
- Lubing the Supercharger....
- Saw this CAI on e-bay
- Rattle under valve cover!!!!
- Persistant belt whine
- SuperSprint / OBX header buzz?!
- Invidia?
- removal of super charger 2003 mini
- Alta silicone coolant hoses
- My Alta exhaust is toast?
- Transmission with LSD Fluid?
- Boost Numbers
- Here is why you should clean your MINI with Seafoam.
- Any experience with TyrolSport GIAC tuning?
- Samco Hoses
- my oil catch can recommendation
- Post Mileage and Mods
- OS Giken Single Plate Clutch torque specs
- Thanks Helix - 15% Pulley and DDM intake
- Oregon RMW Tune July 9th & 10th
- 02 6spd Transmission Grenaded ? about 05
- Seattle RMW Tune
- Boost gauge install help
- DSC Issues
- intercooler bellows/couplers sliding
- Making a lid for the ALTA CAI
- DDMworks intake, just installed
- Cel w/ new 15% pulley+plugs
- Silicone Hoses
- Which 17% pulley to order?
- OEM Dust Shields w/ BBK?
- Tsudo Exhaust
- Those that are running oil coolers, oil flow direction?
- anyone have pics for the sc pully install?
- Need To Upgrade Brakes WOULD LIKE INPUT PLEASE!
- Dinan CAI question
- Cylinder Head Again...
- Filter for Alta intake
- Help installing JCW exhaust
- Will the JCW exhaust work with my '04 Mini S?
- Tuners in the Pacific Northwest
- 15% pulley and throttle response
- Aftermarket LSD - Thoughts.. Advice.. AutoX'ers - ?
- Clutch time....recommendations?
- Changing the pulley on an Auto MCS
- MCS Supercharger 2003-2006
- ebay intake install
- Just thinking....
- Pulley
- obd II interface cable for diagnostics???
- Cravenspeed or M7 CAI
- How can I go faster
- ALTA foam filter
- CAI tests
- Rebuilt long block
- Pulley install order @50k miles?
- Another CAI thread
- Engine project possibility
- Alta V2 CAI
- Heads and Cams
- OS Giken Clutch/FW better than OEM?
- exhaust recommendations?
- Two pistons have carbon build up, two pistons don't
- Exhaust deflections and modding an aftermarket exhaust
- 03 s engine rebuild Gasket Kit recommendations
- 15% or 17% pulley
- Loud noise still there after pulley then supercharger replacement
- Oil Pump and Oil Squirters
- Wanting to do a pulley swap....
- MTF with OS Giken LSD?
- Exhaust header gasket direction and torque specs???
