- Come to the LAS VEGAS Pully Party!!!
- Cylinder work
- v36 software and powerchip?
- FACTORY PULLEY
- Sports suspension, aftermarket suspension upgrades and rattl
- cylinder head bolt specs
- modification questions
- Light Weight Crank Pulley
- Upgrading to v.36 and effect on JCW ECU Programming
- Best 1/4 mile time
- parking
- Anybody doing interesting work on the Heads for the Mini's ?
- JCW exhaust - a low backpressure system?
- JCW and Dinan Combo
- Cleaning element in BMP intake
- Oil Catch can..Anyone tried this??
- Hypothetical Performance Version of the Mini.
- What is needed with aftermarket seats?
- Custom Made Shifter Knob for B&M Short Shifter
- Does the Cooper S Eaton M45 have a built in by-pass?
- Optimum CVT Mods
- Anyone's engine running lean after upgrading exhaust???
- Hella DE Micro foglights; anyone purchase/installed these?
- What is the pulley reduction % on the JCW Kit?
- Installed B&M Short Shift Kit
- Taking the plunge!
- Front lower a arm
- What's your h.p. so far??
- Higher RPMs on MCS engine
- Water temp & oil preasure ranges
- Supersprint exhaust sound file
- Gauge mounting options
- Best aftermarket front fog/driving lights?
- So which pulley? Alta, Mini-Madness, Helix...?
- Verwsion 3.6 ECU program
- ANYONE RUNNING A SUPERTRAPP MUFFLER ON THEIR S?
- Need ideas for performance boost...
- Anyone with aftermkt seats?
- Orciari body kit
- Co2
- Has anyone created a device to measure front and/or rear str
- Just installed Pilo Racing Rear Upper Stress Bar!
- Pilo Racing Installs a boost gauge.... Finally... Pics of fi
- Need help to increase performance
- Alta Air-Air Intercooler and Madness Intake
- Short shifter questions...
- 5spd cooper performance suggestions
- quiter intake; alta is LOUD!
- Catback Borla for the MC
- Colder plugs and 17% pulley?
- Estimated hp based on mods?
- new intake
- Upgrading the brake fluid.
- cam ? for ya
- 15% / 17% / 19% dyno charts
- Milltek header gasket?????
- Turbo CVT?
- Intake temps wih CO2
- Just installed the Miltek header and Alta intake on 03 JCW
- Is nitrous 4U a M7 VENOM Review
- Are there any future Pulley Parties coming in the Michigan a
- Southern Cal Pulley Installers
- MINI Ignition -vs- Dodge Neon Ignition
- 19% pulley
- Jim Conforti Shark Injector
- Front Mount Intercooler may be available soon!
- Somebody shoot me....PLEASE!
- UUC exhaust - "unique" smell
- Race stories
- Pipercross Viper S Cold Air Intake
- Anyone else has this experience with Shark Injector?
- Military Time from the ALTA Intake
- Lightened Flywheel/Clutch - What 2 Buy? - Do you like what y
- M7 Venom Nitrous
- Just Installed B&M Short Shifter
- MOSS intake
- CVT with Modifications
- 50,000 miles just fine pute pully on and now i have yoyo!
- Quote from EVO November Issue
- Quicksilver Header/Manifold
- Installing Short Shifter...
- Plasma booster in Mustang
- YIKES!!! new problem has now reared its ugley head
- Forced Oversteer / Zero toe @ rear wheels
- One click ECU upgrade ?
- Magnaflow plus Pilo Intake?
- How's the Milltech header work for you guys?
- Intercooler: Water-Air VS. Air-Air
- Jivan Ivan's new Remus Turbo Exhaust [PICTURES]
- Turn wheel, lights dim = performance to be had?
- Cold air intake
- Just Installed the Shark Injector; Just Put the MCS Away in
- JCW hesitation as you pull through 3200RPM?
- NOS in my MINI...12.8!
- Fastest 1/4 mile time on BOOST ONLY.
- Great article on FREE horsepower mods!!!!!!!
- It's here!!
- whow can you check the oil in the supercharger
- mini s felt good with the 19% pulley
- M7........Plasma BoosterTechnical Answers
- M7 - Excellent Support!
- Janspeed?
- mini mania shark inj vs stock ecu map for 19% pulley
- Direct Hits Spark Ignition System?
- Information needed for new product (Head and Supercharger)
- Pilo intake
- 19%pulley
- Now Available - Pilo Racing Rear Stress Bar.
- Exhaust noise reduction
- Exhaust Note
- Anyone in CA, with an LSD, get smogged yet?
- JCW Works Kit Belt Squeel
- How much heavier does the dual sunroof make the Mini?
- ODB2 monitoring Software
- NEW Milltek exhaust! IMPRESSIVE!!!
- Disadvantages to pulleys reduced more than %15?
- Dealer Exhaust
- Need up to date truth on V1 vs 8500
- JCW vs. Mini Mania Stage II kit
- UUC Exhaust Update.
- Quaife Installers? HELP!
- "KIND" Nitrous Kit for MINI Coopers
- Ignition Upgrades
- Co2, Intake temps, engine temps, etc...
- 2.0 Neon engine swap???
- 2002 shocks vs. 2003 shocks
- Borla Sport Exhaust Venturi.... What is it?
- Mini Cooper produces 190 Hp and 240
- Quaife, Flywheel and clutch questions
- ECU & JCW: Who's done this? Performance results?
- New HKS Exhaust System
- Available: P-Zero Corsa & OEM exhaust
- PILO Ignition System
- Minis will race again at NPR - Louisiana
- Stainless steel vs. Aluminum pulley
- Is the Phantom Grip LSD for real??
- Best performance upgrades & setup
- John Cooper Works upgrade for MINI brakes?
- Exhaust & Intake mods - Street Perception?
- 350Z owners get ripped off
- Alta exhaust sound?
- LOUDEST intake for the MCS???
- Switching out my Moss intake
- Best price on JCW kit
- More Mods
- ODBII Graphs
- for those in 6th gear: please give me tips on 1-2 shift at W
- Would you mod again?
- if you havent seen a dyno....video works now
- Secondary intercooler? Alternative to water-air intercooler?
- Moisture issue w/ Alta intake
- upgrade supercharger to Eaton M62 specs?
- If $ is not an issue, JCW or Dinan or Aftermarket?
- "S" with a CVT?
- ****** What Model Eaton is in the Cooper S? ********
- Alta Bigger Intercooler Air diverter
- Modded MINI Shoot-out in EVO
- Cooper S Recent Build Intake
- BBC TopGear reviews the Works 197hp, Hartge 200hp, Digi-Tech
- warped brake rotors
- Will this void...
- To be (SWORKS)..or not to be..
- 11 second MINI S
- Which Exhaust should I buy? HELP!!!!!
- Bigger fuel injectors = BETTER mpg ???
- Any odd oil temps?
- complete novice here!
- EVOtech ECU, Anyone has problems with it?
- Madness Header Coming Soon...
- where can i find the offical mini directions for aux gauge i
- help tuners and sponcors
- Technical Question about the ProMini/BMP Intake Installation
- $200 to spend
- Alta shortshift questions...revisited
- ECU....Blackout!!!
- Yeeehaa! Pulley and Exhaust!
- 275bhp kit
- MiniMania Cold Air Intake On Mini Cooper
- weight loss?
- Evo November 03 Issue
- JCW Seats & Wheels
- Any Nor Cal pulley installers?
- Just installed the ProMini Intake, but that's the good news.
- Richmond Virginia Pulley Party
- tracking...straight?
- Technical Discussion of the Merits of 15%, 17%, and 19% Pull
- re: Group Buy 19% pulleys now Available thread
- Emissions Testing Results for Modded MCS
- Mini Mania Cold Air Intake System
- JCW w/ new air intake- anyone done this- results??*
- MINI sport exhaust
- Pipercross Viper for MCS?
- JCW gas mileage
- In Need of Part Reviews
- How does one attached pictures to new topics or replies?
- Power loss from lowering?
- Yet Another UUC Eval.
- Alta Intake vs. Mini Madness vs. Pilo vs. Pipercross
- Parts on Ebay
- I just have a few questions about the alta intake.
- Shark Injector
- Anyone add ECU upgrade to JCW kit?
- Poll: Performance Spark Plug Wire Covers Interest
- battery relocation kit?
- Milltek Exhaust
- Muffler change?
- SEMA Pics
- JCW vs. Aftermarket for the 972nd time; resale value?
- $2000 performance modification suggestion!!
- ECU flash, stumble, yo-yo..... *scratches head*
- Muffler for the CVT
- lite weight pulley for accessorys.
- Alot of Questions for you guys.
- Need Help with HP Gains
- UUC Exhaust - FULL EVALUATION! (long!)
- UUC Exhaust
- Thanks everyone.
- TURBOS,SUPERCHARGERS AND ANYTHING ELSE.
- removal of the speed governer
- Please... Someone talk some sense/insanity into me!
- Changing the pulley?
- Which Aftermarket Intake System Gives the Most Power Gain to
- Thoughts on this exhaust from MiniMania
- how wild can we go before voiding our warranty?
- M7/venom experience
- California and CARB Approved Intakes
- How much for center tube for supersprint exhaust??
- Just added an Alta pulley, car started smoking......
- Not Getting All of the Boost You Deserve?
- What's the normal oil temperature?
- Pictures of your intakes? BMP, Viper, K&N, etc...
- Just got my PILO intake!!! and a ?
- Pipercross Viper Intake vs. BMP Intake for MC
- Torque numbers for exhausts?...
- My MINI Dealer now installs Rogue Cold-Air intakes for the M
- help: thump noise on sharp right hand turn from boot area?
- M7/Venom nitrous installed today
- No Substitute for Cubes except Boost?
- Nology Hotwires and Iridium Spark Plugs
- is there a supercharger for my mc?
- ECU Upgrade Advice?
- where to mount gauge?
- Input on OBDII software
- 100 Octane
- New DINAN stage 1 and 2 performance upgrades for MCS announc
- what is causing the extra weight?
- Pulley and ECU questions I need help with...
- Jackson Header Installed
- I now have More Pulley Power
- Clicking noise with EBC Greens
