- My New STEREO
- what aftermarket gauge most closely resembles stock?
- What can I expect from my future mods
- What happened to the Mini-Mania car
- Belt for the 19% pulley
- Badly damaged belt w/ 19% pulley
- Installed my Borla exhust.
- Dinan
- What else?
- K& N system
- Insurance Coverage
- Question about a reference by maximini
- Customer Service at Alta
- Intake Whistle
- Helix in the Blind
- How much hotter does your pullied car run?
- Boost gauge sucks?
- Custom head work
- How difficult is it to change out a shredded pulley belt?
- 04 Magnaflow
- Intake
- Best Price for Odyssey PC680??
- information on unichip map... help
- Intakes and 20,000 mile service??
- Tornado
- Water to air intercooler by FMD
- Fuel consumption w/ 19%
- alta and uni
- Pulley Brands
- New HAI 1/4 mile times.
- Need part number for belt......
- One ball Set up
- What 0-60 gains from serious mods? Here's an Answer!
- intercooler fan
- Engine monitoring? Oil temp or Intercooler temp
- looking for a new cam
- Intakes: Give me your Two Cents, Please!
- Cleaning Alta Intake
- Playmini header...
- South Florida Pulley Party with Randy Webb
- joemini
- Mini shift knob
- Driving home from work today my CEL and EML came on
- Question about custom exhaust
- Another New Header On Ebay $210
- What's your Mini experience?
- What's different between Mini Cooper and Cooper S?
- B&B exhaust numbers?
- $200 cartune chip in deutschland
- Dinan S1 kit available for MCS
- So next year is 15% reduce stock?
- Plug wires, are they the same for the MC and the MCS
- Lazer and Radar
- M7 thermostat? How's it work?
- warrenty agin
- All of you complaining that Mini Mania ruins your warranty.. complain no more :)
- Borla Exhaust Questions
- LSD Discussion
- Powerchip reflash
- MINI Mania Announcement Today!
- Belt tensioner tool
- Why is everything so expensive???????????
- what's the tractable power band of a stock MCS?
- Trailing Arm?
- new header on ebay for $260
- Ireland Engineering Brake Caliper Relocation Kit
- SC on the 05 MCS, more red. pulley friendly?
- S-afc
- O2 simulator
- ASA LW5 white 15" x 7" wheel search
- 110 Race Gas Question
- Regarding Dinan... Some thoughts
- Alta Intercooler... Arrrggghhh!!!
- ECU Remap Experience for the non S Cooper
- feedback on ebay exhaust
- Who has Mini Mania Stage 3? Impressions?
- short shifters
- Comments from Quicksilver exhaust owners
- What do you think my first mod should be for my MCS?
- West Tuning & JCW
- pressure and temp gauges
- 37.5 chip flash for MCS
- Hot shifter boot after short shift install
- 19% and Intercooler Diverter
- 19% Pulley, just was wondering, what's Randy's take on this?
- What mods would be best
- Cooper S exhaust special
- Good Choice for Brake Pads?
- engine swap for diesel mini's
- Unichip Switches: Where to Mount??
- compression ratio on a cooper
- 19% and only 16lbs of boost??!
- ECU For Performance Head and Cam
- what happened to MaxVelocity.net?
- Re-Installing Stock Exhaust... Couple Questions....
- Lack of Performance Parts Development
- ABS Spin???
- Anyone replaced their shocks?
- Lightweight Crank Pulley
- "The Goods" have been installed
- JCW install on Speed Channel
- Mini Mania Announcement?
- air-to-air intercooler
- MINI weights...
- Help me jack up my Mini
- Helix shift kit / Magnaflow install
- Still no '04 Short Shifter?
- ebc greenstuff
- Air Fuel Gauge Install
- Jitters, or a problem?
- Magnaflow install
- New Cooper/Cooper S performance device found on ebay!
- First time at the track...
- On/off switch for Supercharger
- Mod my mini - make it go fast!
- Head mod illustrated in Gomini mag
- 27bhp increase from chip alone...
- Any MINI Buttonwillow times out there?
- tower brace with unichip
- IAT and electronic trickery?
- Kentucky/Central Pulley Party Aug. 14/15
- Header Time. :)
- play in shifter:( :( how to?
- Boost gauge Help!
- Custom Exhaust
- Alta Upgrades
- Wires and coil pack 0-60 times
- Cold Air Intake cures YoYo ...
- 15% pulley switch to 19%
- Remus Exhaust
- M7 Aluminum Wing Questions
- NOW it drives like a Go Kart!
- Quaife Limited Slip Diff
- 15% Pulley
- Seattle Area Dyno
- My first real mod, pulley install at Helix today
- Anyone have a wire diagram for an SAFC yet?
- Oil Pressure Gauge - tapping the filter cover
- intake, and reduction pulley questions
- Alta Cold Air Intake Just installed.
- MINI warantees & aftermarket
- Performance Suspension Options
- Care to see a One-Click dyno sheet?
- Webb/Powerchip question?
- Turbo conversion?
- What is the fastest Cooper S 1/4 mile time?
- My Impression on UUC LightWeight Flywheel
- Data Logging Choices - Input Sought (CarChip E/X)
- scary steering when breaking hard!!
- Unichip dyno not so good. :(
- Octane Boosters
- Oil in the coolant resevoir... bad sign
- Higher Octane
- 19% pulley with Venom nitrous...
- Modded Airbox/Cowl with BMP PICS
- Just installed my ALTA intake
- Rate Loudness of MC Aftermarket Exhaust
- Any Experience with Mini Madness Performance Kits?
- Engine noise after head upgrade
- Switching back to stock pulley
- Helix Minisports, Dinan and...........who?
- Anyone have a short shifter I can try out?
- Being short ain't so bad
- Modding The BMP/ProMINI CAI setup
- Torque for pulley bolts
- Mini-Madness Water to Air Intercooler
- 30hp from a chip
- Has anyone done an increase in bore or stroke to the MCS?
- Suspension Part Differences Between MC and MCS?
- To mod or not to mod???
- WOW - Great Sounding Exhaust
- Pilo Racing - Short Shift Kit ($65.00)- As seen in vendor An
- Water pump gearing
- Question for those who switch from 15% to 19% Pulley
- What is WOT?
- Oil Catch Can - Testimonial
- Anyone aware of such a clip for the MINI?
- Pulley change
- Quicksilver exhaust sound clip
- A few performance questions....
- knock off parts...Intake and Rear Stress bar...
- i need a cai
- Performance Air Filter or Cold Air intake for Cooper CVT
- A Day at the Dyno
- Helix Short sifter Click
- Higher geared 6th gear
- alta intake pics
- Would it be possible to put a two-step limiter on this....
- 19% Pulley Install -- Did it myself
- Heard a Rumor about MC head
- I need cold air intake advice!
- Alta intercooler water spray system
- Custom Exhaust Question
- Pilo Coil
- Comparison of various pulleys
- I made 30 passes at the dragstrip last night with my 19%...
- Wheres a good Mini Tuner in the West Palm to Miami area?
- Are your rings sealed?
- Pulley install dilema
- Does V38 change A/F
- Picked up from dealer after 11,000 mile service; notes.
- new HP Racing header
- M7 "device" available
- operation cryo cooled plasma flux capacitor horsepower mod
- Who sells UUC Exhaust?
- pulley + intake = better mpg?
- can't find recent post with ac removal pictures
- Status report of longevity of thr MC turbo kit... please
- M7 Device for MINI Cooper S
- Good price for cylinder head install
- Throttle Body question.........
- Pilo Racing - Secret to Cylinder Head Porting !!!
- pulley change
- Shift Light
- Short Shifter at 2nd & 4th
- installer for pulley in the Northwest?
- BFP Cold Air Intake Update 5/20/04!
- Cutting Brake Rotors
- Pulleys
- WTB aftermarket S/C...who sells em?
- Side blowers
- Factory ECU Upgrades
- Rogue vs. K&N Intake for MCS
- Brake Pad Thickness
- Summer Project...
- shifter knobs
- Throttle Bodies
- How much boost exactly.....?
- Who makes the best 15% Pulley? Do I Need a belt with it?
- Burbles Question
- Where to buy Pipercross viper intake?
- A Testament to the Windshield
- GIAC?
- Best price for Alta intake?
- Shift linkage housing
- V38 software
- 04 borla ?
- Alta intercooler diverter
- Intake and 19% Pulley
- Alta intake sounds like an open faucet at idle...
- Brey-Krause Harness Bar and G-Force 5-pt Harnesses Installed
- Dyno Questions (2)
- Unichip or AmD
- Had santa driving the big brown truck pass by...and dropped
- skid plat
- The best Exhaust? (MCS)
- New Tuner - Great stuff
- Hsport rear bar, hitting body?
