- MCS Oil Cooler - 250 bucks
- Pilo Racing - Sneek Peek Cool Charge Intake Manifold
- Just Upgraded to V39
- New BMP Carbon Fiber Intake ???
- Dinan High Flow Cowl Induction System
- Urgent!!! Alta ssk
- Question for any cooper with SuperSprint exhaust or BMP folk
- Anybody Have a Remus Exhaust on Their S?
- Best exhaust
- Dinan Software and Performance Upgrades
- I have a big problem please help!
- Now What?
- Where to buy supersprint exhaust
- Alta Oil Catch Can location - new
- Miltek Header - Before & After Sound Clips w/ Magnaflow
- New Products from GTT in UK!!
- Mod now, or after Warrantee expires?
- Want More Down Low Power
- Long Standing Question, what is a GIAC?
- For Those Who Doubt a Catch Can
- What size pulley on a standard MCS?
- what more?
- Safest amount of boost
- 15% or 17%?
- MTH update?
- When is a 19% not a 19% anymore???
- JCW 200 to 210 Upgrade Docs
- Limited slip
- 19% GIAC with larger injectors - first impressions
- Which Intake?
- MINI Aftermarket in Vegas?
- Helix 19 with upgraded injectors
- Magnaflow Exhaust System UP FOR GRABS!
- Maximum RPM anyone's turned in a MCS
- Bbr
- WOO HOO!!! Pulley!!
- Head Comparison
- Service Engine Light on with Kingsborne Plug wires!
- racing technology
- 15% or 19% Pulley reduces life of SC?
- Turbo and Twincharged MCS
- 15% or 19%?
- TCE Wilwood front brake kit ...
- Ebay intercooler
- Just got my Milltek...
- Should I spend $300 for 4 lb.-ft. torque and 4 hp?
- Simple Question
- Short shifter question (maybe dumb)
- power comparison
- Upgraded from 15% to 19%....
- Fast Forward LTD. Exhaust?????
- DIY Instructions for Shift Knob/Boot R&R?
- More Carbon...the addiction continues!
- How to install Alta catch can in 2003 with alarm system???
- Pilo coil and Nology helped greatly with "stumbles"
- Another Pulley Question (15-17-20)
- Replace lower pulley, Anyone done it?
- Battery Terminal Mount (for modified S airbox)
- Spark Plug Question..
- Cooper conversion to Cooper S exhaust
- Max Boost
- Cleaning IC
- Simple ECU Question
- unichip woes?
- Cat Back Questions, Milltek, Borla???
- To warranty or not-to warranty? (not Magnuson-Moss related)
- M7 Air Gain System... Sneak Peek
- ECU Tuning - are these numbers real?
- Which CAI?
- Megan Exhaust Header from Pilo Racing
- Shark Inj Install
- Finally, we can make some real power!
- Miltek and drone HELP!
- air fuel controller
- How do I uninstall the Alta catch can
- Help Guys, I need to find out where the rev counter wire is in the ecu or anywhere
- Can the Milltek gasket be reused?
- '05 S (need help determining some mods)...
- Loose Plugs
- Will Stock Plugs work with upgraded wires and coil?
- traction problems
- Sensor for boost gauge
- Turbo for the Cooper S, Yes I said "S"!
- 2005 MCS exhaust vs Remus
- MTH Dyno Results
- The 20% Pulley!
- I want more torque!
- Mtf
- 05 Pulley Party, Feb/March.......Anyone?....Anyone?.....
- What Stage?
- CAT Recommendations?
- Oil Change!
- Question for Serious Tuners – Variable-Ratio Pulley
- Official Modded MCS 0-60 Times Thread
- 4 Exhaust Tips?!
- Exhaust expanded? or stretched?
- A close shave
- What's your winter project?
- Is the pilo ignition pack + plasma booster works?
- Remus feed back
- Clutch problems on modified cooper S's?
- Need a part number
- MINI-MADNESS release's new upgrades
- Miltek header and cat-back went on today
- Shift Knob Removal?
- Software Upgrades & Stumble
- Big Bore Kit?
- BMW & Peugeot New engine ..What can be done?
- WTB: M7 Oil Catch Can
- HI-PO Heads: Costs and where
- Madness, Webb water to air or Alta air to air intercooler?
- piston fitting
- Dinan for 05
- JCW Air Filter Box
- John Cooper Works air box
- Swapping 'S' motor into Cooper chassis
- Interesting water pump location
- exhaust spec ?
- AltaCrank Pulley Verdict...
- Any pulley parties in CT? Or any installers?
- Nology wires?
- JCW charger is making weird noise after software!
- Alta short shifter question
- California Pulley party???
- Does Chip Tuning Really Work?
- pulley
- AMD OneClick
- Ebay Oil Catch Cans Any Good?
- Dinan Intakes
- Supersprint Exhaust Inside! . . .
- Flashloader Cable?
- Vendor is always (?) right
- Cooper S pulley
- Unichip Questions....
- hp claims
- GIAC and 19% What happened?
- thinking of my next perf. mod - aside from a pulley....
- will it fit?
- Help! Pulley Problems!!!
- ecu upgrade
- Info about an exhaust
- Help!! Belt shredding problem
- engine measurements
- big injecters
- bmp gains.
- Power... 230 HP and over and clutch
- whp for 15% pulley & giac ecu ?
- Injector Cleanings and inspection???
- Boost Guage Instruction?
- BOOST LOSS NEED HELP!!!!!!! Runing 19% pulley
- Just wondering???
- The customer is always (?) right
- Ebay header HPR $209
- Makes you think :)
- Let's Dispel the Myths!
- Dyno results
- Electric Supercharger
- Supercharger Pulley myths and rumors
- M7 customers BEWARE!!!
- Intakes, intakes and more intakes...
- G-TECH/Pro, ... anyone?
- MCS turbo
- GENNEX Motorsport
- Alta Lightened Crankshaft Pulley Instructions
- MTH, waiting............
- Which direction does the clutch face?
- Ben Fer Downpipe, up pipe did not fit!!!
- Is it really a CAI or just an AI?
- EBay available MODS
- 17% pulley for ALTA bolt-on collet?
- Invidia Exhaust for MCS (56k warning)
- Exhaust tips
- Old exhaust - new MINI ???
- blue mcs
- Supercharger Pulley/Snout size
- Florida Mini moving to California...HeLp?
- did Dinan quit making the cold air intake
- 2005 JCW Kit: Double Your Pleasure - Double Your Fun
- RPM spool down
- Neon srt-4 engine a match?
- JCW upgrade kit DIY
- Shark Injector?
- New belt with 15% pulley?
- help with throttle jerkyness
- catch can catch
- Resonator on Milltek or Magnaflow exhaust?
- Head with cam - clutch problems
- anyone use a AMD pulley here?
- new belt tensioner/idler
- Off to the dyno
- reviews?
- 15% Pulley Installed
- Air Induction Kit - 12.4 bhp and 4.7 lb ft of torque
- MCS soon hopefully...
- alta intake question?
- LSD now with DSC?
- JCW Prices across the country- Please post!
- N2O damage from intercooler sprayer???
- 0-60 times
- 2-4 HP with Alta Silicone Intake Hose?
- CAI advise please
- Zoomers Exhaust for MCS
- Anyone here got a boost gauge in their car without using the Alta mount
- Is CAI bad for the engine?
- ATP Exhaust Cutout
- 2005 MCS JCW Kit 1st Impressions
- Frontmount
- Biggest Bang for your $$
- anyone ever induce "limp home mode"?
- Anyone make a single can cat-back exhaust for the '05 Cooper S?
- Most insane MINI dyno video!!!! MUST SEE!
- Madness V2 header
- 1/4 mile top speed mini
- M7 Blower Upgrade??
- Beware!!!!!!
- '05 One-Ball / Fast Toys
- CAN I use any foam filter cleaner to clean my alta intake?
- High performance heads
- Helix & RDR!
- Dinan Cowl Induction and Throttle Body
- product or vapor
- Another E Bay exhaust
- Replacing OEM pulley...anyone done it?
- MTH | Octane Rating
- exhaust for the open top...
- Yet another Ebay exhaust
- LSD added to the MINIUSA configurator!
- Headgasket trouble with high boost application...
- OBD II Tools
- Aftermarket Clutch Break-In Period...?
- Kool Blue filters
- SS & S
- 24" Supertrapp?
- Just fitted the Alta Induction Kit
- MCS exhaust design
- RDR's TMIC MIA??
- SEMA bling
- 20+hp gain wiht an Ohm sensor???
- Overdrive?
- Headers + no cat = error code?
- What is factory HP should be?
- Pullied car - cooler plugs actually necessary?
- Pilo Racing Piston Information
- Ignition upgrades?
- Pulley & Long-Term Reliability?
- Anyone have the B&M short shifter?
- Modified oem header for the cooper S?
- Pulley Install Question
- Miltek header question
- Post Works kit upgrade feedback:
