- GIAC/pulley/intake question for non-modded dumby
- CUSTOM EXHAUST - JIC - NEED 04 or 05 MCS in LA AREA
- JCW CAI Install Hours w/o Injectors
- Dyno results
- GIAC software installed, what a BEAST! Thanks Garrett, DSR, and New Dimensions!
- Anyone in Atlanta area have an MCS stock air box?
- M7 62mm vs Helix 63mm Throttle Body??
- Question of mods??
- positive Alta CAI feedback
- No money for JC Works, what can I install to start performance mods?
- How to install M7 Throttle body
- ECU Virgin
- What next?
- Short-shifter extension to retain stock height and leverage
- That annoying piece of plastic behind the air intake box
- Can't get WOT reading
- Loose spark plugs
- Pulley came apart
- Bypass valve butterfly adjusting - any numbers?
- V2 Technologies Exhaust
- G-tech RPM Calibration
- GRS Intercooler Evaluation (WMS)
- What is the truth about short shifters
- Another New Top Mount IC
- M7 AGS vs Alta CAI sound clips?
- Alta silicone hose question
- Question on this Module/Chip from ebay??
- Knocking when cold
- Intakes
- Dinan vs Alta impression
- Headed to Helix13 in PA to get work done soon.....
- mesh in hood scoop?
- Auto meter Water Temp gauge jumping around
- Paging Hubie
- Goodyear Gatorback Supercharger Belt
- Can a MCS beat this?
- M7 AGS Owners
- Bosch Injectors
- Stock temp gauge = free underhood gauge?
- Fuel Injector Poll
- The cheapest CAI intake ever!! **FREE**
- Help with DTC
- Injector sizes??
- Another high 05 dyno...
- ECU Location??
- which intake?
- 19% + 4% crank pulley
- Define Twin Charged
- Are you....
- another ebay thing! Sun Hyper Voltage? ? ?
- Helix13 Short shifter?
- How loud is loud (Borla Race/Street)?
- Anyone have the JCW Intake instructions handy?
- Cryo System
- Not One-Ball exhaust, but rather...
- limp mode = belt slip?
- 2005 MCS Stock Intake
- Stock intercooler cover...pointless?
- Air Gain Problems and harness issues?
- Just got an Alta IC
- Dragon and engines
- M7 AGS......Air flow #'s
- Laminova core intercooler
- Alta Crank Pulley install Q's
- Alta crank pulley post Dragon
- Cooper S Supercharger on a Cooper
- What mod next?
- How to monitor timing advance/retard
- Newbie With ?s
- thoughts about Benfer CAI...???
- Sticky Shift kit
- M7 AGS... image
- Exhaust problem help
- How about no exhaust?
- Which Shark Inj. version do I have?
- Ignition upgrades
- JCW Intake - what kind of filter?
- OK LAD's I GOT AN IDEA
- 430whp Mini cruising Phoenix
- Boost Gauge Help
- Fuel milage drop after ECU reset or MTH?
- denso spark plugs
- Radiusing intake track for improved air delivery
- BOOH YA ! Awesome dyno #'s !!
- HELP with JCW intake! Can't find vaccum line!
- AGS reports
- Unichip Software and Cable?
- M7 Oil Catch Can Install Question
- Question for JCW Exhaust owners!
- 2005 MCSA pulley + intake upgrade done
- Alta Catch Can install in an 05?
- Larger injectors
- thermal coating
- Pulley Brand Q
- Next Step?
- Alta Cold Air Intake Installed, my thoughts and comments!
- short shift kit and aftermarket exhausts
- is a bov possible
- New high performance Clutch found for Cooper S
- 2005 rear exhaust hangers
- Fumes
- Can anyone read german?
- B&M Short shift 04+ vs JCW??
- M7 16% pully installed.
- Tuned by.....El Diablito Rojo-N20Mini
- Another Water-to-Air IC for the MINI
- 200+whp modifications
- Mobil 1 $$
- M7 AGS Review
- 2005 MCS Tranny
- MCS vs. Honda SiR-t or in the US Si-t?
- quaife lsd
- JCW Exhaust..new rattle
- oil parts
- schrick cam question.
- M7 pulley? Any help Randy Webb...
- SPI Twincharge featured on Sport Compact Car Magazine
- Webb Motorsports Update
- JCW Intake/Injectors and the MCSa
- Home made intake Idea!?!?
- master work
- Simplest and cheapest performance boost for mechanically impaired newbie
- Intake, exhaust, plugs and pulley wheel.....
- turbo timer on mini cooper S
- Exhaust Back Pressure Q
- New Idea for MINI Performance Parts!
- Oil catch can questions
- One way check Valve for Brake Servo
- M7 AGS - Sound/Video Clips!
- No Cat and no SES
- Miltek is installed
- m7 AGS
- Bay area installer for Alta pulley & intake?
- Question on this product?
- Performance observation
- So M7 Installed The AGS on my 2004 and....
- Removing Bypass Valve??????????????
- Future mods advice/opinion
- Buying an 2003 JCW with Mods - Help
- So I installed my Alta Intake on my 2005...and...
- HAI - how often do you clean the filter?
- my JCW intake whines all the time now
- Schrick cam with stock head...
- Head porting help
- Dinan Boost Upgrade System vs. ?
- Official ALTA Q&A thread!
- RC Engineering Injectors - Intercooler Installation?
- Mod Combo Advice
- Dyno results -- what to do next?
- How can I stop my exhaust from "farting" ?
- yet an other short shifter question
- 2% Crank pulley vs reduction SC pulley
- M7 Project Phase One
- Bypass Valve Part Number
- JCW ECU flash without the kit?
- GIAC and DSC
- M7 Technology pulley.......New
- 15% installed on '05 - comments
- MOD info upgrade forums
- Twincharged dual intercooler question
- K&N Filter question
- Alta or GRS Intercooler
- 15% Pulley Installed, Special Thanks to Outmotoring and Alta!!
- This thing is a joke right?
- Remus Exhaust for MCS - $299 !!!
- 48 degrees in the AM 80 in the PM need a new IC
- M7 Pulley - April 19th?
- Anyone planning to upgrade to 2005 Tranny w/ New gears and LSD?
- New Front Mount IC
- Lsd
- Crank Pulley Install.......
- problem 02 vs 03??
- Help pls!
- i want a Boost guage!
- Sway bar and pulley!
- Would it be pointless to get a JCW intake..
- How can I make my MINI sound good?
- UUC Exhaust Pics..
- HELP! HELP Alta Pulley Install, Allen Bolt Sheered!!!! HELP!
- JCW Intake...what filter
- Foam Filters Explained!!!
- dont click
- Front mount intercooler and carbon fibre manifold
- Cat-back installation
- Spark plug p/n
- ok if 15% is so good y not17%
- JCW Upgrade Retofit??
- First mod.
- Colder plugs NEEDED?
- Turner Motorsports?
- Slave cylinder.... HELP!
- ALTA Intake installed today
- MTH tools in miami fl?
- It has begun.
- CAI increasing SC whine...
- HELP! Need pulley installer near Tampa!
- 15% super charger?? worth it
- Does this look right?
- Help! The dealer says...
- 274.9hp at the crank with M7 Venom.
- Going to the Mini Dealer...ECU question
- Schrick Cam!!!!
- JCW intake CARB approved?
- Mini s w/ Turbo
- how much for gauges?
- schwartz drive
- Who wants to see proof that a part works?
- Why you should pay someone to install your pulley...
- JCW kit for the Automation Cooper S is coming
- what is a wideband O2 sensor and why do I need one?
- Am I crazy for wanting to do this?
- Remus MCS Exhaust
- MTH vs. AMD One Click - what to do?
- Detroit Tuned Rocks
- Magnaflow exhaust rattling
- '04/'05 B&M Short Shift Install
- B&M shifter installer SF Bay Area
- Full JCW 210BHP "Kit" after 600 miles...
- Straight through exhaust
- LIVEWIRE spark plug wires any good?
- M7 Hood Scoop... deltas
- What is the MSRP for JCW exhaust from the dealer?
- Dyno graphs of JCW vs. A.M. MCS....
- Off to my dyno tune this morning
- Exhaust install question.
- shifter upgrade for my slop shifter?
- how to on cam install????
- DYNO ? bonnet open or closed?
- Alta crank pulley
- headers with or without cat???
- My new set-up...
- Need 05 MCS Vacuum Schematic
- SuperSprint headers...
- Pilo Coil & Kingsbourn wires arcing problem
- tranny work or more power.......
- Pilo Racing Header Version 2 - Coming Soon
- What's next?
- Poor Dyno results
- '05 MCS Development Plan
- Off to Hesco in Birminham next Thursday
- 2005 Hai
- Plasma Booster Installation! (Pics)
- installed Twinscrew & more today!!
- JCW Intake installed
- Anyone installed Schrick cams on MCS...
- Just an intake?
- 04-05 BM Short Shift Kit is now Available!
- Pulley Party in Charleston, SC
- Super Hyper Combobulator
- Dyno in Tucson
