- Where has my boost gone?!?
- Power steering Rack
- Revolution Mini Works Race Cams
- Injector upgrades
- 25 PSI off stock supercharger
- Lightest Flywheel?
- Cold air intake
- Any truth about comment from dealer on 15% pulley?
- Detroit Tuned BPV
- Need a charger pulley. Who do I call?
- Running Lean
- amazing setup
- 2004 Clutch Screech
- 2002 jcw hp help
- Where to have 15% pulley install done in NY/NJ/CT area??
- Instructions for replacing Timing chain tensioner?
- Need Help!!
- Twurbo Kit
- How much is my car worth ?
- Tuner Question
- Custom Header
- Alta Ignition & v2 15% Pulley Performance Package and more..
- custom exhaust build thread
- bypass valve repair or replace
- Anybody use silver anti-seize on oil pan gasket?
- Rusted Exhaust Clamps
- What Injectors are these on my R53
- Mishimoto radiator...anyone use??
- 17% Pulley & This?
- Clutch engagement point suddenly raised
- Pulley = Ping
- New Exhaust
- Gutted manifold sound?
- New Guy
- sound like a supercharger leak on 2003 mcs?
- Resonator or CAT?
- Plug wires
- Alta or WMW pulley?
- Quietest SS Cat-back system
- M7 16% reduction pulley
- Need a Dimsport tool for R53 to install tune
- 06 R53 Help!
- Header question
- pulley removal tool to borrow
- Proper torque for spark plugs?
- I searched and didnt find anything
- Who here installed the Way pulley
- Installed Alta CAI today...Something Wrong?
- Potential mod list Help
- Basic mods
- Alta Performance Twurbo Kit
- ACT flywheel
- best proformance R53 exhaust?
- My Short Shift Install Experience
- OEM clutch setup
- What happend to Hubie???
- No name exhaust
- New o2 sensors at 60,000 miles???
- Sprintex Blower
- injectors stuck
- valve cover swap
- Misc. 1st Gen. Parts
- MCS Engine
- Alta Twurbo Kit
- smog check (aftermarket intake issues)
- Shark Injector experience
- Early detonation after pulley install
- GIAC reflash vs JCW reflash on MCS?
- R53 Rear valance/dual exhaust
- belt making a knocking noise? of and another noise too...
- quiet muffler for custom exhaust recomendations
- borla exhaust
- BMP Supersprint Header and exhaust
- Any of y'all ever gotten this package...
- Installed ALTA exhaust
- anyone recommend a certain CAI??
- Launch Control / 2 step
- Need some Gains at the Track
- Clutch: Valeo smf kit vs OEM dmf kit
- Identifying Short Shift Kit
- Flashpoint Mini S Catback Holiday Sale $749
- First clutch job on cooper/ first impressions
- ACT clutch & flywheel + Quaife install in progress...
- Head replacement?
- Opposite One Ball?
- Has anyone used Flowmaster 44 or 40 series mufflers before? Even 10 series mufflers?
- Pivot Cup/Retainer Issues
- SES Issue
- Added noise with short shifter
- Long Term Affects of the 15% Pulley
- Help! CEL on, codes P2096 & P0037
- B&M Short Shifter 06
- Exedy Clutch
- Any opinions on the Single Mass valeo clutch kit?
- Mileage too high for performance mods?
- cracked valve cover
- R56 exhaust on an R53?
- Cranks but Won't Start
- Anyone have this Megan Racing knock off exhaust?
- tuning?
- belt tensioner question
- P0171 (Lean) and 20 mpg?
- Reliable Horsepower?
- Pulley and Intake questions?
- The case for bigger Injectors
- '03 MCS Howling clutch
- My next Step, need input
- Kinda Happy my Headgasket Blew...
- VGS mod debate
- JCW Injectors
- Scangauage low boost question
- Clutch Advice Please
- Quieting my exhaust....
- DSC, ABS, No speed indication failure
- Finished up a project I have wanted done for quite some time now
- steal or aluminum rims?
- Milltek Fitment Question
- Intake only from the front cowl?
- Quieting down the Invidia exhaust. Adding a Hushpower?
- intake and water...
- two NEW questions about pulleys (i think)
- inlet hose color on Alta intake?
- Looking to buy a new clutch what do you recommend?
- Whats the best canned tune out there?
- Ireland engineering exhaust
- Clutchmasters Lightweight Flywheel and FX100 Clutch - Initial Thoughts
- Exhaust Comparison
- quick Q about my newly installed boost gauge
- Cold Air Intake Idea... 4" intake?
- R53 Pulley/CAI/BPV question
- Please help interpret pressure measured by ELM
- Pulling hard right
- Please need help!
- installed Alta CAI, service engine soon light
- A new (used) exhaust...
- Air filter for ProMini intake?
- What's better MPG wise with a15%-19% pulley?
- arp studs or stock????
- Upgraded software / Is it safe to reset ECU
- Cat options
- R53 swap supercharger for gt28 etc.?
- ECU Programming for Automatics
- Abf Tech Division!! Thanks Guys!! :d
- JCW Intake Wiring Help
- Water Meth Results?
- Straight Exhaust Question
- On startup rpm's run up
- Quaife LSD Install - Questions about ring gear torque
- ECU tune or Chip?
- fuel injectors
- ECU Tune in or around NH
- Engine mount options...
- Adding something new
- CM FX200 Clutch and Lightweight Flywheel - Who is happy?
- -15% s/c pulley; +2% crank pulley
- Oil dipstick
- ODB Flash cable @montreal
- Pulley Puller Rental?
- having a pulley installed and needing a crank pulley?
- Flash tool problem
- Mini Powerprog and Bluefin
- Good "canned" tune for intake/17%/exhaust?
- 15% or 17% Reduction
- Chip Tuning a 2006 Cooper Sport with Automatic
- Nitrous
- Exhaust Header Install
- noise (video included). what is it?
- R53 2003 Oil Pressure
- GForce Performance Chip Kit for the MINI COOPER
- Cheaper O2 sensor replacement
- Clutch Job - Quick question on hoisting the engine
- Alta CAI is a MUST
- JCW Pulley Remover - Does it exist?
- 19% Reduction Final Word
- advice on new clutch and flywheel?
- Craven Speed CAI
- New muffler/ exhaust? Help please
- cylinder 2 misfire and DSC turns off
- how to remove the supercharger
- Anyone use Harbor Freight's Cen-Tech Scanner?
- HELP! Engine Rebuild Time
- Does napa make 380cc injectors?
- What are the KNOWN facts about Mini Valvesprings?
- Drawing for Camshaft Gear Holding tool
- Advice please! Single exhaust tip for 2005 s??
- Another Enging Pinging Thread. 2006 Cooper S (auto)
- S/c Pulley Tool
- blow off valve for supercharged mini?
- Alta supercharger
- alternator pulley removal
- O2 sensor behavior
- Low Vacuum
- WL: R53 RMW transplant
- Tuneable Bypass Valve?
- Connecting Rod for R53
- Dual Exhaust help
- considering a mini, looking for input on the mods i'd want to get.
- Koreandian
- what belt size??
- DriveShaftShop Axles
- o2 sensor bung
- Pulley problem
- Just installed the Detroit tuned BPV
- Anybody have a DT BPV that was faulty?
- HELP! Idle is WAY too rough.
- Help!! Alta method boost guage install
- Mynes Tuning Headers Vs. RMW Headers
- Help - how do you remove fuel pressure regulator
- How to? Replace my tranny fluid?
- Custom Tune -- Without Dyno, on Autobahn?
- Cam shaft sprocket holding tool
- Car no longer idles after valve cover replacement - no leaks...old gasket leaked
- Having Problem Installing New Pulley Belt
- Any benefit to tuning after adding a cat back?
- What is a fair price for a bad motor?
- Loud noise after installing new flywheel and clutch
- Performance Muffler for R50
- RMW Custom Tune Party in Austin, TX, Oct 15/16
- Fittiing engine damper to cooper s auto
- Where can I find DIY pulley install instructions with pics?
- 03 JCW upgrades
- Should I use my 440cc injectors w/o a tune?
- Average Stock Clutch / Flywheel Lifespan?
- TSW poly engine mount pic?
- Twin Charger R53 guide?
- New R53 A2A Intercooler from DoS
- Larger intake and exhaust valves
- Compression?
- Installing Short Air Intake Directions
- Project Lower My Mini
- Pulley installation, local help?
- Replacement expansion tank
- Port and Polish
- Instructions for 15% to 17% pulley
- Which Fluid Damper?
- boost pressure
- 17% pulley
- Alta intake blow off valve
- Help!!! Clutch won't fully disengage
- So there goes my Diff... I think. Feedback on Options?
- Best Intake, R53 S
- Is it possible to make 400+whp on a Supercharger?
- First Mods-Milltek, JCW Strut Brace
- Oil consumption on turbo Cooper S
- Connecting Rod and Main Bearings. Does ANYONE ELSE make them?
- New Mini owner looking to make the S go faster
- Weird Noise
- Need some help identifying parts.
- Best tune in So Cal?
