- miltek header and exhaust awsome!!!!!!!!
- Engine Light on because of GIAC?
- Drove over something... need new exhaust.
- Forge Motorsports Top Mount InterCooler
- yikes ballooned shocke towers
- shortblock
- Custom Exhaust System
- Leaking Cat - What options?
- Good Set of Mods for an MCSA?
- My Supercharged baby VS New 350Z
- What's so great about an LSD?
- UNIchip MINI Cooper S ECU Chip Upgrade
- Factory limited slip retrofit anyone?
- 05 MC Tranny Problem
- One ball exhaust question?
- Modified Borla Race
- Almost took a beating from a Scion tC...
- AGS DYNO Results???
- Found my new project
- zoom zoom
- Ok, supercharger seized...
- Update: Mini in Korea
- Intake, which one?
- Dry Ice/Intercoolers
- AGS Install Question
- Pulley removal without special tool?
- miltek exhaust nice!!!
- reseting ecu??
- Newbie has mod questions- head & injectors?
- Cowls below windscreen?
- short shifters
- Any full kit JCW v Dinan Performance Write-ups yet?
- ecu upgrade or not?
- Stock LSD and aftermarket LSD problems?
- Uh Oh....
- Onasled SSK Extension | Impressions
- M7 scoop on today
- Aftermarket bypass valve
- More power decision
- Exhaust is too quiet.. :(
- exhaust how mutch time?
- Exhaust Change
- 15% pulley, alta cai, coil,wires,plugs= 170HP
- Raising the red line with 19%
- Best price for MCS Milltek catback?
- Borla Sport to Loud?
- Will JCW Injectors fit 02 MCS
- Gas pedal ?
- 15% Pulley, new belt required?
- Heat management
- Flap not opening on JCW Intake...
- Water repellant fabric that breathes?
- How can I get the length of shifter that an '05 MC has?
- 263 WHP!!! No turbo!
- 05 convert. MCS exhaust mod .. use just one can.
- Anyone running PLX R-500?
- the downside of mods
- my new findings...
- Forge or Alta Top Mount Intercooler?
- Picking up the IC and Unichip
- Bigger injectors on 15% pulley
- pulley trouble
- New 15% pulley, yahoo!
- Installing JCW injectors. Need Advice and information, please post help!
- Another SC porting option
- Twincharged in Canada?
- Blue Flame Exhaust
- Stupid, but serious question
- Ultrik/minimania 3 piece pulley
- modified supercharger performance
- What is your max. psi of boost?, and what you have to get it?
- The greatest combo to make hp increase!
- 05 exhaust
- Ags Help Fast!!!
- Help
- Socal gang....please help!
- Gaic, UniChip, step up and be counted!
- Anyone using a wideband?
- Optimum power for Mini
- Fire up the flame throwers! Estimates of $ per HP by mod type!
- *new* Playmini Cooper S one-sided exhaust...
- Shift Linkage Broken?
- The Little Car That Could: Another Dyno Thread
- Exhaust or TB?
- Has the Alta exhaust fitment issue been corrected?
- question here... knocking
- My MC Miltek exhaust sound cilp
- What do you think about this?
- *Nitrous oxide on the MINI???* please chime in
- M7 AGS Owners ONLY ! ! !
- Anyone Dyno a MCSA?
- M7 16% Pulley
- Getrag AWD/4WD test report
- Remus Exhaust!!!....looks Great, Sounds Great!
- Looking for intake suggestions...
- What is this?
- Intake/Exhaust/ECU mods and reliability for MC?
- Single sided vs Dual sided exhausts...
- Engine Mod -Head plus Cam -Which Head is THE best for the $
- help!!! my 5 speed trany is making a lot of noise
- what you think about ALTA products?
- What is the best Exhaust System?
- Pacific NW Pulley Party?
- Car is not boosting................
- Larger Top Mount Intercooler
- Where is the twinscrew blower?
- 2% crank + 15% vs 17%?
- ECU Mods Necessary Yet?
- May need to buy a new supercharger for
- amd pulley - any good?
- Anyone check this out?
- MCS w/98K. What to do?
- Fully modified Cars
- 19% + Larger injectors + MTH = All Smiles
- M7 16% Pulley & Milltek Exhaust
- Dyno Results from last night
- Dyno Run After MTH Installed
- I.C.E. Thermo Electric Cooling
- Header Question
- Speed shops in Minnesota
- To flywheel or not???
- Freebie: MCS -- Engine Technical Details
- Any idea what this is????
- Where, exactly, should I place my bung?
- Dyno Run
- Anybody burn out their supercharger from running an aftermarket pulley?
- M7 16% pulley + GIAC for 15%?
- Do it yourself water injection
- Sound is addictive I know. But who makes the quietist pulley or is there such a thing
- M7 Injectors pull through.
- Back pressure on N/A cars
- Alta 15% and Ultrik 15% S/C Pulleys?
- M7 16% pulley installed.
- Mannn.. what should i do next??
- Graphic layout of MCS exhaust (header through tips)?
- Dinan CAI Question
- Supercharger fluid
- Most Power Gain?
- Magnaflow vs. Borla
- Waterpump
- Cowl separator Part Number?
- Does the UUC Exhaust do the 05 MCS tailpipe burble?
- Green as grass newbie needs advice!
- 19%er with a fan question
- 2.4L from PT Cruiser
- ALTA dyno results from Euro Styles East!!
- Group buy on GRS Intercooler
- My AGS Order
- Is the 05 thermostat now a 180?
- urathane engine/trans mounts
- Alta intake instructions...
- Environmental Impact to Power Creation
- Headed to Helix tomorrow for...
- Stock Boost
- CARB Testing ... Does it make parts more expensive for the rest of us?
- New Intercooler - Manifold
- no AC in miami, fl please help!!!!!!!!!!!!!!!
- Any way to tell if a car has LSD?
- Just installed M7 AGS
- Question about used Magnaflow
- slight ticking sound between 3 to 4K
- Buzzing with Alta Intake
- Intercoolers and AC
- AGS and cabin noise
- Father's Day = Dinan or Alta CAI or ??
- Aftermarket exhaust and waranty issues.
- Increasing Flow and Torque
- Best mod(s) to increase low end torque on an MCS?
- full or cat back only?
- Help, I need a stock header
- From JCW CAI to Alta CAI
- M7 AGS how to.....
- How to get crank pulley off?
- Twin Screw
- MINI-friendly performance shops New York State
- JCW CAI and Injectors...o.k. for stock S?
- MCS Performance shop in C. PA or along Blue Rige Parkway?
- Max achievable whp with bolt ons?
- The difference between non-GIAC'd and GIAC'd, in layman's terms...
- whp non venom or turbo MCS?
- A few pulley questions
- Are all Alta CAI filters red?
- Exhaust system for MCS 05
- installing new header questions...
- NEW Milltek Header - $600 - See Marketplace
- Engine swap...again: new Dodge 2.0
- so am i the only one with a MCSA and 15% pulley ?
- Are all GIAC software from Helix13?
- FYI JCW Supercharger not available stand alone
- 360hp MCS on craigslist
- GIAC Cable
- M45 vs M62 S/C
- Heads up! New scoop may be coming...
- My short shift story
- How many of you have the OIL CATCH CAN?
- My Dyno Results of 6/01/05
- HAI - still happy with it?
- At what mileage did you add pulley?
- 15% pulley
- Modded 05 MCS vs 05 Works MCS
- What are the weak links?
- 17% vs 19% vs 15% help please
- rattle noise
- M7.....Looking for
- M7/Cosworth performance packages
- Pulley install in Montreal, QC
- Just ordered M7 scoop
- spec flywheel and clutch
- New Recipe for 205HP and 230HP version!!
- Nitrous!
- Tranny being dropped under warranty today.
- Alta CAI question?
- JCW CAI and Rear Fog Installed and my MINI can't tell time
- Important info for 2005 MCSa and Alta Intake
- First performance mod after 3 days
- New owner questions 2005 MCS
- MISSING : GIAC. Reward if found...
- Which intercooler????
- Intake air temperature
- Turbo Manifold
- Fast Forward Ltd. Exhaust?
- modifying supercharger?
- Manual transmission oil cooler
- Some supercharger pulley install notes
- Anyone Seen Best Price?
- Alta Crank Pulley - what will blow?
- Exhaust opinions please
- SSK Install Woes
- M7 AGS......Heatshield (split off posts)
- Help me decide what my first mods should be.
- My dyno Results
- Injectors upgrade... Fuel regulator?
- Axle Replace Poll
- So Close!
- Broken Axle
- Why these brands?
- 600 mile impressions...and LSD problems?
- Engine Break in period
- Pressure drop
- EML/SES light after TB install
- Plasma booster, good?
- Oxigen Sensor Simulator
- 15 vs 17 vs 19 with JCW intake and injectors
- exhaust..
- Wish We Had A Recipe Book Like This
- Pilo Racing Cylinder Head Flow Bench Numbers Released!
- Oil on belt & pulley?
- wot wud u have checked if u were buying 04 mcs JCW/aftermkt parts with 15k miles
- JE Pistons - Who Has Tried Them?
