View Full Version : Drivetrain (Cooper S)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
  1. Obx Cat Back System?
  2. Alta Overdrive Crank Pulley Dynamically Balanced
  3. Injen intake - fit MCS?
  4. My car is pinging after adding more boost.
  5. Alta red silicone?
  6. Question for Magnaflow owners.
  7. Belt Problems
  8. Pulling a Check Engine Code..
  9. mini s w/ straight thru exhaust??
  10. bad idea? ltwgt crank pulley AND ltwgt flywheel??
  11. OBX High Flow Cat
  12. play or lash in drive train - what is normal
  13. Water Temperature sender install
  14. Overboost conditions ???
  15. My power is variable. Why?
  16. 15psi boost guage with 16% pulley?
  17. Pilo and general short shifter Q's
  18. Short Shift Kit
  19. Finally!
  20. BS detector going off?
  21. Throttlebody and supercharger
  22. Check your bipass valve!
  23. Manifold Gasket????
  24. Silicone hose question on Alta CAI
  25. Flywheel change...worth it?
  26. Alta vs. AGS intake
  27. Vendors Shootout .....
  28. Oil Catch Can Routing
  29. 400cc or 380cc injectors.....
  30. Any interest in a New England Mini Dyno Day?
  31. FYI regarding Silicone hoses from MOSS
  32. 2.085 60ft Stock Cooper S engine
  33. pipe size on JCW exhaust?
  34. Why is my car so loud with the Alta intake installed?
  35. RMS why no presence?
  36. Lsd?
  37. Aftermarket Bypass Valve?
  38. Tensioner Mod
  39. transmission swap
  40. My Mini Delta exhaust...(not 56k friendly!)
  41. Better SC?
  42. alta pulley vs. helix pulley (15%)
  43. ticking noise on acceleration
  44. Removing Resonator
  45. new MCS and MC intakes by aFe
  46. Rspeed Shift knob?
  47. 05 supercharger fit an 04?
  48. Second Catch Can Installed
  49. Purchase used supercharger?
  50. JCW Tuning Kit Soundbytes?
  51. Remus rattles at idle, need help!!!
  52. AWD Needed!
  53. Short shifter install question
  54. Who is the loudest? And is it to loud?
  55. MINI-Madness cowl mod with ALTA intake?
  56. Brand New MILLTEK--It smells bad
  57. Jcw Injectors With Dinan Stage 5 Software
  58. $260 for labor to install pulley? Is this too much?
  59. Intercooler Sprayer Possibility?
  60. best 1/4 mile times
  61. stock pulley
  62. New 05 Intake!
  63. Alternative Injector source
  64. Thinking of getting a 15% pulley on my MCS
  65. Nitrous
  66. I also have B&M shifter install issues
  67. Alta Pulley+Alta Intake+Shark Injector
  68. License plate on bottom grill...
  69. Please Help: 05 MCS Short Shifter Install
  70. Intake Dyno Numbers....
  71. Need light ? I need 200whp? How?
  72. engine internals
  73. Help!! Void Warranty on tensioner/idler
  74. My first mod
  75. For people with the Alta Crank Pulley
  76. Custom Exhaust
  77. Anyone with a modifies SC?
  78. Borla Race to Quiet?
  79. PolyFlex engine bushings installed
  80. What are the 300+whp cars doing for fuel systems
  81. Just installed Alta CAI and Bypass Valve. a couple Q's
  82. MTH for Cooper (non S) question
  83. bigger fuel injectors ???
  84. Freaking Codes
  85. How much HP can i expected with this?
  86. JCW intake mod idea
  87. Amd 1-click + BMW software update?
  88. $16 Catch Can
  89. dyno test...?
  90. Intake pro's and con's
  91. JCW Intake, How to check if my flap is opening?
  92. What's a SteBro Exhaust ?
  93. Jet Hot coating for header and exhaust
  94. possible leak
  95. Question about Alta intake noise...
  96. Have you seen this IC b4???
  97. Vented Hood!
  98. Exhaust Q - which way would you go?
  99. How much are your injectors???
  100. 0-60 in the 5 second range?
  101. Exhaust dimensions
  102. Alta Lightened Crank and Overdrive Pulleys
  103. California modders and Smog?
  104. Stratmosphere is first class!
  105. Motor management
  106. Improving the AGS, one man's journey....
  107. Data-Logging Fun (Stock/GRS ICs & Stock/M7 Scoops)
  108. clutch...
  109. Dyno Discussed by Dinan
  110. Anyone here used "ProScan 2" from myscantool.com?
  111. will 05 tranny w LSD??
  112. power delivery across the rev range for jcw vs aftermkt
  113. WHP Reference Thread
  114. WHP max without Turbo
  115. Anyone running more than 7250 rev?
  116. M7 hood scoop question
  117. 15% pulley with stock ecu
  118. Software, who is the best
  119. MCS Fuel economy suggestions besides removing rear seat.
  120. One-Ball Exhaust Surgery - Before/After Photos
  121. Miletek best price ??
  122. Intercooler fan install?
  123. What exhaust should I get to go with these mods?
  124. Magnaflow Exhaust clamps
  125. **help** Pulley Issue
  126. Intercooler difference 02-03-04 vs 05
  127. Miltek off, Minimania on ....
  128. Stock compression and
  129. OBX MC Exhaust?
  130. alta air diverter
  131. FS: Single Orciari Hood Scoop for CAI
  132. Newb question about filter and intake
  133. 440s out 400s in
  134. Exhaust Rattle - Any Suggestions?
  135. Aftermarket Radiator overflow?
  136. Dyno Fun!!
  137. Lighten this baby!
  138. AC Performance variations
  139. BBR Turbo!
  140. Maganaflow – can I live without a resonator?
  141. ECU upgrades for 16% in Canada?
  142. MC Turbo for under 12k
  143. Alta air diverter
  144. Intake brand question...
  145. Stroker KIT???
  146. First Track Test for new M7 2% Crank Pulley
  147. Blatant plug for Chad's Detroit Tuned!
  148. Alta Exhaust? How is it?
  149. M7 Flywheel and Clutch short Review
  150. CVT Oil Cooler Plumbing
  151. JCW intake install question
  152. Mods and Check Engine Light
  153. Maximum whp
  154. Questions about boost level
  155. Using Nitrous To Spray I/C
  156. WOT modded hesitiation - NOT stumble, yo-yo, etc...
  157. Motor mounts?
  158. OBX Header, MTH Tuner File
  159. Cooper S cylinder head - will British one fit on U.S. model?
  160. Pipercross?
  161. GIAC Flash and a Check Engine Light...
  162. For those of you that have the following
  163. Quaiffe or '05 LSD owners - how does LSD affect your handling?
  164. Replacement shifter bushing - any ideas?
  165. Are you happy with your ignition upgrades?
  166. Nitrous Users
  167. Major Clutch Problems???
  168. wow
  169. Water/alcohol injection
  170. Wideband Sensor
  171. Ready to dyno AGS
  172. Semi-Custom Exhaust
  173. My questions about the JCW Tuning Kit... OWNERS ONLY PLEASE!
  174. Newbie help: How much of a beating can the MCS Trans take?
  175. 440s from M7 on the way
  176. ALTA CAI dyno results
  177. 19% SC Pulley at the Track
  178. 06 vs 07 for Autocross
  179. better performance with Bigger Ground Wire??
  180. MSC trans. with LSD
  181. Is it possible to retrieve OBD codes myself?
  182. Who makes the engine for the MCS?
  183. M7 hood Scoop working?
  184. Is LSD retrofitable on my '05??
  185. 20-30 hp gain from an exhaust
  186. Denso or NGK plugs?
  187. Alta 15% Pulley Install
  188. M7 AGS
  189. Got it installed
  190. Resetting ECU.. Should I or Should I not.?
  191. new clutch suggestions..
  192. Who's got oil coolers?
  193. CF Body Twincharged Cooper in the works
  194. adding torque to JCW MCs
  195. 05 Mustang GT versus MCS COMPARISION!!!
  196. Alta 15% and Milltek exhaus - get JCW programming or not?
  197. Quietest air intake (w.r.t. interior of car)
  198. Interesting MCS Conversations from UK Co
  199. 19% pulley + GIAC + 380cc injectors update
  200. 6000 RPM redline is fine for a diesel, but...
  201. JCW Upgrade Kit installed on '05 MCS?
  202. m7 oil catch can !!!!
  203. Data Logger?
  204. 04 to 05 ?
  205. Accommodate for 19%
  206. I can't keep my foot out of it!
  207. uni chip question?
  208. Injectors
  209. First oil change
  210. Where is the M7 AGS DYNO!!?!?
  211. Will a cooler-rated thermostat confuse the computer?
  212. To: MCS owners w/Minimania Header No Cat
  213. Where to find reduction pulley install instructions
  214. Dinan parts?
  215. Detroit Tuned bypass valve
  216. The ultimate Cooper S air intake?
  217. Please comment on my DYNO graph for best MTH tuning (Long post)
  218. oil catch can
  219. AFC Select
  220. Water Spray Nozzle?
  221. ALta Intake= a grin on my face
  222. post your torque PLEASE
  223. Panel Filter
  224. Pulley removal w/ no tension tool!! (or screwdriver!)
  225. Oil catch can - yes or no? My head hurts...
  226. Got A New Car!!
  227. Alta silicone intake hose compatible with Dinan/JCW/Stock box?
  228. Dyno day in GA
  229. Installing 15% Alta pulley - should I get a JCW belt?
  230. uni chip or bigger intercooler????
  231. Turner motorsports stage 1 kit
  232. New cat, nice price
  233. Pulley change on SC
  234. How to fix the tensioner
  235. Where did you buy your UUC exhaust?
  236. Jardine/Doug Thorley Exhaust system
  237. Wide band O2 sensor
  238. blow off valve.
  239. Do I need a new supercharger?
  240. ECU upgrade post IC/Throttle body upgrade
  241. Has anyone removed the passenger side muffler as a perf. mod?
  242. beta-bim-com
  243. Installed Unichip and Alta IC today
  244. Unichip problem..
  245. JCW Intake/ K&N Filter
  246. Cheapest place for Borla
  247. HELIX is flippin sweet!!
  248. 2005 MCS - Completely Stock Dyno
  249. Milltek sport VS JCW exhaust
  250. Yawn.
