- Installers
- Increasing SC effiency. Different methods?
- Confused - OBX header
- Ecu wiring diagram?
- P0108 overboost after new intake tube.
- Pulley Install
- Place for Installs?
- from Hungary - perf chip
- Long term IC efficiency without CC
- If your engine has EXPLODED, post here and give details
- Back Pressure
- emulating O2 sensor safe?
- Is 19% pulley needs big injectors?
- What's the MAX boost your mini can do?
- Oil filter O-ring
- After Oil Catch Can...still oil found in IC boot..?
- Pulley Party
- BFP Intake... anyone?
- Fireball Tim Racing MCS at SEMA
- Oversize TBs with stock inlet tube...
- Pulley material - aluminum or steel?
- Schrick cam or 2% Crank Pulley?
- Acetone as a gas additive
- Crankshaft Pulley = really Bad idea...
- Interesting TB test, 58, 60 and 62 mm
- JCW Map on a non-works MCS???
- Tranmission Questions...
- Blew up stock intercooler.
- JCW & Cruise Control
- grounding wires install?
- GRS IC Mods
- Catch Can install
- That Alta smell...
- 15 + 2 Feedback Wanted
- When does 15 + 2 = 17.3
- MCS Getrag Upgrades
- Lightweight flywheels on MCS: Thoughts, anyone?
- Cat removal
- Has anyone mounted a M7.....
- Anyone added the GReddy Oil catch can to their MCS?
- Titanium cooper s exhaust
- Helix short shift
- Does anyone know the weights of the different models
- Dastek Unichip
- Shifter BROKE!
- flywheel weight? (MC and MCS)
- SES Light - why would this happen
- Alta Introduces MINI Twincharging System at SEMA 2005
- Aftermarket-Lower Final Drive Ratio-MCS
- '05 transmission compatibility
- When do injectors help
- Big Dynoday in Germany - 11/4/2005
- 16% PULLEY & COLDER PLUGS?
- does new injectors can help?
- Catch can filling quickly?
- Cowl Scoops?
- Tb
- Fastest non-nitrous or twincharged MINI
- HAI Dyno results
- pulley belt
- Boost Gauge?
- Just bought the Borla Race
- AGS heatshield install
- New TB from... M7
- Installed Milltek Catback but...
- I'm noticing lag @ around 3k
- 19% and 4%
- New tranny!
- Any others doing or done crank pulley?
- Turbo surging?
- Unichip interferes with wiper linkage!
- Need "How to install SC pulley" link/site.
- Randy Webb's new exhaust
- a cam and a smog check
- Nology, Magnecor, NGK????
- Turbonator
- Minipowerprog kit?
- Uni-Chip ???
- Proposed mods for Synthia...
- Unichip custom tune by Josh in Atlanta
- Where should I go next?
- Throttle body a good next step?
- Outside Temp effect on engine
- How the MCS Engine Makes Power
- Mileage & mods: better all the time!!
- questions
- Stock Hood Scoop - gap to IC?
- u.s. engine damper
- muffler help
- Has anyone made their own MTH tuner cable?
- Are 19% pullies still the red-headed Step Child?
- was this a bad idea to try??
- Just installed INVIDIA catback
- Your Pulley: What brand? What size(%) and why? Where did you purchase? Satisfied?
- update - code P0136, where to go from here?
- Water injection question
- Tensioner Stop Bar?
- What clutch do you run?
- miltek modd
- Alta INTAKE group buy. (preferably in North/South Carolina)
- Help! I'm throwing a code
- HELP about SuperCharger Pulley & Crank Pulley. Do they Counter-React?
- Duct tape mod?
- Buffalo/Niagara Falls/Southern Ontario Pulley Party
- Pulley Installer: Florida Panhandle: Pensacola to Jacksonville: HELP
- First MCSa with a Lightweight Crank Pulley?
- Cam Shaft upgrade considerations...
- 03' Upgrade
- What do you think about safc select?
- Pulley Installation Costs ??
- Lsd
- Belt Size FYI
- Alta Air Diverter/Water Sprayer ?
- SuperTuner Challenge MINI Exaggerated?
- My conclusions (Pilo, Alta, Magnaflow)
- Noise was the PS fan failure.
- Gutted
- Another oil catch can
- 60mm TB test results
- PBAAIS mod
- Question for those with Alta CAI or swiss cheese mod
- Added Milltek cat back to 06 MCS tonight.....
- AGS Wistles at idle??
- JCW exhaust installed, Vibration and Loud?
- Who has the Best Torque?
- Understanding ECUs
- 200 whp
- dinan, alta intake, and miltek dyno
- What is the best manifold, ecu, pulley combo?
- Oil Temp Tap Point?
- Problem, loss of boost!
- cheap hp
- pulley opinion, honestly
- we need a ecu upgrade shoot out
- New type of Header?
- Problems with o2 sensors going bad....
- Unichip before the Pulley?
- Intake Shootout/Dyno Day
- Pulley change or MTH?
- Qs about slip differential and M7 thermostat??
- Will the Pilo Racing header throw any codes?
- 300whp Spi Power Excel
- New Exhaust = annoying yellow light?
- Crank pulley on intake and snoots to follow
- Dinan ECU flash
- Dinan TB...no core exchange charge!!
- Qs about flywheel?
- Borla Sport, Milltek or Magnaflow?
- Light flywheel/Clutch recomendations/Opinions
- Ported SC mod info
- MyMINI exhaust Review
- ITG filters
- Is nology hoywires and racing coilpack necessary??
- B&M or Alta Shorter Shifter???
- power on a budget
- OBX Exhaust
- Questions about Webb Motorsports Performance Packages
- another ECU chip
- How do I check fuel injectors & spark plugs?
- is it necessary to disconnect the battery?
- what boost
- Catch Can Connection - what about this?
- B&M SS making noise, hitting cover?
- VGS and/or Ryephix(2)?
- Nov. Boston area pulley party?
- Supercharger Oil??
- One Ball Shops
- Speed limiter removal
- Does anyone have an MC (non-S) intake manifold you'd be willing to sell?
- HAI in heavy rain
- 4/2 into 1 Extractors and Exhaust MCSa
- installing new catback? reuse or replace gaseket?
- Yet another dyno datapoint - Alta 15%, TMIC, Intake, and Milltek, 177whp
- aftermarket radiator?
- CAI and Pulley Help for a MINI in need!!!
- M7 Cosworth Camshaft only...
- fitted my oil catch can
- Mini-Madness Superfour Challenge car - 245hp?
- mini-madness cai with alta silicone hose??
- Mini-Madness CAI with Alta Silicone Hose??
- 15% Helix pulley and GIAC installed...
- MTH Software
- Break In Recomendations
- Water to air -or- larger performance intercooler?
- new cam for MC/MCS?
- LSD - is it installed already?
- 2006 mini mods
- Right Front Camber..??
- apexi voltage stabilizer on 05 MCS!!!???
- Pilo Short Shifter install instructions
- Whats this wire?
- new kind of head by Coates
- Nitrous Users
- Just for fun...
- New Alta crank pulley showed up today
- In Praise of the MCS Air Box
- alta oil catch can instalation
- aquamist water injection system...
- resonator elimanator
- Unichip shops in Southern ontarioi (Toronto/Hamilton area)?
- Fuel Pressure Test
- What next?
- recommend a belt with 15% pulley?
- another Invidia MCS group buy..
- ALTA 19% + 2% are this reliable?
- Blew UP!
- considering possibilities of a custom FMIC
- Spark Plug change?
- Who's using and A/F gauge????
- Thoughts on this pulley install method?
- Thump sound coming from below E-Brake area..Help?
- Cosworth MINI Finally Back from the Dyno
- ordering MCS - are gauges worth it?
- Where can I get cleaning fluid for my pipercross intake filter?
- those with custom exhaust...what muffler(s)?
- Pics of my hand fabbed diverter, intake, and catch can
- Npb 14.562 @ 91.28
- Crappy Gas, or Pulley?
- Adding more "mods"
- 15% pulley / acceleration help?
- $6.00 and I have my very own catch can
- I just ordered the crank pulley from Randy
- From BMP/Pro Mini CAI to Alta CAi
- Fuel Pump Test
- Standard Ignition Timing
- Andy, what mods do you have on your car?
- 178 WHP with mods-What's a JCW?
- alta short shifter HELP
- New SC intake Tube
- Mini Madness vs. Dinan (Engine Performance/HP Boost)
- CAI voiding warranty question
- UUC exhaust
- ECU Tuning Programs
- LightWt Crank Pulley on my MCSa
- Any Results/Pics from the Helix Dyno Day?
- Cold air intake and pulley q's????
- Questions about M7 Nitrous installs
- Help a girl out
- MCSa?
- More exhaust questions...
- Exhaust mod??
- Software question
- Borla Sport vs. Milltek
- Pipercross Intake Maintenance
- bav auto MC air intake
- Which exhaust!
- Mini pulling to the right
- Gear Ratio
- alta big intercooler vs stock?
- 2.5" Header...3" Exhaust?
