- How often to clean Alta CAI?
- Are you boosting over 18psi???
- Ported Head Questions
- Passive under hood cooling
- m7 OCC
- Need some Real answers on ECU's!
- M7 vs. Alta Crank Pulley
- Squeaking after Alta Intake
- Any Personal Experience W/ Cosworth?
- Short Shift Mod - Stock parts- Whalen - DYI
- ALTA CAI hose for Automatic
- AmD OneClick
- 15% pulley on the track review
- Have current model mods peaked?
- what is the VGS mod
- Torque Specs for Exhaust bolts?
- Here's a new exhaust I havn't seen before!
- 19% Pulley owners only.
- Unichip throwing SES codes
- K & N Typhoon
- Waiting for FTR software
- short shift for 05'
- Bad Decision??
- EvoTech vs. MTH tuner?
- SuperSprint resonater pipe ordered, thoughts?
- Pulley, No Hub
- Oil Catch Cans - where to mount?
- Custom intercooler diverter?
- Intake testing method
- What mods giveth, timing retard takes away....
- Alta Prototype testing completed.
- Suggested upgrade path
- differences between an 02-04 MCS exahust and 05+ MCS exhaust
- Alta Turbo Kit
- JCW Intake - Installed
- BlueFin in Usa??
- question about Vacuum
- Limited Flashes??
- Race Fuel
- CEL after HAI install
- Am I expecting too much from an ALTA 15% pulley?
- can I pull the LSD and the 05 tranny together
- ALTA intercooler diverter worth it?
- Dyno Testing Methods... let's agree!
- Will installing a JCW air intake affect my warranty?
- Too good to be true?
- Awd
- Plugs for MCS with 15% pulley
- MCS Official Dyno thread
- Acceleration fueling?
- How risky is to install a 15% pulley and intake
- Waiting for Dinan 2006
- Oil Catch Cans and Intercoolers
- I wanna do a 19%, Do I really need all this other crap
- APB: Urgent need for test car
- Dinan Pully?
- New IC Diverter
- MINI power prog?
- Anyone have experience with the Mini Mania Boost upgrage kit?
- Which cold air intake is the best?
- JCW programming on stock MCS?
- Unichip map / remap
- My Dyno - Quite Happy with the Results!!
- 2 new goodies
- My intake is better than yours
- Is it only me having this problem?
- headers-what do you have? which is best?
- The other side of the pulley install
- Test Results Of Removing Pre Cat On Stock Header
- The big day...
- best combination pulley
- injector advice please...
- Nitrous = Motor running bad
- Pulleys?
- Injectors...
- CV pop noise on a MCS 06, anyone??
- PLEASE HELP!17% and 19% pulley Belt
- Cleveland Ohio Pulley Party - March 26
- Thank you WebbMotorsports
- Cone filter in Stock airbox?
- Different gear ratios for Manual and Auto?
- CV joint question
- Larger Injectors and Duty Cycle....
- Apexi S-AFCII
- JCW Engine kit after purchase of MCS
- Alta problems
- hissing noise on the pully?
- Don't Forget Your Head
- G-Tech Repeatability
- M7 Extreme vs Ram scoops
- pully question
- OEM reflash before GIAC?
- water/methanol instead of injectors
- 27PSI plus 100 Octane...
- Any dyno'd JCW's out there??
- 19%
- B&M Short Shifter Kit question..
- Universal Milltek hanger question
- 81k mile performance boost - header and more
- Pulleys, and CAI questions... and stats
- My mini MCS exhaust
- New product : o2 simulator for Mini
- Went and Did It - Thanks Randy
- my turn for the CAI and pulley!!
- MCSa pulley install
- Mini-Madness 15% pulley installed
- CAI - Is there such a things as "Too Cold"
- Madness Pulley
- Installing M7 Ram Intake - issues
- Webb Motorsports Videos
- Schrick Cam Cooper S Part Number
- how many people got the
- Is dynotuning worth it...
- All IK22's Created Equally?
- Keeping Traction
- well... we finally broke something
- 2% Crank Pulley and bigger injectors?
- 91 vs 100 octane gas
- Some Initial IC testing data, Oil Catch Can and Thermal Coating...
- Denso IK22 Gap
- Denso IK's
- Greedy Emanage Ultimate
- Vacuum Gauge?
- 15% pulley and Alta intake
- Performance Ideas
- denso irridium question
- ECU Tuning Options/More Mods
- Know where I can find this?
- ALTA short shifter question
- Headers question? Need opinions
- Crank Pulley reinstall procedure
- Question on Alta Crank Pulleys
- Piloti Shoes Strasse & Spa opinions
- Software for 05'-06', what the heck?
- Spotting LSD
- Oil cooler question...
- GIAC vs MTH
- 2% Crank Pulley + GIAC
- Unichip and turbo
- Webb Motorsports HDI Box
- G-tech, Passport In Car Dyno's
- Flywheel & clutch
- 06 MCS ECU is DIFFERENT THAN 02-05!!!
- JCW CAI owners is your lower plug out?
- Bypass valve comments
- Open eaton M45
- HAI Install....
- Cheapest Schrick Cam Ever
- MCS IC help....
- Polished Alum. Catch Can = $40
- welding OBX header to stock cat
- advice
- Your top 5 mods on a stock Cooper S
- Has anybody built their own
- short shifter
- boost controllers
- Which Header?
- Sachs racing clutch problems
- Looking for opinions on mods!
- Totally Wacky Data
- more revs??
- Which Scoop?
- Installed OBX Headers
- code 0420 ... catalitic...
- top end.
- Website for FTR products?
- Randy when can i get this...
- MINI Cooper S Header - In General
- Getrag AWD for MCS?
- transmission oil leak
- warranty issues
- oil catch can
- Installed Alta Intake - Very pleased with results
- ALTA IC with Thermal Dispersant
- Exhaust System
- Broken Camshaft
- Weight for Quaife diff.
- New MCS Turbo Kit? Pic speaks for its self...
- UUC Stage 3 clutch
- "Ping" sound and burble concerns after pulley install.
- remove under hood insulation
- Exhaust questions.....
- Illegal aftermarket exhaust...
- Miltek header on an 05 JCW
- Twin Charge on the track
- JCW Pulley Question
- Belt Tensioner Tool in Miami?
- When do you usually shift your MCS
- Dinan Exhaust
- M7 AGS installation instructions...
- "Reset" info
- cooper and cooper S manifold question
- JET Chips ... any info
- Megan Stuff
- just wanted to share
- ok Need help with a decision.....
- E-85 110 octane
- LSD RetroFit?
- FREE: '03 MCS Exhaust
- fuel on plug #4 threads
- Torque specs - flywheel , pressure plate, clutch swap
- The TEAMMIGHTYMINIZ Intake Shootout presented by motoring|underground
- Help-b&m Short Shifter
- Borla Agressive Installation problem
- Pulley Party, anyone?
- I just don't get the NO2 thing
- m7 venom kit
- Gear oil
- what happened to $60 NTH?
- anyone knows this header?
- Alta exhaust...anyone?
- Motor Mount Q
- Exhaust advice needed please
- What next...
- aFe Intake for MCS!! Anyone looking
- Planned mods... forgetting anything?
- 15% pully installed
- oil catch can!!! is it needed after a few add-ons?
- RC 440CC Too Much?
- Cheapest price on Alta Intake TUBE ONLY?
- Nitrous opinions
- Nitrous opinions
- SF Bay Pulley party?
- good reading on blueprinting
- 15% or 16%?
- Front Mount Intercooler
- Air Filter Types
- AEM-UEGO, Can it emulate our Oxygen Sensor?
- MTH Header + File 210hp?
- Aftermarket Resonator?
- TwinCharge Kits
- Alta Exhaust
- Milltek vs Invidia
- DIY Cold Air Intake
- 295whp
- JCW package technically another model?
- Weekend Project-DIY inexpensive CAI
- Desno plugs
- Aftermarket Exhaust 06 Mini S
- IC Diverter Build
- RC engineering injectors.
- MCS vs. RX-7
- Further discussion of minimc's exhaust Sticky
- Anyone running this..??
- Stock Header With No Pre Cat?
- my new Megan Racing 2-piece header!
- Exhaust System - detailed explanation
- Dowl falling from Fidanza Flywheel?
- SC inlet plenum MOD
- CAI air box dimensions
