- What is this?
- Variation in boost
- Alta Intercooler Air Diverter
- Anybody used an IC sprayer? <eom>
- Anyone with info on this header?
- Reduced and amazed!
- p0301 problem
- Supercharge pulley problem
- The Magical DFIC...
- Daily driver setup- Your thoughts??
- 19% Pulley Installed
- HAI MPG drop
- M7 DFIC impressions 5-8-06
- mileage before first dyno run?
- WMS Pulley and HDI Intake...WOW!!!
- BIM-COM program abandoned?
- New IC Water Spray Controller
- alta intake sound
- should i: mcs spark plugs in a cooper????
- Dinan Is Killllllerrrr
- Fault Code p1661?
- Do you think its rich or lean......
- Pulley People with OBC - MPG?
- GT Tuning Intake
- 19% or 17% + 2% crank pulley?
- Boost Controller For Supercharger?????
- Clutch install
- MyMini Cooper S ColdAir Filter Kit #3
- Must Fight Temptation
- The sound of gears turning...
- Over heating...electrical fan isntall?
- Anybody had warranty voided due to 15% pulley? (eom)
- Does 15% pulley require other mods?
- AFE Intake?
- Full Aftermarket Exhaust or Just Cat Back?
- ** Milltek Cat-back Group Buy - Important update **
- Intake/wastegate question
- twincharge
- Looking for a Southern California Tuner
- how many miles to break in a new cam?
- air trapped in cooling system
- When to replace the supercharger belt?
- Exhaust question for a race mini...
- A newb question about mods...
- Piper Cross Cold Air Intake
- I Have Go-Fast Bits!!!
- "Uni-Chip"
- Intake systems??? Help
- Yes, my M7 DFIC is on the way!!!
- It's Glorious!!! (Randy Webb Exhaust)
- DINAN says NO to crank pulley
- MCSa questions..
- Optional Milltek Exhaust Tips
- Quaife install
- 17% Pulley + Belt + MTH = Squeal / ? Slip
- EGT range?
- Invidia same as Skunk2?
- JCW 210-230 Hp upgrade help
- ** Milltek Cat-back Group Buy - LAST CALL **
- 20hp?
- A video clip of my 2005 MCSa With my new HAI installed!
- RFI - Ultrik W/A Intercooler
- MCS airbox screw size
- K&N vs Green
- One ball replacement pipe
- Can a Magnaflow trash a Catalytic Converter?
- safc
- Quaife
- ***Help with HAI!!!***
- MAP Sensor Question
- ** Milltek Group Buy **
- InMOTION ECU PERFORMANCE UPGRADE ?
- Place to buy JCW package?
- 17% + 2% Crank, should I or shouldn't I
- Problem with clutch engagement point
- CAI/HAI and MPG
- engine revs in 6th gear at 75mph?
- change pulleys in place ???
- Alta Boxtop Prototype
- Anyone know if this exhaust any good ?
- Exhaust note.. suitable for the not so young.. Your opinion please...
- HAI or CAI
- Wisdom of raising the rev limiter??
- Labour cost for fitting head,cam and injectors...
- 19% Reduction Pulley
- Anyone know the Specs to Standard Cooper S CAM shaft??
- larger sized pulleys for twincharger
- Webb Motorsports Input
- Greddy Emanage ultimate ?
- Port and Polish with enlarge exhaust Valve Question....
- Quaife Tranny Fluid
- To prevent further hijacking of another thread I have a question.
- Initial Impressions, 15% pulley, CAI and GIAC
- Cut it out.
- ~$2000 and 04 JCW, question about upgrade path.
- JCW works upgrade kit on 05 MCS.. question
- methanol
- Alta short shifter problem? HELP!!!!!
- Megan Racing Headers.
- Question on O2 sensor
- Clicking noise in the front end... From the problem....
- One-ball sound
- Wanted-OPINIONS- 1st & 2nd gear- Twincharge vs. typical 19% setup
- What to do with $5,000 =)
- Borla Exhaust (Race Version) 2004+ Cooper S
- One-Balling/Removing Resonator
- belt wear
- Fireball Mini Cooper
- Freakin A - now THAT'S a SC pulley..
- Dyno Day for Merlin (05 JCW)
- ECU Upgrade Options?
- I have a question about the clutch engagement point.
- Combusion chamber and fuel system cleaning do help.
- who knows about Schrick cams?
- Milltek Header Question
- auxillary oil cooler
- ALTA CAI, how loud is loud?
- 10W40 = more heat???
- Remus exhaust rusting???
- CAI group buy
- Pegasus oil cooler and thermostat
- speaking of the 05/06 tranny
- Fuel delivery specs
- Are there differences for the Milltek cat-back exhaust for different years?
- Not thrilled with the 15% pulley and CAI
- Alta turbo on Ebay for $3400 and change
- HELP!!! Please read!
- Help!!! Gauge Install Help!!
- What happened to andy@ross-tech.com?
- Dyno Pull at Battleground
- GTech reading low
- Spark plugs and pulleys go like peanut butter and jelly???
- Bbr Mini
- Terrible Fuel Consumption
- leak oil from power steering...
- Pulley + CAI on the track video
- World's Fastest Mini
- Stock motor new limit
- Twin Charge Kits, Are They Safe?
- JCW 210 + UniChip or GIAC?
- dyno'd my car
- O2 sensor cleaning
- install help
- there somting wrong
- GIAC ECU Flash
- getting pretty excited about new mods
- Spec Clutch & UUC flywheel install help
- Who has a modded SC
- She's Alive!! (New Motor Mount)
- Back from HELIX.
- One ball exhaust rattle
- --- Local LA Mini Tune Shop ? ---
- Project MiniTX
- Throttle bodies hype or helpful
- Pulley install, by who?
- stuff it with what? (oil catch can)
- MCS or MC front bearing/hubs?
- Milltek header note?
- Borla Sport or Magnaflow?
- lethargic JCW....do I have a problem?
- Anyone has Hamann or Eisenhaus Exhaust Installed?
- Exhaust Tips
- 5 is a charm........
- RMS Supercharger
- Quaife LSD installation
- Twincharger recommendations please
- Lightweight flywheel - necessary?
- CAI vs. HAI
- More IC Results.... GTT
- Moving battery box
- Destroyed Clutch...19%
- M7 AGS video
- Crank pulley survey
- Pully? Need quick answer
- Twincharge Videos
- Schrick "race" cam owners please publish your torque numbers
- Good mileage for doing mods?
- Problem Contacting Webb Motor Sports
- Alta crank pulley, HELP needed
- Installed m7 thermostat.
- JCW air intake?
- So I'm shopping for an intake...
- Stainless steel Scorpion exhaust 4 sale
- New Helix 15% Twin Cone 380cc injectors
- Reduction Pulleys - Straight Answers
- Which pulley is best for me??? 15/17/19%?
- Reliable for Daily Driver?
- Dodge Caliber AWD option maybe?
- Super Sprint
- Front mount intercooler
- Another pre cat removed
- afternoon of installs!!! catch can, strut brace, airbox mod.
- Better gas mileage with stock exhaust?
- header question
- Intercooler comparison
- M7 DFIC
- How about a different SC?
- Milltek Header install ?s
- UniChip = Buttery Goodness...
- 415whp
- mini of towson
- Twin charge or 06 tranny w LSD
- Aftermarket + Warranty
- Alta CAI Box Top!?
- AutoWeek article M7tuning + FTR
- Front Mount Stock Intercooler
- carbon fiber strut bar fittment!
- Venom Nitrous
- what to do with 1200?
- Dinan....???
- Installed Milltek Full Exhaust System!
- Questions about OBX header and cats
- Vibration Under torque!!
- Open-air bypass valve on MCS
- Milltek Header vs Larini header
- Vacuum tubing (which size?)
- Carolina PULLEY install....... any1 need HELP??
- Nology HotWires and Bigger Coil Pack == Contradiction?
- Helix 15% pulley owner satisfaction
- Cold plugs?
- 15% question..
- 19%...Wow
- battery box help
- alta intake installed = service engine light?
- boost of Stock MSC?
- Header for MCS
- Kellners
- VEMS stand alone ECU
- cooper s hood
- differences between the MCSa and manual intake pipe
- Dinan intake+ - factory sale - comments?
- MCS Upgrades - best bang for buck?
- All Wheel drive kit available!
- invidia or magnaflow?
- Alta Turbo Or M7 Cosworth?
- Unichip questions and sugestions please
- Problem with Helix Short Shift Kit?
- How to reset the stock ECU ??
- Getting a 19%!!!!!
- loss in boost??
- Any 210hp JCW folk upgrade to a 17% and Miltek header
- Very pleased with Helix Short Shifter
- please some 1 help alta oil catch can
- Build your own Air filters @ SBfilters.com
- Question for TC guys
- Alta diverter modified for Ram Intake
- 15% Pulley Belt Shredded
- 19% GIAC AND injectors??
